Sign in to follow this
Bryan
Can't compile MAME to save my life.
I've downloaded MinGW & all the other stuff that you unzip over it. I've set up my path, and I've tried both the 069 and the 081 sources, and I always get the same compile error in XP:
Compiling src/usrintrf.c...
src/usrintrf.c: In function `do_loadsave':
src/usrintrf.c:3772: `va_start' used in function with fixed args
make: *** [obj/mame/usrintrf.o] Error 1
Looking through the code, it appears that glibc is to blame, but I don't know what the fix is.
What the heck should I do? I can't seem to find any info on this in Google.
-Bry
huh? Did you get this code from mame.net?! This error is most definatly not coming from the latest official source code. :ponder:
Yup. Got everything from MAME.net:
mame081s.zip
9177 kB Source code archive of MAME 0.81.
MinGW-2.0.0-3.exe 12525 kB
MinGW 2.0.0 compile environment for use in Windows. Execute the file to install MinGW.
mingw-over.zip 549 kB
Other files needed to compile MAME in the MinGW compile environment. Uncompress this over the MinGW directory.
gcc-3.2.2-20030208-1.tar.gz 7148 kB
GCC 3.2.2, required for MAME 0.66 and newer. Uncompress this over the MinGW directory.
dx70_mgw.zip 240 kB
DirectX 7.0 headers, required for MAME 0.68 and newer. Uncompress this over the MinGW directory, after mingw-over.zip. Add c:mingwbin to your PATH. Compile the Win32 version by typing make.
I even tried a newer GCC library... no luck, same error. For the moment I'm using an old version of MAME which I can compile.
-Bry
I got a question. Did you make a new folder for the new srcs or did you overwrite the old ones?
New folder. In fact, I deleted it and extracted everything twice... in order. Then I extracted the MAME sources into a mame folder inside mingw, set the path, then ran make. It only gets so far, though. I found the exact line in the code that causes the problem (in the interface code), and it's not a valid error as far as I can tell.
Anyway, I found some different stuff on the Net about the error, but not pertaining to MAME. So, I'm still stuck.
-Bry
Well, it's been a long time since I've compiled anything on a PC and it was just MAME32. I mainly compile MacMAME + now. I don't think I can help you too much.
Hopefully this will point you to the right direction, did you ask this question on the mame.net boards? I think they would know what's up.
mameworld.net has a compiling board and think they could help you too.
mame081s.zip
Well that can't be becuase the funtion do_loadsave() starts at line 3801, and your error is occuring at line 3772 which claims to be inside the do_loadsave() function, so something is seriously messed up on your end. I would reverify that you have the correct source code installed. :wink:
I was taking a look at do_loadsave() as well (although in the 0.80.1 XMAME sources... should be mostly the same), and it doesn't use va_start at all (Nor does it really have any reason to). Either something is wrong with the sources you have, or your compiler is seriously buggered.
--Zero
do_loadsave calls usrintf_showmessage (4 times), which has the offending function (va_start). I don't know why the compiler doesn't attribute the error to usrintf_showmessage. All this stuff came straight from mame.net's DL page. Can anyone DL the sources and tools and try it?
-Bry
   -Bry
void CLIB_DECL usrintf_showmessage(const char *text,...)
The "..." in the function declaration implies that it uses variable arguments. Can you verify that your version of the source code contains the "..." as shown above in the usrintf_showmessage() function?
   -Bry
Yep.. I already checked that:
va_list arg;
va_start(arg,text);
vsprintf(messagetext,text,arg);
va_end(arg);
messagecounter = 2 * Machine->refresh_rate;
void CLIB_DECL usrintf_showmessage_secs(int seconds, const char *text,...)
va_list arg;
va_start(arg,text);
va_end(arg);
messagecounter = seconds * Machine->refresh_rate;
void do_loadsave(struct mame_bitmap *bitmap, int request_loadsave)
int file = 0;
mame_pause(1);
do
 InputCode code;
 if (request_loadsave == LOADSAVE_SAVE)
 	displaymessage(bitmap, "Select position to save to");
 else
 	displaymessage(bitmap, "Select position to load from");
 update_video_and_audio();
 reset_partial_updates();
 if (input_ui_pressed(IPT_UI_CANCEL))
 	break;
 code = code_read_async();
 if (code != CODE_NONE)
 	if (code >= KEYCODE_A && code <= KEYCODE_Z)
   file = 'a' + (code - KEYCODE_A);
 	else if (code >= KEYCODE_0 && code <= KEYCODE_9)
   file = '0' + (code - KEYCODE_0);
 	else if (code >= KEYCODE_0_PAD && code <= KEYCODE_9_PAD)
while (!file);
mame_pause(0);
if (file > 0)
 	usrintf_showmessage("Save to position %c", file);
 else
 	usrintf_showmessage("Load from position %c", file);
 cpu_loadsave_schedule(request_loadsave, file);
else
 	usrintf_showmessage("Save cancelled");
 else
 	usrintf_showmessage("Load cancelled");
