lonesome_pa #1 Posted June 21, 2004 Ok, I picked this up today in an unlabeled 5200 cart. I opened the cart, and the board below is what I found. Problem, nothing is written on the chips. It does look like that someone either painted or magic marked over the chips. I tried to clean it with goo-gone (carefully) but no luck. I cant make anything out, if there is anything there at all. Is there any other way to find out what this game is? Obviously, to try it out in a 5200 is out, since I nor anyone I know own one. Quote Share this post Link to post Share on other sites
lonesome_pa #2 Posted June 21, 2004 Ooops forgot the attach button......stupid me. Quote Share this post Link to post Share on other sites
classics #3 Posted June 21, 2004 Take some rubbing alcohol and uncover the numbers on the chips, that should tell. Quote Share this post Link to post Share on other sites
MrRetroGamer #4 Posted June 21, 2004 If you want to pop it in the mail, I'd test it for you and send it back. I'm in NY so it wont take too long to get here. Visual ID on the PCB is probably not going to happen. Quote Share this post Link to post Share on other sites
lonesome_pa #5 Posted June 22, 2004 Take some rubbing alcohol and uncover the numbers on the chips, that should tell. I tried rubbing alcohol and I even tried goof off, but no luck. Quote Share this post Link to post Share on other sites
lonesome_pa #6 Posted June 22, 2004 If you want to pop it in the mail, I'd test it for you and send it back. I'm in NY so it wont take too long to get here. Visual ID on the PCB is probably not going to happen. Sure, if you want to pm me your addy, I can shoot it off to ya. And is just the board ok? The case was pretty cracked up and I tossed it. Thanks for the offer. My luck, it's Pac-Man. Quote Share this post Link to post Share on other sites
