JerseyDevil #1 Posted February 14, 2005 Can you put 2 automatic RF switches in the same line? TV===RF===RF===cable line I am looking to hook up my N64 and NES at the same time and I don't have the A/V wires. Obviously, I would only play one system at a time. Quote Share this post Link to post Share on other sites
thegamezmaster #2 Posted February 14, 2005 You should be able to daisy chain them and it should work. Just make sure the ends or the signal path is correct. Quote Share this post Link to post Share on other sites
SteveW #3 Posted February 14, 2005 I've found that having two or three RF switchboxes hooked up tend to degrade the TV image quality when the games aren't on. I'll have to jiggle the wires to get a good picture. Quote Share this post Link to post Share on other sites
JB #4 Posted February 14, 2005 I've found that having two or three RF switchboxes hooked up tend to degrade the TV image quality when the games aren't on. I'll have to jiggle the wires to get a good picture.This IS the same site that insists you should use an adapter to hook your Atari directly into the antenna connector. It's not like anyone WATCHES TV on their television. Quote Share this post Link to post Share on other sites
JerseyDevil #5 Posted February 14, 2005 You should be able to daisy chain them and it should work. Just make sure the ends or the signal path is correct. I hooked 'em up and they work fine. I'm not sure why I thought it might not work. Thanks. Quote Share this post Link to post Share on other sites
