caveman #1 Posted October 10, 2004 I was on the net looking for ColecoVision emulators, and I came across a site that sounded like MacMess can emulate CV roms. Is this true? I don't see it listed in MESS when I run it. If not, does anyone know/have a Mac CV emulator? Thanks. Quote Share this post Link to post Share on other sites
oesii #2 Posted October 10, 2004 I've used MacMess with Colecovision before. Does a pretty good job. I would also recommend Mugrat. Anything Richard Bannister is working on is worth checking out: http://www.bannister.org/software/mugrat.htm Quote Share this post Link to post Share on other sites
caveman #3 Posted October 13, 2004 Thanks for the tip. Now how do I get it to appear in the system list? And yes, Roger Bannister does do excellent work- got the Handy- but I can't run Mugrat on Mac 9.2....or can I? Quote Share this post Link to post Share on other sites
oesii #4 Posted October 13, 2004 I'm pretty sure all of Richard's new emus only run on OS X. Like DOS or Windows 95 it's going to get harder and harder to find newer and better emus for the aging OS 9. For MacMess, I have a folder called ROMS and then a folder inside of that called Coleco. You need to put the coleco.rom (attached) bios file inside the coleco folder. MacMess should pick it up but since you're using an older version you might have to point the program to where your bios files are located. coleco.zip Quote Share this post Link to post Share on other sites
Albert #5 Posted October 13, 2004 Thanks for the tip. Now how do I get it to appear in the system list? And yes, Roger Bannister does do excellent work- got the Handy- but I can't run Mugrat on Mac 9.2....or can I? Unfortunately Mugrat is only for OS X. It's a fairly new emulator and is quite good so far--it's what I use anytime I need to emulate ColecoVision games. ..Al Quote Share this post Link to post Share on other sites
