cdoty #1 Posted April 30, 2005 (edited) I've updated the Jaguar version of Frog Feast. Both frogs can now be controlled using seperate controllers. Frog Feast website If you test this on a real Jaguar , you will notice flashing graphics when you jump and stick out your tongue. The graphics are also corrupt when you enter the water. This fixes itself the next time the frog is moved or updated. This seems to happen when an object is added to the object list. I can update the position or data pointer and it doesn't happen. I've tried rebuilding the object list at different times in the frame. Edited April 30, 2005 by cdoty Quote Share this post Link to post Share on other sites
Matthias #2 Posted May 1, 2005 Hello! I've updated the Jaguar version of Frog Feast. Both frogs can now be controlled using seperate controllers.Frog Feast website 847061[/snapback] Are you sure the link is updated? http://www.game-shoppe.com/Files/JagFrog.zip I only get the version dated 27. April 2005 when downloading. :-( Regards Matthias Quote Share this post Link to post Share on other sites
cdoty #3 Posted May 1, 2005 Ok, the new version is definately up there. Quote Share this post Link to post Share on other sites
