Henry Lee #1 Posted June 21, 2004 The neverending saga of trying to fin out what happened to dead 4 port, I unscrewed the Ac power box but can'y get it to open. I try everything, now it got scars and everything.. I was trying to open to change the fuse (like Crosbow said)...by the way does anybody if we can use a generic power supply with the same voltage and how do you open a A5200 AC power supply? Quote Share this post Link to post Share on other sites
+Mitch #2 Posted June 21, 2004 You did get the two other screws under the feet didn't you? There should be four screws in all. Once you get all of them out it should open without too much problem. Mitch Quote Share this post Link to post Share on other sites
Rob Mitchell #3 Posted June 21, 2004 I had to open mine up some time ago. I remember maybe removing some screws .. and then wrapping it in a soft wrag and then hitting it around the glue line to break the glue and then it opened up. Replacing the fuse made it work again. Rob Mitchell, Atlanta, GA Quote Share this post Link to post Share on other sites
Henry Lee #4 Posted June 21, 2004 you mean 4 screws?? i just see two?? is there glue in there? Quote Share this post Link to post Share on other sites
Lemmi #5 Posted June 21, 2004 you mean 4 screws?? i just see two?? is there glue in there? under the rubber feet the glue holds them down there are 2 more screws Quote Share this post Link to post Share on other sites
Henry Lee #6 Posted June 21, 2004 Thank you all! have a good night! Quote Share this post Link to post Share on other sites
