Sign in to follow this
Atari Master
Going to operate on my Joystick.
I can't play PAC-MAN with it.So i'm gonna opean it up and do a test.
Wile the Joystick is open i'm going to use the joysticks red button to tutch the metal things to see if it goes in that direction.
If it dosent it either means that the joysticks metal things are fryed or my 7800 is broken.
Would this possibly work?
Yes, simply press the metal tabs with your finger (It won't shock you). If Pac-Man doesn't go in the direction you pressed the "switch" is bad. If it does work then prehaps your Joystick handle is cracked, check to make sure.
You can order replacement parts at Best Electronics. If you can't repair and plan to throw it out I am more than happy to take it for parts, e-mail me.
Or you could order a new custom controller from me at my website Junies Creations, if your interested.
Good Luck on getting the Joystick back to new
I hope Atari Master didnt electrocute himself!!! Those Atari joysticks can be killers!!!!
Yes Atari Master.... Always use rubber if you're operating.
[ 04-23-2002: Message edited by: moycon ]
Amen! Atari Master....
I always say.... If it smells like cologne...Leave it alone!!!
HEY WAIT!!! Are we on the same page here friend????
Word man good philosophy "If it smells like fish its a dish , If it smells like cologne leave it alone"
And Atarimaster understands none of this .. Bad moycon putting images into a childs mind
