wrldstrman #1 Posted June 29, 2004 is the only diffrence between lochjaw and shark attack the label..or is there someting in the game or on the inside that makes them diffrent. Quote Share this post Link to post Share on other sites
Rick Weis #2 Posted June 29, 2004 is the only diffrence between lochjaw and shark attack the label..or is there someting in the game or on the inside that makes them diffrent. just the label. but i have never opened one up. Rick Quote Share this post Link to post Share on other sites
candiru #3 Posted June 29, 2004 Graphically, I think there is a cloud in a different place. There was also a bug fix between releases because the diver would sometimes get stuck. Seems like I read that somewhere. Quote Share this post Link to post Share on other sites
ianoid #4 Posted June 29, 2004 lochjaw is both a label variant and a subtle ROM variant. There are some subtle graphics changes, with minimal effect on gameplay. If you started Shark Attack and Lochjaw up side by side, you wouldn't have much trouble finding differences, more than just clouds, as I understand them. There are a few differences with the mazes if I remember correctly. Quote Share this post Link to post Share on other sites
Tempest #5 Posted June 29, 2004 IIRC: 1. The ship graphic at the top is in a different position 2. The clouds have moved 3. The 'line' under your character extends the full length. 4. Lochjaw had a bad bug where you could get hung up on walls 5. There are diamonds in the maze on start up. Tempest Quote Share this post Link to post Share on other sites
CPUWIZ #6 Posted June 29, 2004 IIRC: 1. The ship graphic at the top is in a different position 2. The clouds have moved 3. The 'line' under your character extends the full length. 4. Lochjaw had a bad bug where you could get hung up on walls 5. There are diamonds in the maze on start up. Tempest Yep and on top of that, all Lochjaw carts are made with EPROM boards. Just like this one. Quote Share this post Link to post Share on other sites
MattG/Snyper2099 #7 Posted June 30, 2004 So all lochjaws have those boards with standard ROMS or is there an EPROM under that RF shield? Quote Share this post Link to post Share on other sites
Spirantho #8 Posted June 30, 2004 So all lochjaws have those boards with standard ROMS or is there an EPROM under that RF shield? There's got to be an EPROM under that shield - the 74LS04 IC there is an inverter, I think, which you need when you want to use EPROMS - you need an inverter when you replace a ROM with an EPROM, and it was just the same in those days. Quote Share this post Link to post Share on other sites
Bruce Tomlin #9 Posted June 30, 2004 If they were going to the trouble to get real ROMs made, it would be no more trouble to get an active-high CS line to do away with the 7404 chip. There's a chance (since I can't see the side view) that it may be a plastic case (no erase window) EPROM, but I don't think they made those back then. Quote Share this post Link to post Share on other sites
CPUWIZ #10 Posted June 30, 2004 There are regular old 2732's in those. Quote Share this post Link to post Share on other sites
