ttony_at #1 Posted June 6, 2005 I found a game chip which I assume comes from a game for Atari 2600 but can't be sure. I've been curious as to what this game was when it played. It fits perfectly in the Atari 2600 and 7800 but does not play. Just a bunch of random wavy colourful lines shows on screen and bad audio as if it hadn't been inserted properly. Inside the lines I can see some responce to joystick movements as if the game is playing a little. Printed on the (4cm x 3.5 cm) board the game chips sits on: ©1982, 75724, REV B. It has a disc capacitor wired to it. And printed on the (3cm x 1.5cm) chip: ©1982, 73982, 2332-16785, E 3982, Do these numbers give any clues as to what it is? Quote Share this post Link to post Share on other sites
keilbaca #2 Posted June 6, 2005 sounds like frogger Quote Share this post Link to post Share on other sites
elliott #3 Posted June 6, 2005 Did you put it in with the chip facing back? If not there is your problem. Quote Share this post Link to post Share on other sites
ttony_at #4 Posted June 7, 2005 (edited) Did you put it in with the chip facing back? If not there is your problem. Tried both ways. Only with chip facing forward it displays something that responds to joystick movment. I tried it in an Atari 7800 and it shows a blank screen with changing tiny line garbage on the left and with audio sounds like the tanks in Combat. I thought there's a site where the numbes on chips could identify the games? Edited June 7, 2005 by ttony_at Quote Share this post Link to post Share on other sites
