Goochman #1 Posted January 17, 2005 Ok, Ive got an old Gateway Solo 2300 laptop computer I want to use as my SIO2PC machine. I am running WinXP Pro and Ape 2.0.9 - APE finds COM1 just fine but when I try to load software on my Atari the machine locks up - Im sure its because the mouse is also trying to use COM1 hence an IRQ conflict. Any suggestions on getting this fixed? My IRQ days were long ago Quote Share this post Link to post Share on other sites
dinosaur #2 Posted January 17, 2005 Look in your setup BIOS and see if you can change the IRQ of your COM port. I guess that your laptop only have one serial port on your laptop. You might try using a PS/2 mouse,if your laptop has a port for one, and setting your serial port to a different address and IRQ Quote Share this post Link to post Share on other sites
Goochman #3 Posted January 17, 2005 Look in your setup BIOS and see if you can change the IRQ of your COM port. I guess that your laptop only have one serial port on your laptop. You might try using a PS/2 mouse,if your laptop has a port for one, and setting your serial port to a different address and IRQ I have a docking station that has 2 PS/2 ports (mouse and keyboard) which I have hooked up - 1 serial port - any suggestions on IRQ or address? I used to know these things but havent had to deal with them in a long time! Quote Share this post Link to post Share on other sites
dinosaur #4 Posted January 17, 2005 Try setting your PS/2 mouse port to COMM2 : address: 2f8 IRQ:3 and your serial port to COMM1: address:3f8 IRQ:4 Use COMM1 for the SIO2PC OR vice versa. Remember you will have to change your setup BIOS settings ro do this, and you MIGHT have to change your device manager settings in WinDoz. Quote Share this post Link to post Share on other sites
Goochman #5 Posted January 18, 2005 I think Im hosed with this laptop....no matter what I do it locks up - I cannot switch the com port for the mouse but have been able to switch the com port for the serial connection - no help The mouse shows up as a PS/2 mouse and connection - it doesnt list the mouse as utilizing a com port - unless Im missing something? XP allows you to reconfigure everything from the OS - alas no luck Im open to any ideas Quote Share this post Link to post Share on other sites
Cybernoid #6 Posted January 18, 2005 Have you tried adjusting the "Framing Threshold" above 7 or the "Safety Margin" under "Basic Serial Setup"? Quote Share this post Link to post Share on other sites
Goochman #7 Posted January 18, 2005 Have you tried adjusting the "Framing Threshold" above 7 or the "Safety Margin" under "Basic Serial Setup"? Im not really sure what these do? Any suggestions? I also am using the DSR mode - there are 2 other options? Quote Share this post Link to post Share on other sites
Cybernoid #8 Posted January 18, 2005 Does your PC lock up or your Atari? I usually use the RI "Serial Control" option. I think this is what you will want with a one chip interface. The safety margin is useful if your PC is slow, but I assume that this is not the case. I would try 2 or 3, just to see... Adjust the Framing Threshold only if your Atari locks up after is switches to high speed SIO... These suggestions are only if the Atari is locking up, not the PC... _C_ Quote Share this post Link to post Share on other sites
Goochman #9 Posted January 18, 2005 The PC locks up Atari keeps on chugging the laptop is a 233mhz with not enough memory to run XP (getting more memory) Quote Share this post Link to post Share on other sites
belboz #10 Posted January 18, 2005 Can you hit ctrl-alt-del when the pc is locked up? Or is it froze hard? Besides trying the other options instead of DSR on the sio2pc interface, here are some other things to try. 1) Test the COM port. Try running Hyperterminal and telling it to talk to COM1 directly (i.e. don't pick a modem if your laptop has one). See if that locks XP up. If it does it is probably an XP/Laptop issue with the COM port. If you have an external modem (even if it is old) this is also a way to test the COM port. 2) Try a different drive emulator. This one is Windows based. http://retrobits.net/atari810.html This one is the original and is DOS based. http://www.tcainternet.com/wa5bdu/sio2pc.htm 3) Try running all these Windows based apps (APE, Atari 810, Hyperterminal) with the sio2pc interface unplugged from the PC completely. 4) If all else fails try booting into DOS mode and skipping XP altogether. Then run the DOS based sio2pc above. Quote Share this post Link to post Share on other sites
belboz #11 Posted January 18, 2005 In #3 above I am just curious if the software still locks up with no interface plugged into the com port. Maybe the sio2pc cable is defective and doing something to cause the PC to lock up when accessing the com port. Quote Share this post Link to post Share on other sites
Goochman #12 Posted January 18, 2005 PC locks up - nothing can be done I dont have DOS on this machine so no back fall (no diskette drive either ) Ill try that other windows based drive emulator - that might help clairfy the port issues - Ill also try hyperterm. Thanks for the suggestions Quote Share this post Link to post Share on other sites
Goochman #13 Posted January 18, 2005 Interesting news...........the A810 worked like a champ! It also appears to provide about the same level of functionality as APE (none of the PRO stuff) - so for now I am a happy camper - thanks for the heads up belboz! I ran APE after A810 worked and another lockup Quote Share this post Link to post Share on other sites
belboz #14 Posted January 18, 2005 Glad that helped. I believe Atari 810 uses the RI signal for control. You might want to try reconfiguring APE for that (if you haven't already). Quote Share this post Link to post Share on other sites
Goochman #15 Posted January 18, 2005 RI is the only 1 I hadnt tried - will try that on next reboot - thanks for the tips - I am a happy camper now! Quote Share this post Link to post Share on other sites
dinosaur #16 Posted January 19, 2005 Why would you want to run bloated XP on a 233MHz? Win 98SE should work fine. I tried XP on my main computer and took it out and reinstalled Win98SE. Quote Share this post Link to post Share on other sites
Goochman #17 Posted January 19, 2005 Why would you want to run bloated XP on a 233MHz?Win 98SE should work fine. I tried XP on my main computer and took it out and reinstalled Win98SE. I got roped into it - I wanted to run Win2K but this PC has no floppy disk and it wont boot from CDROM for some reason - So I couldnt remove the OS prior to installing another one - anyhow, I ended up with WinXP Classics has put a new version of APE up on his site - I am going to try that one today to see if it fixes my issues. Quote Share this post Link to post Share on other sites
Goochman #18 Posted January 19, 2005 Ive got some great news! The latest version of APE also now works with my slow PC - Classics just put up v 2.2.2 on his website and it works like a champ Thanks for everyones help! Quote Share this post Link to post Share on other sites
dinosaur #19 Posted January 19, 2005 I had the same problem with my "Atari" laptop. Mine is an IBM ThinkPad 365 XD (CD-ROM,no floppy) It came to me with the hard drive formatted clean with no OS! The BIOS setup would not let you boot from the CD. SO...... I took a 100 Meg PCMCIA hard drive to another laptop and installed Win98 on it and the driver for a Trantor parallel-to SCSI adaptor. I then,on my desktop, made a bootable CD with DOS 6.22 containing DOS6.22,PCXformer 3.8,the Trantor driver.Norton Disk Doctor,and all the Atari files that I wanted. Put the PCMCIA drive in the slot,selected "Boot from network" and it booted the IBM. I then installed Win98 (minimal) on the IBM hard drive. Put the CD into the IBM,and with DiskDoctor,made the IBM hard drive bootable. Shut it down. I removed the PCMCIA drive from the IBM,hooked up the SCSI CD-ROM,with the bootable CD in it, and booted the IBM. Went to the CD,FDISKed the C: drive,formatted it (with DOS 6.22 and SYS)made it bootable,and copied all the files from the CD. VOILA! Quote Share this post Link to post Share on other sites
Goochman #20 Posted January 19, 2005 Hmmmmmmmmmm............that just might work Now to find a PCMCIA HD for cheap Quote Share this post Link to post Share on other sites
dinosaur #21 Posted January 19, 2005 I had the same problem with my "Atari" laptop. Mine is an IBM ThinkPad 365 XD (CD-ROM,no floppy). It came to me with the hard drive formatted clean with no OS! A lawyer gave it to me. (fiqures!) The BIOS setup would not let you boot from the CD. SO...... I took a 100 Meg PCMCIA hard drive to another laptop and installed Win98 on it I then,on my desktop, made a CD with DOS 6.22 containing DOS6.22,PCXformer 3.8,.Norton Disk Doctor,and all the Atari files that I wanted. Put the PCMCIA drive in the slot,selected "Boot from network" and it booted the IBM. I then installed Win98 (minimal) on the IBM hard drive. Put the CD into the IBM,and with DiskDoctor,made the IBM hard drive bootable. Shut it down. I removed the PCMCIA drive from the IBM,and booted the IBM. with the CD in it, and booted the IBM. Went to the CD,FDISKed the C: drive,formatted it (with DOS 6.22 and SYS)made it bootable,and copied all the files from the CD. VOILA! I am a packrat and collect all kinds of stuff.I bought the PCMCIA hard drive and the Trantor SCSI adaptor at a thrift store quite a while ago,and had never used either,except to test them.You never know when something will come in handy! I have seen parallel-to SCSI adaptor cables on eBay for sale. I wonder if someone could write an Atari driver for one? Quote Share this post Link to post Share on other sites
dinosaur #22 Posted January 19, 2005 Cheap PCMCIA hard drives: http://search.ebay.com/PCMCIA-hard-drive Quote Share this post Link to post Share on other sites
Goochman #23 Posted January 20, 2005 Just curious - how did you install Win98 on the PCMCIA card? I believe you need a Win98 machine inorder to do this first? Or did you copy the Win98 installer to the PCMCIA disk? Quote Share this post Link to post Share on other sites
Goochman #24 Posted January 20, 2005 Ya know what - I dont think I can 'boot from network' with this laptop Quote Share this post Link to post Share on other sites
+Mitch #25 Posted January 20, 2005 Wouldn't it just be easier to get an laptop HD to IDE adapter? They're only a couple bucks. Then you can stick it in as a secondary drive on a regular PC and copy the WIN98 setup files to it. Mitch Quote Share this post Link to post Share on other sites
