Sign in to follow this
That80sGuy
TECH: 1942 Sound problem
I have a 1942 that has barely audible sound. I can turn the volume up and down but you can't hear it unless you put your head up to the speaker. Anyone have any suggestions? I can't find any schematics for the boards.
Thanks!
Hmm ... There is a finger size hole in the paper part of the speaker. But so I hooked up a known good speaker and the result is the same. Its like the sound output is not being amplified.
Sometimes there is a separate voltage output for the amplifier chip. Make sure all your voltages are good.
-Bry
You should also check the volume potentiometer. If that's no good you aren't going to get predictable results.
My best guess, though, is insufficient voltage out of the sound circuit someplace. You could be looking at a bad op amp in the audio portion of the PCB.
