Sign in to follow this
hex65000
FS: 2600 carts & guidebooks....
Here's my running list of extras I have for the 2600. I have tried to be very critical of each item so that there are no surprises. If you would like to see pictures of any of these, please PM me and we'll move from there. All of these have been cleaned inside and outside and tested for functionality. In some cases, I have multiple copies of these items, I'd rather move the one at the top of the stack first. if there is a common that you are looking for in better shape let me know -- it will be priced appropriately mind you.
** Name * Sticker Type * Publisher / Rarity *** notes Price
-- Football : picture label : Atari / 1 === Main sticker is okay, has some wear and is slightly lifting in 3 of 4 corners, front label is slightly curling up from the bottom $1.00
-- Frogger : standard : Parker Bros / 1 === Sticker has serious wear and actiplaque, tiny tear in bottom right corner of main label, sticker is not lifting though $1.00
-- Missile Command : Capital Letters/picture : Atari / 1 === Nothing noteworthy, very good cond. $1.00
-- Night Driver : picture label : Atari / 1 === Main sticker looks very good, front label has a scuff and 1/8" of the upper left corner has curled/creased $1.00
-- Pac Man : picture label : Atari / 1 === Main sticker looks good, front sticker has minor scuff. $1.00
-- Space Invaders : Capital Letters/picture : Atari / 1 === Main sticker shows some wear and minor actiplaque, front label looks pretty good. $1.00
-- Football : text only (3) : Sears / 2 === Main sticker has been punched through at screw and at rectangular hole, front label is rather nice $1.00
-- Frogs and Flies : Blue Label : Mattel / 2 === Trivial actiplaque, otherwise looks very good. $2.00
-- Grand Prix : Color : Activision / 2 === definite Actiplaque, three trivial tears at top of label, some wear at the corner edge. Front looks good but has actiplaque too $2.00
-- Haunted House : picture label : Atari / 2 === Main sticker has actiplaque and some scuffs, front label is good, but upper left corner has lifted and has 1/4" crease $2.00
-- Home Run : text only : Atari / 2 === Main sticker looks good, but small 1/4" spot where the black color has rubbed off (circular) and glue is giving up around all edges. Front sticker is very good $2.00
-- Journey Escape : Silver w/ picture : Data Age / 2 === Sticker is definately worn, 1/4" of front label is lifting on the right side. $1.00
-- Jr. Pac Man : Red label : Atari / 2 === Main sticker has at 3 small tears (all at the border of the sticker), front label is good but is starting to show signs of a seam crease $3.00
-- Kaboom : Color : Activision / 2 === minor semi-circle discoloration, otherwise nice $3.00
-- Keystone Kapers : Color : Activision / 2 === definite Actiplaque, front has some wear and fading $2.00
-- Laser Blast : Color : Activision / 2 === definite Actiplaque, front has seam crease/tear $2.00
-- Lock N' Chase : Blue Label : Mattel / 2 === trivial sticker damage; actiplaque $3.00
-- Mega Force : black w/ screenshot : 20th fox / 2 === main label has big tear and label damage at crease to front label, front label has minor tear $2.00
-- Megamania : Color : Activision / 2 === definite Actiplaque, front of label is badly faded and slight lifting. $1.00
-- Mouse Trap : text only : Coleco / 2 === very small tear at bottom of sticker, dents where screws are, some of the gloss coating is gone, front looks very good. $2.00
-- Ms. Pac Man : Silver label : Atari / 2 === spot near front of cart where the foil has come off, very mild actiplaqe on front label $2.00
-- Othello : picture label : Atari / 2 === Main sticker looks very good, front label has 1/8" of the upper left corner has curled/creased $2.00
-- Outlaw : picture label : Atari / 2 === Main sticker looks good, has some wear; front label has partial seam crease/tear $2.00
-- Q-Bert : standard : Parker Bros / 2 === Definate signs of wear and actiplaque, front of label is starting to lift $2.00
-- Raiders of the Lost Ark : Silver label : Atari / 2 === Main sticker and front sticker look very good, only trivial wear noted. $3.00
-- Realsports Football : Silver label : Atari / 2 === Main sticker looks good, has some wear; front label has some seam wrinkles, but looks good $2.00
-- Riddle of the Sphinx : Picture label : Imagic / 2 === Main sticker is clearly damaged. and spotty, front of sticker some of the test has been wiped away. $1.00
-- Slot Racers : Picture label : Atari / 2 === Main sticker is okay, rectangular hole has been punched. Front sticker looks good, some signs of seam crease $1.00
-- Space Jockey : Black label : US Games / 2 === Main sticker has had the screws punched through and has some scuffing. Front label is also scuffed a bit. $2.00
-- Starmaster : Color : Activision / 2 === Main sticker is good, some wear and actiplaque, front label has part of the sticker missing. Most of the first S in 'Starmaster' is gone. Front part of sticker is lifting off the cart. $2.00
-- Street Racer : Picture label : Atari / 2 === Main sticker is good, but has some wear, front sticker has small 1/4" linear tear on the right side. otherwise good. $2.00
-- Pac Man : picture label : Sears / 3 === Main sticker looks good, but has a minor scuff and 1/4" of lower left corner has lifted, front sticker looks good, but left side is just starting to lift $3.00
-- Planet Patrol : standard : Spectravision / 3 === main label has notable wear and has dents at the screws and the rectangular hole has been punched. front sticker has some wear, but looks good. $3.00
-- Super Challenge Football : Blue Label : Mattel / 3 === Trivial actiplaque, otherwise looks very good. $2.00
-- Gopher : standard case : US Games / 4 === main label has minor discoloration on right side, left side of front label has some discoloration $3.00
** Guide books
They are sorted in alphabetical order by game and the platform that it supports is also listed.
Condition: The books are generally in decent shape, and are good for reading through etc. If you are particularly concerned about condition, let me know and I'll describe in detail/ scan if I have to the book in question.
Blade 2 -- (Xbox, PS2) ; $3.00
Blinx: The Time Sweeper -- (Xbox) ; $3.00
Donkey Kong 64 [official guide] -- (N64) ; $3.00
Final Fantasy 8 [official guide] -- (PSx) ; $4.00
Final Fantasy 10 pt.1 [official guide] -- (PS2) ; $4.00
Getaway, The -- (PS2) ; $3.00
Hitman: Contracts -- (PS2, XBox, PC) ; $3.00
Kelly Slater: Pro Surfer -- (XBox, PS2, GC) ; $2.00
Lord of the Rings: Return of the King -- (XBox, PS2, GC, PC) ; $3.00
Matt Hoffmans' Pro BMX 2 -- (XBox, PS2, GC) ; $2.00
Pokemon: Trading Card Game -- (GB Color) ; $3.00
Silent Hill 3 -- (PS2) ; $3.00
Yoshi's Island: Mario Advance 3 -- (GB Adv) ; $3.00
Shipping: USPS media mail or whatever cost's less or is appropriate. You will pay actual shipping costs. If you live near Cincinnati / nothern KY, we can work out some kind of face-to-face exchange if you desire.
Payment: Money orders or Paypal Direct cash transfers. I don't accept credit cards through PayPal.
Hex.
[ Off to get thrown in the basement... ]
