Zach Posted April 11, 2005 Share Posted April 11, 2005 (edited) Thanks, TJ. I think I've got something that can draw sprites. I'll have to see if I can get them moving. The beauty of Retrofan's playfield design is that every other scanline has fewer color changes, so there is time for other tasks. ;;same code as before lda #%11110111 sta PF1 lda #%00001110 sta PF2 lda #$00 sta COLUBK ldx #$3a ldy #$c3 SLEEP 4 stx COLUPF lda #%00010000 sta PF0 sty COLUPF lda #%10001000 sta PF1 lda #$00 stx COLUBK sta COLUPF sty COLUBK lda #$ff sta PF2 ;; new code for drawing sprites ldy santa_current_line lda santagrp,Y sta GRP0 lda santacolu,Y sta COLUP0 stx WSYNC lda #%11110000 sta PF1 sta PF2 lda #0 sta PF0 sta COLUBK stx COLUPF iny lda santagrp,Y sta GRP0 lda santacolu,Y sta COLUP0 iny sty santa_current_line ldy jack_current_line lda #0 sta PF1 sta PF2 lda jackgrp,Y sta GRP1 inc jack_current_line stx WSYNC Edited April 14, 2005 by Zach Quote Link to comment Share on other sites More sharing options...
Retrofan Posted April 15, 2005 Author Share Posted April 15, 2005 Hey, that's nice. I'm happy to see that my mockup screen is inspiring Zach to code someting challenging with it. It's good that there will be some more days to Christmas. Quote Link to comment Share on other sites More sharing options...
Zach Posted May 5, 2005 Share Posted May 5, 2005 (edited) I made some recent progress. The sprites are moving now, and the background consists of the row shown previously, plus the row below it (stretched out, of course). I've got two sprites in the kernel, but the timing is so tight, there is no room for any missiles or balls or anything else. The question will be whether a fun game can be made with just the background and two sprites. xbert.zip Edited May 5, 2005 by Zach Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 5, 2005 Share Posted May 5, 2005 I've got two sprites in the kernel, but the timing is so tight, there is no room for any missiles or balls or anything else. Can you post some (kernel) code? Quote Link to comment Share on other sites More sharing options...
Zach Posted May 5, 2005 Share Posted May 5, 2005 My method for drawing sprites is a little unorthodox. The data for each sprite consists of an entire 256 byte page filled mostly with zeros. That way, I don't have to determine where to draw the sprite - just draw it on every line. The idea was inspired by an email by Manuel a couple months ago where he explained the fastest way he knew to draw a missile. Although you stated that this kernel would probably be impossible, Thomas, I'm sure you could have solved the problem in half the time it took me. I'll be wildly impressed if you can squeeze in a missile or something. Here is the code for the first row. ;----------------------------------------- ; Loop starts on cycle 69 with Y set to santa_current_line ; and A set to 0. loop ldx santagrp,Y ;73 stx GRP0 ;76 ldx santacolu,Y ;4 ; First line updates the pun'kin stx COLUP0 ;7 sta PF0 ;10 sta COLUBK ;13 ldx #%11110000 ;15 stx PF1 ;18 stx PF2 ;21 ldx platformcolor1 ;24 stx COLUPF ;27 ldx jack_current_line ;30 lda jackgrp,x ;34 ldx.w platformcolor2 ;38 stx COLUPF ;41 inc jack_current_line ;46 sta GRP1 ;49 lda #0 ;51 sta PF1 ;54 sta PF2 ;57 iny ;59 sty santa_current_line;62 ldx santagrp,Y ;66 stx GRP0 ;69 ldx santacolu,Y ;73 stx COLUP0 ;76 ldx #%11110111 ;2 ; Second line draws the green blocks stx PF1 ;5 ldx #%00001110 ;7 stx PF2 ;10 sta COLUBK ;13 ldx platformcolor1 ;16 SLEEP 3 ;19 stx COLUPF ;22 ldy #$c3 ;24 ;Green ldx #%00010000 ;26 stx PF0 ;29 ldx #%10001000 ;31 sty COLUPF ;34 stx.w PF1 ;38 ldx platformcolor2 ;41 stx COLUBK ;44 sta COLUPF ;47 sty COLUBK ;50 ldx #$ff ;52 stx PF2 ;55 ldy santa_current_line;58 iny ;60 dec counter ;65 bne loop ;69 assume branch crosses a page boundary ;--------------------------------------- Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted May 5, 2005 Share Posted May 5, 2005 I'll be wildly impressed if you can squeeze in a missile or something. Well, you have three(!) counters (jack_current_line, santa_current_line and counter). Use (ind),y adressing for the sprite graphics and only one single counter (counting down). That alone should save you a lot of cycles. And if you can avoid using Y for something else than counting, then you can remove the remaining counter and save some more cycles. Quote Link to comment Share on other sites More sharing options...
Zach Posted May 6, 2005 Share Posted May 6, 2005 (edited) So by using (ind),Y you mean that Y will represent the current scanline as counted from the bottom? And ind will point to an address within the 256 bytes of sprite graphics? In this case, Would'nt there be a problem with sometimes crossing a page boundary, costing indeterminantly 5 or 6 cycles? Here is how Santa's sprite data looks now: ORG $FC00 santagrp .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00 .byte #%00000110 .byte #%00011100 .byte #%01111110 .byte #%01111110 .byte #%01111110 .byte #%01111110 .byte #%01010110 .byte #%01111110 .byte #%01000110 .byte #%01111100 .byte #%00111100 .byte #%01111110 .byte #%01111111 .byte #%01101101 .byte #%11111101 .byte #%11101100 .byte #%01111100 .byte #%01111100 .byte #%00101000 .byte #%01101000 .byte #%00001100 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00 .byte $00,$00,$00,$00,$00,$00,$00,$00,$00 Edited May 6, 2005 by Zach Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted May 6, 2005 Share Posted May 6, 2005 So by using (ind),Y you mean that Y will represent the current scanline as counted from the bottom? And ind will point to an address within the 256 bytes of sprite graphics? Yes and yes. In this case, Would'nt there be a problem with sometimes crossing a page boundary, costing indeterminantly 5 or 6 cycles? Yes, kinda, not really. If you only read sprite graphic data when you are drawing the sprite (i.e., not on every scanline), then you only need to be concerned with the area in front of your sprite graphic data. Worst-case example: You are displaying a sprite at scanline 192. So you read sprite data with this: lda (ind),Y where Y is 192. So ind needs to be an address from $xx00 - $xx63. So you've still got 64 bytes of room there, so even in the most extreme case (where you are using the entire visible display to draw a sprite) you can still have 64-line tall sprites. The real key is that you only read data when you are drawing the sprite. Here's some fake-y code I slapped together (warning: untested!) ;--this is in VBLANK lda #<SpriteData sec sbc SpriteYPosition clc adc #SPRITEHEIGHT sta SpritePtr lda #>SpriteData sta SpritePtr+1 ;--snip ;--this is part of the kernel lda #SPRITEHEIGHT dcp SpriteYCounter bcc SkipDraw lda (SpritePtr),Y sta GRP0 ReturnFromSkipDraw ;--snip ;--this is data: org $FEF0 SpriteData .byte #%00000000 .byte #%00011000 .byte #%00111100 .byte #%01100110 .byte #%01111110 .byte #%01011010 .byte #%00111100 .byte #%00011000 The first snippet shows how you would set up your pointers correctly. The second snippet shows how (using SkipDraw) you would draw your sprite during your kernel. The third snippet shows how your sprite data needs to be upside down and, generally, positioned near the end of a page. Quote Link to comment Share on other sites More sharing options...
Zach Posted May 6, 2005 Share Posted May 6, 2005 (edited) Thanks, vdub_bobby. Unfortunately, I'm not convinced that there is time for Skipdraw in this kernel. In particular, the line where the green blocks are drawn requires many color changes. In that line, I use the following: ldy santa_current_line ;3 iny ;2 ldx santagrp,Y ;4 stx GRP0 ;3 It only takes 12 cycles to update GRP0 on that line. The new value of santa_current_line is saved on the next line. If I counted correctly, Skipdraw takes 17 cycles when the branch is not taken. Edited May 6, 2005 by Zach Quote Link to comment Share on other sites More sharing options...
vdub_bobby Posted May 6, 2005 Share Posted May 6, 2005 (edited) Thanks, vdub_bobby. Unfortunately, I'm not convinced that there is time for Skipdraw in this kernel. In particular, the line where the green blocks are drawn requires many color changes. In that line, I use the following: ldy santa_current_line;3 iny ;2 ldx santagrp,Y ;4 stx GRP0 ;3 It only takes 12 cycles to update GRP0 on that line. The new value of santa_current_line is saved on the next line. If I counted correctly, Skipdraw takes 17 cycles when the branch is not taken. 850706[/snapback] SkipDraw does indeed take 17 cycles, whether the branch is taken or not. But if that isn't fast enough, you can use SwitchDraw, which only takes 15 cycles: ;--SwitchDraw ; TopLine == top line of sprite ; BottomLine == bottom line of sprite ORed with $80 ; requires scanline counter < $80 (i.e., 128 lines, though you ; can get around this by interlacing your graphics) cpy TopLine ;+3 3 beq SwitchDraw ;+2 5 bpl Wait ;+2 7 lda (ind),Y ;+5 12 sta GRP0 ;+3 15 ReturnFromSwitchDraw ;--snip SwitchDraw lda BottomLine ;+3 9 sta TopLine ;+3 12 bmi ReturnFromSwitchDraw ;+3 15 branch always Wait SLEEP 4 ;+4 12 bpl ReturnFromSwitchDraw ;+3 15 branch always Edited May 6, 2005 by vdub_bobby Quote Link to comment Share on other sites More sharing options...
Zach Posted May 6, 2005 Share Posted May 6, 2005 Switchdraw might work. It's worth a try. Quote Link to comment Share on other sites More sharing options...
dm4714 Posted May 7, 2005 Share Posted May 7, 2005 Hello, here are mockup screens for a new Q*Bert. Yes I know: the game exists for the 2600 and there are copyrights on it. But I want to try to make graphics better (but it's not easy). Please give comments: Version 1: Version 2: And if the copyrights are a problem: Here is Santa-Q (or X*Bert?, he jumps on a X-mas tree and turn on the lights): 743490[/snapback] Hi -- what are you using to design your mockup images? Quote Link to comment Share on other sites More sharing options...
Retrofan Posted May 9, 2005 Author Share Posted May 9, 2005 I'm using Photoshop/Mac for my mockup screens. Quote Link to comment Share on other sites More sharing options...
dm4714 Posted May 12, 2005 Share Posted May 12, 2005 Hello, here are mockup screens for a new Q*Bert. Yes I know: the game exists for the 2600 and there are copyrights on it. But I want to try to make graphics better (but it's not easy). Please give comments: Version 1: Version 2: And if the copyrights are a problem: Here is Santa-Q (or X*Bert?, he jumps on a X-mas tree and turn on the lights): 743490[/snapback] Hi -- what are you using to design your mockup images? 851084[/snapback] I'm curious -- what settings within Paintshop are you using for the graphics? I mean, are is it a one-for-one in size or are you converting it or something? Can you share the png? Quote Link to comment Share on other sites More sharing options...
Retrofan Posted May 13, 2005 Author Share Posted May 13, 2005 I'm not using Paintshop, I'm using Photoshop (Adobe). I'm drawing the graphics in 160 x 200 (RGB) using a VCS color table (internet download) and a 4 x 4 pixel grid. Then I'm reducing the colors to only the used (2 - 8 bit), stretching the image horizontal to 320 x 200 pixels and saving it as a GIF file. Quote Link to comment Share on other sites More sharing options...
