lonesome_pa #1 Posted May 20, 2004 I understand that if you have Metroid Prime and Metroid Fusion, you can get special bonuses when you link the two together. But, does it work if you play the Fusion game in the Gameboy Player attachment instead of an actual Advance system????? Quote Share this post Link to post Share on other sites
shep #2 Posted May 20, 2004 No, because the GCN has to have the disc to emulate the Gameboy. Quote Share this post Link to post Share on other sites
Ze_ro #3 Posted May 20, 2004 From what I can tell, you have to actually link the Gamecube to a Gameboy Advance to activate the secrets in this game... This means that both the Gamecube and GBA would have to be running at the same time, which you obviously can't do with a GB Player. However, if you have two Gamecubes, you could have one of them running Metroid Prime, and the other running Metroid Fusion (using the GB Player), and activate the secrets that way. --Zero Quote Share this post Link to post Share on other sites
rogueleader #4 Posted May 20, 2004 However, if you have two Gamecubes, you could have one of them running Metroid Prime, and the other running Metroid Fusion (using the GB Player), and activate the secrets that way. --Zero Probably not, because the Gameboy player does not have the place to plug in the gameboy link cable that is needed to connect the GBA to the GC! Quote Share this post Link to post Share on other sites
Xot #5 Posted May 20, 2004 I understand that if you have Metroid Prime and Metroid Fusion, you can get special bonuses when you link the two together. But, does it work if you play the Fusion game in the Gameboy Player attachment instead of an actual Advance system????? Don't fret over it, the unlockables aren't anything spectacular anyways. The Prime "bonus" is you can play as the suit from Fusion. OOOOOH. Quote Share this post Link to post Share on other sites
sigma #6 Posted May 20, 2004 I understand that if you have Metroid Prime and Metroid Fusion, you can get special bonuses when you link the two together. But, does it work if you play the Fusion game in the Gameboy Player attachment instead of an actual Advance system????? Don't fret over it, the unlockables aren't anything spectacular anyways. The Prime "bonus" is you can play as the suit from Fusion. OOOOOH. and the other way around is that you can play the original metroid Quote Share this post Link to post Share on other sites
JB #7 Posted May 20, 2004 Probably not, because the Gameboy player does not have the place to plug in the gameboy link cable that is needed to connect the GBA to the GC! Yes it does. Right over the cart slot. Quote Share this post Link to post Share on other sites
Avid Fan #8 Posted May 24, 2004 If you really want that Metroid (NES) someone will probably put it on a memory card for you if you send it with postage to send back. Its really cool to mave the original with a save game feature Quote Share this post Link to post Share on other sites
Xot #9 Posted May 24, 2004 Or you could get Metroid Zero Mission. Quote Share this post Link to post Share on other sites
