Sign in to follow this
Sharky
Help Needed with Half Life 2
:x
I purchased Half-Life 2, and I had to go online, to create an account and enter my serial
number and for it to download updates.
So far, the game took me over 3 hours to install, but I got it going and all, and works well, trouble is I have to be online to just to play the game.
Theres a box, called OFFLINE Mode, and when I click on that, it comes with error, such as could not connect to...
This really bothers me having to go online just to play an offline game.
I do believe it can be played offline, and should be played offline, but how...
Any ideas ? :?
Are you online when you click the offline mode box? I belive you need to be. I know haw bad it is, most painfull install ever.
906766[/snapback]
I finally fixed it somehow, I can play now offline, I've never come across a game so painful to install like that.
Trouble is now, my game just keep crashing or locking up every times it auto-saves, this is completely preventing any fun for this game.
I can't find a way to turn auto-save off.
Right now i've just given up, some error engine.dll and closes if I try running it in a window to try to solve the problem.
More than enough to play the game,
This is what first comes typing dxdiag
System Information
Time of this report: 8/9/2005, 04:10:43
      Machine name: COMPUTER
  Operating System: Windows 98 (4.10, Build 2222)  A
          Language: English (Regional Setting: English)
System Manufacturer: n/a
      System Model: n/a
              BIOS: n/a
          Processor: AMD Sempron  2400+,  MMX,  3DNow, ~1.7GHz
            Memory: 448MB RAM
          Page File: 81MB used, 1518MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: /PackageInstall
    DxDiag Version: 4.09.0000.0904 32bit
and Display Devices
Display Devices
        Card name: VIA/S3G UniChrome Graphics
    Manufacturer: VIA/S3 Graphics, Inc.
        Chip type: VIA/S3G UniChrome Graphics
        DAC type:
      Device Key: Enum\PCI\VEN_1106&DEV_7205&SUBSYS_70611462&REV_01\000800
  Display Memory: 63.5 MB
    Current Mode: 1024 x 768 (32 bit)(optimal refresh rate)
          Monitor: AlphaScan 712
  Monitor Max Res: 1280,1024
      Driver Name: vtdisp.drv
  Driver Version: 4.14.0010.0039 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/23/2003 15:37:56, 291424 bytes
      WHQL Logo'd: No
  WHQL Date Stamp: None
              VDD: *vdd
        Mini VDD: vtmini.vxd
    Mini VDD Date: , 0 bytes
Device Identifier: {D7B71FE6-3145-11CF-F577-6B50A0C2C935}
        Vendor ID: 0x1106
        Device ID: 0x7205
        SubSys ID: 0x70611462
      Revision ID: 0x0001
      Revision ID: 0x0001
      Video Accel: ModeMPEG2_B
Deinterlace Caps: n/a
        Registry: OK
    DDraw Status: Enabled
      D3D Status: Enabled
      AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
The game runs very smooth, hardly any lag at all, I might not been getting all the speical affects because of the graphics card, just crashing every time I try to save or it the game automatically saves. :ponder:
Edited by Sharky
