Zybex #1 Posted January 1, 2005 Schematic [*]R1 1,5 Kilo Ohms [*]R2 2,7 Kilo Ohms [*]R3,R4 5,6 Kilo Ohms [*]R5 39 Kilo Ohms [*]R6 500 Ohms [*]R7 22 Ohms [*]R8 100 Ohms [*]Q1 Transistor 2N2222 (You can use a 2N3904, but quality suffers) Questions : - Who is TIA? TIA is a processor of ATARI 2600. You must look for pins 2,5,7,8 - How i can get 5v? Use a multimeter, and get the 5v from the voltage regulator. - How i can get ground? Wow, try any metal shields inside Some pictures (not of my property) : TIA pins, chroma and audio >> http://www.cheeptech.com/2600mods/2600mods.shtml Transistor : http://www.electroflash.org.nz/images/npn.gif http://www-ece.rice.edu/~jdw/figs/2n3904b.jpg Sorry about my english Quote Share this post Link to post Share on other sites
Zybex #2 Posted January 1, 2005 http://www.fairchildsemi.com/ds/PN/PN2222A.pdf 2N2222 Datasheet Quote Share this post Link to post Share on other sites
Jacob Rose #3 Posted January 3, 2005 Cool! A few weeks ago I did a resistors-only composite hack based on the one posted on AtariAge, with help from Stella list archives and schematics of the 2600A to find the right pins, but this looks almost as simple, so I might give it a try. Can you explain what's going on here for those of us who haven't made a transistor circuit since high school? =) Quote Share this post Link to post Share on other sites
Zybex #4 Posted January 7, 2005 The schematics is here : Quote Share this post Link to post Share on other sites
n8littlefield #5 Posted January 11, 2005 Ok, so I'm looking into ordering the parts for this mod - but was wondering does 1,5 = 1.5? 2,7 = 2.7? Just want to make sure I order the right parts. Thanks! Quote Share this post Link to post Share on other sites
Atari-Jess #6 Posted January 12, 2005 Ok, so I'm looking into ordering the parts for this mod - but was wondering does 1,5 = 1.5? 2,7 = 2.7? Just want to make sure I order the right parts. Thanks! I would say yes because he's in Chile. (many countries use , instead of .) Quote Share this post Link to post Share on other sites
lbaeza #7 Posted January 13, 2005 Hi Here's the list with some more familiar notation: [*]R1 1.5K Ohms [*]R2 2.7K Ohms [*]R3,R4 5.6K Ohms [*]R5 39K Ohms [*]R6 500 Ohms [*]R7 22 Ohms [*]R8 100 Ohms Regards Quote Share this post Link to post Share on other sites
n8littlefield #8 Posted January 13, 2005 Thanks for the input. Now, can anyone tell me why I cannot find a 500 ohm resistor? Does anyone know of an online source? I found some great kits of resistors, with all of the ones needed included, but the closest they come is 560... Quote Share this post Link to post Share on other sites
spongebue #9 Posted January 13, 2005 get some smaller ones and wire them in series (that is, 1 after another) if they add up to 500 (or close to it) then you are good to go. Of course, you could wire some resistors up in parallel, but then the math gets a bit complicated to figure out which one you need Quote Share this post Link to post Share on other sites
Susuwatari #10 Posted January 13, 2005 Just wire 2x 1K resistrs in paralell and you'll get 500 ohms. And yes the math is complicated if you use mixed resistors in parallel but if all the resistors in parallel are the same, you just divide the resistor by the total number in the circuit. In this case, 1000/2 = 500. Quote Share this post Link to post Share on other sites
christianscott27 #11 Posted January 13, 2005 i feel like i should know this already but... has anyone come up with a way to make an A/V out for the 7800? Quote Share this post Link to post Share on other sites
krupkaj #12 Posted June 20, 2005 I have got my first VCS last week. It is 2600 jr. with some games. It has quite nice video through RF, but I would like to have composite and audio output. I like this modiffication, but I have question. My 2600 jr. is PAL Will this mod work with my PAL machine? In case it is for NTSC only do anybody know how to modiffy my one? Quote Share this post Link to post Share on other sites
+batari #13 Posted June 20, 2005 Just want to give a warning to anyone who tries this mod. I did it, and it worked and gave a sharp picture, but the whites and bright colors were way overdriven, to the point that I had to crank the contrast to a minimum and turn down the brightness, and they are still a little too bright. Ben Heck's 2.0 mod is very similar but uses different resistor values. When I get a chance, I'm may swap out the resistors to his and see if it works any better. Or, if anyone can suggest a way to fix the existing circuit to change the output of the brighter colors to a more tolerable level, let me know. Quote Share this post Link to post Share on other sites
+batari #14 Posted June 21, 2005 Or, if anyone can suggest a way to fix the existing circuit to change the output of the brighter colors to a more tolerable level, let me know. 877809[/snapback] Hi, I just experimented with changing the resistor values, and found that R8 is too small... I changed it to 250 ohms and the whites are no longer overdriven. Actually, all the colors look better now. Quote Share this post Link to post Share on other sites
krupkaj #15 Posted June 22, 2005 Thanks, but will that work with my PAL VCS? Quote Share this post Link to post Share on other sites
+batari #16 Posted June 22, 2005 Thanks, but will that work with my PAL VCS? 878766[/snapback] It would probably do something, but wouldn't work very well since the resistor values were chosen for NTSC color signals. However, here is one I found that reportedly is made just for PAL, which is essentially the same but with different resistor values and tapping off of pin 6 instead of pin 8 of the TIA. Quote Share this post Link to post Share on other sites
krupkaj #17 Posted June 22, 2005 Thats it. I have read somewhere that PAL TIA has different pinout than NTSC one. I will try it and the let you know what it does. Thanks for scheme. Quote Share this post Link to post Share on other sites
keilbaca #18 Posted June 22, 2005 Exactly right. Pin 8 for NTSC, pin 6 for PAL. Should work fine Glad to see that the mod was going good for you guys, but I also had the too bright problem. Thats when I just went to straight resistors, thus the mod I offer at the marketplace. Quote Share this post Link to post Share on other sites
gizmomelb #19 Posted January 28, 2006 Thats it. I have read somewhere that PAL TIA has different pinout than NTSC one. I will try it and the let you know what it does. Thanks for scheme. 878777[/snapback] Hi Krupkaj, as another PAL Atari owner I was just wondering how the PAL modification went? Was the picture output clear or did it need modifying? Thanks, Gizmomelb Quote Share this post Link to post Share on other sites
