keitaro #1 Posted June 29, 2005 hi, I´ve a 2600 (woody version) , but the image is not clear, It´s like interferences (I don´t know how to explain this very well...), but is not problem of the tv (I tried with a 2600jr I have and works well). Is there any solution? Quote Share this post Link to post Share on other sites
Hendra #2 Posted June 29, 2005 Is there a channel switch at the bottom of the console? If there is one, try to switch it to another channel. Quote Share this post Link to post Share on other sites
keitaro #3 Posted June 29, 2005 yes, the channel 2-3 switch, I tried to sintonize in both positionsm but the image quality is the same Quote Share this post Link to post Share on other sites
Laner #4 Posted June 29, 2005 Are you using a switchbox? If so, you might want to try one of these instead: http://www.atariage.com/store/product_info...?products_id=42 You don't have to buy it from the AA store - they can be found at Radio Shack. Quote Share this post Link to post Share on other sites
maibock #5 Posted June 29, 2005 Does the picture start out fine and then get progrssively worse? If so, I think keilbaca has a solution, at least he did for me.. Quote Share this post Link to post Share on other sites
keitaro #6 Posted July 3, 2005 no, the picture is not fine from the start Quote Share this post Link to post Share on other sites
LYNXGUY #7 Posted July 3, 2005 I had that problem with my 2600 and I bought a new switch box and it didn't work so I bought another new switch box and that worked and I got both of them from Radio Shack, weird huh ?? You might have a faulty channel switch or a short in the wire going to the switch box or maybe not, just a few ideas that's all. Quote Share this post Link to post Share on other sites
LocalH #8 Posted July 3, 2005 Best thing to do would probably be to do (or get someone to do) the composite or S-Video mod, and just forget about RF completely. It sounds like your 2600 isn't shielded all too well. Quote Share this post Link to post Share on other sites
shadow460 #9 Posted July 4, 2005 I had to pry the top offa my old switch box to get it to work. It never worked when it was assembled. I took off the top and stuck it to the back of an old TV. Quote Share this post Link to post Share on other sites
