joeybastard #1 Posted October 29, 2004 I'm rearranging my gameroom and I want to upgrade some of my stuff. Question 1: Is the Genesis 2 AV cable the same as the 32x AV cable? 2: Is the Genesis 1 AV cable the same as the SMS AV cable? 3. Is the Jaguar Composite Video Cable very expensive or hard to find? They look like the same pinouts, but before I buy them off the internet, I'd like to know they are going to work. Quote Share this post Link to post Share on other sites
ApolloBoy #2 Posted October 30, 2004 1: Yes. 2: Yes. 3: I'm not too sure... Quote Share this post Link to post Share on other sites
xenomorpher #3 Posted October 30, 2004 3. Is the Jaguar Composite Video Cable very expensive or hard to find? On ebay I saw some range 14.99- 29.99 because I was looking to buy one but kind of forgot about it since I can live without one. Quote Share this post Link to post Share on other sites
christianscott27 #4 Posted October 30, 2004 a friend of mine built a jag comp. cable for me, according to him it was fairly cheap and easy. heres the instructions if you're inclined. Q. I want something better than RF output from my Jaguar. What do I do?| A. Atari will be offering an adaptor in the near future (early 1994) to give | the Jaguar RGB, S-Video, and other output formats. In the meantime, if you | are willing to build your own composite video/stereo cable for the Jaguar, | Dennis Brown ([email protected]) offers the following instructions: | | Parts (from Radio Shack): 274-384 solderless phono plugs (4) | 278-772 25-conductor ribbon connector | 276-1564 34-position card-edge connecter | | Cut off ten of the pins from the 34-position card-edge connector. Then, | on the Jaguar's AV connector, wire the pins as follows: | | 1 3 5 7 9 11 13 15 17 19 21 23 | - - - - - - - - - - - - | - - - - - - - - - - - - | 2 4 6 8 10 12 14 16 18 20 22 24 | | 1 - Audio out 16 - Monochrome video (LUMA) | 2 - Audio out 18 - Ground | 3 - Ground 20 - Ground | 4 - Ground 22 - Standard composite color video out | | NOTE: If you are using standard composite video, the only video connection | you need is pin 22. This is a full signal, not just the color | complement to the monochrome output. Quote Share this post Link to post Share on other sites
