Sign in to follow this
Mot
CC2: ROMDB update help please.
If you have hand entered new menu items into your cc2 menu, then I would like your help.
Can you please run this program that check if they are in the CC2ROMDB.TXT.
It puts all the entries that are not in the DB into an output file. You can then post the resulting entries here.
You can get the program here:
http://www.geocities.com/mot505/Chk4NewMenuItems.html
Thank you very much.
I will be updating the one I keep on my site:
See also:
http://www.atariage.com/forums/viewtopic.php?t=61860
After a bit of thinking, I managed to figure out how to set it up properly per your instructions :P
(I have my ROMs laid out slightly differently directory wise to the standard CC2 structure!)
Anyhow I get this output:
Activision proto #1 ACTPROT1 4K 78BIOS
Activision proto #1 (PAL) ACTPRT1P 4K 78BIOS
Activision proto #2 ACTPROT2 4K 78BIOS
Activision proto #2 (PAL) ACTPRT2P 4K 78BIOS
Air-Sea Battle AIRSEA 2K 78BIOS
Backgammon (PAL) BACKGMNP 4K 78BIOS
Backfire BACKFIRE 4K 78BIOS
Barnstorming (PAL) BARNSTMP 4K 78BIOS
Base Attack (PAL) (Z-Tack) BASEATTK 4K 78BIOS
Bloody Human Freeway (proto) BHFREEWY 2K 78BIOS
Bloody Human Freeway (PAL) (proto) BHFREWYP 2K 78BIOS
Challenge CHALENGE 4K 78BIOS
Climber 5 (Phillyclassic 4) CLIMBER5 4K 78BIOS
Combat Rock CMBTROCK 4K 78BIOS
Crackpots (PAL) CRACKPTP 4K 78BIOS
Donald Duck's Speedboat (PAL) DONALDP F8 78BIOS
Donkey Kong (PAL) DONKEYP 4K 78BIOS
Double Dunk (PAL) DBLDUNKP F6 78BIOS
Euchre EUCHREP 4K 78BIOS
Euchre (PAL) EUCHREP 4K 78BIOS
Excalibur (proto) EXCLBR00 SC SC
Galactic (PAL) GALACTIC 4K 78BIOS
Inca Gold (PAL) INCAGOLD 4K 78BIOS
International Soccer SOCCER 4K 78BIOS
Looping LOOPING F8 78BIOS
Marble Craze (PAL) MARBLEP F4 78BIOS
Miner 2049'er Volume 2 MINER2 3F 78BIOS
Minesweeper MINESW 4K 78BIOS
Mr. Postman (PAL) POSTMANP 4K 78BIOS
No Escape! (PAL) NOESCP 4K 78BIOS
Open Sesame (PAL) OPENSMEP 4K 78BIOS
Pac-Man Arcade (PAL) PACARCDP F8 78BIOS
Pengo PENGO F8 78BIOS
Pengo (PAL) PENGOP F8 78BIOS
Pesco PESCO 4K 78BIOS
Polaris POLARIS 3F 26QUICK
Polaris (PAL) POLARISP 3F 26QUICK
Pooyan (PAL) POOYANP 4K 78BIOS
QB (PAL) QBP 4K 78BIOS
Rubik's Cube RUBIKS 4K 78BIOS
Rubik's Cube RUBIKS3D 4K 78BIOS
Save Our Ship (PAL) SAVESHIP 4K 78BIOS
Sea Monster (PAL) SEAMON 4K 78BIOS
Skeleton SKELE 4K 78BIOS
Skeleton (PAL) SKELEP 4K 78BIOS
Sokoban SOKOBAN 4K 78BIOS
Space Invaders Invasion SPCINV 4K 78BIOS
Space Treat (PAL) SPCETRTP 4K 78BIOS
Synthcart (PAL) SYNTHCRP F8 78BIOS
Targ (proto) TARG 4K 78BIOS
Venetian Blinds (demo) VENETIAN 2K 78BIOS
Venetian Blinds (PAL) (demo) VENETINP 2K 78BIOS
Warring Worms WARRINGW 4K 78BIOS
Words Attack WORDS 4K 78BIOS
Given some games in there are already known about, does this mean the checksum of the dumps I'm running are different to all that you've encountered so far, or are some of my naming convensions off?
Sorry, I tried to be clear :)
Any suggestions on how to make the instructions more clear would be gladly accepted.
Does this mean that you have sub-dir’s on your MMC? Or how can you have any different then <root>MENU.CC2 and <root>GAME<gameNames>.BIN?
(clip)
Thanks for the new entries, but I forgot to add the CRC to the output! :(
So can you d/l and try it again? Please!
The program only looks at if the CRC is in the database, so all of these versions of binary files are not in the current database.
I don’t know if we need to have an approval process for entries in the database but I will add them to mine.
By different directory structure, I don't mean on my MMC, I mean on my HD. Where my ROMs are located is deeper than just one sublevel below where I normally store the executables I run (such as the menu generator) and I don't store my master list of ROMs in a directory called GAMES either ;)
Rerun it, attached it to maintain column spacing :P
newentries.zip
Thank you :wink:
I will add...
Cool stuff, looks like I need to do some updating as well. :)
Mahem, where did you find a PAL Pengo ROM, I've looked all over for one without any luck. Can you post it please. :)
Mitch
I believe the PAL Pengo ROM came from Marco when I was angling to buy the PAL lab loaner of it from him. Whether the cart I now have is any different to the actual real release (which is about as easy to find heh!) I don't know, but it's all that's out there I guess. Right... let's see here...
pengopal.zip
For the record, it's just as well someone here (ie. me) has a master ROMs directory that has both NTSC and PAL ;)
Why I decided to do that, I don't know. Probably because there's lots of games only on NTSC, and I'd want to play the PAL versions of whatever was available too. So I just go for everything!
As it stands, my MENU.CC2 file has 1073 entries currently. My policy is to have one version (both NTSC and PAL where possible) of each game and one version only; official where possible, unofficial where one didn't originally exist. No clones, no pirates, no hacks (well almost). Homebrews and protos are in. Although of course some PAL versions are only available via the pirate/clone route and these have been allowed. If a real version exists, then it is used primarily.
I added the new entries by MayhemUK and assigned companies to them and I also added companies to other’s that didn’t have them before.
I uploaded the updated DB and I updated the:
and
http://www.geocities.com/mot505/CC2MenuGen.html
and just the db at:
http://www.geocities.com/mot505/CC2ROMDB.zip
I found the the jar in the zip file of the Java Menu Generator didn’t seem to work, so I added just a link to the jar file on the site.
I ran the Java Menu Generator with the new entries and I got more recognized roms in the menu.
Anyone else have hand entered new menu items in your cc2 menu?
Thanks.
