ApolloBoy #1 Posted September 1, 2005 Alright, I disabled the lockout chip in my NES months ago and so far it's been doing great. However, as I turn it on, it seems to repeatedly turn itself on and off until I push the power button in. Sometimes, when turned on, the screen goes black and the power indicator goes off. Would adding a ground wire to the lockout chip fix anything? Quote Share this post Link to post Share on other sites
The_Collector #2 Posted September 1, 2005 Not having disabled the lockout chip on a NES I may be in the dark. It sounds like the 72 pin blinky screen problem, but like I said could be way off. Did you try cleaning the pin connectors? Quote Share this post Link to post Share on other sites
JB #3 Posted September 1, 2005 Not having disabled the lockout chip on a NES I may be in the dark. It sounds like the 72 pin blinky screen problem, but like I said could be way off. Did you try cleaning the pin connectors? 923137[/snapback] You are way off. Disabling the lockout chip SHOULD fix the blinky screen problem, as the lockout chip is responsible for the blinky screen. Quote Share this post Link to post Share on other sites
Famicoman #4 Posted September 1, 2005 Probobly. I heard that the Ground wire is optional, but it might be what you need. Quote Share this post Link to post Share on other sites
keilbaca #5 Posted September 1, 2005 You just have to cut pin 4 on the Nintendo marked chip, no ground needed. *plays Gradius 2 famicom cart* Quote Share this post Link to post Share on other sites
