walters #1 Posted June 15, 2005 How do i make the atari audio rom sounds? Do i have to write code to trigger the sounds off the rom chip? Or Is their code to set the Attack,decay of the audio sounds? What are the setting for the audio sounds for code? Every game has different sounds why is that how did the programmer do this to have different sounds? how do i do this to program different sounds? Quote Share this post Link to post Share on other sites
Thomas Jentzsch #2 Posted June 15, 2005 Do i have to write code to trigger the sounds off the rom chip? Yes. Or Is their code to set the Attack,decay of the audio sounds? No. What are the setting for the audio sounds for code? Read the docs please (e.g. Stella Programmers Guide). Quote Share this post Link to post Share on other sites
walters #3 Posted June 15, 2005 The 2600,7800,5200 system have different sound card rom chips right? is this hardware sound card rom chips? inside the these systems? How do i trigger these sounds on the 2600,7800,5200 without a game card do i use voltages on the sound card "pins"? Quote Share this post Link to post Share on other sites
+batari #4 Posted June 15, 2005 (edited) is this hardware sound card rom chips? inside the these systems? No, it's an ASIC called the TIA. How do i trigger these sounds on the 2600,7800,5200 without a game card do i use voltages on the sound card "pins"? 874581[/snapback] Sort of, but it's not a good idea. It's possible pull the TIA out of the 2600, build a state machine (or use a microcontroller) to write to its internal registers and capture the audio at the output, but this would be really hard to do, and not worth the effort, since the TIA is not very good as a general purpose sound chip, especially compared to what's available today. Edited June 15, 2005 by batari Quote Share this post Link to post Share on other sites
danwinslow #5 Posted June 15, 2005 You need to learn to program these machines. You create sounds by programming registers that control the sound generation hardware. Quote Share this post Link to post Share on other sites
