Sign in to follow this
kisrael
N64 and Yoshi's Story - tempremental
I'm having the hardest time getting Yoshi's Story to run on this N64 of mine...actually I brought one copy back to EB thinking it was defective...though I had YS on the system a long time ago and so I don't think that's the problem...
i fiddled around with and without the memory expansion pack, but no luck.
Most other games will work though some are tempremental.
Any suggestions?
AFAIK Yoshi's story doesn't make use of the the RAM expansion. It shouldn't matter if it's installed or not. What I would do is open it with a security bit and clean the contacts with an eraser.
Indeed. I've noticed the N64 in particular is way more sensitive to grime than other systems. 9 out of 10 games I get off eBay I have to clean thoroughly first before they work in my console.
847752[/snapback]
Well, it will probably stand as the most complex cartridge based system (unless at some point solidstate memory is so cheap that the decide it's better to go back to carts because the load times are too long) so it makes sense that it might be more sensitive than some of its older brethren.
Any suggestions?
846078[/snapback]
Odd...
I just picked up Yoshi's Story yesterday with a bunch of other N64 titles and it is the only one that consistently does not work on the first, second or sometimes more tries... even after cleaning.
I've also noticed that N64 carts can be inserted and removed from the console with very little resistance - I've got 3 N64's here and they all seem to be the same, I am wondering if this is common, or I have worn out slots...
