Sign in to follow this
J.Max
Odd Colecovision problem
I just got a new Colecovision system, and I can't get any sound. Anyone here ever have this problem, or know of anywhere else I might be able to get help?
Are there any cuts in the RCA cable? Did you check the motherboard for detachments? You might want to post this in Hardware.
I would try a different RF cable. It's detachable on the CV.
If you're lucky, it's just a bad connection to the RF modulator, maybe a bad solder joint. I had one where a bad solder joint on one of the chroma lines caused the display to go all sepia-toned. You've still got to open it up to fix it, though.
I opened it up, and there doesn't seem to be anything obviously wrong with it. I can't see where the RF connector goes in, because theres a board on top that I can't remove. I have tried three RF cables, and still nothing.
Forgive me if this sounds dumb but you're not plugging the RF cable directly into an RCA video jack on your TV are you?
No, I'm not. That wouldn't give me this problem anyway; it would just give me a garbled mess.
I'm using a RCA/Coax adaptor and going into the coax input, like I do with all of my older systems.
OK, dude, just asking, sometimes people make mistakes.
