Sign in to follow this
vdub_bobby
Fastest way to display missiles/ball (2600)
Is there a faster way to display a variable-height ball/missile in the 2600 than this:
  lda BallHeight
 dcp BallY
 sbc BallHeight
 sta ENABL    ;+14
Hi there!
  lda BallHeight
 dcp BallY
 sbc BallHeight
 sta ENABL    ;+14
Hm...
lda BallHeight
dcp BallY
rol
sta ENABL
maybe?
Greetings,
Manuel
Redundancy? It seems to me that if your sprite is #N lines, you could just execute a routine that produces #N lines. The check is being done once before you need it, and no time is being wasted checking in lines that do need it.
I don't follow this exactly...could you explain a little further?
Maybe if I understood it's use a bit clearer :lol:
You need:
To save cycles when dealing with variable heights.
Solution:
Write specific kernal portions dealing with each specific height.
Getting there via indirect jumps maybe?
Makes a lotta rom overhead, but it's one way of saving cycles.
lda BallHeight
dcp BallY
rol
sta ENABL
maybe?
Greetings,
Manuel
Don't you need two 'rol's?
So are you using the carry bit to enable the ball? If you were able to use the Z status you could use the old Combat trick of pointing the stack to the ENABL register and php the status after the subtraction.
You need:
Solution:
I think we are talking past each other :)
I need to draw the ball like you normally draw a player - it can show up on any scanline and can be any height. I.e., I am drawing a line (not a point, so I can't do what DEBRO suggested, 'cpy BallY php' - at least I haven't figured out a way to do it). I am drawing a vertical line that can be of variable length (varying between 1 and ~8 scanlines tall) and it can appear anywhere on the screen.
Some other possibilities I have come up with are the code cybergoth suggested (15 cycles) and, if I can restrict my variable heights to intervals of four, this:
lda BallHeight
dcp BallY
sbc #ADJUSTER
sta ENABL    ;+13
Where, for example, if BallHeight = 0, 3, 7, 11, etc. then ADJUSTER = 0.
And I don't have time to do jumps, indirect or otherwise :), in my kernel. This is specifically for the Prince of Persia kernel I am messing around with where I am drawing an asymmetrical PF every scanline and the ball and both players every other scanline; I have zero extra cycles in my kernel right now. As far as I know, the SkipDraw routine is the fastest way to draw a sprite (assuming you need constant cycles and without giant tables as tall as the screen) anyone has come up with, but I haven't ever read anything about the fastest way to draw a ball/missile when it is taller than one scanline.
I knew I didn't describe that well enough ;)
What I was trying to describe is unrolling a display loop. You no longer would need to CPY and such because that specific kernal already "knows" the height and already has the ball sprite enabled. You save cycle time because no loop is used and no tests are needed. The indirect jump I was referring to happens on the scanlines above the player (where you have the time to do the test, because the sprites aren't being drawn there).
Could you post the attempted routine for your "draw player+sword" loop (the one that's using too many cycles)?
  lda BallHeight
 dcp BallY
 sbc BallHeight
 sta ENABL    ;+14
Clever code!
Hm, I did something like this in Cave1K:
  tya
 sbc     yWall1
 adc     hWall1
 lda     #$00
 adc     #$01
 sta     ENABL  ; = 15
But your code is faster.
Well, it isn't taking too many cycles now...but if I could cut a few cycles off I could maybe squeeze one of the missiles into the loop somewhere.
So here's the code.
Actually, I'm not currently using the 'fastest' routine I posted above, I'm using the one Cybergoth suggested.
   sta WSYNC
  nop
  ldy #PLAYAREAHEIGHT-1  ;+2    4
  ldx #PLAYAREAHEIGHT-2  ;+2    6
  lda (PFColorPtr),Y
  sta COLUPF             ;+8   14
  SLEEP 5
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  dec SwordYPosition     ;+5   40
PlayAreaLoop
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  lda #P1HEIGHT-1        ;+2   58
  dcp P1YPosition        ;+5   63
  bcs DoDraw2            ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw2
  lda (PlayerPtrR),Y     ;+5   71
  sta GRP1               ;+3   74
  lda (Player2ColorPtr),Y
  sta COLUP1             ;+8    6
  lda SwordHeight
  cmp SwordYPosition
  rol
  rol
  sta ENABL              ;+13   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  lda #P0HEIGHT-1        ;+2   58
  dcp P0YPosition        ;+5   63
  bcs DoDraw1            ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw1
  lda (PlayerPtrL),Y     ;+5   71
  sta GRP0               ;+3   74
  dey
  sta HMOVE              ;+3    3
  lda (PlayerColorPtr),Y ;+5
  sta COLUP0             ;+3   11
  lda (PFColorPtr),Y
  sta COLUPF             ;+8   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  dex
  bpl PlayAreaLoop       ;+4/5 40
Maybe it's time to share my code too? ;)
.skipDraw1:                ; 5         @30
   sec                    ; 2
   sbc     yP0            ; 3
   adc     #PLAYER_H      ; 2 =  7
   SLEEP   4              ; 4 =  4
   lda     pf2RLst0,x     ; 4
   sta     PF2            ; 3         @48 *!*
   lda     pf1RLst0,x     ; 4
   sta     PF1            ; 3 = 14    @55
   SLEEP   6              ; 6 =  6
   lda     #0             ; 2
   sta     GRP1           ; 3
   sta     ENAM1          ; 3         @69
   bcs     .contDraw1a    ; 2³= 10/11
   bcc     .skipDraw0a    ; 3
.skipDraw0:                ;10         @60
   lda     (ptrC1),y      ; 5
   sta.w   COLUP1         ; 4         @69
   adc     #$fc           ; 2
   sta     ENAM1          ; 3 = 13    @74
.skipDraw0a:
   sec                    ; 2
   sta.w   HMOVE          ; 3         @04
   lda     #0             ; 2
   sta     GRP0           ; 3
   beq     .contDraw0     ; 3         @12
.nextRow:
   SLEEP   4              ; 4 =  4
.nextBlock:                ;           @63
   sbc     yP1            ; 3
   adc     #ENEMY_H       ; 2 =  5
   lda     colLst0,x      ; 4
   sta     COLUPF         ; 3 =  7    @75
   SLEEP   12             ;12                     12 free cycles
   lda     pf1LLst0,x     ; 4
   sta     PF1            ; 3         @18
   lda     pf2LLst0,x     ; 4
   sta     PF2            ; 3 = 14    @25
   tya                    ; 2
   bcc     .skipDraw1     ; 2³=  4/5
   sbc     yP0            ; 3
   adc     #PLAYER_H      ; 2 =  5
   lda     pf1RLst0,x     ; 4
   sta     PF1            ; 3         @41
   lda     pf2RLst0,x     ; 4
   sta     PF2            ; 3 = 14    @48 *!*
   lda     (ptrP1),y      ; 5
   sta.w   GRP1           ; 4 =  9    @VDEL!      1 cycle to optimize!
   bcc     .skipDraw0     ; 2³=  9/10
   lda     (ptrC1),y      ; 5
   sta     COLUP1         ; 3         @67         >[email protected]!
   adc     #$fc           ; 2
   sta     ENAM1          ; 3 = 13    @72         >[email protected]!
.contDraw1a:
   lda     (ptrP0),y      ; 5 =  5
   sta     HMOVE          ; 3         @04
   sta     GRP0           ; 3         @07
   lda     (ptrC0),y      ; 5 = 11
.contDraw0:                ;           @12
   sta     COLUP0         ; 3         @15
   adc     #$fc           ; 2
   sta     ENAM0          ; 3 =  8    @20
   lda     pf1LLst0,x     ; 4
   sta     PF1            ; 3         @27
   lda     pf2LLst0,x     ; 4
   sta     PF2            ; 3         @34
   lda     pf1RLst0,x     ; 4
   sta     PF1            ; 3         @41
   lda     pf2RLst0,x     ; 4
   sta     PF2            ; 3 = 28    @48 *!*
   dey                    ; 2
   tya                    ; 2
   cmp     BlockTbl,x     ; 4
   bne     .nextRow       ; 2³
   dex                    ; 2
   bpl     .nextBlock     ; 2³= 15
Thanks for posting it. This is an example of redundancy below. Notice how the loop is no longer a loop...but just a string of code. What this does is free 5 cycles from the bottom of each group, in addition to freeing up the X register (so you should be able to come up with a better use for it). I didn't look at the variables too closely, but eliminating the compare in each group will also be possible now that the X register is free to use.
   sta WSYNC
  nop
  lda (PFColorPtr),Y
  sta COLUPF             ;+8   14
  SLEEP 5
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
;changes begin here...
;PlayAreaLoop ... label not needed
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  bcs DoDraw2_1          ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw2_1
  sta GRP1               ;+3   74
  sta COLUP1             ;+8    6
  lda SwordHeight
  cmp SwordYPosition
  rol
  rol
  sta ENABL              ;+13   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  bcs DoDraw1_1          ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw1_1
  sta GRP0               ;+3   74
  dey
  sta HMOVE              ;+3    3
  sta COLUP0             ;+3   11
  lda (PFColorPtr),Y
  sta COLUPF             ;+8   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  NOP   ;2 free
  STA    $2D;3 free      40
;next group
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  bcs DoDraw2_2          ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw2_2
  sta GRP1               ;+3   74
  sta COLUP1             ;+8    6
  lda SwordHeight
  cmp SwordYPosition
  rol
  rol
  sta ENABL              ;+13   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  bcs DoDraw1_2          ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw1_2
  sta GRP0               ;+3   74
  dey
  sta HMOVE              ;+3    3
  sta COLUP0             ;+3   11
  lda (PFColorPtr),Y
  sta COLUPF             ;+8   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  NOP   ;2 free
  STA    $2D;3 free      40
;next group
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  bcs DoDraw2_3          ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw2_3
  sta GRP1               ;+3   74
  sta COLUP1             ;+8    6
  lda SwordHeight
  cmp SwordYPosition
  rol
  rol
  sta ENABL              ;+13   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  lda (PF3Ptr),Y
  sta PF2                ;+8   48
  lda (PF4Ptr),Y
  sta PF1                ;+8   56
  bcs DoDraw1_3          ;+2/3 65/66
  lda #0                 ;+2   67
  .byte $2C              ;-1   66
DoDraw1_3
  sta GRP0               ;+3   74
  dey
  sta HMOVE              ;+3    3
  sta COLUP0             ;+3   11
  lda (PFColorPtr),Y
  sta COLUPF             ;+8   19
  lda (PF1Ptr),Y
  sta PF1                ;+8   27
  lda (PF2Ptr),Y
  sta PF2                ;+8   35
  NOP   ;2 free
  STA    $2D;3 free      40
;next group
;etc...etc...
Ok, now I understand what you mean! :D
Unfortunately, since I loop 64 times, that solution probably isn't feasible.
You wouldn't need 64 copies if a test is done before the top WSYNC to decide when to jump to this section (this is designed to display the players...none of that code is needed if the players don't exist on the scanlines) ;) Since those cycles would be free, there's plenty of time to check when players are coming up...and then branch to this.
  lda BallHeight
 dcp BallY
 sbc BallHeight
 sta ENABL    ;+14
Well, I got around to actually using this in a program, and it doesn't work :P
Turns out I had the carry states backwards in my head. This will work though:
lda BallHeight
dcp BallY
sbc BallAdjuster
sta ENABL      ;+14
Where BallAdjuster = BallHeight - 2
