RRAD500
Problems with my atari 2600
Hey everyone,
i just bought my first atari 2600, primarily because i LOVED paul slocum's synthcart when i tried it on my computer. My atari powers on alright and plays sound fine, but the colors often "bleed," and the colors are off; green comes up as a weird blue/purple. for example, the backgrounds to 'combat,' 'stampede' and 'street racer' are this color.
is this a problem with my atari? ive tried cleaning the connectors, playing with rthe channels on the tv and the atari. ive tried it on a few different tvs and this problem is there every time.
has this happened to anyone else? any ideas?
Inside the atari is a pot that you adjust with a screwdriver. Its easy to spot, depending on the version. What atari do you have? 4 switch or 6 switch?
i have a "light sixer" atari. i opened up the atari last night expecting to find something like that, but couldnt find it
My Jr. changes colors like that if you press down on it's top with your finger. I do not know why.
yeah its strange the coloration is right, but theres a "tie dye" effect on everything: like theres no solid colors, purple will fade to blue and then back to purple.
but i suspect this is because my game switch sucks. im gonna try the coaxial -> rf direct converter. eventually ill do the composite video
Is it you tv? we had a lightning hit here an one of our tvs did that, needded to be degaused.. (spelling?)
910228[/snapback]
If its not the tv, its an adapter problem, or a rf box problem.
The reason why I said the adapter is because I did a mod for chickybaby, and I couldn't have all 3 LED's, the power LED and both difficulty switch LED's because when all 3 were on, the colors changed, sometimes wavy with noise interference, and sometimes just a color change. It was fine with 2, so I took out the power LED.
910086[/snapback]
The Pot is inside the metal housing in the center. This metal housing has 3 holes in it. Under the leftmost hole, you will find the pot and you can correct the color with a screwdriver. It is not the top and not the bottom hole, it is middle left. All my light sixers have this hole, but they are all PAL. Maybe NTSC is different ?!
Armin
