Curt Vendel
Atari 815 - Controller Source...
Will post some interesting info at a later time, Atari was developing an Atari 816 and 817 line of Disk drives as well, here is the source to the 815 Disk Controller:
.TITLE DUAL 815 DISK CONTROLLER
; * 815 DUAL DISK CONTROLLER *
; PROGRAMMER: BOB WARNE
; ADDITIONAL COMMENTS, LABELS & EQUATES BY DAVE STAUGAS
.ENABLE AMA
.RADIX 10
.ASECT
; MEMORY MAP:
; 0000-00FF RAM (USED FOR DATA BUFFER)
; 0100-0101 SYNCHRONOUS SERIAL DATA ADAPTER REGISTERS (MOTOROLA MC68B52)
; 0180-01FF RAM (STACK AND PROGRAM SCRATCH)
; 0200-021F MAPS TO PIA #2
; 0280-029F MAPS TO PIA #3
; 0380-039F MAPS TO PIA #1
; 0800-0FFF CONTROLLER ROM (PART #1)
; 7000-77FF CONTROLLER ROM (PART #2)
; EQUATES^H
BIT7 = ^H080
BIT6 = ^H040
BIT5 = ^H020
BIT4 = ^H010
BIT3 = ^H008
BIT2 = ^H004
BIT1 = ^H002
BIT0 = ^H001
; PAGE 0
ZPRL = ^H0000 ;START OF ZERO PAGE DATA BUFFER
ZP80 = ^H0080
ZP91 = ^H0091
FRMCRC = ^H00A0
ZPCRC = ^H00AE
ZPNTL = ^H00C0
ZPNTH = ^H00C1
SCTPT = ^H00F6
CRCLP = ^H00F7
IDAM = ^H00F8
TRKNO = ^H00F9
BYTE00 = ^H00FA
SCTNO = ^H00FB
BYTE01 = ^H00FC
CRC1 = ^H00FD
CRC2 = ^H00FE
BYTE4E = ^H00FF
.= ^H0100 ;START OF SSDA HARDWARE SPACE
; THE NEXT TWO ADDRESSES MAP TO THE MOTOROLA MC68B52 (SSDA)
; DATA BITS ARE REVERSED (0 -> 7, 1 -> 6, 2 -> 5, ETC)
; FROM THE BIT DEFINITIONS IN THE LITERATURE SO THAT
; SERIAL DATA IS SHIFTED MSB FIRST.
SSDA0: .=.+1
; WHEN READ, THIS ADDR IS A STATUS REGISTER.
; BITS FOR THIS REGISTER ARE DEFINED:
; 7 - RECEIVER DATA AVAILABLE (RDA)
; 6 - TRANSMITTER DATA REGISTER AVAILABLE (TDRA)
; 5 - DATA CARRIER DETECT BAR (DCD)
; 4 - CLEAR TO SEND BAR (CTS)
; 3 - TRANSMITTER UNDERFLOW (TUF)
; 2 - RECEIVER OVERRUN (RX OVRN)
; 1 - RECEIVER PARITY ERROR (PE)
; 0 - INTERRUPT REQUEST (IRQ)
; BIT EQUATES FOR SSDA0 (READ):
RDA = BIT7 ;RECEIVER DATA AVAILABLE
TDRA = BIT6 ;TRANSMITTER DATA REGISTER AVAILABLE
DCD = BIT5 ;DATA CARRIER DETECT BAR
CTS = BIT4 ;CLEAR TO SEND BAR
TUF = BIT3 ;TRANSMITTER UNDERFLOW
RXOVRN = BIT2 ;RECEIVER OVERRUN
PE = BIT1 ;RECEIVER PARITY ERROR
IRQ = BIT0 ;INTERRUPT REQUEST
; WHEN WRITTEN, THIS ADDRESS IS CONTROL REGISTER #1
; 7 - RECEIVER RESET (RX RS)
; 6 - TRANSMITTER RESET (TX RS)
; 5 - STRIP SYNCH CHARACTERS (STRIP SYNCH)
; 4 - CLEAR SYNCH
; 3 - TRANSMITTER INTERRUPT ENABLE (TIE)
; 2 - RECEIVER INTERRUPT ENABLE (RIE)
; 1 - ADDRESS CONTROL #1 (AC1)
; 0 - ADDRESS CONTROL #2 (AC2)
; BIT EQUATES FOR SSDA0 (WRITE):
RXRS = BIT7 ;RECEIVER RESET
TXRS = BIT6 ;TRANSMITTER RESET
STRIPS = BIT5 ;STRIP SYNCH CHARACTERS
CLEARS = BIT4 ;CLEAR SYNCH
TIE = BIT3 ;TRANSMITTER INTERRUPT ENABLE
RIE = BIT2 ;RECEIVER INTERRUPT ENABLE
AC1 = BIT1 ;ADDRESS CONTROL #1
AC2 = BIT0 ;ADDRESS CONTROL #2
SSDA1: .=.+1
; A READ OF THIS ADDRESS ACCESSES DATA FROM THE SSDA RECEIVE
; DATA FIFO.
; A WRITE TO THIS ADDRESS ACCESSES ANY OF 4 INTERNAL REGISTERS
; WHICH ARE SELECTED BY WRITING APPROPRIATE DATA TO THE AC1, AC2
; DATA BITS IN CONTROL REGISTER #1.
; BIT DEFINITIONS FOR THE FOUR WRITE ONLY REGISTERS:
; AC1=0 & AC2=0 SELECT CONTROL REGISTER #2:
; 7 - PERIPHERAL CONTROL #1 (PC1) ALWAYS 1
; 6 - PERIPHERAL CONTROL #2 (PC2) ALWAYS 0
; 5 - 1 BYTE/2 BYTE TRANSFER ALWAYS 0 (TWO BYTE)
; 4 - WORD LENGTH SELECT 1 (WS1) ALWAYS 1
; 3 - WORD LENGTH SELECT 2 (WS2) ALWAYS 1
; 2 - WORD LENGTH SELECT 3 (WS3) ALWAYS 0
; 1 - TRANSMIT SYNCH CODE ON UNDERFLOW 1
; 0 - ERROR INTERRUPT ENABLE (EIE) 1
; BIT EQUATES FOR CONTROL REGISTER #2:
PC1 = BIT7 ;PERIPHERAL CONTROL #1
PC2 = BIT6 ;PERIPHERAL CONTROL #2
BYTE12 = BIT5 ;1 OR 2 BYTE TRANSFER
WS1 = BIT4 ;WORD LENGTH SELECT #1
WS2 = BIT3 ;WORD LENGTH SELECT #2
WS3 = BIT2 ;WORD LENGTH SELECT #3
TXSUND = BIT1 ;TRANSMIT SYNCH ON UNDERFLOW
EIE = BIT0 ;ERROR INTERRUPT ENABLE
; AC1=1 & AC2=0 SELECTS CONTROL REGISTER #3
; 7 - EXTERNAL/INTERNAL SYNCH MODE CONTROL (E/I SYNCH) =0
; 6 - 1 SYNCH CHAR/2 SYNCH CHAR MODE CONTROL =0
; 5 - CLEAR CTS BAR STATUS =0
; 4 - CLEAR TRANSMITTER UNDERFLOW STATUS (CTUF) =0
; 3 - NOT USED
; 2 - NOT USED
; 1 - NOT USED
; 0 - NOT USED
; BIT EQUATES FOR CONTROL REGGISTER #3
EISYNC = BIT7 ;EXTERNAL/INTERNAL SYNCH MODE CONTROL
SYNC12 = BIT6 ;SYNCH CHAR MODE CONTROL
CCTS = BIT5 ;CLEAR CTS BAR STATUS
CTUF = BIT4 ;CLEAT TUF STATUS
; AC1=0 & AC2=1 SELECTS SYNCH CODE REGISTER
; AC1=1 & AC2=1 SELECTS TRANSMIT DATA FIFO
.= ^H0180 ;START OF STACK & SCRATCH RAM
STPNT: .=.
RAM3: .=.+1
; NEXT FIVE BYTES ARE SAVE AREA FOR COMMAND FRAME INPUT
UNITNB: .=.+1 ;DRIVE UNIT # (ASCII)
CTLCMD: .=.+1 ;CONTROLLER COMMAND
AUX1: .=.+1 ;LSB OF 16-BIT LOGICAL SECTOR #
AUX2: .=.+1 ;MSB OF 16-BIT LOGICAL SECTOR #
RCDCSM: .=.+1 ;COMMAND FRAME CHECKSUM
TMPOUT: .=.+1 ;ALL SERIAL OUTPUT SHIFTED FROM THIS ADDR
DICKSM: .=.+1 ;DATA FIELD CHECKSUM TEMP
.=.+8 ;SPARE
; NEXT 4 BYTES SENT TO COLLEEN FOR STATUS COMMAND ON BOTTOM DRV
STFLG2: .=.+1 ;BOTTOM DRV STATUS FLAGS
DEVST2: .=.+1 ;BOTTOM DRV XTRA STATUS
WCTLB2: .=.+1 ;BOTTOM DRV WORST CASE TIMEOUT (LSB)
WCTMB2: .=.+1 ;DELAY (MSB)
; NEXT 2 BYTES ARE CODES FOR PORTB2:
EGON: .=.+1 ;ERASE GATE TURN ON CODE
WGOFF: .=.+1 ;WRITE GATE TURN OFF CODE (LEAVES EG ON)
; NEXT 2 BYTES ARE USED FOR CRC GENERATION:
BAKER: .=.+1 ;CRC GENERATION SCRATCH 1
ABLE: .=.+1 ;CRC GENERATION SCRATCH 2
GAPBYT: .=.+1 ;BYTE INIT'D TO $4E FOR CRC WRITE
DH80T: .=.+1 ;DOUBLE HEAD & 80 TRK TEST BYTE
; 7 - DOUBLE=1 / SINGLE=0 HEAD DRIVE
; 6 - 80 TRK=1 / 40 TRK=0 TRACK DENSITY
; BIT EQUATES:
DBLHED = BIT7 ;DOUBLE/SINGLE HEADED DRVS
TPI96 = BIT6 ;TRACK DENSITY BIT
.=.+3 ;SPARE
STPDIR: .=.+1
RDCRC2: .=.+1
RDCRC1: .=.+1
STPNB2: .=.+1 ;# OF STEPS TO DESIRED TRACK, BOTTOM DRV
PRTRK2: .=.+1 ;PRESENT TRACK #, BOTTOM DRV
SPSDC2: .=.+1 ;LOOP COUNTER FOR BOTTOM DRV SHUTDOWN TIMER
SPMDC2: .=.+1
SCRT1: .=.+1
SCRT2: .=.+1
SCTTBL: .=.+11 ;START OF 11-BYTE ID FIELD
SPMDLC: .=.+1 ;1 SEC LOOP COUNT FOR SPM SHUT-OFF (4 * 125 MS)
.=.+27 ;SPARE
STPSCR: .=.+1 ;STEP ROUTINE SCRATCH
PRSTRK: .=.+1 ;PRESENT TRACK #, TOP DRV
STPNBR: .=.+1 ;# OF STEPS TO DESIRED TRK #, TOP DRV
; THE NEXT 4 BYTES SENT TO COLLEEN FOR STATUS COMMAND, TOP DRV
STFLGS: .=.+1 ;STATUS FLAGS (TOP DRV) SHIPPED TO COLLEEN
; BIT DEFINITIONS FOR CONTROLLER STATUS FLAGS BYTE:
; 7 - TRACK DENSITY (0=40 TRK, 1=80 TRK)
; 6 - SERIAL BAUD RATE (0=19.2KB, 1=38.4KBAUD)
; 5 - SECTOR SIZE (0=128B/S, 1=256 BYTES/SECTOR)
; 4 - MOTOR/SELECT LITE STATUS (0=OFF, 1=ON)
; 3 - WRITE PROTECT STATUS (1=WRITE PROTECTED)
; 2 - READ/WRITE ERROR (SET IF ERROR, LAST R/W)
; 1 - INVALID DATA FRAME " "
; 0 - INVALID COMMAND FRAME " "
; BIT EQUATES FOR STFLGS:
TRK80 = BIT7 ;TRACK DENSITY
BAUD38 = BIT6 ;SERIAL BAUD RATE
SEC256 = BIT5 ;SECTOR SIZE
MTR0 = BIT4 ;MOTOR ON STATUS
WPS0 = BIT3 ;WRITE PROTECT
RWE0 = BIT2 ;READ/WRITE ERROR
INVDF0 = BIT1 ;INVALID DATA FRAME ERROR
INVCF0 = BIT0 ;INVALID COMMAND FRAME ERROR
DEVSTA: .=.+1 ;TOP DRV EXTRA STATUS
; BIT DEFINITIONS FOR EXTRA STATUS BYTE:
; 7 - N/A
; 6 - N/A
; 5 - N/A
; 4 - NO ID MARK?
; 3 - N/A
; 2 - N/A
; 1 - N/A
; 0 - N/A
; BIT EQUATES FOR DEVSTA:
NOID = BIT4 ;NO ID MARK FOUND?
DUM10 = BIT3 ;???
WCTLSB: .=.+1 ;WORST CASE TIMEOUT SENT TO COLLEEN (LSB)
WCTMSB: .=.+1 ;(MSB)
PACNTR: .=.+1 ;R/W ERROR RETRY COUNT
.=.+2 ;SPARE
SSCTMS: .=.+1 ;MSB,16-BIT LOGICAL SECTOR # (SECTOR BREAKDOWN)
SSCTLS: .=.+1 ;LSB, SAVED BY SEC BRKDWN BUT NOT USED
.=.+1 ;SPARE
TRKNBR: .=.+1 ;TRACK # COMPUTED IN SECTOR BREAK-DOWN
SCTNBR: .=.+1 ;SECTOR # FROM SECTOR BREAK-DOWN
INMODE: .=.+1 ;INTERNAL MODE REGISTER
; BIT DEFINITIONS FOR INMODE:
; 7 - 19.2/38.4 KBAUD SERIAL DATA RATE (19.2 KBAUD = 1)
; 6 - DRIVE SELECT (TOP DRIVE = 1, BOTTOM DRIVE = 0)
; 5 - SIDE SELECT (FOR DUAL HEADED DRIVES, SIDE0=0, SIDE1=1)
; 4 - N/A
; 3 - N/A
; 2 - SPM2 NOT ON >1 SEC IF SET
; 1 - N/A
; 0 - IF SET, WITHIN COMMAND INPUT ROUTINE (ALSO USED FOR DATA/CMD FRAME
; CHECKSUM ROUTINE SELECT)
; BIT EQUATES FOR INMODE:
BAUD19 = BIT7 ;SERIAL DATA RATE SELECT
TOPDRV = BIT6 ;DRIVE SELECT
SIDE1 = BIT5 ;SIDE SELECT
DUM1 = BIT4 ;DUMMY BIT NOT USED
DUM2 = BIT3 ;DUMMY BIT NOT USED
S2NRDY = BIT2 ;BOTTOM DRV, SPM NOT READY
DUM3 = BIT1 ;DUMMY BIT NOT USED
CMDFIN = BIT0 ;COMMAND FRAME INPUT
CRCTST = BIT0 ;CRC TESTING INDICATOR
DUM11 = BIT0 ;DUMMY BIT USED
INSTAT: .=.+1 ;INTERNAL STATUS REGISTER
; BIT DEFINITIONS FOR INTERNAL STATUS REGISTER:
; 7 - RECEIVING NEW COMMAND WORDS IF SET
; 6 - BUSY, SET WHENEVER GOING TO A ROUTINE THAT WILL KEEP US
; AWAY FROM THE COMMAND FRAME MONITOR MORE THAN 400 MS
; 5 - SHUTDOWN IN PROGRESS, WHEN SET INDICATES CONTROL SHOULD RTS
; FROM MAIN MONITOR--DOES NOT INDICATE 400 MS ABSENCE
; 4 - NO DISK
; 3 - FORMAT ERROR IF SET, AND READ AFTER WRITE FLAG!
; 2 - SPINDLE MOTOR HAS NOT BEEN ON 1 SEC IF SET
; 1 - COMMAND RECEIVE ERROR IF SET
; 0 - IF SET, COLLEEN HAS NOT BEEN WITH US 100 MS+
; BIT EQUATES FOR INSTAT:
RECCMD = BIT7 ;RECEIVING COMMAND
BUSY = BIT6 ;CONTROLLER BUSY
SHTDWN = BIT5 ;SHUTDOWN IN PROGRESS
NODISK = BIT4 ;NO DISK
FMTER = BIT3 ;FORMAT ERROR
RDAFWR = BIT3 ;READ AFTER WRITE INDICATOR
S1NRDY = BIT2 ;SPM TOP DRIVE NOT READY
CRECR = BIT1 ;COMMAND RECEIVE ERROR
NO800 = BIT0 ;COLLEEN HAS NOT BEEN WITH US
INSCRT: .=.+1 ;LAST INDEX +1 TO TERMINATE INPUT OR CHECKSUM
TMRSCR: .=.+1 ;TIMER SCRATCH
FSCTBP: .=.+1 ;FORMAT VERIFY ERROR RETRY COUNT
BFRPNT: .=.+1 ;FORMAT BAD SECTOR # BUFFER INDEX
.=.+1 ;SPARE
TMPSB: .=.+1 ;*2 TEMP STORAGE FOR SECTOR BUILD-UP
MSBSB: .=.+1 ;MSB FOR SECTOR BUILD-UP
CSSCRT: .=.+1
YSAVE: .=.+1
.=.+1 ;SPARE
CTABL: .=.+1 ;JUMP INDIRECT ADDRESS FOR COMMAND INTERPRETER
CTABH: .=.+1 ;MSB
CISCRT: .=.+1 ;COMMAND INTERPRETER SCRATCH
SPMSDC: .=.+1 ;LOOP COUNTER FOR TOP DRV SHUTDOWN TIMER
.= ^H0200 ;START OF PIA #3 ADDR SPACE
PORTA3: .=.+1 ;PORT A, ONBOARD PIA #3
; BIT ASSIGNMENTS FOR PORT A, PIA #3:
; 7 - DRIVE ADDR DECODE INPUT
; 6 - N/A
; 5 - N/A
; 4 - WRITE LIGHT, TOP DRIVE OUTPUT
; 3 - READ LIGHT, TOP DRIVE OUTPUT
; 2 - 96/48 TPI SENSE (96 = 0) INPUT
; 1 - MOTOR ON/DRV SELECT, BOTTOM DRV OUTPUT
; 0 - DRIVE ADDR DECODE 2 INPUT
; BIT EQUATES FOR PORTA3:
DRVAD1 = BIT7 ;DRIVE ADDRESS DECODE #1
DUM4 = BIT6 ;DUMMY BIT NOT USED
DUM5 = BIT5 ;DUMMY BIT NOT USED
WLTOP = BIT4 ;WRITE LIGHT, TOP DRIVE
RLTOP = BIT3 ;READ LIGHT, TOP DRIVE
TPISNS = BIT2 ;TPI SENSE
SELBOT = BIT1 ;MOTOR ON/DRV SEL BOTTOM DRIVE
DRVAD2 = BIT0 ;DRIVE ADDRESS DECODE #2
PADDR3: .=.+1 ;PORT A, PIA #3 DATA DIRECTION CONTROL (1=OUTPUT TO PIA)
PORTB3: .=.+1 ;PORT B, PIA #3
; BIT DEFINITIONS FOR PORT B, PIA #3:
; 7 - DRIVE MANUFACTURER (=0 IF NOT MPI) INPUT
; 6 - # OF HEAD(S) (DOUBLE HEADED IF =0) INPUT
; 5 - BOTTOM DRV STEPPER MOTOR PHASE 4 OUTPUT
; 4 - BOTTOM DRV STEPPER MOTOR PHASE 3 OUTPUT
; 3 - BOTTOM DRV STEPPER MOTOR PHASE 2 OUTPUT
; 2 - BOTTOM DRV STEPPER MOTOR PHASE 1 OUTPUT
; 1 - EXTENDED PROM SPACE INSTALLED IF =0 INPUT
; 0 - INNER TRKS AMPLIFIER ADJUST (0=TRK>20) OUTPUT
; BIT EQUATES FOR PORTB3:
DMANUF = BIT7 ;DRIVE MANUFACTURER
HEADNO = BIT6 ;# OF HEADS/DRV
SPBOT4 = BIT5 ;BOTTOM STEPPER PHASE 4
SPBOT3 = BIT4 ;BOTTOM STEPPER PHASE 3
SPBOT2 = BIT3 ;BOTTOM STEPPER PHASE 2
SPBOT1 = BIT2 ;BOTTOM STEPPER PHASE 1
XTPROM = BIT1 ;EXTENDED PROM SPACE
AMPADJ = BIT0 ;INNER TRACK AMPLIFIER ADJUST
PBDDR3: .=.+1 ;DATA DIRECTION CONTROL, PORT B PIA #3
PIA3EC: .=.+1
TIMR3R = ^H0215
TIMR23 = ^H021F
.= ^H0280 ;START OF PIA #2 ADDR SPACE
PORTA2: .=.+1 ;PORT A, PIA #2
; BIT DEFINITIONS FOR PORT A, PIA #2:
; 7 - WRITE LIGHT, BOTTOM DRIVE (0=ON) OUTPUT
; 6 - READ LIGHT, BOTTOM DRIVE (0=ON) OUTPUT
; 5 - N/A
; 4 - BOTTOM DRIVE, BOTTOM HEAD READ (0=ON) OUTPUT
; 3 - BOTTOM DRIVE, TOP HEAD READ (0=ON) OUTPUT
; 2 - N/A
; 1 - TOP DRIVE, BOTTOM HEAD READ (1=ON) OUTPUT
; 0 - TOP DRIVE, TOP HEAD READ (1=ON) OUTPUT
; BIT EQUATES FOR PORTA2:
WLBOT = BIT7 ;WRITE LIGHT, BOTTOM DRV
RLBOT = BIT6 ;READ LIGHT, BOTTOM DRV
DUM7 = BIT5 ;DUMMY BIT NOT USED
BDBHRD = BIT4 ;BOTTOM DRV, BOTTOM HEAD, READ
BDTHRD = BIT3 ;BOTTOM DRV, TOP HEAD, READ
DUM8 = BIT2 ;DUMMY BIT NOT USED
TDBHRD = BIT1 ;TOP DRIVE, BOTTOM HEAD, READ
TDTHRD = BIT0 ;TOP DRIVE, TOP HEAD, READ
PADDR2: .=.+1 ;DATA DIRECTION CONTROL REG, PORT A, PIA #2
PORTB2: .=.+1 ;PORT B, PIA #2
; BIT DEFINITIONS FOR PORT B, PIA #2:
; (ALL BITS ENABLED WHEN 0)
; 7 - BOTTOM DRIVE, BOTTOM HEAD ERASE OUTPUT
; 6 - BOTTOM DRIVE, BOTTOM HEAD WRITE OUTPUT
; 5 - BOTTOM DRIVE, TOP HEAD ERASE OUTPUT
; 4 - BOTTOM DRIVE, TOP HEAD WRITE OUTPUT
; 3 - TOP DRIVE, BOTTOM HEAD ERASE OUTPUT
; 2 - TOP DRIVE, BOTTOM HEAD WRITE OUTPUT
; 1 - TOP DRIVE, TOP HEAD ERASE OUTPUT
; 0 - TOP DRIVE, TOP HEAD WRITE OUTPUT
; BIT EQUATES FOR PORTB2:
BDBHER = BIT7 ;BOTTOM DRIVE, BOTTOM HEAD ERASE
BDBHWR = BIT6 ;BOTTOM DRV, BOTTOM HEAD WRITE
BDTHER = BIT5 ;BOT DRV, TOP HEAD ERASE
BDTHWR = BIT4 ;BOT DRV, TOP HEAD WRITE
TDBHER = BIT3 ;TOP DRV, BOTTOM HEAD ERASE
TDBHWR = BIT2 ;TOP DRV, BOTTOM HEAD WRITE
TDTHER = BIT1 ;TOP DRV, TOP HEAD ERASE
TDTHWR = BIT0 ;TOP DRV, TOP HEAD WRITE
PBDDR2: .=.+1 ;DATA DIRECTION CONTROL, PORT B, PIA #2
PIA2EC: .=.+1
TIMR2R = ^H0295
TIMR22 = ^H029F
.= ^H0380 ;START OF PIA #1 ADDR SPACE
PORTA1: .=.+1 ;PORT A, PIA #1
; BIT DEFINITIONS FOR PORT A, PIA #1:
; 7 - SYNCH MATCH INPUT
; 6 - CLK RESET OUTPUT
; 5 - CTS BAR RESET OUTPUT
; 4 - WRITE PROTECT, TOP DRIVE INPUT
; 3 - MASTER RESET SSDA OUTPUT
; 2 - N/A
; 1 - MOTOR ON, DRIVE SELECT, TOP DRIVE OUTPUT
; 0 - WRITE PROTECT, BOTTOM DRIVE INPUT
; BIT EQUATES FOR PORTA1:
SYNCMT = BIT7 ;SYNCH MATCH
CLKRST = BIT6 ;CLK RESET
CTSRST = BIT5 ;CTS BAR RESET
WPTOP = BIT4 ;WRITE PROTECT, TOP DRV
MRSSDA = BIT3 ;MASTER RESET SSDA
DUM9 = BIT2 ;DUMMY BIT USED IN PROGRAM
SELTOP = BIT1 ;MOTOR ON, DRV SELECT TOP DRV
WPBOT = BIT0 ;WRITE PROTECT, BOTTOM DRV
PADDR1: .=.+1 ;DATA DIRECTION CONTROL, PORT A, PIA #1
PORTB1: .=.+1 ;PORT B, PIA #1
; BIT DEFINITIONS FOR PORT B, PIA #1:
; 7 - SERIAL DATA INPUT INPUT
; 6 - COMMAND FRAME INPUT (1=RECEIVING CMD FRAME)
; 5 - TOP DRIVE STEPPER MOTOR PHASE 4 OUTPUT
; 4 - TOP DRIVE STEPPER MOTOR PHASE 3 OUTPUT
; 3 - TOP DRIVE STEPPER MOTOR PHASE 2 OUTPUT
; 2 - TOP DRIVE STEPPER MOTOR PHASE 1 OUTPUT
; 1 - READY/VCC INPUT
; 0 - SERIAL DATA OUTPUT OUTPUT
; BIT EQUATES FOR PORTB1:
SERIN = BIT7 ;SERIAL DATA INPUT
CMDFRM = BIT6 ;COMMAND FRAME
SPTOP4 = BIT5 ;TOP DRV, STEPPER 4
SPTOP3 = BIT4 ;TOP DRV, STEPPER 3
SPTOP2 = BIT3 ;TOP DRV, STEPPER 2
SPTOP1 = BIT2 ;TOP DRV, STEPPER 1
RDY = BIT1 ;READY/VCC
SEROUT = BIT0 ;SERIAL DATA OUTPUT
PBDDR1: .=.+1 ;DATA DIRECTION CONTROL FOR PORT B, PIA #1
PIA1EC: .=.+1
TIMR1R = ^H0395
TIMR3 = ^H039E
TIMR2 = ^H039F
; PAGE 8
; THE FOLLOWING ARE ADDRESSES INTO A JUMP TABLE FOR 38 KBAUD SERIAL
; AND DOUBLE HEADED DRIVES ROUTINES. THE TABLE WILL ULTIMATELY
; RESIDE AT 800 HEX.
XTND0 = ^H0800
XTND1 = ^H0803
XTND2 = ^H0806
XTND3 = ^H0809
XTND4 = ^H080C
XTND5 = ^H080F ;FORMAT VERIFY FOR 38KBAUD, DOUBLE HEAD, OR 96 TPI
XTND6 = ^H0812 ;SECTOR # VALIDITY TEST, > 720
XTND7 = ^H0815
XTND8 = ^H0818 ;DATA FIELD INPUT, 38K BAUD
XTND9 = ^H081B
XTND10 = ^H081E ;SIDE 2 CLRS?
XTND11 = ^H0821
XTND12 = ^H0824
XTND13 = ^H0827
XTND14 = ^H082A
; MISCELLANEOUS EQUATES
TIMOUT = 224 ;WORST CASE TIME OUT VALUE TO SHIP TO COLLEEN
MAXTRK = 39 ;MAXIMUM TRACK #, THIS TIME AROUND
ACK = 'A ;ACKNOWLEGE CODE
NAK = 'N ;NEGATIVE ACKNOWLEGE
CMPLT = 'C ;COMMAND COMPLETE CODE
ERROR = 'E ;COMMAND EXECUTION ERROR
; COMMANDS SUPPORTED BY CONTROLLER
DOWNL = ^H020 ;DOWN LOAD
FORMT = ^H021 ;FORMAT DISK
WRINOV = ^H050 ;WRITE SECTOR WITHOUT VERIFY
RDSPIN = ^H051 ;CONTINUOUSLY READ A SECTOR (FOR TESTING ALIGNMENT)
READSC = ^H052 ;READ A SECTOR
STATCD = ^H053 ;STATUS COMMAND
READAD = ^H054 ;READ FROM ADDRESS
MTRDLY = ^H055 ;MOTOR ON DELAY 30 SEC
VERIFY = ^H056 ;VERIFY A SECTOR AGAINST INPUT DATA
WRIVER = ^H057 ;WRITE A SECTOR WITH VERIFY
; DATA PATTERNS USED FOR FORMATTING:
DAM = ^H0FB ;DATA ADDRESS MARK
; START OF ROM BASED PROGRAM
.=^H00800
; POWER-ON INTIALIZATION
INIT: CLD ;BINARY ARITHMETIC
LDA #BDBHRD+BDTHRD+TDBHRD+TDTHRD
LDX #255
TXS ;STACK POINTER -> $1FF
STA PORTA2
STX PORTB2 ;INIT TO READ, ALL HEADS
STX PADDR2 ;ALL PORTA2 BITS ARE OUTPUT
STX PBDDR2 ;AND PORTB2 TOO
LDA #0
STA PORTA1 ;TURN OFF TOP DRV SPM
STA PORTA3 ;TURN OFF BOTTOM DRV TOO
STA PORTB3 ;CLEAR BOTTOM DRV STEPPER BITS
LDA #WLTOP+RLTOP+SELBOT
STA PADDR3 ;BITS SET FOR OUTPUT
LDX #CLKRST+CTSRST+MRSSDA+SELTOP
STX PADDR1 ;BITS SET FOR OUTPUT
LDX #SPTOP1+SPTOP2+SPTOP3+SPTOP4
STX PBDDR1 ;TOP DRIVE STEPPERS SET AS OUTPUT
INX
STX PBDDR3 ;BOTTOM DRIVE STEPPERS (& BIT0) SET AS OUT
LDX #SPTOP4+SPTOP3
STX PORTB1 ;INIT STP PHASE,BOTH DRVS
STX PORTB3
STX PIA1EC
STX PIA3EC
STX PIA2EC
; INITIALIZATION CONTINUED
INITC: LDX #CLKRST+CTSRST+MRSSDA
STX PORTA1 ;NABL RD CLK SWITCH,TUF LATCH
;AND SSDA CHIP
LDA #RXRS+TXRS+CLEARS
STA SSDA0 ;REST REC(X)MIT. NABL C2 WRITE
LDA #PC1+WS1+WS2+TXSUND+EIE
STA SSDA1 ;INIT C2 REG
LDA #RXRS+TXRS+CLEARS+AC1
STA SSDA0 ;NABL C3 WRITE
LDA #0
STA SSDA1 ;INIT C3 REG
; POWER ON RAM TEST
RAMTST: LDX #127 ;128-BYTE BLOCKS TO TEST
RT1: STA ZPRL(X)
STA ZP80(X)
STA RAM3(X) ;CLR & CHK 3 128 BYTE 6532'S
CMP ZPRL(X)
BNE RTERR
CMP ZP80(X)
BNE RTERR
CMP RAM3(X)
BNE RTERR
DEX
BPL RT1
BMI PASRAM
RTERR: LDA #RLTOP ;TOP READ LITE
RTERR1: STA PORTA3 ;FLASH DRV1 RD LAMP FOR RAM
RTERR2: DEX ;FAILURE INDICATION
BNE RTERR2
INY
BNE RTERR2
EOR #RLTOP
BPL RTERR1
; WE PASSED
PASRAM: LDA #NO800+S1NRDY ;SET INSTAT FOR COLEN ABSNT
STA INSTAT ;AND SPM UNSTABL
LDA #BAUD19+TOPDRV+S2NRDY ;SET INMODE FOR 19K I/O ROUTS
STA INMODE ;SPM2 UNSTBL,&DRIVE1 SEL
LDA #MAXTRK
STA PRTRK2 ;ASSUME DRIVE2 ON TRK 39
STA PRSTRK ;ASSUME DRV1 ON TRK 39
LDA #4
STA SPMDLC ;SET FOR 4 DELAYS OF 125MS EACH
;FOR SPM STABL
LDA #TIMOUT&255
STA WCTLSB
STA WCTLB2
LDA #TIMOUT/256
STA WCTMSB ;SET WORS CASE TIMOUT STAT BYTES
STA WCTMB2 ;FOR BOTH DRIVE 1 AND 2
STA DEVSTA ;CLR ALL CONTROLR STAT DRV1
STA DEVST2 ;DITTO FOR DRV2
STA SPMSDC ;CLR SHUTDN TIME DRV1
STA SPSDC2 ;DITTO FOR DRV2
; COPY ID FIELD INTO RAM
LDX #10 ;11-BYTE ID FIELD
SCTSET: LDA IDFLD(X)
STA SCTTBL(X)
DEX
BPL SCTSET ;PRLMNARY SETUP OF RD/WRTSET
;SYNC DATA
INX ;X=0
LDY #BAUD38+SEC256
LDA PORTB3
AND #XTPROM ;CHECK EXTRA PROM FLAG
BNE INIT50
JSR XTND14 ;GO TO XTRA ROM FOR MOR DH/96
;TPI AND 38K TSTING
INIT50: STY STFLGS ;SET DRV1 STAT TO REFLCT DH/96
;TPI AND 38K CAPABILITIES
STY STFLG2 ;DITTO FOR DRV2
STX DH80T ;SET FOR SGL HEAD, 40 TRACK
JSR CLRST ;CLEAR ERROR FLAGS ON TOP DRV
JSR CLRST2 ;BOTTOM TOO
; WARM START RE-ENTRY POINT
INIT2: LDX #255 ;REDO STACK POINTER
TXS ;TO TOP OF STACK
LDA #^CWPS0
JSR CLRST1 ;CLEAR TOP DRV WP STATUS
LDA #^CWPS0
JSR CLRS12 ;BOTTOM DRV TOO
LDX #WPS0 ;GET WRITE PROTECT STATUS BIT IN X
LDA PORTA1 ;CHECK HARDWARE FOR STATUS
TAY ;SAVE IN Y FOR BOTTOM DRV TEST
AND #WPTOP ;CHECK TOP DRV WRITE PROTECT
BEQ INIT29 ;IF NOT PROTECTED, GOTO BOTTOM DRV CHECK
TXA ;ELSE, GET WP FLAG IN ACCUM
JSR ORSTF ;SET IT IN TOP DRV STATUS FLAGS
INIT29: TYA ;GET PORTA1 IN ACCUM AGAIN
AND #WPBOT ;CHECK BOTTOM DRV WRITE PROTECT
BEQ INIT21 ;IF NOT PROTECTED, GET ON WITH INIT
JSR ORSTF2 ;SET IT IN BOTTOM DRV STATUS FLAGS
INIT21: LDX #BDBHRD+BDTHRD+TDBHRD+TDTHRD
STX PORTA2 ;TURN OFF ALL LTS AND RD NABLS
LDA PORTA3
AND #^C<WLTOP+RLTOP>
STA PORTA3
BIT DH80T
BPL INIT22
JSR XTND10 ;GO TO XTRA ROM FOR SIDE2 CLRS
INIT22: LDA #TOPDRV
JSR ORINMD ;SET FOR DRV1 SRVICE
LDA #MAXTRK
JSR CSTEP ;CALC STPS NEEDED FOR TRK 39 DRV
STY STPNBR ;1 AND SAVE TMP
LDA #^CTOPDRV
JSR ANDNMD ;SET FOR DRIV2 SRVICE
LDA #MAXTRK
JSR CSTEP ;CALC STPS NEEDED FOR TRK 39,DRV
STY STPNB2 ;2 AND SAVE TMP
LDA #SHTDWN
JSR ORINST ;SET SHUTDN BIT IN INTRNL STAT
LDA #^CRDAFWR
JSR ANINS
INIT3: LDX SPMSDC
BEQ INIT4 ;BRNCH IF DRV1 TIMED OUT
LDA #255
STA TIMR23 ;SET 125MS DELA
DEX
STX SPMSDC ;UPDATE AND SAV DRV1 TIMR SCRT
INIT4: LDX SPSDC2
BEQ INIT5 ;BRNCH IF DRV2 TIMED OUT
LDA #255
DEX
STX SPSDC2 ;UPDATE AND SAV DRV2 TIMR SCRT
INIT5: LDX SPMSDC
BNE INIT6 ;BRNCH IF DRV1 NOT TIMED OUT
LDX #^H080
LDY STPNBR ;GET SET TO STP DRV1
BEQ INIT11 ;BRNCH IF NO STPS NEEDED ON DRV1
JSR STEP1 ;STEP DRV1 AND SAV STP CNTR
BEQ INIT11 ;BRNCH IF LAST STP JUST DONE
INIT51: STY STPNBR
INIT6: LDX SPSDC2
BNE INIT7 ;BRNCH IF DRV2 NOT TIMED OUT
LDX #^H080
LDY STPNB2 ;GET SET TO STP DRV2
BEQ INIT12 ;BRNCH IF NO STPS NEEDED ON DRV2
JSR STP2 ;STP DRV2 AND SAV STP CNTR
BEQ INIT12 ;BRNCH IF LAST STP JUST DONE
INIT61: STY STPNB2
INIT7: LDX SPMSDC
BNE INIT8 ;BRNCH TO POLL TIMR IF DRV1 NOT
;TIMED OUT
LDX SPSDC2
BNE INIT8 ;RNCH TO POLL TIMR IF DRV2 NOT
;TIMED OUT
LDX STPNBR
BNE INIT9 ;BRNCH TO POLL 5MS TIMR IF DRV1
;NOT ON TRK 39
LDX STPNB2
BNE INIT9 ;BRNCH TO POLL 5MS TIMR IF DRV2
;NOT ON TRK 39
INIT71: LDA #^CSHTDWN
JSR ANINS ;CLR SHUTDN BIT IN INTRNL STAT
JMP MMON ;LEAVE THIS ROUT--POLL FOR CMND
INIT11: LDA #CLKRST+CTSRST+MRSSDA
STA PORTA1 ;TURN OFF SPM1
LDA #S2NRDY
JSR ORINST ;SET SPM1 UNSTBL BIT
JMP INIT51
INIT12: LDA #0
STA PORTA3 ;TURN OFF SPM2
LDA #S2NRDY
JSR ORINMD ;SET SPM2 UNSTBL BIT
JMP INIT61
INIT8: BIT TIMR3R
BMI INIT10 ;BRNCH IF 125MS UP
JSR MMON
INIT9: BIT TIMR1R
BMI INIT5 ;BRNCH IF 5MS UP
JSR MMON
JMP INIT9
INIT10: BIT TIMR1R
BMI INIT13 ;BRNCH IF 5 MS UP
JSR MMON
JMP INIT10
INIT13: JMP INIT3
; MAIN MONITOR
; MONITORS THE READY PORT FOR
; COLLEEN PRESENCE. MONITORS THE CMND
; FRAME,BRINGS IN 5 BYTE COMMAND, CHE
; CKS FOR VALID CHECKSUM, CHECKS IF
; CMND ADDRESS IS FOR FLOPPY BEFORE
; GOING TO CMND INTERPRET ROUT
MMON: LDA PORTB1
LSR
LSR
BCS NCOLL ;TST RDY PORT &BRNCH IF COLEN AB
;SENT
LDA INSTAT
LSR
BCS JCOLL ;TST IF COLEN PRSNT 100MS BRNCH
;IF NOT
BIT PORTB1 ;
BVC NOCF ;TST FOR CMND FRAME BRNCH IF NO
BIT INSTAT
BVC EDGE ;BRNCH IF MISSED EDGE BY 400US
LDA #^H0A4
JSR TIMER
BIT PORTB1 ;WAIT 100MS,THEN TEST IF
BVS EDGE ;CMND FRAME STILL PRESNT
NOCF: LDA INSTAT
AND #BUSY+SHTDWN
BNE MMX ;TST TO JSR BACK TO BUSY OR
JMP MMON ;SPIN IN MAIN MONITOR ROUT
MMX: RTS
JCOLL: LDA #^H0A4
JSR TIMER
LDA #^CNO800
JSR ANINS ;SET STAT TO REFLCT COLEN NOT
;PRESNT 100MS
JMP MMON
NCOLL: LDA #NO800
JSR ORINST ;SET INTRNL STAT NOT RDY BIT
JMP NOCF
EDGE: LDA #RECCMD
JSR ORINST ;SET INTRNL STAT "NEW CMND BIT"
LDX #0
LDA #5
STA INSCRT ;SET UP TO BRING IN CMND
JSR CINPUT
; MAIN MONITOR (CONTINUED)
MMON1: LDX #0
DEC INSCRT ;SET UP TO GEN CS ON 4 BYTE
JSR CDCKSM ;CMND
BEQ CCMD ;BRNCH IF CS OK
LDA #CRECR ;SET COMMAND RECEIVE ERROR
JSR ORINST ;IN INSTAT
CCMD: LDA PORTA3 ;CHECK DRIVE ADDR DECODE
LSR ;CHECK DRV ADDR #2
BCC ADRDC3 ;IF SET, GOTO ADRDC3
LDX #'1
ASL ;RESTORE PORTA3
BMI ADRDC5 ;IF DRV ADDR #1 IS SET, BRANCH
LDX #'5
ADRDC5: CPX UNITNB
BEQ ADRDC7 ;BRNCH IF DRIV ADDRESED IS ODD
INX
CPX UNITNB
BEQ ADRDC6 ;BRNCH IF EVEN DRIV ADRESED IS U
CCF: BIT PORTB1
BVS CCF ;SPIN TIL COMND FRAM GONE
LDA #^C<RECCMD+CRECR> ;CLR REC NEW CMND AND
JSR ANINS ;CS ERR BITS
JMP MMON ;RETURN TO MON SER BUS
ADRDC6: LDA #^C<TOPDRV>
JSR ANDNMD ;UPDATE INMODE FOR DRIV 2 SEL
ADRDC8: JSR CMDI ;GO COMMAND INTERP---FOR US
JMP MMON
ADRDC7: LDA #TOPDRV
JSR ORINMD ;UPDATE INMODE FOR DRIV 1 SEL
BNE ADRDC8
ADRDC3: LDX #'3
ASL
BMI ADRDC5
LDX #'7
BNE ADRDC5
; COMMAND INTERPRETER
CMDI: LDA INSTAT ;CHECK RECEIVE ERROR FLAG
AND #CRECR ;MASK OFF OTHERS
BNE CMD2 ;IF CHECKSUM ERROR, GOTO INVALID CMD NAK
LDA CTLCMD ;ELSE, FETCH CMD CODE FROM CMD FRAME
LDX #TBBT-TABB ;MAXIMUM INDEX INTO LEGAL CMD CODE TABLE
XTAB: CMP TABB(X) ;COMPARE REC'D CMD W/LEGAL CMD LIST
BEQ GTCMD ;GOT A MATCH, GO EXECUTE
DEX ;ELSE, DECREMENT INDEX
BPL XTAB ;LOOP IF ^AANY LEGAL ENTRIES LEFT
BMI CMD2 ;NO, UNCONDITIONAL SEND INVALID CMD FRAME
GTCMD: LDA TABL(X) ;YES, FETCH LO ADDR OF ROUT
STA CTABL ;SAVE IN INDIRECT JUMP VECTOR
LDA TABH(X) ;FETCH HI ADDR TOO
STA CTABH ;SAVE IN HI ADDR OF VECTOR
JMP @CTABL ;JUMP TO SELECTED COMMAND ROUTINE
CMD2: LDA #INVCF0 ;SET INVALID CMD FRAME FLAG
JSR OR0STX ;IN PRESENT DRIVE STATUS BYTE
JSR MFUTST ;SET SPM ON BIT IN STATUS TOO
CMD3: BIT PORTB1
BVS CMD3 ;WAIT TIL CMD FRAME GONE
LDA #NAK ;LOAD NAK CODE
JSR SAA2 ;SEND IT TO COLLEEN
LDA #^CCRECR ;CLEAR CMD RECEIVE ERROR FLAG
JSR ANINS ; IN INTERNAL STATUS REGISTER
RTS ;RETURN TO MAIN MONITOR
; COMMAND INTERPRETER LOOK-UP TABLES
TABB: .BYTE DOWNL,FORMT,WRINOV,RDSPIN,READSC,STATCD,READAD,MTRDLY,VERIFY,WRIVER
TBBT =.-1
TABL: .BYTE DOWNLD&255 ;DOWN LOAD
.BYTE FRMT&255 ;FORMAT
.BYTE WRITE1&255 ;WRITE, NO VERIFY
.BYTE RDSPN&255 ;READ SPIN
.BYTE READ&255 ;READ SECTOR
.BYTE STCMD&255 ;STATUS COMMAND
.BYTE RDADR&255 ;READ FROM ADDRESS
.BYTE MOTRON&255 ;MOTOR ON DELAY
.BYTE WRITE&255 ;VERIFY ENTERS AT WRITE
.BYTE WRITE&255 ;WRITE/VERIFY
TABH: .BYTE DOWNLD/256
.BYTE FRMT/256
.BYTE WRITE1/256
.BYTE RDSPN/256
.BYTE READ/256
.BYTE STCMD/256
.BYTE RDADR/256
.BYTE MOTRON/256
.BYTE WRITE/256
.BYTE WRITE/256
; WRITE ROUTINE
WRITE: LDA #RDAFWR
JSR ORINST ;SET INSTAT FOR READ AFTR WRITE
; WRITE, NO VERIFY ENTRY POINT:
WRITE1: JSR TSN ;GO INSUR RECVD SECTR NUMBR VAL
BCC WR10 ;BRNCH IF SCTOR VALID
JMP WR91
WR10: LDA #^H04E
STA GAPBYT
JSR SETSUP
BEQ WR92 ;BRNCH IF NO STEPS NEEDE
JSR STEP
WR92: STY STPNBR ;SAV TEMP NUMBR STEPS NEEDED
STX STPDIR ;SAV STEP DIRECT TEMP
JSR INPUT ;GO INPUT DATA FIELD,COMP,CALC-
;-ULATE CS AND COMPAR CS'S
BEQ WR20 ;BRNCH IF NO CS ERR
WR5: LDA #MTR0+INVDF0
WR51: JSR OR0STX ;SET SPM AND DATA FRAME ERROR FLGS
JMP INIT2
WR20: JSR SAA1 ;GO ACK DATA FIELD
LDX STPDIR
LDY STPNBR
JSR STPTST ;GO EXECUT STEPS IF NEEDED
JSR SPMDY ;INSURE SPM STABL
LDA CTLCMD
CMP #VERIFY ;CHECK FOR VERIFY ONLY
BNE WR201 ;BRNCH IF HERE FOR WRITE
JSR CRCSUP
JMP WR30 ;GO DO VERFY
WR201: JSR WPTST
BEQ WR2 ;BRNCH IF NOT WP
JMP WR7
WR2: JSR CRCSUP
WRITE2: LDY #0 ;Y SET TO INDICAT PASS
JSR SYNC ;THRU SYNC LOOP FOR IDAM
BNE WR21 ;BRNCH IF HAV SYNC
LDA #NOID
JSR ORST1 ;UPDATE DEVICE STAT FOR NO ID
JMP WR8
WR21: JSR FWSL
LDX #12
JSR FSL
LDX EGON
STX PORTB2
LDX #5
JSR FSL
JSR FWSL1 ;GO XMIT REMAINDR OF DATA FIELD
;GAP AND ID
SEC ;CARRY MUST REFLECT LST BIT XMIT
;ED.
LDX #0 ;CLR BUFR POINTR
JSR WSL ;GO XMIT 128 BYTE BUFR THRU
;CLK/DTA LOOKUP TBL
; WRITE CRC'S
; (CALLED ONLY ONCE BY WRITE ROUTINE, COULD BE "IN-LINE")
; WCRC WRITES 2 CRC'S FOR DATA FIELD
; DURING WRITE ROUT. NOT USED B
; BY FORMAT ROUT
WCRC: LDX #128-3 ;INDEX FOR 2 BYTES
WCRC1: BIT SSDA0
BVC WCRC1 ;POLL SSDA FOR XMIT REG AVAIL
LDA BAKER-<128-3>(X)
ROR
LSR
LSR
LSR
TAY
LDA CDLT(Y)
STA SSDA1
AND #^H01F
TAY
LSR
LDA CDLT(Y)
STA SSDA1
INX
BPL WCRC1
WSPIN: LDA SSDA0
AND #TUF
BEQ WSPIN ;BRNCH TIL TUF SET IN STATREG
LDA #RDA+TDRA+CTS+PE+IRQ
STA SSDA0 ;REST XMIT
LDA PORTA1
AND #^CCTSRST
STA PORTA1 ;REST CTS FF
ORA #CTSRST
STA PORTA1 ;SET CTS FF
LDA WGOFF
STA PORTB2
JSR EGOFF
LDA INSTAT
AND #RDAFWR
BEQ WR36 ;BRNCH IF NO READ CHK REQIRED
WR30: LDA #READSC
STA CTLCMD
JSR RDWRLT
JSR WFRD ;GO RD SCTR TO VRIFY
BCS WRITE9 ;BRNCH IF BAD WRITE VRIFY
WR36: LDA #MTR0
JSR OR0STX ;UPDTE STAT FOR GOOD WRITE
JSR RDSUB
WR360: LDA #CMPLT
WR6: JSR SAA2 ;OUTPUT TO COLLEEN
JMP INIT2 ;GOTO SHUTDOWN
WR91: LDA #^CRDAFWR
JSR ANINS
JMP CMD2
WR7: LDA #MTR0+WPS0+RWE0 ;SET STATUS FOR WP
WR70: JSR OR0STX
LDA #ERROR ;SET A FOR ERR
JMP WR6
WR8: LDX PACNTR
BEQ WRITE9 ;BRNCH TO GIV UP WRITE ATMPT
JSR ERRTRY ;REPOSITON HEAD
JMP WRITE2 ;REATMPT WRITE
WRITE9: LDA #MTR0+RWE0
JMP WR70 ;GO SET STATUS FOR ERR
WFRD: LDA #1
STA PACNTR ;SET FOR 2 READ ATTEMPTS
WR3: LDY #0
JSR SYNC ;LOOK FOR IDAM
BNE WR300 ;BRNCH IF HAV SYNC
LDA #NOID
JMP WR44
WR300: JSR RDSUB
LDA #3
LDY #1
JSR SYNC01 ;LOOK FOR DAM
BEQ WR34 ;BRNCH IF NO SYNC
LDX #0
WR31: BIT SSDA0
BPL WR31
LDA SSDA1
CMP #^H0FB
BNE WR34
LDA INMODE
LSR
BCS WR40 ;BRNCH IF HERE ON FORMAT CHK
LDA SSDA1
CMP ZPRL(X)
BNE WR34 ;BRNCH IF ONE DATA FIELD WORD
;ERR
WR32: INX
WR33: BIT SSDA0
BPL WR33 ;BRNCH TIL RDA
LDA SSDA1
CMP ZPRL(X)
BNE WR34
INX
BEQ WR37 ;BRNCH IF ALL DATA FIELD OK
LDA SSDA1
CMP ZPRL(X)
BEQ WR32
WR34: DEC PACNTR
BPL WR3 ;BRNCH TO RETRY READ CHK
SEC
RTS
WR37: LDA SSDA1
CMP BAKER
BNE WR43 ;BRNCH IF CRC1 NO MATCH
WR35: BIT SSDA0
BPL WR35
LDA SSDA1
CMP ABLE
BNE WR43
JSR RDSUB
CLC ;CRY=NO ERR ON RETRN
RTS
WR40: LDA SSDA1
CMP #^H0B6
BNE WR34 ;BRNCH IF ERR
WR41: INX
WR42: BIT SSDA0
BPL WR42
LDA SSDA1
CMP #^H0B6
INX
BEQ WR37 ;BRNCH IF 256 BYTES CHKD
LDA SSDA1
CMP #^H0B6
BEQ WR41 ;BRNCH IF NO ERR
JMP WR34
WR43: LDA #DUM10
WR44: JSR ORST1 ;SET BIT IN DEVICE STATUS
JMP WR34
; READ ROUTINE
READ: JSR TSN ;TEST FOR VALID SCT NUMBR
BCC READ01
JMP CMD2
READ01: JSR SETSUP
JSR STPTST
JSR SPMDY ;GO INSUR SPM STABL
READ0: LDY #0 ;Y SET TO INDICAT PASS THRU
JSR SYNC ;SYNC LOOP FOR IDAM
BNE READ00
LDA #NOID ;BIT IS IN DEVSTA
JMP RD35 ;UPDATE CNTRLR STAT FOR ERR
READ00: JSR RDSUB
LDY #1 ;Y SET TO INDICATE PASS THRU
LDA #3
JSR SYNC01 ;SYNC LOOP FOR DAM
BEQ READ6 ;BRNCH IF NO SYNC
READ1: BIT SSDA0 ;POLL STATREG FOR RDA
BPL READ1
LDA SSDA1 ;SRVICE SSDA
CMP #DAM ;FIRST WORD MUST BE DAM
BNE READ6 ;GO TO ERR IF NOT DAM
LDA SSDA1
STA ZPRL(X) ;STOR IN XFER BUFR
READ2: INX
READ3: BIT SSDA0 ;POLL STATREG FOR RDA
BPL READ3
LDA SSDA1
INX
BEQ READ4 ;BRNCH IF BUFRS FUL
LDA SSDA1
STA ZPRL(X)
JMP READ2
READ4: LDA SSDA1
STA RDCRC1 ;SAVE CRC1
READ5: BIT SSDA0
BPL READ5
LDA SSDA1
STA RDCRC2 ;SAVE CRC2
JSR CRCSUP
LDA RDCRC1
CMP BAKER
BNE RD34
LDA RDCRC2
CMP ABLE
BNE RD34
RD31: LDA #MTR0
JSR OR0STX
RD32: LDA #CMPLT
RD33: STA TMPOUT
JSR SETOP
JSR BFROUT
JMP INIT2
RD34: LDA #DUM10
RD35: JSR ORST1 ;UPDATE CONTRLR STAT FOR ERR
READ6: LDX PACNTR
BEQ READ7 ;BRNCH TO GIV UP READ ATTEMPT
JSR ERRTRY ;GO REPOSITION HEAD
JMP READ0 ;TRY TO READ AGAIN
READ7: LDA #MTR0+RWE0
JSR OR0STX ;UPDATE STATUS TO REFLECT ERR
LDA #ERROR
JMP RD33 ;OUTPUT "E" TO COLEN
RDSUB: LDA #^C<NOID+DUM10>
JSR ANDST1
RTS
; DOWNLOAD
; INPUTS 256 BYTES FROM COLN,
; XECUTES PROGRAM THEN,STRTNG AT ZP00.
DOWNLD: JSR SAA
LDX #1
STX AUX2
JSR INPUT
BNE DNLD6 ;BRNCH IF DATAFRAM ERR
PHA
JSR ZPRL ;GO XECUTE PROGRM
BIT INMODE
BVC DNLD2 ;BRNCH TO SET DRV2 STAT BYTES
STA STFLGS ;SAV A(Y)(X),PS IN DRV1 STAT BYTES
STX STFLGS+1
STY STFLGS+2
PLA
STA STFLGS+3
JMP DNLD4
DNLD2: STA STFLG2 ;SAV [email protected](Y),PS IN DRV2 STAT BYTEZ
STX STFLG2+1
STY STFLG2+2
PLA
STA STFLG2+3
DNLD4: LDA #CMPLT
JSR SAA2
JMP INIT21
DNLD6: JSR MFUTST ;UPDATuE SPM FLG BIT
LDA #2
JMP WR51 ;GO UPDATE STAT FOR DATA FRAM ER
; READ-SPIN (ALIGNMENT TEST)
; RDSPIN---TURNS ON SPM,RDLITE,&HD
; NABL. SPINS TIL NXT CMD RECVD.
; USED FOR TSTIN ONLY
RDSPN: LDX #READSC
STX CTLCMD
JSR SETSUP
JSR STPTST
JMP INIT71
; READ FROM ADDRESS (128-BYTE)
RDADR: CLC
LDA AUX1
TAY
ORA AUX2
BEQ EXTST
LDA AUX2
JMP RDADR1
EXTST: LDY #XSTAT&255
LDA PORTB3
AND #XTPROM
BNE RDADR0
SEC ;SET CRY IF XTNDED ROM INSTALD
RDADR0: LDA #XSTAT/256
RDADR1: STY ZPNTL
STA ZPNTH ;SET 0-PGE POINTR
LDY #0
RDADRL: LDA @ZPNTL(Y)
STA ZPRL(Y) ;MOV 128 BYTES TO BUFRS
INY
BPL RDADRL
BCC RDADR3
JSR XTND1 ;GO TO UPDATE IF X ROM INSTLD
RDADR3: LDX #1
STX AUX1
DEX
STX AUX2
JMP RD32
; STATUS CMND
; TESTS TO DETERMINE WHICH
; DRIVE TO XMIT STATUS FOR, SENDS
; 4 BYTE STATUS AND CHKSM TO COL-
; -LEEN WHICH RELECTS STATE OF
; DRIVE DURING LAST COMMAND. UP-
; DATES DRIVE STATUS UPON COMPLET-
; -ION OF STATUS CMND
STCMD: JSR SAA ;ACK CMND
LDX #4
BIT INMODE
BVC SCMD20 ;BRNCH IF CMND FOR DRV2
SCMD10: LDA WCTMSB-4(X) ;MOVE 4 BYTE STAT FOR DRV1
STA STPNT(X) ;INTO MORE CONVENIENT LOC.
DEX
BNE SCMD10
STCMD1: LDY #4
STY INSCRT
JSR CDCKSM ;GEN CS ON 4 BYTE STAT
STA RCDCSM
LDA #CMPLT
STA TMPOUT ;SET TO XMIT "C"
JSR SETOP ;OPEN SERIAL OUTPUT PORT
LDX #128-5 ;5 BYTES TO SEND
JSR OUTPUT
STCMD2: LDY #15
STCMD3: DEY ;SET DELA OF
BNE STCMD3 ;74 MACH CYC
LDY UNITNB-<128-5>(X)
STY TMPOUT
JSR OUTPUT ;OUTPUT 1 BYTE
INX
BPL STCMD2
JSR RSTOUT ;CLOSE OUTPUT PORT
BIT INMODE
BVC SCMD21 ;BRNCH IF CMND FOR DRV2
JSR CLRST ;CLR ALL STAT BUT WP
JSR SPMFU ;UPDATE DRV1 SPM FLG
JMP INIT2
SCMD20: LDA WCTMB2-4(X) ;MOVE 4 BYTE STAT FOR DRV2
STA STPNT(X) ;INTO MORE CONVEINIENT LOC
DEX
BNE SCMD20
BEQ STCMD1 ;FWR BUYTES THAN JMP
SCMD21: JSR CLRST2 ;CLR ALL BUT BASIC STATUS FOR DR
;VE 2
JSR SPM2FU ;UPDATE DRV2 SPM FLG
JMP INIT2
; FORMAT ROUTINE
FRMT: JSR SAA
JSR SPMON ;TURN ON SPM IF NOT ALREADY
JSR RDWRLT
JSR SPMDY ;INSURE MOTOR UP TO SPEED
JSR WPTST
BEQ CONFRM ;TEST DISC NOT WP,IF NOT,BRNCH.
LDA #MTR0+WPS0+RWE0
JSR OR0STX
LDA #^H0FF
STA ZPRL ;DS TRMS TO FRNT
STA ZPRL+1
JMP READ7
CONFRM: LDY #MAXTRK+5
JSR REHME
LDX #^H0FE
STX IDAM ;INIT ID FIELD LIST
LDX #^H04E
STX BYTE4E
LDX #0
STX BYTE00
STX TRKNO
STX SCTTBL+4
INX
STX BYTE01
TRKLP: JSR STSUP2 ;GO TO TST FOR <20 TRK SWITCH
LDX #0
STX SCTPT
STX CRCLP
INX
STX SCTTBL+6
FCRCLP: LDX #^H0F8
JSR CRCGEN ;GO GEN 2 BYTE CRC ON 5 BYTE ID
;FIELD FOR THIS TRK,SCT NUMBER.
LDX CRCLP
LDA BAKER
STA FRMCRC(X)
INX
LDA ABLE
STA FRMCRC(X)
INX
STX CRCLP
LDY SCTPT
LDX SCTRS(Y)
BIT STFLGS
BPL FORM0
JSR XTND4 ;GO TO XTRA ROM IF 38K CAPABL
FORM0: STX SCTTBL+6
INC SCTPT
CPY #18
BNE FCRCLP ;BRNCH IF MOR CRCS TO DO
LDX #0
STX SCTPT
LDA FRMCRC(X)
STA CRC1 ;STORE FIRST CRC IN ID LIST
INX
STX SCTNO ;REST SCT NUMBER TO 01
LDA FRMCRC(X) ;STOR SECOND CRC IN ID LIST
STA CRC2
STX CRCLP ;SAVE CRC LIST POINTER
FWT: LDA TIMR1R
BPL FWT ;WAIT FOR LAST STEP TO SETTLE.
JSR STST1 ;WAIT 10MS FOR LAST STP SETL
JSR FWSL
LDX EGON
STX PORTB2 ;TURN ON ERASE GATE
LDX #255 ;SET X AS 255 BYTE COUNTER.
JSR FSL ;GO XMIT 255 BYTES OF "4E"
DEX ;SETS X TO FF AS X EQUALS 00 ON
;RETURN FROM PREVIOUS JSR.
DEX
JSR FSL ;XMIT 255 BYTES OF "4E"
SCTLP: LDA #^H0AA
TAY
LDX #8
JSR FSL ;XMIT 8 BYTES OF "00". THIS IS S
;ECOND HALF OF GAP3.
LDA #^H044
LDY #^H089
LDX #3
JSR FSL ;XMIT 3 BYTES OF "A1". THIS IS
;ID AM SYNC LEADER.
LDA #^H055
LDY #^H054
LDX #1
JSR FSL ;XMIT 1 BYTE "FE". THIS IS ID AM
LDX #^H0F9
CLC
JSR WSL ;XMIT 7 BYTES OF ID FIELD THRU
;ID FIELD TABLE.
LDA #^H092
FONE: BIT SSDA0
BVC FONE
STA SSDA1
LDY #^H054
STY SSDA1 ;XMIT 1 BYTE "4G" FAST-LATE
LDX #18
JSR FSL ;XMIT 20 MORE BYTES OF "4E". THI
;S IS FIRST HALF GAP 2.
INC CRCLP
LDX CRCLP
LDA FRMCRC(X) ;MOVE CRC1 FOR NXT SCTOR INTO
STA CRC1 ;ID FIELD LIST
LDA #^H0AA
TAY
LDX #12
JSR FSL ;XMIT 12 BYTES OF "00". THIS IS
;LAST HALF OF GAP 2.
INC CRCLP
LDX CRCLP
LDA FRMCRC(X) ;MOVE NXT CRC2 INTO ID
STA CRC2 ;FIELD LIST
LDA #^H044
LDY #^H089
LDX #3
JSR FSL ;XMIT 3 BYTES "A1" THIS IS DAM
;SYNC LEADER
LDA #^H055
LDY #^H045
INX
JSR FSL ;XMIT 1 BYTE "FB" THIS IS DAM.
LDA #^H045
LDY #^H014
INX
JSR FSL ;XMIT 1 BYTE "00"
LDA #^H045
LDX #^H0FF ;XMIT 255 BYTES "00". THIS,PLUS
JSR FSL ;PREVIOS XMIT=128 BYTE DATA FLD
LDA #^H045
LDY #^H029
INX
;XMIT 1 BYTE "48" THIS IS
JSR FSL ;CRC1 FOR DATA FIELD OF ALL "00"
LDA #^H014
LDY #^H0AA
INX
;XMIT 1 BYTE "29" THIS IS
JSR FSL ;CRC2 FOR DATA FIELD ALL "00"
LDA #^H092
LDY #^H054
INX
;XMIT 1 BYTE "4E" THIS IS
JSR FSL ;1 BYTE OF GAP 3 FIRST HALF
LDA #^H092
LDX #23 ;XMIT 23 BYTES "4E" THIS
JSR FSL ;COMPLETES FIRST HALF GAP3
LDY SCTPT
LDX SCTRS(Y)
STX SCTNO ;MOV NXT SCTR IN
INC SCTPT
CPY #17 ;CHK FOR 18 SCTRS FRMTD
BNE JSCTLP ;IF NOT, GO DO ANOTHER
LDA #RXRS+TXRS+CLEARS+AC1+AC2
LDA WGOFF
STA PORTB2 ;TURN OFF WG
INC TRKNO
INC SCTTBL+4
JSR EGOFF
LDX #MAXTRK+1
LDA DH80T
BEQ FONE1
JSR XTND3 ;GO TEST FOR MAX # OF TRKS TO FORMAT
FONE1: CPX TRKNO ;CHK FOR ALL TRKS FORMATED
BEQ FTST
LDX #^H080 ;X MUST BE NEG VALUE BEFOR ENTRY
;TO STEP ROUT TO STEP IN
JSR STEP
JMP TRKLP ;GO FORMAT ANOTHR TRK
JSCTLP: JMP SCTLP ;MUST GO TO SCTLP FROM HERE BRNCH
;OUT OF RANGE
; FORMAT TEST
; TESTS ALL SCTRS
; AFTR ACTUAL
; FORMAT AND COMPILES LISTING OF
; BAD SCTRS TO SEND TO COLEN AT
; END. (63 BAD SCTRS MAX)
FTST: LDA #READSC
STA CTLCMD
JSR RDWRLT
LDX #0
STX BFRPNT
LDY #^H080
FT1: LDA SCTRS(X) ;ALTRNATLY MOVE SCTR #'S
STA ZPRL(Y) ;FROM ROM INTO BUFRS
INY ;AT HEX LOC.0080 TO 0091
INX ;INCLUSIV
INX
CPX #18
BNE FT2
LDX #1
STX ZP91
FT2: CPX #17
BNE FT1
DEC SCTTBL+4
FT21: LDX #128
FT3: LDA ZPRL(X)
INX
STX FSCTBP ;SAV SCTR PNTR
STA SCTTBL+6
JSR STSUP1 ;DO CRC ON SCTR ID FIELD
LDA #^H060
STA ABLE
LDA #^H0B1
STA BAKER
LDA #DUM11
JSR ORINMD ;SET LSB INMODE FOR WFRD
;ROUT TSTING
JSR WFRD ;READ 1 SCTR
DEC INMODE
BCS FT5 ;BRNCH IF SCTR READ ERR
FT4: LDX FSCTBP
CPX #128+18
BNE FT3 ;BRNCH IF MOR SCTRS TO READ
LDY SCTTBL+4
BNE FT40 ;BRANCH IF ALL TRKS NOT READ
LDA DH80T
BEQ FT6 ;BRANCH IF NOT DH OR 96 TPI DRVS
JSR XTND5
JMP FT6
FT40: DEY
STY SCTTBL+4
LDX #0
LDY #1
JSR STPTST ;STP TO NXT TRK
JMP FT21 ;CONT TST
FT5: LDA #FMTER
JSR ORINST ;SET FORMAT ERR BIT INSTAT
; TRACK/SECTOR CONVERSION TO
; 2 BYTE SECTOR NUMBER
SCTBU: LDY #0
STY MSBSB
LDX BFRPNT
LDA SCTTBL+4 ;GET TRK NMBR
ASL
STA TMPSB ;SAVE TIMES TWO
ASL
ROL MSBSB
ASL
ROL MSBSB
ASL
ROL MSBSB
ADC TMPSB
TAY
LDA #0
ADC MSBSB
STA MSBSB
TYA
CLC
ADC SCTTBL+6
STA ZPRL(X)
LDA #0
ADC MSBSB
INX
STA ZPRL(X)
LDA DH80T
BEQ FT51
JSR XTND11 ;GOTO INCREASE SEC # FOR SIDE 2
FT51: INX
STX BFRPNT
CPX #128-2
BNE FT4 ;BRNCH IF BAD SCTR BUFR NOT FULL
FT6: LDA #^H0FF
LDX BFRPNT
STA ZPRL(X)
INX
STA ZPRL(X)
STA SCTTBL+4
LDA #FORMT
STA CTLCMD
LDA INSTAT
AND #FMTER
BNE FT7 ;BRNCH IF ANY BAD SCTRS
JMP RD31
FT7: LDA #^CFMTER
JSR ANINS ;CLR
BY the way CURT, this is great info keep it coming....  :cool:
956669[/snapback]
This is HOT. Expecting more great stuff from the VAX !
Thanks a lot Curt!
When I put this ROM inside my 810 drive will it become a 815 ?
No. :roll:
956672[/snapback]
What the difference between the 815 and 810 drive ?
The 810 was a single drive with single sided, single density (approx 88K)
The 815 was a dual drive unit and both drives were single sided, double density for 178K of storage. The other really nice feature was your could assign the drives up to Drive ID 7/8
I remember when I first got one, I dreamed of having 4 of them and running a monster BBS system with them, but I got a Corvus HD instead :-)
Curt
No. :roll:
956672[/snapback]
960985[/snapback]
One thing that isn't immediately obvious to me from the 815 source listing, is the disk controller chip used. What disk controller chip was used in the 815? It looks a lot like a 1771, but it...isn't... a 1793?
-Thom
-Thom
Judging by the code, It is a 68b52 which i think is a type of Asynchronous Communications Interface Adapter from what i am able to find out about the chip which is very little. (ie nothing). Looks like the 815 used the processor to do all the hard work of writing data to the disk , calculating crc etc instead of using a disk controller.
Must an owner of an 815 to dump both roms and append it to curts listing.
James
Curt
No. :roll:
956672[/snapback]
960985[/snapback]
Reading through the code it appears to have also been designed to support Double sided and 80 track mechanisms?
DSDD 80 track would be 720KB/mechanism!
If you look at the left side of this board, you can see that the head amplifier section has circuits for four heads - only two of which are populated on this unit.
So, yes. Atari was planning for a DS drive, I expect.
Bob
Bob
Can you please dump the roms for everyone's curiosity (namely mine :) )
James
815_ROMs.zip
OK - raw dumps of A106 and A107, with an .ATR of the two ROMs that are set to load at $4000 and $4800. (you might want to edit the load addresses and dis-assemble from disk) The ROMs look like they load into $0800 (A107) and $1000 (A106). Code starts at $800.
Bob
A preliminary look at the rom shows a few interesting things. The code is almost the same as what curt has provided, tho curts code has been truncated.
The rom has an extra command (X). There is no 38k baud code. no rom jump table at 800 tho there are several jumps to the non existent table. A bit on one port is checked before a jump to missing table but as this bit never changes, the jumps never happen.
It doesn't have a FDC chip. No idea what encoding is used on the disk.
James
Well, the encoding is not readable on a USD 1050, or any other drives, I would expect.
AFIK, the 815s are DD only. DOS 2.0D will 'see' them (as D3: & D4:) and format their disks.
I have another ROM dump from an 815, which is probably the same as the first post.
Bob
815ROMS.atr
956669[/snapback]
Thanks a lot Curt!
What VAX ??? Atari's old headquarters vax computer talked about in a 2006 thread?
PS interesting talk about 815's. I've always wanted to work with one or 4 :)
Bob
815ROMS.atr
Apart from a106 and a107 loading at wrong addresses (need to be swapped around) they are identical, which is slightly different to what Curt has posted above.
James
Here is dissembly listing from bob1200xl roms.
Have added some comments from orignal source from curt.
enjoy
; User equates
TIMR2 = $039F
TIMR3 = $039E
TIM1R = $0395
PIA1EC = $0384
PBDDR1 = $0383
PORTB1 = $0382
PADDR1 = $0381
PORTA1 = $0380
TIMR22 = $029F
TIMR2R = $0295
PIA2EC = $0284
PBDDR2 = $0283
PORTB2 = $0282
PADDR2 = $0281
PORTA2 = $0280
TIMR23 = $021F
TIMR3R = $0215
PIA3EC = $0204
PBDDR3 = $0203
PORTB3 = $0202
PADDR3 = $0201
PORTA3 = $0200
SSDA1 = $0101
SSDA0 = $0100
CMPLT = $43 ;C complete
; Code equates
ZPRL = $0000
ZP80 = $0080
ZP91 = $0091
FRMCRC = $00A0
ZPCRC = $00AE
ZPNTL = $00C0
ZPNTH = $00C1
SCTPT = $00F6
CRCLP = $00F7
IDAM = $00F8
TRKNO = $00F9
BYTE00 = $00FA
SCTNO = $00FB
BYTE01 = $00FC
CRC1 = $00FD
CRC2 = $00FE
BYTE4E = $00FF
L0106 = $0106
L0119 = $0119
L0131 = $0131
RAM3 = $0180
STPNT = $0180
UNITNB = $0181 ;DRIVE UNIT # (ASCII)
CTLCMD = $0182 ;CONTROLLER COMMAND
AUX1 = $0183 ;LSB OF 16-BIT LOGICAL SECTOR #
AUX2 = $0184 ;MSB OF 16-BIT LOGICAL SECTOR #
RCDCSM = $0185 ;COMMAND FRAME CHECKSUM
TMPOUT = $0186 ;ALL SERIAL OUTPUT SHIFTED FROM THIS ADDR
DICKSM = $0187 ;DATA FIELD CHECKSUM TEMP
STFLG2 = $0190 ;BOTTOM DRV STATUS FLAGS
DEVST2 = $0191 ;BOTTOM DRV XTRA STATUS
WCTLB2 = $0192 ;BOTTOM DRV WORST CASE TIMEOUT (LSB)
WCTMB2 = $0193 ;DELAY (MSB)
EGON = $0194 ;ERASE GATE TURN ON CODE
WGOFF = $0195 ;ERASE GATE TURN ON CODE
BAKER = $0196 ;CRC GENERATION SCRATCH 1
ABLE = $0197 ;CRC GENERATION SCRATCH 2
GAPBYT = $0198 ;BYTE INIT'D TO $4E FOR CRC WRITE
DH80T = $0199 ;DOUBLE HEAD & 80 TRK TEST BYTE
STPDIR = $019D
RDCRC2 = $019E
RDCRC1 = $019F
STPNB2 = $01A0 ;# OF STEPS TO DESIRED TRACK, BOTTOM DRV
PRTRK2 = $01A1 ;PRESENT TRACK #, BOTTOM DRV
SPSDC2 = $01A2 ;LOOP COUNTER FOR BOTTOM DRV SHUTDOWN TIMER
SPMDC2 = $01A3
SCRT1 = $01A4
SCRT2 = $01A5
SCTTBL = $01A6 ;START OF 11-BYTE ID FIELD
SPMDLC = $01B1 ;1 SEC LOOP COUNT FOR SPM SHUT-OFF (4 * 125 MS)
STPSCR = $01CD ;STEP ROUTINE SCRATCH
PRSTRK = $01CE ;PRESENT TRACK #, TOP DRV
STPNBR = $01CF ;# OF STEPS TO DESIRED TRK #, TOP DRV
STFLGS = $01D0 ;STATUS FLAGS (TOP DRV) SHIPPED TO COLLEEN
DEVSTA = $01D1 ;TOP DRV EXTRA STATUS
WCTLSB = $01D2 ;WORST CASE TIMEOUT SENT TO COLLEEN (LSB)
WCTMSB = $01D3 ;(MSB)
PACNTR = $01D4 ;R/W ERROR RETRY COUNT
SSCTMS = $01D7 ;MSB,16-BIT LOGICAL SECTOR # (SECTOR BREAKDOWN)
SSCTLS = $01D8 ;LSB, SAVED BY SEC BRKDWN BUT NOT USED
TRKNBR = $01DA ;TRACK # COMPUTED IN SECTOR BREAK-DOWN
SCTNBR = $01DB ;SECTOR # FROM SECTOR BREAK-DOWN
INMODE = $01DC ;INTERNAL MODE REGISTER
; 4 - N/A
; 3 - N/A
; 1 - N/A
INSTAT = $01DD ;INTERNAL STATUS REGISTER
; 4 - NO DISK
INSCRT = $01DE ;LAST INDEX +1 TO TERMINATE INPUT OR CHECKSUM
TMRSCR = $01DF ;TIMER SCRATCH
FSCTBP = $01E0 ;FORMAT VERIFY ERROR RETRY COUNT
BFRPNT = $01E1 ;FORMAT BAD SECTOR # BUFFER INDEX
TMPSB = $01E3 ;*2 TEMP STORAGE FOR SECTOR BUILD-UP
MSBSB = $01E4 ;MSB FOR SECTOR BUILD-UP
CSSCRT = $01E5
YSAVE = $01E6
CTABL = $01E8 ;JUMP INDIRECT ADDRESS FOR COMMAND INTERPRETER
CTABH = $01E9 ;MSB
SPMSDC = $01EB ;LOOP COUNTER FOR TOP DRV SHUTDOWN TIMER
; unused jump addresses
XTND1 = $0803
XTND3 = $0809
XTND4 = $080C
XTND5 = $080F
XTND6 = $0812 ;SECTOR # VALIDITY TEST, > 720
XTND7 = $0815
XTND8 = $0818
XTND9 = $081B
XTND10 = $081E ;SIDE 2 CLRS?
XTND11 = $0821
XTND13 = $0827
XTND14 = $082A
; Start of code
*= $0800
cld ; D8
lda #$1B ; A9 1B
ldx #$FF ; A2 FF
txs ; 9A
sta PORTA2 ; 8D 80 02
stx PORTB2 ; 8E 82 02
stx PADDR2 ; 8E 81 02
stx PBDDR2 ; 8E 83 02
lda #$00 ; A9 00
sta PORTA1 ; 8D 80 03
sta PORTA3 ; 8D 00 02
sta PORTB3 ; 8D 02 02
lda #$1A ; A9 1A
sta PADDR3 ; 8D 01 02
ldx #$6A ; A2 6A
stx PADDR1 ; 8E 81 03
L0827 ldx #$3C ; A2 3C
stx PBDDR1 ; 8E 83 03
inx ; E8
stx PBDDR3 ; 8E 03 02
ldx #$30 ; A2 30
stx PORTB1 ; 8E 82 03
stx PORTB3 ; 8E 02 02
stx PIA1EC ; 8E 84 03
stx PIA3EC ; 8E 04 02
stx PIA2EC ; 8E 84 02
ldx #$68 ; A2 68
stx PORTA1 ; 8E 80 03
lda #$D0 ; A9 D0
sta SSDA0 ; 8D 00 01
lda #$9B ; A9 9B
sta SSDA1 ; 8D 01 01
lda #$D2 ; A9 D2
lda #$00 ; A9 00
ldx #$7F ; A2 7F
L085C sta ZPRL,X ; 95 00
sta ZP80,X ; 95 80
sta RAM3,X ; 9D 80 01
cmp ZPRL,X ; D5 00
bne L0875 ; D0 0E
cmp ZP80,X ; D5 80
bne L0875 ; D0 0A
cmp RAM3,X ; DD 80 01
bne L0875 ; D0 05
dex ; CA
bpl L085C ; 10 E9
bmi L0884 ; 30 0F
L0875 lda #$08 ; A9 08
L0877 sta PORTA3 ; 8D 00 02
L087A dex ; CA
bne L087A ; D0 FD
iny ; C8
bne L087A ; D0 FA
eor #$08 ; 49 08
bpl L0877 ; 10 F3
L0884 lda #$05 ; A9 05
sta INSTAT ; 8D DD 01
lda #$C4 ; A9 C4
sta INMODE ; 8D DC 01
lda #$27 ; A9 27
sta PRTRK2 ; 8D A1 01
sta PRSTRK ; 8D CE 01
lda #$04 ; A9 04
sta SPMDLC ; 8D B1 01
lda #$E0 ; A9 E0
sta WCTLSB ; 8D D2 01
sta WCTLB2 ; 8D 92 01
lda #$00 ; A9 00
sta WCTMSB ; 8D D3 01
sta WCTMB2 ; 8D 93 01
sta DEVSTA ; 8D D1 01
sta DEVST2 ; 8D 91 01
sta SPMSDC ; 8D EB 01
sta SPSDC2 ; 8D A2 01
; copy ID field into ram
ldx #$0A ; A2 0A
L08B9 lda IDFLD,X ; BD 9D 17
sta SCTTBL,X ; 9D A6 01
dex ; CA
bpl L08B9 ; 10 F7
inx ; E8
ldy #$60 ; A0 60
lda PORTB3 ; AD 02 02
and #$02 ; 29 02
bne L08CF ; D0 03
jsr XTND14 ; 20 2A 08 GO TO XTRA ROM FOR MOR DH/96
;TPI AND 38K TSTING
L08CF sty STFLGS ; 8C D0 01
sty STFLG2 ; 8C 90 01
stx DH80T ; 8E 99 01
jsr CLRST ; 20 4C 15
jsr CLRST2 ; 20 55 15
INIT2 ldx #$FF ; A2 FF
txs ; 9A
lda #$F7 ; A9 F7
jsr CLRST1 ; 20 4E 15 CLEAR TOP DRV WP STATUS
lda #$F7 ; A9 F7
jsr CLRS12 ; 20 57 15
ldx #$08 ; A2 08
lda PORTA1 ; AD 80 03
tay ; A8
and #$10 ; 29 10
beq L08F9 ; F0 04
txa ; 8A
jsr ORSTF ; 20 2D 15 SET IT IN TOP DRV STATUS FLAGS
L08F9 tya ; 98
and #$01 ; 29 01
beq L0902 ; F0 04
txa ; 8A
jsr ORSTF2 ; 20 45 15 SET IT IN BOTTOM DRV STATUS FLAGS
L0902 ldx #$1B ; A2 1B
stx PORTA2 ; 8E 80 02
lda PORTA3 ; AD 00 02
and #$E7 ; 29 E7
bit DH80T ; 2C 99 01
bpl L0917 ; 10 03
jsr XTND10 ; 20 1E 08 GO TO XTRA ROM FOR SIDE2 CLRS
L0917 lda #$40 ; A9 40
jsr ORINMD ; 20 73 15
lda #$27 ; A9 27
jsr CSTEP ; 20 3E 17 CALC STPS NEEDED FOR TRK 39 DRV
sty STPNBR ; 8C CF 01
lda #$BF ; A9 BF
jsr ANDNMD ; 20 7A 15 SET FOR DRIV2 SRVICE
lda #$27 ; A9 27
sty STPNB2 ; 8C A0 01
lda #$20 ; A9 20
jsr ORINST ; 20 34 15 SET SHUTDN BIT IN INTRNL STAT
lda #$F7 ; A9 F7
jsr ANINS ; 20 6C 15
L093B ldx SPMSDC ; AE EB 01
beq L0949 ; F0 09
lda #$FF ; A9 FF
sta TIMR23 ; 8D 1F 02
dex ; CA
stx SPMSDC ; 8E EB 01
L0949 ldx SPSDC2 ; AE A2 01
beq L0957 ; F0 09
lda #$FF ; A9 FF
dex ; CA
stx SPSDC2 ; 8E A2 01
L0957 ldx SPMSDC ; AE EB 01
bne L096B ; D0 0F
ldx #$80 ; A2 80
ldy STPNBR ; AC CF 01
beq L099B ; F0 38 BRNCH IF NO STPS NEEDED ON DRV1
jsr STEP1 ; 20 8D 10 STEP DRV1 AND SAV STP CNTR
beq L099B ; F0 33
L0968 sty STPNBR ; 8C CF 01
L096B ldx SPSDC2 ; AE A2 01
bne L097F ; D0 0F
ldx #$80 ; A2 80
ldy STPNB2 ; AC A0 01
beq L09A8 ; F0 31
jsr L10C6 ; 20 C6 10
beq L09A8 ; F0 2C
L097C sty STPNB2 ; 8C A0 01
L097F ldx SPMSDC ; AE EB 01
bne L09B5 ; D0 31
bne L09B5 ; D0 2C
ldx STPNBR ; AE CF 01
bne L09BD ; D0 2F
ldx STPNB2 ; AE A0 01
bne L09BD ; D0 2A
L0993 lda #$DF ; A9 DF
jmp MMON ; 4C D6 09
L099B lda #$68 ; A9 68
lda #$04 ; A9 04
jmp L0968 ; 4C 68 09
L09A8 lda #$00 ; A9 00
lda #$04 ; A9 04
jmp L097C ; 4C 7C 09
L09B5 bit TIMR3R ; 2C 15 02
bmi L09C8 ; 30 0E
jsr MMON ; 20 D6 09
L09BD bit TIM1R ; 2C 95 03
bmi L0957 ; 30 95
jsr MMON ; 20 D6 09
jmp L09BD ; 4C BD 09
L09C8 bit TIM1R ; 2C 95 03
bmi L09D3 ; 30 06
jsr MMON ; 20 D6 09
jmp L09C8 ; 4C C8 09
L09D3 jmp L093B ; 4C 3B 09
; MAIN MONITOR
; GOING TO CMND INTERPRET ROUTINE
MMON lda PORTB1 ; AD 82 03
lsr A ; 4A
lsr A ; 4A
bcs L0A0F ; B0 32
lda INSTAT ; AD DD 01
lsr A ; 4A
bcs L0A02 ; B0 1F
bit PORTB1 ; 2C 82 03
bvc L09F7 ; 50 0F
bit INSTAT ; 2C DD 01
bvc L0A17 ; 50 2A
lda #$A4 ; A9 A4
jsr TIMER ; 20 12 15
bvs L0A17 ; 70 20
L09F7 lda INSTAT ; AD DD 01
and #$60 ; 29 60
bne L0A01 ; D0 03
jmp MMON ; 4C D6 09
L0A01 rts ; 60
L0A02 lda #$A4 ; A9 A4
lda #$FE ; A9 FE
jmp MMON ; 4C D6 09
L0A0F lda #$01 ; A9 01
jmp L09F7 ; 4C F7 09
L0A17 lda #$80 ; A9 80
ldx #$00 ; A2 00
lda #$05 ; A9 05
sta INSCRT ; 8D DE 01
jsr CINPUT ; 20 B6 11
ldx #$00 ; A2 00
dec INSCRT ; CE DE 01
jsr CDCKSM ; 20 D9 15
beq L0A35 ; F0 05
lda #$02 ; A9 02
L0A35 lda PORTA3 ; AD 00 02
lsr A ; 4A
bcc L0A6C ; 90 31
ldx #$31 ; A2 31
asl A ; 0A RESTORE PORTA3
bmi L0A42 ; 30 02 IF DRV ADDR #1 IS SET, BRANCH
ldx #$35 ; A2 35
L0A42 cpx UNITNB ; EC 81 01
beq L0A65 ; F0 1E BRNCH IF DRIV ADDRESED IS ODD
inx ; E8
beq L0A5A ; F0 0D BRNCH IF EVEN DRIV ADRESED IS U
L0A4D bit PORTB1 ; 2C 82 03
bvs L0A4D ; 70 FB SPIN TIL COMND FRAM GONE
lda #$7D ; A9 7D CLR REC NEW CMND AND
jsr ANINS ; 20 6C 15 CS ERR BITS
jmp MMON ; 4C D6 09 RETURN TO MON SER BUS
L0A5A lda #$BF ; A9 BF
jsr ANDNMD ; 20 7A 15 UPDATE INMODE FOR DRIV 2 SEL
L0A5F jsr L0A75 ; 20 75 0A GO COMMAND INTERP---FOR US
jmp MMON ; 4C D6 09
L0A65 lda #$40 ; A9 40
jsr ORINMD ; 20 73 15 UPDATE INMODE FOR DRIV 1 SEL
bne L0A5F ; D0 F3
L0A6C ldx #$33 ; A2 33
asl A ; 0A
bmi L0A42 ; 30 D1
ldx #$37 ; A2 37
bne L0A42 ; D0 CD
L0A75 lda INSTAT ; AD DD 01 CHECK RECEIVE ERROR FLAG
and #$02 ; 29 02 MASK OFF OTHERS
bne CMD2 ; D0 1E IF CHECKSUM ERROR, GOTO INVALID CMD NAK
lda CTLCMD ; AD 82 01 ELSE, FETCH CMD CODE FROM CMD FRAME
ldx #$0A ; A2 0A MAXIMUM INDEX INTO LEGAL CMD CODE TABLE
L0A81 cmp TABB,X ; DD B2 0A COMPARE REC'D CMD W/LEGAL CMD LIST
beq L0A8B ; F0 05 GOT A MATCH, GO EXECUTE
dex ; CA ELSE, DECREMENT INDEX
bpl L0A81 ; 10 F8 LOOP IF ANY LEGAL ENTRIES LEFT
bmi CMD2 ; 30 0F NO, UNCONDITIONAL SEND INVALID CMD FRAME
L0A8B lda TABL,X ; BD BD 0A YES, FETCH LO ADDR OF ROUT
sta CTABL ; 8D E8 01 SAVE IN INDIRECT JUMP VECTOR
lda TABH,X ; BD C8 0A FETCH HI ADDR TOO
sta CTABH ; 8D E9 01 SAVE IN HI ADDR OF VECTOR
jmp (CTABL) ; 6C E8 01 JUMP TO SELECTED COMMAND ROUTINE
CMD2 lda #$01 ; A9 01 SET INVALID CMD FRAME FLAG
jsr OR0STX ; 20 1E 15 IN PRESENT DRIVE STATUS BYTE
jsr MFUTST ; 20 12 11 SET SPM ON BIT IN STATUS TOO
L0AA2 bit PORTB1 ; 2C 82 03
bvs L0AA2 ; 70 FB WAIT TIL CMD FRAME GONE
lda #$4E ; A9 4E LOAD NAK CODE
jsr SAA2 ; 20 82 17 SEND IT TO COLLEEN
lda #$FD ; A9 FD CLEAR CMD RECEIVE ERROR FLAG
jsr ANINS ; 20 6C 15 IN INTERNAL STATUS REGISTER
rts ; 60 RETURN TO MAIN MONITOR
TABB .byte $20
.byte "!PQRSTUVWX"
;TABL .byte $21,$1E,$D8,$68,$78,$BD,$76,$70
; .byte $D3,$D3,$8C
;TABH .byte $0D,$0E,$0A,$0D,$0C,$0D,$0D,$10
; .byte $0A,$0A,$0D
TABL: .BYTE <DOWNLD ;DOWN LOAD
.BYTE <FRMT ;FORMAT
.BYTE <WRITE1 ;WRITE, NO VERIFY
.BYTE <RDSPN ;READ SPIN
.BYTE <READ ;READ SECTOR
.BYTE <STCMD ;STATUS COMMAND
.BYTE <RDADR ;READ FROM ADDRESS
.BYTE <MOTRON ;MOTOR ON DELAY
.BYTE <WRITE ;VERIFY ENTERS AT WRITE
.BYTE <WRITE ;WRITE/VERIFY
.BYTE <CMDX ;cOMMAND X WHAT DOES IT DO?
TABH: .BYTE >DOWNLD
.BYTE >FRMT
.BYTE >WRITE1
.BYTE >RDSPN
.BYTE >READ
.BYTE >STCMD
.BYTE >RDADR
.BYTE >MOTRON
.BYTE >WRITE
.BYTE >WRITE
.BYTE >CMDX
; Write
WRITE lda #$08 ; A9 08
jsr ORINST ; 20 34 15 SET INSTAT FOR READ AFTR WRITE
WRITE1 jsr TSN ; 20 A7 15 GO INSUR RECVD SECTR NUMBR VAL
bcc L0AE0 ; 90 03 BRNCH IF SCTOR VALID
jmp L0BBD ; 4C BD 0B
L0AE0 lda #$4E ; A9 4E wr10
sta GAPBYT ; 8D 98 01
jsr SETSUP ; 20 39 12
beq L0AED ; F0 03 BRNCH IF NO STEPS NEEDE
jsr STEP ; 20 88 10
L0AED sty STPNBR ; 8C CF 01 SAV TEMP NUMBR STEPS NEEDED
stx STPDIR ; 8E 9D 01 SAV STEP DIRECT TEMP
jsr INPUT ; 20 59 16 GO INPUT DATA FIELD,COMP,CALC-
; -ULATE CS AND COMPAR CS'S
beq L0B00 ; F0 08 BRNCH IF NO CS ERR
L0AF8 lda #$12 ; A9 12
L0AFA jsr OR0STX ; 20 1E 15 SET SPM AND DATA FRAME ERROR FLGS
jmp INIT2 ; 4C DE 08
L0B00 jsr SAA1 ; 20 80 17 GO ACK DATA FIELD
ldx STPDIR ; AE 9D 01
jsr STPTST ; 20 5E 17 GO EXECUT STEPS IF NEEDED
jsr SPMDY ; 20 B2 13 INSURE SPM STABL
cmp #$56 ; C9 56 CHECK FOR VERIFY ONLY
bne L0B1C ; D0 06 BRNCH IF HERE FOR WRITE
jsr CRCSUP ; 20 0F 12
jmp L0BA0 ; 4C A0 0B GO DO VERFY
L0B1C jsr WPTST ; 20 5E 15
beq L0B24 ; F0 03 BRNCH IF NOT WP
jmp L0BC5 ; 4C C5 0B
L0B24 jsr CRCSUP ; 20 0F 12
L0B27 ldy #$00 ; A0 00 Y SET TO INDICAT PASS
jsr SYNC ; 20 65 14 THRU SYNC LOOP FOR IDAM
bne L0B36 ; D0 08 BRNCH IF HAV SYNC
lda #$10 ; A9 10
jsr ORST1 ; 20 81 15 UPDATE DEVICE STAT FOR NO ID
jmp L0BCF ; 4C CF 0B
L0B36 jsr FWSL ; 20 F1 15
ldx #$0C ; A2 0C
jsr FSL ; 20 61 10
ldx EGON ; AE 94 01
ldx #$05 ; A2 05
jsr FSL ; 20 61 10
jsr FWSL1 ; 20 3F 16 GO XMIT REMAINDR OF DATA FIELD
; GAP AND ID
sec ; 38 CARRY MUST REFLECT LST BIT XMIT
; ED.
ldx #$00 ; A2 00 CLR BUFR POINTR
jsr WSL ; 20 DC 12 GO XMIT 128 BYTE BUFR THRU
; CLK/DTA LOOKUP TBL
; WRITE CRC'S
; BY FORMAT ROUT
ldx #$7D ; A2 7D INDEX FOR 2 BYTES
L0B54 bit SSDA0 ; 2C 00 01
bvc L0B54 ; 50 FB POLL SSDA FOR XMIT REG AVAIL
lda L0119,X ; BD 19 01
ror A ; 6A
lsr A ; 4A
lsr A ; 4A
lsr A ; 4A
tay ; A8
lda CDLT,Y ; B9 B9 17
and #$1F ; 29 1F
tay ; A8
lsr A ; 4A
inx ; E8
bpl L0B54 ; 10 DD
L0B77 lda SSDA0 ; AD 00 01
and #$08 ; 29 08
beq L0B77 ; F0 F9 BRNCH TIL TUF SET IN STATREG
lda #$D3 ; A9 D3
lda PORTA1 ; AD 80 03 REST XMIT
and #$DF ; 29 DF
sta PORTA1 ; 8D 80 03 REST CTS FF
ora #$20 ; 09 20
sta PORTA1 ; 8D 80 03 SET CTS FF
lda WGOFF ; AD 95 01
sta PORTB2 ; 8D 82 02
jsr EGOFF ; 20 29 12
and #$08 ; 29 08
beq L0BAD ; F0 0D BRNCH IF NO READ CHK REQIRED
L0BA0 lda #$52 ; A9 52
sta CTLCMD ; 8D 82 01
jsr RDWRLT ; 20 70 11
jsr L0BDF ; 20 DF 0B GO RD SCTR TO VRIFY
bcs L0BDA ; B0 2D BRNCH IF BAD WRITE VRIFY
L0BAD lda #$10 ; A9 10
jsr OR0STX ; 20 1E 15 UPDTE STAT FOR GOOD WRITE
jsr L0D1B ; 20 1B 0D
lda #CMPLT ; A9 43 Complete
L0BB7 jsr SAA2 ; 20 82 17 OUTPUT TO COLLEEN
jmp INIT2 ; 4C DE 08 GOTO SHUTDOWN
L0BBD lda #$F7 ; A9 F7
jmp CMD2 ; 4C 9A 0A
L0BC5 lda #$1C ; A9 1C SET STATUS FOR WP
L0BC7 jsr OR0STX ; 20 1E 15
lda #$45 ; A9 45 SET A FOR ERR
jmp L0BB7 ; 4C B7 0B
L0BCF ldx PACNTR ; AE D4 01
beq L0BDA ; F0 06 BRNCH TO GIV UP WRITE ATMPT
jsr ERRTRY ; 20 33 11 REPOSITON HEAD
jmp L0B27 ; 4C 27 0B REATMPT WRITE
L0BDA lda #$14 ; A9 14
jmp L0BC7 ; 4C C7 0B GO SET STATUS FOR ERR
L0BDF lda #$01 ; A9 01
sta PACNTR ; 8D D4 01 SET FOR 2 READ ATTEMPTS
L0BE4 ldy #$00 ; A0 00
jsr SYNC ; 20 65 14 LOOK FOR IDAM
bne L0BF0 ; D0 05 BRNCH IF HAV SYNC
lda #$10 ; A9 10
jmp L0C72 ; 4C 72 0C
L0BF0 jsr L0D1B ; 20 1B 0D
lda #$03 ; A9 03
ldy #$01 ; A0 01
jsr SYNC01 ; 20 75 14 LOOK FOR DAM
beq L0C2E ; F0 32 BRNCH IF NO SYNC
ldx #$00 ; A2 00
L0BFE bit SSDA0 ; 2C 00 01
bpl L0BFE ; 10 FB
lda SSDA1 ; AD 01 01
cmp #$FB ; C9 FB
bne L0C2E ; D0 24
lda INMODE ; AD DC 01
lsr A ; 4A
bcs L0C4F ; B0 3F BRNCH IF HERE ON FORMAT CHK
cmp ZPRL,X ; D5 00
bne L0C2E ; D0 17 BRNCH IF ONE DATA FIELD WORD ERR
L0C17 inx ; E8
L0C18 bit SSDA0 ; 2C 00 01
bpl L0C18 ; 10 FB BRNCH TIL RDA
cmp ZPRL,X ; D5 00
bne L0C2E ; D0 0A
inx ; E8
beq L0C35 ; F0 0E BRNCH IF ALL DATA FIELD OK
cmp ZPRL,X ; D5 00
beq L0C17 ; F0 E9
L0C2E dec PACNTR ; CE D4 01
bpl L0BE4 ; 10 B1 BRNCH TO RETRY READ CHK
sec ; 38
rts ; 60
L0C35 lda SSDA1 ; AD 01 01
cmp BAKER ; CD 96 01
bne L0C70 ; D0 33 BRNCH IF CRC1 NO MATCH
L0C3D bit SSDA0 ; 2C 00 01
bpl L0C3D ; 10 FB
cmp ABLE ; CD 97 01
bne L0C70 ; D0 26
clc ; 18 CRY=NO ERR ON RETRN
rts ; 60
L0C4F lda SSDA1 ; AD 01 01
cmp #$B6 ; C9 B6
bne L0C2E ; D0 D8 BRNCH IF ERR
L0C56 inx ; E8
L0C57 bit SSDA0 ; 2C 00 01
bpl L0C57 ; 10 FB
cmp #$B6 ; C9 B6
bne L0C2E ; D0 CB BRNCH IF ERR
inx ; E8
beq L0C35 ; F0 CF BRNCH IF 256 BYTES CHKD
cmp #$B6 ; C9 B6
beq L0C56 ; F0 E9 BRNCH IF NO ERR
jmp L0C2E ; 4C 2E 0C
L0C70 lda #$08 ; A9 08
L0C72 jsr ORST1 ; 20 81 15 SET BIT IN DEVICE STATUS
; READ
READ jsr TSN ; 20 A7 15 TEST FOR VALID SCT NUMBR
bcc L0C80 ; 90 03
jmp CMD2 ; 4C 9A 0A
L0C80 jsr SETSUP ; 20 39 12
jsr SPMDY ; 20 B2 13 GO INSUR SPM STABL
L0C89 ldy #$00 ; A0 00 Y SET TO INDICAT PASS THRU
jsr SYNC ; 20 65 14 SYNC LOOP FOR IDAM
bne L0C95 ; D0 05
lda #$10 ; A9 10 BIT IS IN DEVSTA
jmp L0D03 ; 4C 03 0D UPDATE CNTRLR STAT FOR ERR
L0C95 jsr L0D1B ; 20 1B 0D
ldy #$01 ; A0 01 Y SET TO INDICATE PASS THRU
lda #$03 ; A9 03
jsr SYNC01 ; 20 75 14 SYNC LOOP FOR DAM
beq L0D06 ; F0 65 BRNCH IF NO SYNC
L0CA3 bit SSDA0 ; 2C 00 01 POLL STATREG FOR RDA
bpl L0CA3 ; 10 FB
lda SSDA1 ; AD 01 01 SRVICE SSDA
cmp #$FB ; C9 FB FIRST WORD MUST BE DAM
bne L0D06 ; D0 57 GO TO ERR IF NOT DAM
sta ZPRL,X ; 95 00 STOR IN XFER BUFR
L0CB4 inx ; E8
L0CB5 bit SSDA0 ; 2C 00 01 POLL STATREG FOR RDA
bpl L0CB5 ; 10 FB
inx ; E8
beq L0CCA ; F0 08 BRNCH IF BUFRS FUL
sta ZPRL,X ; 95 00
jmp L0CB4 ; 4C B4 0C
L0CCA lda SSDA1 ; AD 01 01
sta RDCRC1 ; 8D 9F 01
L0CD0 bit SSDA0 ; 2C 00 01
bpl L0CD0 ; 10 FB
sta RDCRC2 ; 8D 9E 01
lda RDCRC1 ; AD 9F 01
bne L0D01 ; D0 1B
lda RDCRC2 ; AD 9E 01
cmp ABLE ; CD 97 01
bne L0D01 ; D0 13
L0CEE lda #$10 ; A9 10
RD32 lda #CMPLT ; A9 43 complete
L0CF5 sta TMPOUT ; 8D 86 01
jsr SETOP ; 20 8F 17
jsr BFROUT ; 20 86 12
L0D01 lda #$08 ; A9 08
L0D03 jsr ORST1 ; 20 81 15 UPDATE CONTRLR STAT FOR ERR
L0D06 ldx PACNTR ; AE D4 01
beq L0D11 ; F0 06
jsr ERRTRY ; 20 33 11 GO REPOSITION HEAD
jmp L0C89 ; 4C 89 0C
L0D11 lda #$14 ; A9 14
jsr OR0STX ; 20 1E 15 UPDATE STATUS TO REFLECT ERR
lda #$45 ; A9 45
jmp L0CF5 ; 4C F5 0C
L0D1B lda #$E7 ; A9 E7
jsr ANDST1 ; 20 94 15
rts ; 60
; download (different)
DOWNLD jsr SAA ; 20 7B 17 Send Ack
ldx #$01 ; A2 01
stx SCTTBL+4 ; 8E AA 01 different from here
dex ; CA
stx CSSCRT ; 8E E5 01
jsr L1661 ; 20 61 16
bne L0D60 ; D0 2E same here down
pha ; 48
jsr $0000 ; 20 00 00
bit INMODE ; 2C DC 01
bvc L0D4B ; 50 10
sta STFLGS ; 8D D0 01
stx DEVSTA ; 8E D1 01
sty WCTLSB ; 8C D2 01
pla ; 68
jmp L0D58 ; 4C 58 0D
L0D4B sta STFLG2 ; 8D 90 01
stx DEVST2 ; 8E 91 01
sty WCTLB2 ; 8C 92 01
pla ; 68
L0D58 lda #CMPLT ; A9 43
jsr SAA2 ; 20 82 17
jmp L0902 ; 4C 02 09
L0D60 jsr MFUTST ; 20 12 11
lda #$02 ; A9 02
jmp L0AFA ; 4C FA 0A
; Read spin
RDSPN ldx #$52 ; A2 52
stx CTLCMD ; 8E 82 01
jmp L0993 ; 4C 93 09
; Read Addr. different
RDADR lda AUX2 ; AD 84 01
cmp #$02 ; C9 02
bcc L0D80 ; 90 03
jmp CMD2 ; 4C 9A 0A
L0D80 jsr SAA ; 20 7B 17 SEND ACK
ldy AUX1 ; AC 83 01
jsr L0DA3 ; 20 A3 0D
jmp RD32 ; 4C F3 0C
; Command X added
CMDX ldy #$D9 ; A0 D9
and #$02 ; 29 02
bne L0D96 ; D0 01
sec ; 38
L0D96 lda #$17 ; A9 17
bcc L0DA0 ; 90 03
jsr XTND1 ; 20 03 08 GO TO UPDATE IF X ROM INSTLD
L0DA0 jmp RD32 ; 4C F3 0C
L0DA3 sty ZPNTL ; 84 C0
sta ZPNTH ; 85 C1
ldy #$00 ; A0 00
L0DA9 lda (ZPNTL),Y ; B1 C0
sta $0000,Y ; 99 00 00
iny ; C8
bpl L0DA9 ; 10 F8
ldx #$01 ; A2 01
stx SCTTBL+6 ; 8E AC 01
dex ; CA
jmp RD32 ; 4C F3 0C
; STATUS
STCMD jsr SAA ; 20 7B 17 SEND ACK
L0DC0 ldx #$04 ; A2 04
bvc L0E0A ; 50 43 BRNCH IF CMND FOR DRV2
L0DC7 lda STPNBR,X ; BD CF 01 MOVE 4 BYTE STAT FOR DRV1
sta STPNT,X ; 9D 80 01 INTO MORE CONVENIENT LOC
dex ; CA
bne L0DC7 ; D0 F7
L0DD0 ldy #$04 ; A0 04
sty INSCRT ; 8C DE 01
jsr CDCKSM ; 20 D9 15 GEN CS ON 4 BYTE STAT
sta RCDCSM ; 8D 85 01
jsr SETOP ; 20 8F 17 OPEN SERIAL OUTPUT PORT
ldx #$7B ; A2 7B 5 BYTES TO SEND
jsr OUTPUT ; 20 42 13
L0DE8 ldy #$0F ; A0 0F
L0DEA dey ; 88 SET DELA OF
bne L0DEA ; D0 FD 74 MACH CYC
ldy L0106,X ; BC 06 01 106+7B=181
sty TMPOUT ; 8C 86 01
jsr OUTPUT ; 20 42 13 OUTPUT 1 BYTE
inx ; E8
bpl L0DE8 ; 10 EF
jsr RSTOUT ; 20 D4 12 CLOSE OUTPUT PORT
bvc L0E15 ; 50 14 BRNCH IF CMND FOR DRV2
jsr CLRST ; 20 4C 15 CLR ALL STAT BUT WP
jsr SPMFU ; 20 17 11 UPDATE DRV1 SPM FLG
L0E0A lda WCTMB2-4,X ; BD 8F 01 MOVE 4 BYTE STAT FOR DRV2
sta STPNT,X ; 9D 80 01 INTO MORE CONVEINIENT LOC
dex ; CA
bne L0E0A ; D0 F7
beq L0DD0 ; F0 BB
L0E15 jsr CLRST2 ; 20 55 15 CLR ALL BUT BASIC STATUS FOR DRiVE 2
jsr SPM2FU ; 20 25 11 UPDATE DRV2 SPM FLG
; Format
FRMT jsr SAA ; 20 7B 17 SEND ACK
jsr SPMON ; 20 75 13 TURN ON SPM IF NOT ALREADY
jsr SPMDY ; 20 B2 13 INSURE MOTOR UP TO SPEED
beq L0E3D ; F0 0E TEST DISC NOT WP,IF NOT,BRNCH
lda #$1C ; A9 1C
lda #$FF ; A9 FF
sta ZPRL ; 85 00 DS TRMS TO FRNT
sta ZPRL+1 ; 85 01
jmp L0D11 ; 4C 11 0D
L0E3D ldy #$2C ; A0 2C
jsr REHME ; 20 FE 12
ldx #$FE ; A2 FE
stx IDAM ; 86 F8 INIT ID FIELD LIST
ldx #$4E ; A2 4E
stx BYTE4E ; 86 FF
ldx #$00 ; A2 00
stx BYTE00 ; 86 FA
stx TRKNO ; 86 F9
inx ; E8
stx BYTE01 ; 86 FC
L0E56 jsr STSUP2 ; 20 64 12 GO TO TST FOR <20 TRK SWITCH
ldx #$00 ; A2 00
stx SCTPT ; 86 F6
stx CRCLP ; 86 F7
inx ; E8
L0E63 ldx #$F8 ; A2 F8
jsr CRCGEN ; 20 FB 13 GO GEN 2 BYTE CRC ON 5 BYTE ID
; FIELD FOR THIS TRK,SCT NUMBER.
ldx CRCLP ; A6 F7
lda BAKER ; AD 96 01
sta FRMCRC,X ; 95 A0
inx ; E8
lda ABLE ; AD 97 01
inx ; E8
stx CRCLP ; 86 F7
ldy SCTPT ; A4 F6
ldx SCTRS,Y ; BE A8 17
bit STFLGS ; 2C D0 01
bpl L0E85 ; 10 03
jsr XTND4 ; 20 0C 08 GO TO XTRA ROM IF 38K CAPABL. not present
L0E85 stx SCTTBL+6 ; 8E AC 01
inc SCTPT ; E6 F6
cpy #$12 ; C0 12
bne L0E63 ; D0 D5 BRNCH IF MOR CRCS TO DO
ldx #$00 ; A2 00
stx SCTPT ; 86 F6
lda FRMCRC,X ; B5 A0
sta CRC1 ; 85 FD STORE FIRST CRC IN ID LIST
inx ; E8
stx SCTNO ; 86 FB REST SCT NUMBER TO 01
lda FRMCRC,X ; B5 A0 STOR SECOND CRC IN ID LIST
sta CRC2 ; 85 FE
stx CRCLP ; 86 F7 SAVE CRC LIST POINTER
L0E9F lda TIM1R ; AD 95 03
bpl L0E9F ; 10 FB WAIT FOR LAST STEP TO SETTLE
jsr L176D ; 20 6D 17 WAIT 10MS FOR LAST STP SETL
jsr FWSL ; 20 F1 15
ldx EGON ; AE 94 01
stx PORTB2 ; 8E 82 02 TURN ON ERASE GATE
ldx #$FF ; A2 FF SET X AS 255 BYTE COUNTER.
jsr FSL ; 20 61 10 GO XMIT 255 BYTES OF "4E"
dex ; CA SETS X TO FF AS X EQUALS 00 ON
; RETURN FROM PREVIOUS JSR.
dex ; CA
jsr FSL ; 20 61 10 XMIT 255 BYTES OF "4E"
; format rest of track loop
L0EBD lda #$AA ; A9 AA
tay ; A8
ldx #$08 ; A2 08
jsr FSL ; 20 61 10 XMIT 8 BYTES OF "00". THIS IS S
; ECOND HALF OF GAP3.
lda #$44 ; A9 44
ldy #$89 ; A0 89
ldx #$03 ; A2 03
jsr FSL ; 20 61 10 XMIT 3 BYTES OF "A1". THIS IS
; ID AM SYNC LEADER.
lda #$55 ; A9 55
ldy #$54 ; A0 54
ldx #$01 ; A2 01
jsr FSL ; 20 61 10 XMIT 1 BYTE "FE". THIS IS ID AM
ldx #$F9 ; A2 F9
clc ; 18
jsr WSL ; 20 DC 12 XMIT 7 BYTES OF ID FIELD THRU
; ID FIELD TABLE.
lda #$92 ; A9 92
L0EDF bit SSDA0 ; 2C 00 01
bvc L0EDF ; 50 FB
ldy #$54 ; A0 54
sty SSDA1 ; 8C 01 01 XMIT 1 BYTE "4G" FAST-LATE
ldx #$12 ; A2 12
jsr FSL ; 20 61 10 XMIT 20 MORE BYTES OF "4E". THI
; S IS FIRST HALF GAP 2.
inc CRCLP ; E6 F7
ldx CRCLP ; A6 F7
lda FRMCRC,X ; B5 A0 MOVE CRC1 FOR NXT SCTOR INTO
sta CRC1 ; 85 FD ID FIELD LIST
lda #$AA ; A9 AA
tay ; A8
ldx #$0C ; A2 0C
jsr FSL ; 20 61 10 XMIT 12 BYTES OF "00". THIS IS
; LAST HALF OF GAP 2.
inc CRCLP ; E6 F7
ldx CRCLP ; A6 F7
lda FRMCRC,X ; B5 A0 MOVE NXT CRC2 INTO ID
sta CRC2 ; 85 FE FIELD LIST
lda #$44 ; A9 44
ldy #$89 ; A0 89
ldx #$03 ; A2 03
jsr FSL ; 20 61 10 XMIT 3 BYTES "A1" THIS IS DAM
; SYNC LEADER
lda #$55 ; A9 55
ldy #$45 ; A0 45
inx ; E8
jsr FSL ; 20 61 10 XMIT 1 BYTE "FB" THIS IS DAM.
lda #$45 ; A9 45
ldy #$14 ; A0 14
inx ; E8
jsr FSL ; 20 61 10 XMIT 1 BYTE "00"
lda #$45 ; A9 45
ldx #$FF ; A2 FF XMIT 255 BYTES "00". THIS,PLUS
jsr FSL ; 20 61 10 PREVIOS XMIT=128 BYTE DATA FLD
lda #$45 ; A9 45
ldy #$29 ; A0 29
inx ; E8
; XMIT 1 BYTE "48" THIS IS
jsr FSL ; 20 61 10 CRC1 FOR DATA FIELD OF ALL "00"
lda #$14 ; A9 14
ldy #$AA ; A0 AA
inx ; E8
; XMIT 1 BYTE "29" THIS IS
jsr FSL ; 20 61 10 CRC2 FOR DATA FIELD ALL "00"
lda #$92 ; A9 92
ldy #$54 ; A0 54
inx ; E8
; XMIT 1 BYTE "4E" THIS IS
jsr FSL ; 20 61 10 1 BYTE OF GAP 3 FIRST HALF
lda #$92 ; A9 92
ldx #$17 ; A2 17 XMIT 23 BYTES "4E" THIS
jsr FSL ; 20 61 10 COMPLETES FIRST HALF GAP3
ldy SCTPT ; A4 F6
stx SCTNO ; 86 FB MOV NXT SCTR IN
inc SCTPT ; E6 F6
cpy #$11 ; C0 11 CHK FOR 18 SCTRS FRMTD
bne L0F7E ; D0 29
lda #$D3 ; A9 D3
sta SSDA0 ; 8D 00 01 REST XMIT
sta PORTB2 ; 8D 82 02 TURN OFF WG
inc TRKNO ; E6 F9
inc SCTTBL+4 ; EE AA 01
ldx #$28 ; A2 28
lda DH80T ; AD 99 01
beq L0F72 ; F0 03
jsr XTND3 ; 20 09 08 GO TEST FOR MAX # OF TRKS TO FORMAT
L0F72 cpx TRKNO ; E4 F9 CHK FOR ALL TRKS FORMATED
beq L0F81 ; F0 0B
ldx #$80 ; A2 80
jsr STEP ; 20 88 10
jmp L0E56 ; 4C 56 0E GO FORMAT ANOTHR TRK
L0F7E jmp L0EBD ; 4C BD 0E
; Format test
; TESTS ALL SCTRS
; AFTR ACTUAL
L0F81 lda #$52 ; A9 52
ldx #$00 ; A2 00
stx BFRPNT ; 8E E1 01
ldy #$80 ; A0 80
L0F90 lda SCTRS,X ; BD A8 17
iny ; C8
inx ; E8
inx ; E8
cpx #$12 ; E0 12
bne L0FA1 ; D0 04
ldx #$01 ; A2 01
stx ZP91 ; 86 91
L0FA1 cpx #$11 ; E0 11
bne L0F90 ; D0 EB
dec SCTTBL+4 ; CE AA 01
L0FA8 ldx #$80 ; A2 80
L0FAA lda ZPRL,X ; B5 00
inx ; E8
stx FSCTBP ; 8E E0 01
sta SCTTBL+6 ; 8D AC 01
jsr STSUP1 ; 20 56 12 DO CRC ON SCTR ID FIELD
lda #$60 ; A9 60
sta ABLE ; 8D 97 01
lda #$B1 ; A9 B1
sta BAKER ; 8D 96 01
lda #$01 ; A9 01
dec INMODE ; CE DC 01
bcs L0FF2 ; B0 25
L0FCD ldx FSCTBP ; AE E0 01
cpx #$92 ; E0 92
bne L0FAA ; D0 D6
ldy SCTTBL+4 ; AC AA 01
bne L0FE4 ; D0 0B
beq L103D ; F0 5F BRANCH IF NOT DH OR 96 TPI DRVS
jsr XTND5 ; 20 0F 08
jmp L103D ; 4C 3D 10
L0FE4 dey ; 88
sty SCTTBL+4 ; 8C AA 01
ldx #$00 ; A2 00
ldy #$01 ; A0 01
jsr STPTST ; 20 5E 17 STP TO NXT TRK
jmp L0FA8 ; 4C A8 0F CONT TST
L0FF2 lda #$08 ; A9 08
jsr ORINST ; 20 34 15 SET FORMAT ERR BIT INSTAT
ldy #$00 ; A0 00
sty MSBSB ; 8C E4 01
ldx BFRPNT ; AE E1 01
lda SCTTBL+4 ; AD AA 01 GET TRK NMBR
asl A ; 0A
sta TMPSB ; 8D E3 01 SAVE TIMES TWO
asl A ; 0A
rol MSBSB ; 2E E4 01
asl A ; 0A
asl A ; 0A
adc TMPSB ; 6D E3 01
tay ; A8
lda #$00 ; A9 00
adc MSBSB ; 6D E4 01
sta MSBSB ; 8D E4 01
tya ; 98
clc ; 18
adc SCTTBL+6 ; 6D AC 01
sta ZPRL,X ; 95 00
lda #$00 ; A9 00
inx ; E8
sta ZPRL,X ; 95 00
beq L1035 ; F0 03
jsr XTND11 ; 20 21 08 GOTO INCREASE SEC # FOR SIDE 2
L1035 inx ; E8
cpx #$7E ; E0 7E
bne L0FCD ; D0 90 BRNCH IF BAD SCTR BUFR NOT FULL
L103D lda #$FF ; A9 FF
sta ZPRL,X ; 95 00
inx ; E8
sta ZPRL,X ; 95 00
sta SCTTBL+4 ; 8D AA 01
lda #$21 ; A9 21
and #$08 ; 29 08
bne L1059 ; D0 03 BRNCH IF ANY BAD SCTRS
jmp L0CEE ; 4C EE 0C
L1059 lda #$F7 ; A9 F7
jsr ANINS ; 20 6C 15 CLR 105B. curts code ends here
FSL bit SSDA0 ; 2C 00 01
bvc FSL ; 50 FB
dex ; CA
bne FSL ; D0 F2
rts ; 60
; Motor on delay. command U
MOTRON jsr SAA ; 20 7B 17 SEND ACK
ldx #$FF ; A2 FF
bvc L1082 ; 50 05
bvs L1085 ; 70 03
L1082 stx SPSDC2 ; 8E A2 01
L1085 jmp L0DC0 ; 4C C0 0D
; step
STEP bit INMODE ; 2C DC 01
bvc L10C6 ; 50 39
STEP1 lda #$A0 ; A9 A0
sta TIMR3 ; 8D 9E 03
and #$3C ; 29 3C
inx ; E8
bmi L10AC ; 30 12
dec PRSTRK ; CE CE 01
lsr A ; 4A
sta STPSCR ; 8D CD 01
and #$02 ; 29 02
beq L10BE ; F0 19
lda #$20 ; A9 20
ora STPSCR ; 0D CD 01
bpl L10C1 ; 10 15
L10AC inc PRSTRK ; EE CE 01
asl A ; 0A
and #$40 ; 29 40
beq L10BE ; F0 07
lda #$04 ; A9 04
bpl L10C1 ; 10 03
L10BE lda STPSCR ; AD CD 01
L10C1 sta PORTB1 ; 8D 82 03
dey ; 88
rts ; 60
L10C6 lda #$A0 ; A9 A0
and #$3C ; 29 3C
inx ; E8
bmi L10E5 ; 30 12
dec PRTRK2 ; CE A1 01
lsr A ; 4A
and #$02 ; 29 02
beq L10F7 ; F0 19
lda #$20 ; A9 20
bpl L10FA ; 10 15
L10E5 inc PRTRK2 ; EE A1 01
asl A ; 0A
and #$40 ; 29 40
beq L10F7 ; F0 07
lda #$04 ; A9 04
bpl L10FA ; 10 03
L10F7 lda STPSCR ; AD CD 01
L10FA sta PORTB3 ; 8D 02 02
dey ; 88
rts ; 60
L10FF ldx #$00 ; A2 00
cpx SCTTBL+4 ; EC AA 01
clc ; 18
bne L1111 ; D0 0A
lda SCTTBL+5 ; AD AB 01
bne L1111 ; D0 05
lda #$03 ; A9 03
cmp SCTTBL+6 ; CD AC 01
L1111 rts ; 60
MFUTST bit INMODE ; 2C DC 01
bvc SPM2FU ; 50 0E
SPMFU lda PORTA1 ; AD 80 03
lsr A ; 4A
lsr A ; 4A
lda #$10 ; A9 10
bcs L1122 ; B0 02
lda #$00 ; A9 00
L1122 jmp ORSTF ; 4C 2D 15
SPM2FU lda PORTA3 ; AD 00 02
lsr A ; 4A
lsr A ; 4A
lda #$10 ; A9 10
bcs L1130 ; B0 02
lda #$00 ; A9 00
L1130 jmp ORSTF2 ; 4C 45 15
; REPOSITION HEAD
ERRTRY dex ; CA
stx PACNTR ; 8E D4 01
tya ; 98
bne L1145 ; D0 0B
cpx #$02 ; E0 02
bne L1145 ; D0 07
ldy #$2C ; A0 2C
bmi L1162 ; 30 1D
L1145 cpx #$01 ; E0 01
bne L1165 ; D0 1C
ldy STPDIR ; AC 9D 01
bmi L1159 ; 30 0B
dec TRKNBR ; CE DA 01
jsr L1166 ; 20 66 11
inc TRKNBR ; EE DA 01
bpl L1162 ; 10 09
L1159 inc TRKNBR ; EE DA 01
L1162 jsr L1166 ; 20 66 11
L1165 rts ; 60
L1166 lda TRKNBR ; AD DA 01
rts ; 60
RDWRLT lda INMODE ; AD DC 01
asl A ; 0A
bpl L1199 ; 10 23
ldx #$1A ; A2 1A
asl A ; 0A
bmi L117D ; 30 02
ldx #$19 ; A2 19
L117D stx PORTA2 ; 8E 80 02
and #$E7 ; 29 E7
ldx CTLCMD ; AE 82 01
cpx #$52 ; E0 52
beq L1195 ; F0 06
ora #$10 ; 09 10
L1191 sta PORTA3 ; 8D 00 02
rts ; 60
L1195 ora #$08 ; 09 08
bne L1191 ; D0 F8
L1199 ldx #$53 ; A2 53
asl A ; 0A
bmi L11A0 ; 30 02
ldx #$4B ; A2 4B
L11A0 txa ; 8A
cpx #$52 ; E0 52
beq L11AB ; F0 03
clc ; 18
adc #$40 ; 69 40
L11AB sta PORTA2 ; 8D 80 02
rts ; 60
L11AF lda PORTB1 ; AD 82 03
bpl L11AF ; 10 FB
bmi L11BD ; 30 07
CINPUT bit PORTB1 ; 2C 82 03
bvc L120C ; 50 51
bpl CINPUT ; 10 F9
L11BD lda INMODE ; AD DC 01
and #$81 ; 29 81
cmp #$01 ; C9 01
beq L11ED ; F0 27
ldy #$0B ; A0 0B
L11C8 dey ; 88
bne L11C8 ; D0 FD
ldy #$78 ; A0 78
L11CD tya ; 98
ldy #$0E ; A0 0E
L11D0 dey ; 88
bne L11D0 ; D0 FD
tay ; A8
rol A ; 2A
ror UNITNB,X ; 7E 81 01
iny ; C8
bpl L11F4 ; 10 16
lda UNITNB,X ; BD 81 01
eor #$FF ; 49 FF
sta UNITNB,X ; 9D 81 01
inx ; E8
cpx INSCRT ; EC DE 01
bne L1205 ; D0 19
rts ; 60
L11ED ldy #$78 ; A0 78
nop ; EA
ldy #$09 ; A0 09
bne L11D0 ; D0 DC
L11F4 lda INMODE ; AD DC 01
and #$81 ; 29 81
cmp #$01 ; C9 01
bne L11CD ; D0 D0
tya ; 98
ldy #$02 ; A0 02
nop ; EA
nop ; EA
nop ; EA
bne L11D0 ; D0 CB
L1205 ldy #$0D ; A0 0D
L1207 dey ; 88
bne L1207 ; D0 FD
beq CINPUT ; F0 AA
L120C jmp CMD2 ; 4C 9A 0A
CRCSUP lda #$01 ; A9 01
ldx #$00 ; A2 00
ldy #$E2 ; A0 E2
sty BAKER ; 8C 96 01
ldy #$95 ; A0 95
sty ABLE ; 8C 97 01
jsr L1403 ; 20 03 14
lda #$FE ; A9 FE
rts ; 60
EGOFF lda #$1A ; A9 1A
L122E lda TIM1R ; AD 95 03
bpl L122E ; 10 FB
lda #$FF ; A9 FF
rts ; 60
SETSUP jsr SAA ; 20 7B 17 SEND ACK
lda #$03 ; A9 03
jsr L16F6 ; 20 F6 16
lda SCTNBR ; AD DB 01
STSUP1 ldx #$F8 ; A2 F8 DO CRC ON SCTR ID FIELD
ldx BAKER ; AE 96 01
stx SCTTBL+8 ; 8E AE 01
sta SCTTBL+9 ; 8D AF 01
STSUP2 lda PORTB3 ; AD 02 02
ldx SCTTBL+4 ; AE AA 01
cpx #$14 ; E0 14
bvc L1274 ; 50 03
jsr XTND13 ; 20 27 08
L1274 bcc L127A ; 90 04
and #$FE ; 29 FE
bne L127C ; D0 02
L127A ora #$01 ; 09 01
L127C sta PORTB3 ; 8D 02 02
rts ; 60
; Buffer out?
BFROUT jsr L10FF ; 20 FF 10
bcc L129C ; 90 0E
lda #$21 ; A9 21
cmp CTLCMD ; CD 82 01
beq L129C ; F0 07
L1295 lda ZPRL,X ; B5 00
sta ZP80,X ; 95 80
inx ; E8
bpl L1295 ; 10 F9
L129C clc ; 18
bmi L12A5 ; 30 03
jmp XTND9 ; 4C 1B 08
L12A5 php ; 08
ldy #$08 ; A0 08
L12AB dey ; 88
bne L12AB ; D0 FD
L12AE ldy #$08 ; A0 08
L12B0 dey ; 88
bne L12B0 ; D0 FD
ldy ZPRL,X ; B4 00
plp ; 28
jsr L15D0 ; 20 D0 15
php ; 08
inx ; E8
bne L12AE ; D0 EB
lda CSSCRT ; AD E5 01
plp ; 28
adc #$00 ; 69 00
ldy #$07 ; A0 07
L12CE dey ; 88
bne L12CE ; D0 FD
; Close output port
RSTOUT ldx PBDDR1 ; AE 83 03
dex ; CA
rts ; 60
WSL bit SSDA0 ; 2C 00 01
bvc WSL ; 50 FB
lda ZPRL,X ; B5 00
ror A ; 6A
lsr A ; 4A
lsr A ; 4A
lsr A ; 4A
tay ; A8
lda ZPRL,X ; B5 00
and #$1F ; 29 1F
tay ; A8
lsr A ; 4A
inx ; E8
bne WSL ; D0 DF
rts ; 60
REHME ldx #$24 ; A2 24
bvc L1308 ; 50 03
jsr XTND7 ; 20 15 08 unused. what does it do?
L1308 bit INMODE ; 2C DC 01
bvs L132E ; 70 21
L1310 jsr STEP ; 20 88 10
beq L1320 ; F0 0B
L1315 lda TIM1R ; AD 95 03
bpl L1315 ; 10 FB
jmp L1310 ; 4C 10 13
jmp L132E ; 4C 2E 13 how does it get here?
L1320 sty PRTRK2 ; 8C A1 01
L1323 lda #$80 ; A9 80
L1328 lda TIM1R ; AD 95 03+
bpl L1328 ; 10 FB
rts ; 60
L132E stx PORTB1 ; 8E 82 03
L1331 jsr STEP ; 20 88 10
beq L133D ; F0 07
L1336 lda TIM1R ; AD 95 03
bpl L1336 ; 10 FB
bmi L1331 ; 30 F4
L133D sty PRSTRK ; 8C CE 01
beq L1323 ; F0 E1
; send byte sio
OUTPUT lda PORTB1 ; AD 82 03 output
and #$FE ; 29 FE
sta PORTB1 ; 8D 82 03 start bit
ldy ZPRL ; A4 00
ldy #$78 ; A0 78
L134E nop ; EA
nop ; EA
nop ; EA
sty YSAVE ; 8C E6 01
ldy #$0E ; A0 0E
L1356 dey ; 88
bne L1356 ; D0 FD
ldy YSAVE ; AC E6 01
lsr A ; 4A
ror TMPOUT ; 6E 86 01
rol A ; 2A
iny ; C8
bpl L134E ; 10 E7
lsr A ; 4A
sec ; 38
rol A ; 2A
ldy #$11 ; A0 11
L136C dey ; 88
bne L136C ; D0 FD
nop ; EA
nop ; EA
rts ; 60
; Turn on motor
SPMON bit INMODE ; 2C DC 01 +*drive 1 or 2?
bvc L1396 ; 50 1C
lsr A ; 4A
lsr A ; 4A
bcs L1390 ; B0 0F
lda #$6A ; A9 6A
lda #$FF ; A9 FF
sta TIMR2 ; 8D 9F 03
lda #$04 ; A9 04
L1390 lda #$18 ; A9 18
rts ; 60
L1396 lda PORTA3 ; AD 00 02
lsr A ; 4A
lsr A ; 4A
bcs L13AC ; B0 0F
lda #$02 ; A9 02
lda #$FF ; A9 FF
lda #$04 ; A9 04
sta SPMDC2 ; 8D A3 01
L13AC lda #$18 ; A9 18
rts ; 60
SPMDY bit INMODE ; 2C DC 01
bvc L13DC ; 50 25
lsr A ; 4A
lsr A ; 4A
lsr A ; 4A
bcc L13D6 ; 90 17
L13BF lda TIM1R ; AD 95 03
bpl L13BF ; 10 FB
dec SPMDLC ; CE B1 01
beq L13D1 ; F0 08
lda #$FF ; A9 FF
jmp L13BF ; 4C BF 13
L13D1 lda #$FB ; A9 FB
L13D6 lda #$10 ; A9 10
jsr L1523 ; 20 23 15
rts ; 60
L13DC lda INMODE ; AD DC 01
and #$04 ; 29 04
beq L13FA ; F0 17
L13E3 lda TIMR3R ; AD 15 02
bpl L13E3 ; 10 FB
dec SPMDC2 ; CE A3 01
beq L13F5 ; F0 08
lda #$FF ; A9 FF
jmp L13E3 ; 4C E3 13
L13F5 lda #$FB ; A9 FB
L13FA rts ; 60
; Generate CRC
CRCGEN lda #$FF ; A9 FF
sta ABLE ; 8D 97 01
L1403 lda INMODE ; AD DC 01
lsr A ; 4A
.BYTE $BD,$AE,$00 ;lda ZPCRC,X ABSOLUTE,X. not zeropage,X
; Error in assembler?
bcc L140E ; 90 02
lda ZPRL,X ; B5 00
L140E eor BAKER ; 4D 96 01
sta SCRT1 ; 8D A4 01
lsr A ; 4A
lsr A ; 4A
lsr A ; 4A
lsr A ; 4A
tay ; A8
lsr A ; 4A
tya ; 98
bcc L145C ; 90 39
eor ZPRL,X ; 55 00
L1425 and #$0F ; 29 0F
sta SCRT2 ; 8D A5 01
lda SCRT1 ; AD A4 01
and #$F0 ; 29 F0
eor SCRT2 ; 4D A5 01
lsr A ; 4A
lsr A ; 4A
lsr A ; 4A
eor ABLE ; 4D 97 01
sta ABLE ; 8D 97 01
lda SCRT2 ; AD A5 01
asl A ; 0A
asl A ; 0A
asl A ; 0A
asl A ; 0A
eor ABLE ; 4D 97 01
asl A ; 0A
sta ABLE ; 8D 97 01
inx ; E8
bne L1403 ; D0 A8
rts ; 60
L145C .BYTE $5D,$AE,$00 ;EOR ZPCRC,X ABSOLUTE,X not zero page,X
; as above
jmp L1425 ; 4C 25 14
L1462 jmp L1508 ; 4C 08 15
; SYNC
SYNC lda #$06 ; A9 06
L146A dec SPMDC2 ; CE A3 01
beq L1462 ; F0 F3
cpy #$01 ; C0 01
beq L1462 ; F0 EF
lda #$FF ; A9 FF
SYNC01 sta TIMR23 ; 8D 1F 02
L1478 lda TIMR3R ; AD 15 02
bmi L146A ; 30 ED
lda #$D0 ; A9 D0
lda #$9B ; A9 9B
lda #$D1 ; A9 D1
lda #$44 ; A9 44
and #$BF ; 29 BF
ora #$40 ; 09 40
lda #$41 ; A9 41
L14A3 lda TIMR3R ; AD 15 02
bmi L146A ; 30 C2
bit PORTA1 ; 2C 80 03
bpl L14A3 ; 10 F6
lda #$89 ; A9 89
ldx #$04 ; A2 04
L14B4 dex ; CA
bne L14B4 ; D0 FD
bmi L1478 ; 30 BC
lda #$40 ; A9 40
lda #$DB ; A9 DB
cpy #$02 ; C0 02
beq L1506 ; F0 3C
ldx #$02 ; A2 02
lda #$03 ; A9 03
L14D1 bit TIM1R ; 2C 95 03
bmi L1478 ; 30 A2
bpl L14D1 ; 10 F6
L14DB lda SSDA1 ; AD 01 01
cmp #$A1 ; C9 A1
bne L1478 ; D0 96
dex ; CA
bne L14DB ; D0 F6
tya ; 98
bne L1506 ; D0 1E
ldx #$78 ; A2 78
L14EA bit SSDA0 ; 2C 00 01
bpl L14EA ; 10 FB
cmp L0131,X ; DD 31 01
bne L1478 ; D0 81
inx ; E8
beq L1503 ; F0 03
jmp L1478 ; 4C 78 14
L1503 inx ; E8
bpl L14EA ; 10 E4
L1506 lda #$01 ; A9 01
L1508 rts ; 60
; how does it get here?
lda #$08 ; A9 08 $1509
jsr STEP ; 20 88 10
rts ; 60
TIMER sta TMRSCR ; 8D DF 01
L1515 dey ; 88
bne L1515 ; D0 FD
dec TMRSCR ; CE DF 01
bne L1515 ; D0 F8
rts ; 60
; Update status bits
OR0STX bit INMODE ; 2C DC 01
bvc L153B ; 50 18
L1523 pha ; 48
lda #$E8 ; A9 E8
and STFLGS ; 2D D0 01
pla ; 68
ORSTF ora STFLGS ; 0D D0 01
rts ; 60
ORINST ora INSTAT ; 0D DD 01
rts ; 60
L153B pha ; 48
lda #$E8 ; A9 E8
and STFLG2 ; 2D 90 01
pla ; 68
ORSTF2 ora STFLG2 ; 0D 90 01
rts ; 60
CLRST lda #$E8 ; A9 E8
CLRST1 and STFLGS ; 2D D0 01
rts ; 60
CLRST2 lda #$E8 ; A9 E8
CLRS12 and STFLG2 ; 2D 90 01
rts ; 60
WPTST lda PORTA1 ; AD 80 03
bvc L1569 ; 50 03
and #$10 ; 29 10
rts ; 60
L1569 and #$01 ; 29 01
rts ; 60
ANINS and INSTAT ; 2D DD 01
rts ; 60
ORINMD ora INMODE ; 0D DC 01
rts ; 60
ANDNMD and INMODE ; 2D DC 01
rts ; 60
ORST1 bit INMODE ; 2C DC 01
bvc L158D ; 50 07
ora DEVSTA ; 0D D1 01
rts ; 60
L158D ora DEVST2 ; 0D 91 01
rts ; 60
ANDST1 bit INMODE ; 2C DC 01
bvc L15A0 ; 50 07
and DEVSTA ; 2D D1 01
rts ; 60
L15A0 and DEVST2 ; 2D 91 01
rts ; 60
; test for valid sector number
TSN ldx AUX2 ; AE 84 01
lda AUX1 ; AD 83 01
beq L15B9 ; F0 0A
L15AF cpx #$03 ; E0 03
bcs L15BD ; B0 0A
cmp #$D1 ; C9 D1
bcs L15C9 ; B0 12
L15B7 clc ; 18
rts ; 60
L15B9 cpx #$00 ; E0 00
bne L15AF ; D0 F2
L15BD sec ; 38
and #$C0 ; 29 C0
beq L15C8 ; F0 03
jsr XTND6 ; 20 12 08
L15C8 rts ; 60
L15C9 cpx #$02 ; E0 02
beq L15BD ; F0 F0
jmp L15B7 ; 4C B7 15
L15D0 lda CSSCRT ; AD E5 01
adc ZPRL,X ; 75 00
sta CSSCRT ; 8D E5 01
rts ; 60
; Caculate chksum
CDCKSM lda #$00 ; A9 00
clc ; 18
L15DC adc UNITNB,X ; 7D 81 01
php ; 08
inx ; E8
beq L15EA ; F0 04
plp ; 28
jmp L15DC ; 4C DC 15
L15EA plp ; 28
adc #$00 ; 69 00
cmp UNITNB,X ; DD 81 01
rts ; 60
FWSL lda PORTA2 ; AD 80 02
ora #$1B ; 09 1B
nop ; EA
nop ; EA
nop ; EA
asl A ; 0A
bmi L1611 ; 30 12
asl A ; 0A
asl A ; 0A
lda #$EF ; A9 EF
ldx #$CF ; A2 CF
ldy #$DF ; A0 DF
bcs L1621 ; B0 18
lda #$BF ; A9 BF
ldx #$3F ; A2 3F
ldy #$7F ; A0 7F
bcc L1621 ; 90 10
L1611 asl A ; 0A
asl A ; 0A
lda #$FE ; A9 FE
ldx #$FC ; A2 FC
ldy #$FD ; A0 FD
bcs L1621 ; B0 06
lda #$FB ; A9 FB
ldx #$F3 ; A2 F3
ldy #$F7 ; A0 F7
L1621 stx EGON ; 8E 94 01
sty WGOFF ; 8C 95 01
lda #$D3 ; A9 D3
lda #$92 ; A9 92
ldy #$54 ; A0 54
ldx #$93 ; A2 93
stx SSDA0 ; 8E 00 01
rts ; 60
FWSL1 lda #$AA ; A9 AA
tay ; A8
ldx #$0C ; A2 0C
jsr FSL ; 20 61 10
lda #$44 ; A9 44
ldy #$89 ; A0 89
ldx #$03 ; A2 03
jsr FSL ; 20 61 10
lda #$55 ; A9 55
ldy #$45 ; A0 45
inx ; E8
jsr FSL ; 20 61 10
rts ; 60
INPUT jsr L10FF ; 20 FF 10
bcc L1663 ; 90 02;
L1661 ldx #$80 ; A2 80
L1663 lda #$FF ; A9 FF
sta TIMR22 ; 8D 9F 02
ldy #$07 ; A0 07
inc INMODE ; EE DC 01
clc ; 18
bmi L1679 ; 30 03
jmp XTND8 ; 4C 18 08 unused data field input ,38k baud
L1679 php ; 08
L167A lda TIMR2R ; AD 95 02
bmi L16EF ; 30 70
L167F lda PORTB1 ; AD 82 03
bpl L167A ; 10 F6
ldy #$0C ; A0 0C
L1686 dey ; 88
bne L1686 ; D0 FD
ldy #$78 ; A0 78
L168B tya ; 98
ldy #$0F ; A0 0F
L168E dey ; 88
bne L168E ; D0 FD
tay ; A8
rol A ; 2A
ror ZPRL,X ; 76 00
iny ; C8
bpl L16E0 ; 10 45
lda ZPRL,X ; B5 00
eor #$FF ; 49 FF
sta ZPRL,X ; 95 00
plp ; 28
php ; 08
inx ; E8
bne L16E5 ; D0 3C
ldx #$04 ; A2 04
L16AB dex ; CA
bne L16AB ; D0 FD
ldx #$06 ; A2 06
jsr L11AF ; 20 AF 11
sta DICKSM ; 8D 87 01
bcc L16C2 ; 90 07
L16BB lda ZP80,X ; B5 80
sta ZPRL,X ; 95 00
inx ; E8
bpl L16BB ; 10 F9
L16C2 lda CSSCRT ; AD E5 01
plp ; 28
adc #$00 ; 69 00
cmp DICKSM ; CD 87 01
php ; 08
ldy #$5A ; A0 5A
L16D1 dey ; 88
bne L16D1 ; D0 FD
plp ; 28
beq L16DF ; F0 08
lda #$4E ; A9 4E
jsr SAA2 ; 20 82 17
jmp L0AF8 ; 4C F8 0A
L16DF rts ; 60
L16E0 lda INMODE ; AD DC 01
bmi L168B ; 30 A6
L16E5 ldy #$06 ; A0 06
sty TIMR22 ; 8C 9F 02
L16EA dey ; 88
bne L16EA ; D0 FD
beq L167F ; F0 90
L16EF dec INMODE ; CE DC 01
plp ; 28
lda #$FF ; A9 FF
rts ; 60
L16F6 lda AUX2 ; AD 84 01
sta SSCTMS ; 8D D7 01
lda AUX1 ; AD 83 01
sta SSCTLS ; 8D D8 01
ldx #$04 ; A2 04
L1704 ror AUX2 ; 6E 84 01
ror A ; 6A
dex ; CA
bne L1704 ; D0 F9
ror AUX2 ; 6E 84 01
ldx #$04 ; A2 04
L1710 lsr AUX2 ; 4E 84 01
dex ; CA
bne L1710 ; D0 FA
L1716 asl A ; 0A
cmp AUX2 ; CD 84 01
bcs L172E ; B0 12
sta AUX1 ; 8D 83 01
lsr A ; 4A
sta TRKNBR ; 8D DA 01
sec ; 38
lda AUX2 ; AD 84 01
sbc AUX1 ; ED 83 01
sta SCTNBR ; 8D DB 01
rts ; 60
L172E lsr A ; 4A
tax ; AA
dex ; CA
lda #$10 ; A9 10
clc ; 18
adc AUX2 ; 6D 84 01
sta AUX2 ; 8D 84 01
txa ; 8A
jmp L1716 ; 4C 16 17
CSTEP ldx #$80 ; A2 80
ldy #$00 ; A0 00
sec ; 38
bvs L174E ; 70 06
sbc PRTRK2 ; ED A1 01
jmp L1751 ; 4C 51 17
L174E sbc PRSTRK ; ED CE 01
L1751 beq L175D ; F0 0A
bpl L175C ; 10 07
ldx #$00 ; A2 00
eor #$FF ; 49 FF
clc ; 18
adc #$01 ; 69 01
L175C tay ; A8
L175D rts ; 60
STPTST beq L177A ; F0 1A
L1760 jsr STEP ; 20 88 10
beq L176D ; F0 08
L1765 lda TIM1R ; AD 95 03
bpl L1765 ; 10 FB
jmp L1760 ; 4C 60 17
L176D lda #$14 ; A9 14
L1772 lda TIM1R ; AD 95 03
bpl L1772 ; 10 FB
L177A rts ; 60
SAA bit PORTB1 ; 2C 82 03 ssa
bvs SAA ; 70 FB
SAA1 lda #$41 ; A9 41 ACK
SAA2 sta TMPOUT ; 8D 86 01
rts ; 60
;Open serial out port
SETOP ldx PORTB1 ; AE 82 03
inx ; E8
rts ; 60
; 11 byte id field
IDFLD .byte $A1,$A1,$A1,$FE,$FF,$00,$FF,$01
.byte $FF,$FF,$4E
; sector table. where is sector 1???
SCTRS .byte $0A,$09,$12,$08,$11,$07,$10,$06
.byte $0F,$05,$0E,$04,$0D,$03,$0C,$02
.byte $0B
CDLT .byte $AA,$A9,$A4,$A5,$92,$91,$94,$95
.byte $4A,$49,$44,$45,$52,$51,$54,$55
.byte $2A,$29,$24,$25,$12,$11,$14,$15
L17D9 .byte $04,$D0,$02,$00,$01,$07,$0C,$00
.byte $00,$00,$AA,$55,$00,$00,$00,$00
.byte $00,$00,$00,$00,$00,$00,$00,$00
.byte $00,$00,$00
* = $17FC
.word $0800,$0800
I noticed that the original post from Curt was a bit truncated for some reason. The full listing was shared with me and after speaking with Curt, he gave permission to publish it here.
        .TITLE DUAL 815 DISK CONTROLLER
;       *   815 DUAL DISK CONTROLLER    *
;  PROGRAMMER:  BOB WARNE
;  ADDITIONAL COMMENTS, LABELS & EQUATES BY DAVE STAUGAS
        .ENABLE AMA
        .RADIX  10
        .ASECT
;       MEMORY MAP:
;   0000-00FF  RAM (USED FOR DATA BUFFER)
;   0100-0101  SYNCHRONOUS SERIAL DATA ADAPTER REGISTERS (MOTOROLA MC68B52)
;   0180-01FF  RAM (STACK AND PROGRAM SCRATCH)
;   0200-021F  MAPS TO PIA #2
;   0280-029F  MAPS TO PIA #3
;   0380-039F  MAPS TO PIA #1
;   0800-0FFF  CONTROLLER ROM (PART #1)
;   7000-77FF  CONTROLLER ROM (PART #2)
;  EQUATES^H
BIT7    =       ^H080
BIT6    =       ^H040
BIT5    =       ^H020
BIT4    =       ^H010
BIT3    =       ^H008
BIT2    =       ^H004
BIT1    =       ^H002
BIT0    =       ^H001
;  PAGE 0
ZPRL    =       ^H0000          ;START OF ZERO PAGE DATA BUFFER
ZP80    =       ^H0080
ZP91    =       ^H0091
FRMCRC  =       ^H00A0
ZPCRC   =       ^H00AE
ZPNTL   =       ^H00C0
ZPNTH   =       ^H00C1
SCTPT   =       ^H00F6
CRCLP   =       ^H00F7
IDAM    =       ^H00F8
TRKNO   =       ^H00F9
BYTE00  =       ^H00FA
SCTNO   =       ^H00FB
BYTE01  =       ^H00FC
CRC1    =       ^H00FD
CRC2    =       ^H00FE
BYTE4E  =       ^H00FF
        .=      ^H0100          ;START OF SSDA HARDWARE SPACE
;  THE NEXT TWO ADDRESSES MAP TO THE MOTOROLA MC68B52 (SSDA)
;     DATA BITS ARE REVERSED (0 -> 7, 1 -> 6, 2 -> 5, ETC)
;       FROM THE BIT DEFINITIONS IN THE LITERATURE SO THAT
;       SERIAL DATA IS SHIFTED MSB FIRST.
SSDA0:  .=.+1
;  WHEN READ, THIS ADDR IS A STATUS REGISTER.
;    BITS FOR THIS REGISTER ARE DEFINED:
;  7 - RECEIVER DATA AVAILABLE (RDA)
;  6 - TRANSMITTER DATA REGISTER AVAILABLE (TDRA)
;  5 - DATA CARRIER DETECT BAR (DCD)
;  4 - CLEAR TO SEND BAR (CTS)
;  3 - TRANSMITTER UNDERFLOW (TUF)
;  2 - RECEIVER OVERRUN (RX OVRN)
;  1 - RECEIVER PARITY ERROR (PE)
;  0 - INTERRUPT REQUEST (IRQ)
;  BIT EQUATES FOR SSDA0 (READ):
RDA     =       BIT7            ;RECEIVER DATA AVAILABLE
TDRA    =       BIT6            ;TRANSMITTER DATA REGISTER AVAILABLE
DCD     =       BIT5            ;DATA CARRIER DETECT BAR
CTS     =       BIT4            ;CLEAR TO SEND BAR
TUF     =       BIT3            ;TRANSMITTER UNDERFLOW
RXOVRN  =       BIT2            ;RECEIVER OVERRUN
PE      =       BIT1            ;RECEIVER PARITY ERROR
IRQ     =       BIT0            ;INTERRUPT REQUEST
;  WHEN WRITTEN, THIS ADDRESS IS CONTROL REGISTER #1
;  7 - RECEIVER RESET (RX RS)
;  6 - TRANSMITTER RESET (TX RS)
;  5 - STRIP SYNCH CHARACTERS (STRIP SYNCH)
;  4 - CLEAR SYNCH
;  3 - TRANSMITTER INTERRUPT ENABLE (TIE)
;  2 - RECEIVER INTERRUPT ENABLE (RIE)
;  1 - ADDRESS CONTROL #1 (AC1)
;  0 - ADDRESS CONTROL #2 (AC2)
;  BIT EQUATES FOR SSDA0 (WRITE):
RXRS    =       BIT7            ;RECEIVER RESET
TXRS    =       BIT6            ;TRANSMITTER RESET
STRIPS  =       BIT5            ;STRIP SYNCH CHARACTERS
CLEARS  =       BIT4            ;CLEAR SYNCH
TIE     =       BIT3            ;TRANSMITTER INTERRUPT ENABLE
RIE     =       BIT2            ;RECEIVER INTERRUPT ENABLE
AC1     =       BIT1            ;ADDRESS CONTROL #1
AC2     =       BIT0            ;ADDRESS CONTROL #2
SSDA1:  .=.+1
;  A READ OF THIS ADDRESS ACCESSES DATA FROM THE SSDA RECEIVE
;  DATA FIFO.
;  A WRITE TO THIS ADDRESS ACCESSES ANY OF 4 INTERNAL REGISTERS
;  WHICH ARE SELECTED BY WRITING APPROPRIATE DATA TO THE AC1, AC2
;  DATA BITS IN CONTROL REGISTER #1.
;  BIT DEFINITIONS FOR THE FOUR WRITE ONLY REGISTERS:
;   AC1=0 & AC2=0 SELECT CONTROL REGISTER #2:
;  7 - PERIPHERAL CONTROL #1 (PC1)   ALWAYS 1
;  6 - PERIPHERAL CONTROL #2 (PC2)   ALWAYS 0
;  5 - 1 BYTE/2 BYTE TRANSFER        ALWAYS 0 (TWO BYTE)
;  4 - WORD LENGTH SELECT 1  (WS1)   ALWAYS 1
;  3 - WORD LENGTH SELECT 2  (WS2)   ALWAYS 1
;  2 - WORD LENGTH SELECT 3  (WS3)   ALWAYS 0
;  1 - TRANSMIT SYNCH CODE ON UNDERFLOW     1
;  0 - ERROR INTERRUPT ENABLE   (EIE)       1
;  BIT EQUATES FOR CONTROL REGISTER #2:
PC1     =       BIT7            ;PERIPHERAL CONTROL #1
PC2     =       BIT6            ;PERIPHERAL CONTROL #2
BYTE12  =       BIT5            ;1 OR 2 BYTE TRANSFER
WS1     =       BIT4            ;WORD LENGTH SELECT #1
WS2     =       BIT3            ;WORD LENGTH SELECT #2
WS3     =       BIT2            ;WORD LENGTH SELECT #3
TXSUND  =       BIT1            ;TRANSMIT SYNCH ON UNDERFLOW
EIE     =       BIT0            ;ERROR INTERRUPT ENABLE
;   AC1=1 & AC2=0 SELECTS CONTROL REGISTER #3
;  7 - EXTERNAL/INTERNAL SYNCH MODE CONTROL (E/I SYNCH)  =0
;  6 - 1 SYNCH CHAR/2 SYNCH CHAR MODE CONTROL            =0
;  5 - CLEAR CTS BAR STATUS                              =0
;  4 - CLEAR TRANSMITTER UNDERFLOW STATUS (CTUF)         =0
;  3 - NOT USED
;  2 - NOT USED
;  1 - NOT USED
;  0 - NOT USED
; BIT EQUATES FOR CONTROL REGGISTER #3
EISYNC  =       BIT7            ;EXTERNAL/INTERNAL SYNCH MODE CONTROL
SYNC12  =       BIT6            ;SYNCH CHAR MODE CONTROL
CCTS    =       BIT5            ;CLEAR CTS BAR STATUS
CTUF    =       BIT4            ;CLEAT TUF STATUS
;  AC1=0 & AC2=1 SELECTS SYNCH CODE REGISTER
;  AC1=1 & AC2=1 SELECTS TRANSMIT DATA FIFO
        .=      ^H0180          ;START OF STACK & SCRATCH RAM
STPNT:  .=.
RAM3:   .=.+1
;  NEXT FIVE BYTES ARE SAVE AREA FOR COMMAND FRAME INPUT
UNITNB: .=.+1                   ;DRIVE UNIT # (ASCII)
CTLCMD: .=.+1                   ;CONTROLLER COMMAND
AUX1:   .=.+1                   ;LSB OF 16-BIT LOGICAL SECTOR #
AUX2:   .=.+1                   ;MSB OF 16-BIT LOGICAL SECTOR #
RCDCSM: .=.+1                   ;COMMAND FRAME CHECKSUM
TMPOUT: .=.+1                   ;ALL SERIAL OUTPUT SHIFTED FROM THIS ADDR
DICKSM: .=.+1                   ;DATA FIELD CHECKSUM TEMP
        .=.+8                   ;SPARE
; NEXT 4 BYTES SENT TO COLLEEN FOR STATUS COMMAND ON BOTTOM DRV
STFLG2: .=.+1                   ;BOTTOM DRV STATUS FLAGS
DEVST2: .=.+1                   ;BOTTOM DRV XTRA STATUS
WCTLB2: .=.+1                   ;BOTTOM DRV WORST CASE TIMEOUT (LSB)
WCTMB2: .=.+1                   ;DELAY (MSB)
;       NEXT 2 BYTES ARE CODES FOR PORTB2:
EGON:   .=.+1                   ;ERASE GATE TURN ON CODE
WGOFF:  .=.+1                   ;WRITE GATE TURN OFF CODE (LEAVES EG ON)
;       NEXT 2 BYTES ARE USED FOR CRC GENERATION:
BAKER:  .=.+1                   ;CRC GENERATION SCRATCH 1
ABLE:   .=.+1                   ;CRC GENERATION SCRATCH 2
GAPBYT: .=.+1                   ;BYTE INIT'D TO $4E FOR CRC WRITE
DH80T:  .=.+1                   ;DOUBLE HEAD & 80 TRK TEST BYTE
;   7 - DOUBLE=1 / SINGLE=0 HEAD DRIVE
;   6 - 80 TRK=1 / 40 TRK=0 TRACK DENSITY
;  BIT EQUATES:
DBLHED  =       BIT7            ;DOUBLE/SINGLE HEADED DRVS
TPI96   =       BIT6            ;TRACK DENSITY BIT
        .=.+3                   ;SPARE
STPDIR: .=.+1
RDCRC2: .=.+1
RDCRC1: .=.+1
STPNB2: .=.+1                   ;# OF STEPS TO DESIRED TRACK, BOTTOM DRV
PRTRK2: .=.+1                   ;PRESENT TRACK #, BOTTOM DRV
SPSDC2: .=.+1                   ;LOOP COUNTER FOR BOTTOM DRV SHUTDOWN TIMER
SPMDC2: .=.+1
SCRT1:  .=.+1
SCRT2:  .=.+1
SCTTBL: .=.+11                  ;START OF 11-BYTE ID FIELD
SPMDLC: .=.+1                   ;1 SEC LOOP COUNT FOR SPM SHUT-OFF (4 * 125 MS)
        .=.+27                  ;SPARE
STPSCR: .=.+1                   ;STEP ROUTINE SCRATCH
PRSTRK: .=.+1                   ;PRESENT TRACK #, TOP DRV
STPNBR: .=.+1                   ;# OF STEPS TO DESIRED TRK #, TOP DRV
;  THE NEXT 4 BYTES SENT TO COLLEEN FOR STATUS COMMAND, TOP DRV
STFLGS: .=.+1                   ;STATUS FLAGS (TOP DRV) SHIPPED TO COLLEEN
; BIT DEFINITIONS FOR CONTROLLER STATUS FLAGS BYTE:
;  7 - TRACK DENSITY            (0=40 TRK, 1=80 TRK)
;  6 - SERIAL BAUD RATE         (0=19.2KB, 1=38.4KBAUD)
;  5 - SECTOR SIZE              (0=128B/S, 1=256 BYTES/SECTOR)
;  4 - MOTOR/SELECT LITE STATUS (0=OFF,    1=ON)
;  3 - WRITE PROTECT STATUS     (1=WRITE PROTECTED)
;  2 - READ/WRITE ERROR         (SET IF ERROR, LAST R/W)
;  1 - INVALID DATA FRAME               "       "
;  0 - INVALID COMMAND FRAME            "       "
; BIT EQUATES FOR STFLGS:
TRK80   =       BIT7            ;TRACK DENSITY
BAUD38  =       BIT6            ;SERIAL BAUD RATE
SEC256  =       BIT5            ;SECTOR SIZE
MTR0    =       BIT4            ;MOTOR ON STATUS
WPS0    =       BIT3            ;WRITE PROTECT
RWE0    =       BIT2            ;READ/WRITE ERROR
INVDF0  =       BIT1            ;INVALID DATA FRAME ERROR
INVCF0  =       BIT0            ;INVALID COMMAND FRAME ERROR
DEVSTA: .=.+1                   ;TOP DRV EXTRA STATUS
; BIT DEFINITIONS FOR EXTRA STATUS BYTE:
;  7 - N/A
;  6 - N/A
;  5 - N/A
;  4 - NO ID MARK?
;  3 - N/A
;  2 - N/A
;  1 - N/A
;  0 - N/A
; BIT EQUATES FOR DEVSTA:
NOID    =       BIT4            ;NO ID MARK FOUND?
DUM10   =       BIT3            ;???
WCTLSB: .=.+1                   ;WORST CASE TIMEOUT SENT TO COLLEEN (LSB)
WCTMSB: .=.+1                   ;(MSB)
PACNTR: .=.+1                   ;R/W ERROR RETRY COUNT
        .=.+2                   ;SPARE
SSCTMS: .=.+1                   ;MSB,16-BIT LOGICAL SECTOR # (SECTOR BREAKDOWN)
SSCTLS: .=.+1                   ;LSB, SAVED BY SEC BRKDWN BUT NOT USED
        .=.+1                   ;SPARE
TRKNBR: .=.+1                   ;TRACK # COMPUTED IN SECTOR BREAK-DOWN
SCTNBR: .=.+1                   ;SECTOR # FROM SECTOR BREAK-DOWN
INMODE: .=.+1                   ;INTERNAL MODE REGISTER
;  BIT DEFINITIONS FOR INMODE:
;  7 - 19.2/38.4 KBAUD SERIAL DATA RATE (19.2 KBAUD = 1)
;  6 - DRIVE SELECT (TOP DRIVE = 1, BOTTOM DRIVE = 0)
;  5 - SIDE SELECT (FOR DUAL HEADED DRIVES, SIDE0=0, SIDE1=1)
;  4 - N/A
;  3 - N/A
;  2 - SPM2 NOT ON >1 SEC IF SET
;  1 - N/A
;  0 - IF SET, WITHIN COMMAND INPUT ROUTINE (ALSO USED FOR DATA/CMD FRAME
;                                       CHECKSUM ROUTINE SELECT)
; BIT EQUATES FOR INMODE:
BAUD19  =       BIT7            ;SERIAL DATA RATE SELECT
TOPDRV  =       BIT6            ;DRIVE SELECT
SIDE1   =       BIT5            ;SIDE SELECT
DUM1    =       BIT4            ;DUMMY BIT NOT USED
DUM2    =       BIT3            ;DUMMY BIT NOT USED
S2NRDY  =       BIT2            ;BOTTOM DRV, SPM NOT READY
DUM3    =       BIT1            ;DUMMY BIT NOT USED
CMDFIN  =       BIT0            ;COMMAND FRAME INPUT
CRCTST  =       BIT0            ;CRC TESTING INDICATOR
DUM11   =       BIT0            ;DUMMY BIT USED
INSTAT: .=.+1                   ;INTERNAL STATUS REGISTER
;  BIT DEFINITIONS FOR INTERNAL STATUS REGISTER:
;  7 - RECEIVING NEW COMMAND WORDS IF SET
;  6 - BUSY, SET WHENEVER GOING TO A ROUTINE THAT WILL KEEP US
;         AWAY FROM THE COMMAND FRAME MONITOR MORE THAN 400 MS
;  5 - SHUTDOWN IN PROGRESS, WHEN SET INDICATES CONTROL SHOULD RTS
;         FROM MAIN MONITOR--DOES NOT INDICATE 400 MS ABSENCE
;  4 - NO DISK
;  3 - FORMAT ERROR IF SET, AND READ AFTER WRITE FLAG!
;  2 - SPINDLE MOTOR HAS NOT BEEN ON 1 SEC IF SET
;  1 - COMMAND RECEIVE ERROR IF SET
;  0 - IF SET, COLLEEN HAS NOT BEEN WITH US 100 MS+
; BIT EQUATES FOR INSTAT:
RECCMD  =       BIT7            ;RECEIVING COMMAND
BUSY    =       BIT6            ;CONTROLLER BUSY
SHTDWN  =       BIT5            ;SHUTDOWN IN PROGRESS
NODISK  =       BIT4            ;NO DISK
FMTER   =       BIT3            ;FORMAT ERROR
RDAFWR  =       BIT3            ;READ AFTER WRITE INDICATOR
S1NRDY  =       BIT2            ;SPM TOP DRIVE NOT READY
CRECR   =       BIT1            ;COMMAND RECEIVE ERROR
NO800   =       BIT0            ;COLLEEN HAS NOT BEEN WITH US
INSCRT: .=.+1                   ;LAST INDEX +1 TO TERMINATE INPUT OR CHECKSUM
TMRSCR: .=.+1                   ;TIMER SCRATCH
FSCTBP: .=.+1                   ;FORMAT VERIFY ERROR RETRY COUNT
BFRPNT: .=.+1                   ;FORMAT BAD SECTOR # BUFFER INDEX
        .=.+1                   ;SPARE
TMPSB:  .=.+1                   ;*2 TEMP STORAGE FOR SECTOR BUILD-UP
MSBSB:  .=.+1                   ;MSB FOR SECTOR BUILD-UP
CSSCRT: .=.+1
YSAVE:  .=.+1
        .=.+1                   ;SPARE
CTABL:  .=.+1                   ;JUMP INDIRECT ADDRESS FOR COMMAND INTERPRETER
CTABH:  .=.+1                   ;MSB
CISCRT: .=.+1                   ;COMMAND INTERPRETER SCRATCH
SPMSDC: .=.+1                   ;LOOP COUNTER FOR TOP DRV SHUTDOWN TIMER
        .=      ^H0200          ;START OF PIA #3 ADDR SPACE
PORTA3: .=.+1                   ;PORT A, ONBOARD PIA #3
;  BIT ASSIGNMENTS FOR PORT A, PIA #3:
;  7 - DRIVE ADDR DECODE                INPUT
;  6 - N/A
;  5 - N/A
;  4 - WRITE LIGHT, TOP DRIVE           OUTPUT
;  3 - READ LIGHT, TOP DRIVE            OUTPUT
;  2 - 96/48 TPI SENSE (96 = 0)         INPUT
;  1 - MOTOR ON/DRV SELECT, BOTTOM DRV  OUTPUT
;  0 - DRIVE ADDR DECODE 2              INPUT
; BIT EQUATES FOR PORTA3:
DRVAD1  =       BIT7            ;DRIVE ADDRESS DECODE #1
DUM4    =       BIT6            ;DUMMY BIT NOT USED
DUM5    =       BIT5            ;DUMMY BIT NOT USED
WLTOP   =       BIT4            ;WRITE LIGHT, TOP DRIVE
RLTOP   =       BIT3            ;READ LIGHT, TOP DRIVE
TPISNS  =       BIT2            ;TPI SENSE
SELBOT  =       BIT1            ;MOTOR ON/DRV SEL BOTTOM DRIVE
DRVAD2  =       BIT0            ;DRIVE ADDRESS DECODE #2
PADDR3: .=.+1                   ;PORT A, PIA #3 DATA DIRECTION CONTROL (1=OUTPUT TO PIA)
PORTB3: .=.+1                   ;PORT B, PIA #3
;  BIT DEFINITIONS FOR PORT B, PIA #3:
;  7 - DRIVE MANUFACTURER (=0 IF NOT MPI)       INPUT
;  6 - # OF HEAD(S) (DOUBLE HEADED IF =0)       INPUT
;  5 - BOTTOM DRV STEPPER MOTOR PHASE 4         OUTPUT
;  4 - BOTTOM DRV STEPPER MOTOR PHASE 3         OUTPUT
;  3 - BOTTOM DRV STEPPER MOTOR PHASE 2         OUTPUT
;  2 - BOTTOM DRV STEPPER MOTOR PHASE 1         OUTPUT
;  1 - EXTENDED PROM SPACE INSTALLED IF =0      INPUT
;  0 - INNER TRKS AMPLIFIER ADJUST (0=TRK>20)   OUTPUT
; BIT EQUATES FOR PORTB3:
DMANUF  =       BIT7            ;DRIVE MANUFACTURER
HEADNO  =       BIT6            ;# OF HEADS/DRV
SPBOT4  =       BIT5            ;BOTTOM STEPPER PHASE 4
SPBOT3  =       BIT4            ;BOTTOM STEPPER PHASE 3
SPBOT2  =       BIT3            ;BOTTOM STEPPER PHASE 2
SPBOT1  =       BIT2            ;BOTTOM STEPPER PHASE 1
XTPROM  =       BIT1            ;EXTENDED PROM SPACE
AMPADJ  =       BIT0            ;INNER TRACK AMPLIFIER ADJUST
PBDDR3: .=.+1                   ;DATA DIRECTION CONTROL, PORT B PIA #3
PIA3EC: .=.+1
TIMR3R  =       ^H0215
TIMR23  =       ^H021F
        .=      ^H0280          ;START OF PIA #2 ADDR SPACE
PORTA2: .=.+1                   ;PORT A, PIA #2
;  BIT DEFINITIONS FOR PORT A, PIA #2:
;  7 - WRITE LIGHT, BOTTOM DRIVE (0=ON)         OUTPUT
;  6 - READ LIGHT, BOTTOM DRIVE  (0=ON)         OUTPUT
;  5 - N/A
;  4 - BOTTOM DRIVE, BOTTOM HEAD READ (0=ON)    OUTPUT
;  3 - BOTTOM DRIVE, TOP HEAD READ    (0=ON)    OUTPUT
;  2 - N/A
;  1 - TOP DRIVE, BOTTOM HEAD READ (1=ON)       OUTPUT
;  0 - TOP DRIVE, TOP HEAD READ    (1=ON)       OUTPUT
; BIT EQUATES FOR PORTA2:
WLBOT   =       BIT7            ;WRITE LIGHT, BOTTOM DRV
RLBOT   =       BIT6            ;READ LIGHT, BOTTOM DRV
DUM7    =       BIT5            ;DUMMY BIT NOT USED
BDBHRD  =       BIT4            ;BOTTOM DRV, BOTTOM HEAD, READ
BDTHRD  =       BIT3            ;BOTTOM DRV, TOP HEAD, READ
DUM8    =       BIT2            ;DUMMY BIT NOT USED
TDBHRD  =       BIT1            ;TOP DRIVE, BOTTOM HEAD, READ
TDTHRD  =       BIT0            ;TOP DRIVE, TOP HEAD, READ
PADDR2: .=.+1                   ;DATA DIRECTION CONTROL REG, PORT A, PIA #2
PORTB2: .=.+1                   ;PORT B, PIA #2
;  BIT DEFINITIONS FOR PORT B, PIA #2:
;     (ALL BITS ENABLED WHEN 0)
;  7 - BOTTOM DRIVE, BOTTOM HEAD ERASE          OUTPUT
;  6 - BOTTOM DRIVE, BOTTOM HEAD WRITE          OUTPUT
;  5 - BOTTOM DRIVE, TOP HEAD ERASE             OUTPUT
;  4 - BOTTOM DRIVE, TOP HEAD WRITE             OUTPUT
;  3 - TOP DRIVE, BOTTOM HEAD ERASE             OUTPUT
;  2 - TOP DRIVE, BOTTOM HEAD WRITE             OUTPUT
;  1 - TOP DRIVE, TOP HEAD ERASE                OUTPUT
;  0 - TOP DRIVE, TOP HEAD WRITE                OUTPUT
; BIT EQUATES FOR PORTB2:
BDBHER  =       BIT7            ;BOTTOM DRIVE, BOTTOM HEAD ERASE
BDBHWR  =       BIT6            ;BOTTOM DRV, BOTTOM HEAD WRITE
BDTHER  =       BIT5            ;BOT DRV, TOP HEAD ERASE
BDTHWR  =       BIT4            ;BOT DRV, TOP HEAD WRITE
TDBHER  =       BIT3            ;TOP DRV, BOTTOM HEAD ERASE
TDBHWR  =       BIT2            ;TOP DRV, BOTTOM HEAD WRITE
TDTHER  =       BIT1            ;TOP DRV, TOP HEAD ERASE
TDTHWR  =       BIT0            ;TOP DRV, TOP HEAD WRITE
PBDDR2: .=.+1                   ;DATA DIRECTION CONTROL, PORT B, PIA #2
PIA2EC: .=.+1
TIMR2R  =       ^H0295
TIMR22  =       ^H029F
        .=      ^H0380          ;START OF PIA #1 ADDR SPACE
PORTA1: .=.+1                   ;PORT A, PIA #1
;  BIT DEFINITIONS FOR PORT A, PIA #1:
;  7 - SYNCH MATCH                              INPUT
;  6 - CLK RESET                                OUTPUT
;  5 - CTS BAR RESET                            OUTPUT
;  4 - WRITE PROTECT, TOP DRIVE                 INPUT
;  3 - MASTER RESET SSDA                        OUTPUT
;  2 - N/A
;  1 - MOTOR ON, DRIVE SELECT, TOP DRIVE        OUTPUT
;  0 - WRITE PROTECT, BOTTOM DRIVE              INPUT
; BIT EQUATES FOR PORTA1:
SYNCMT  =       BIT7            ;SYNCH MATCH
CLKRST  =       BIT6            ;CLK RESET
CTSRST  =       BIT5            ;CTS BAR RESET
WPTOP   =       BIT4            ;WRITE PROTECT, TOP DRV
MRSSDA  =       BIT3            ;MASTER RESET SSDA
DUM9    =       BIT2            ;DUMMY BIT USED IN PROGRAM
SELTOP  =       BIT1            ;MOTOR ON, DRV SELECT TOP DRV
WPBOT   =       BIT0            ;WRITE PROTECT, BOTTOM DRV
PADDR1: .=.+1                   ;DATA DIRECTION CONTROL, PORT A, PIA #1
PORTB1: .=.+1                   ;PORT B, PIA #1
;  BIT DEFINITIONS FOR PORT B, PIA #1:
;  7 - SERIAL DATA INPUT                        INPUT
;  6 - COMMAND FRAME                            INPUT (1=RECEIVING CMD FRAME)
;  5 - TOP DRIVE STEPPER MOTOR PHASE 4          OUTPUT
;  4 - TOP DRIVE STEPPER MOTOR PHASE 3          OUTPUT
;  3 - TOP DRIVE STEPPER MOTOR PHASE 2          OUTPUT
;  2 - TOP DRIVE STEPPER MOTOR PHASE 1          OUTPUT
;  1 - READY/VCC                                INPUT
;  0 - SERIAL DATA OUTPUT                       OUTPUT
; BIT EQUATES FOR PORTB1:
SERIN   =       BIT7            ;SERIAL DATA INPUT
CMDFRM  =       BIT6            ;COMMAND FRAME
SPTOP4  =       BIT5            ;TOP DRV, STEPPER 4
SPTOP3  =       BIT4            ;TOP DRV, STEPPER 3
SPTOP2  =       BIT3            ;TOP DRV, STEPPER 2
SPTOP1  =       BIT2            ;TOP DRV, STEPPER 1
RDY     =       BIT1            ;READY/VCC
SEROUT  =       BIT0            ;SERIAL DATA OUTPUT
PBDDR1: .=.+1                   ;DATA DIRECTION CONTROL FOR PORT B, PIA #1
PIA1EC: .=.+1
TIMR1R  =       ^H0395
TIMR3   =       ^H039E
TIMR2   =       ^H039F
;  PAGE 8
; THE FOLLOWING ARE ADDRESSES INTO A JUMP TABLE FOR 38 KBAUD SERIAL
;  AND DOUBLE HEADED DRIVES ROUTINES.  THE TABLE WILL ULTIMATELY
;  RESIDE AT 800 HEX.
XTND0   =       ^H0800
XTND1   =       ^H0803
XTND2   =       ^H0806
XTND3   =       ^H0809
XTND4   =       ^H080C
XTND5   =       ^H080F          ;FORMAT VERIFY FOR 38KBAUD, DOUBLE HEAD, OR 96 TPI
XTND6   =       ^H0812          ;SECTOR # VALIDITY TEST, > 720
XTND7   =       ^H0815
XTND8   =       ^H0818          ;DATA FIELD INPUT, 38K BAUD
XTND9   =       ^H081B
XTND10  =       ^H081E          ;SIDE 2 CLRS?
XTND11  =       ^H0821
XTND12  =       ^H0824
XTND13  =       ^H0827
XTND14  =       ^H082A
;  MISCELLANEOUS EQUATES
TIMOUT  =       224             ;WORST CASE TIME OUT VALUE TO SHIP TO COLLEEN
MAXTRK  =       39              ;MAXIMUM TRACK #, THIS TIME AROUND
ACK     =       'A              ;ACKNOWLEGE CODE
NAK     =       'N              ;NEGATIVE ACKNOWLEGE
CMPLT   =       'C              ;COMMAND COMPLETE CODE
ERROR   =       'E              ;COMMAND EXECUTION ERROR
;       COMMANDS SUPPORTED BY CONTROLLER
DOWNL   =       ^H020           ;DOWN LOAD
FORMT   =       ^H021           ;FORMAT DISK
WRINOV  =       ^H050           ;WRITE SECTOR WITHOUT VERIFY
RDSPIN  =       ^H051           ;CONTINUOUSLY READ A SECTOR (FOR TESTING ALIGNMENT)
READSC  =       ^H052           ;READ A SECTOR
STATCD  =       ^H053           ;STATUS COMMAND
READAD  =       ^H054           ;READ FROM ADDRESS
MTRDLY  =       ^H055           ;MOTOR ON DELAY 30 SEC
VERIFY  =       ^H056           ;VERIFY A SECTOR AGAINST INPUT DATA
WRIVER  =       ^H057           ;WRITE A SECTOR WITH VERIFY
;  DATA PATTERNS USED FOR FORMATTING:
DAM     =       ^H0FB           ;DATA ADDRESS MARK
;       START OF ROM BASED PROGRAM
        .=^H00800
;       POWER-ON INTIALIZATION
INIT:   CLD                     ;BINARY ARITHMETIC
        LDA     #BDBHRD+BDTHRD+TDBHRD+TDTHRD
        LDX     #255
        TXS                     ;STACK POINTER -> $1FF
        STA     PORTA2
        STX     PORTB2          ;INIT TO READ, ALL HEADS
        STX     PADDR2          ;ALL PORTA2 BITS ARE OUTPUT
        STX     PBDDR2          ;AND PORTB2 TOO
        LDA     #0
        STA     PORTA1          ;TURN OFF TOP DRV SPM
        STA     PORTA3          ;TURN OFF BOTTOM DRV TOO
        STA     PORTB3          ;CLEAR BOTTOM DRV STEPPER BITS
        LDA     #WLTOP+RLTOP+SELBOT
        STA     PADDR3          ;BITS SET FOR OUTPUT
        LDX     #CLKRST+CTSRST+MRSSDA+SELTOP
        STX     PADDR1          ;BITS SET FOR OUTPUT
        LDX     #SPTOP1+SPTOP2+SPTOP3+SPTOP4
        STX     PBDDR1          ;TOP DRIVE STEPPERS SET AS OUTPUT
        INX
        STX     PBDDR3          ;BOTTOM DRIVE STEPPERS (& BIT0) SET AS OUT
        LDX     #SPTOP4+SPTOP3
        STX     PORTB1          ;INIT STP PHASE,BOTH DRVS
        STX     PORTB3
        STX     PIA1EC
        STX     PIA3EC
        STX     PIA2EC
;       INITIALIZATION CONTINUED
INITC:  LDX     #CLKRST+CTSRST+MRSSDA
        STX     PORTA1          ;NABL RD CLK SWITCH,TUF LATCH
                                ;AND SSDA CHIP
        LDA     #RXRS+TXRS+CLEARS
        STA     SSDA0           ;REST REC(X)MIT. NABL C2 WRITE
        LDA     #PC1+WS1+WS2+TXSUND+EIE
        STA     SSDA1           ;INIT C2 REG
        LDA     #RXRS+TXRS+CLEARS+AC1
        STA     SSDA0           ;NABL C3 WRITE
        LDA     #0
        STA     SSDA1           ;INIT C3 REG
;  POWER ON RAM TEST
RAMTST: LDX     #127            ;128-BYTE BLOCKS TO TEST
RT1:    STA     ZPRL(X)
        STA     ZP80(X)
        STA     RAM3(X)         ;CLR & CHK 3 128 BYTE 6532'S
        CMP     ZPRL(X)
        BNE     RTERR
        CMP     ZP80(X)
        BNE     RTERR
        CMP     RAM3(X)
        BNE     RTERR
        DEX
        BPL     RT1
        BMI     PASRAM
RTERR:  LDA     #RLTOP          ;TOP READ LITE
RTERR1: STA     PORTA3          ;FLASH DRV1 RD LAMP FOR RAM
RTERR2: DEX                     ;FAILURE INDICATION
        BNE     RTERR2
        INY
        BNE     RTERR2
        EOR     #RLTOP
        BPL     RTERR1
;  WE PASSED
PASRAM: LDA     #NO800+S1NRDY   ;SET INSTAT FOR COLEN ABSNT
        STA     INSTAT          ;AND SPM UNSTABL
        LDA     #BAUD19+TOPDRV+S2NRDY   ;SET INMODE FOR 19K I/O ROUTS
        STA     INMODE          ;SPM2 UNSTBL,&DRIVE1 SEL
        LDA     #MAXTRK
        STA     PRTRK2          ;ASSUME DRIVE2 ON TRK 39
        STA     PRSTRK          ;ASSUME DRV1 ON TRK 39
        LDA     #4
        STA     SPMDLC          ;SET FOR 4 DELAYS OF 125MS EACH
                                ;FOR SPM STABL
        LDA     #TIMOUT&255
        STA     WCTLSB
        STA     WCTLB2
        LDA     #TIMOUT/256
        STA     WCTMSB       ;SET WORS CASE TIMOUT STAT BYTES
        STA     WCTMB2       ;FOR BOTH DRIVE 1 AND 2
        STA     DEVSTA     ;CLR ALL CONTROLR STAT DRV1
        STA     DEVST2     ;DITTO FOR DRV2
        STA     SPMSDC       ;CLR SHUTDN TIME DRV1
        STA     SPSDC2       ;DITTO FOR DRV2
; COPY ID FIELD INTO RAM
        LDX     #10             ;11-BYTE ID FIELD
SCTSET: LDA     IDFLD(X)
        STA     SCTTBL(X)
        DEX
        BPL     SCTSET       ;PRLMNARY SETUP OF RD/WRTSET
                             ;SYNC DATA
        INX                     ;X=0
        LDY     #BAUD38+SEC256
        LDA     PORTB3
        AND     #XTPROM         ;CHECK EXTRA PROM FLAG
        BNE     INIT50
        JSR     XTND14          ;GO TO XTRA ROM FOR MOR DH/96
                                ;TPI AND 38K TSTING
INIT50: STY     STFLGS          ;SET DRV1 STAT TO REFLCT DH/96
                                ;TPI AND 38K CAPABILITIES
        STY     STFLG2          ;DITTO FOR DRV2
        STX     DH80T           ;SET FOR SGL HEAD, 40 TRACK
        JSR     CLRST           ;CLEAR ERROR FLAGS ON TOP DRV
        JSR     CLRST2          ;BOTTOM TOO
;       WARM START RE-ENTRY POINT
INIT2:  LDX     #255            ;REDO STACK POINTER
        TXS                     ;TO TOP OF STACK
        LDA     #^CWPS0
        JSR     CLRST1          ;CLEAR TOP DRV WP STATUS
        LDA     #^CWPS0
        JSR     CLRS12          ;BOTTOM DRV TOO
        LDX     #WPS0           ;GET WRITE PROTECT STATUS BIT IN X
        LDA     PORTA1          ;CHECK HARDWARE FOR STATUS
        TAY                     ;SAVE IN Y FOR BOTTOM DRV TEST
        AND     #WPTOP          ;CHECK TOP DRV WRITE PROTECT
        BEQ     INIT29          ;IF NOT PROTECTED, GOTO BOTTOM DRV CHECK
        TXA                     ;ELSE, GET WP FLAG IN ACCUM
        JSR     ORSTF           ;SET IT IN TOP DRV STATUS FLAGS
INIT29: TYA                     ;GET PORTA1 IN ACCUM AGAIN
        AND     #WPBOT          ;CHECK BOTTOM DRV WRITE PROTECT
        BEQ     INIT21          ;IF NOT PROTECTED, GET ON WITH INIT
        JSR     ORSTF2          ;SET IT IN BOTTOM DRV STATUS FLAGS
INIT21: LDX     #BDBHRD+BDTHRD+TDBHRD+TDTHRD
        STX     PORTA2       ;TURN OFF ALL LTS AND RD NABLS
        LDA     PORTA3
        AND     #^C<WLTOP+RLTOP>
        STA     PORTA3
        BIT     DH80T
        BPL     INIT22
        JSR     XTND10       ;GO TO XTRA ROM FOR SIDE2 CLRS
INIT22: LDA     #TOPDRV
        JSR     ORINMD        ;SET FOR DRV1 SRVICE
        LDA     #MAXTRK
        JSR     CSTEP        ;CALC STPS NEEDED FOR TRK 39 DRV
        STY     STPNBR       ;1 AND SAVE TMP
        LDA     #^CTOPDRV
        JSR     ANDNMD        ;SET FOR DRIV2 SRVICE
        LDA     #MAXTRK
        JSR     CSTEP        ;CALC STPS NEEDED FOR TRK 39,DRV
        STY     STPNB2       ;2 AND SAVE TMP
        LDA     #SHTDWN
        JSR     ORINST        ;SET SHUTDN BIT IN INTRNL STAT
        LDA     #^CRDAFWR
        JSR     ANINS
INIT3:  LDX     SPMSDC
        BEQ     INIT4        ;BRNCH IF DRV1 TIMED OUT
        LDA     #255
        STA     TIMR23       ;SET 125MS DELA
        DEX
        STX     SPMSDC       ;UPDATE AND SAV DRV1 TIMR SCRT
INIT4:  LDX     SPSDC2
        BEQ     INIT5        ;BRNCH IF DRV2 TIMED OUT
        LDA     #255
        DEX
        STX     SPSDC2       ;UPDATE AND SAV DRV2 TIMR SCRT
INIT5:  LDX     SPMSDC
        BNE     INIT6        ;BRNCH IF DRV1 NOT TIMED OUT
        LDX     #^H080
        LDY     STPNBR       ;GET SET TO STP DRV1
        BEQ     INIT11       ;BRNCH IF NO STPS NEEDED ON DRV1
        JSR     STEP1        ;STEP DRV1 AND SAV STP CNTR
        BEQ     INIT11       ;BRNCH IF LAST STP JUST DONE
INIT51: STY     STPNBR
INIT6:  LDX     SPSDC2
        BNE     INIT7        ;BRNCH IF DRV2 NOT TIMED OUT
        LDX     #^H080
        LDY     STPNB2       ;GET SET TO STP DRV2
        BEQ     INIT12       ;BRNCH IF NO STPS NEEDED ON DRV2
        JSR     STP2         ;STP DRV2 AND SAV STP CNTR
        BEQ     INIT12       ;BRNCH IF LAST STP JUST DONE
INIT61: STY     STPNB2
INIT7:  LDX     SPMSDC
        BNE     INIT8        ;BRNCH TO POLL TIMR IF DRV1 NOT
                             ;TIMED OUT
        LDX     SPSDC2
        BNE     INIT8        ;RNCH  TO POLL TIMR IF DRV2 NOT
                             ;TIMED OUT
        LDX     STPNBR
        BNE     INIT9        ;BRNCH TO POLL 5MS TIMR IF DRV1
                             ;NOT ON TRK 39
        LDX     STPNB2
        BNE     INIT9        ;BRNCH TO POLL 5MS TIMR IF DRV2
                             ;NOT ON TRK 39
INIT71: LDA     #^CSHTDWN
        JSR     ANINS        ;CLR SHUTDN BIT IN INTRNL STAT
        JMP     MMON         ;LEAVE THIS ROUT--POLL FOR CMND
INIT11: LDA     #CLKRST+CTSRST+MRSSDA
        STA     PORTA1       ;TURN OFF SPM1
        LDA     #S2NRDY
        JSR     ORINST        ;SET SPM1 UNSTBL BIT
        JMP     INIT51
INIT12: LDA     #0
        STA     PORTA3       ;TURN OFF SPM2
        LDA     #S2NRDY
        JSR     ORINMD        ;SET SPM2 UNSTBL BIT
        JMP     INIT61
INIT8:  BIT     TIMR3R
        BMI     INIT10       ;BRNCH IF 125MS UP
        JSR     MMON
INIT9:  BIT     TIMR1R
        BMI     INIT5        ;BRNCH IF 5MS UP
        JSR     MMON
        JMP     INIT9
INIT10: BIT     TIMR1R
        BMI     INIT13       ;BRNCH IF 5 MS UP
        JSR     MMON
        JMP     INIT10
INIT13: JMP     INIT3
;    MAIN MONITOR
;            MONITORS THE READY PORT FOR
;    COLLEEN PRESENCE. MONITORS THE CMND
;    FRAME,BRINGS IN 5 BYTE COMMAND, CHE
;    CKS FOR VALID CHECKSUM, CHECKS IF
;    CMND ADDRESS IS FOR FLOPPY BEFORE
MMON:   LDA     PORTB1
        LSR
        LSR
        BCS     NCOLL        ;TST RDY PORT &BRNCH IF COLEN AB
                             ;SENT
        LDA     INSTAT
        LSR
        BCS     JCOLL        ;TST IF COLEN PRSNT 100MS  BRNCH
                             ;IF NOT
        BIT     PORTB1       ;
        BVC     NOCF         ;TST FOR CMND FRAME  BRNCH IF NO
        BIT     INSTAT
        BVC     EDGE         ;BRNCH IF MISSED EDGE BY 400US
        LDA     #^H0A4
        JSR     TIMER
        BIT     PORTB1       ;WAIT 100MS,THEN TEST IF
        BVS     EDGE         ;CMND FRAME STILL PRESNT
NOCF:   LDA     INSTAT
        AND     #BUSY+SHTDWN
        BNE     MMX          ;TST TO JSR BACK TO BUSY OR
        JMP     MMON         ;SPIN IN MAIN MONITOR ROUT
MMX:    RTS
JCOLL:  LDA     #^H0A4
        JSR     TIMER
        LDA     #^CNO800
        JSR     ANINS        ;SET STAT TO REFLCT COLEN NOT
                             ;PRESNT 100MS
        JMP     MMON
NCOLL:  LDA     #NO800
        JSR     ORINST        ;SET INTRNL STAT NOT RDY BIT
        JMP     NOCF
EDGE:   LDA     #RECCMD
        JSR     ORINST        ;SET INTRNL STAT "NEW CMND BIT"
        LDX     #0
        LDA     #5
        STA     INSCRT       ;SET UP TO BRING IN CMND
        JSR     CINPUT
;   MAIN MONITOR (CONTINUED)
MMON1:  LDX     #0
        DEC     INSCRT       ;SET UP TO GEN CS ON 4 BYTE
        JSR     CDCKSM       ;CMND
        BEQ     CCMD         ;BRNCH IF CS OK
        LDA     #CRECR          ;SET COMMAND RECEIVE ERROR
        JSR     ORINST          ;IN INSTAT
CCMD:   LDA     PORTA3          ;CHECK DRIVE ADDR DECODE
        LSR                     ;CHECK DRV ADDR #2
        BCC     ADRDC3          ;IF SET, GOTO ADRDC3
        LDX     #'1
        ASL                     ;RESTORE PORTA3
        BMI     ADRDC5          ;IF DRV ADDR #1 IS SET, BRANCH
        LDX     #'5
ADRDC5: CPX     UNITNB
        BEQ     ADRDC7          ;BRNCH IF DRIV ADDRESED IS ODD
        INX
        CPX     UNITNB
        BEQ     ADRDC6          ;BRNCH IF EVEN DRIV ADRESED IS U
CCF:    BIT     PORTB1
        BVS     CCF             ;SPIN TIL COMND FRAM GONE
        LDA     #^C<RECCMD+CRECR>       ;CLR REC NEW CMND AND
        JSR     ANINS           ;CS ERR BITS
        JMP     MMON            ;RETURN TO MON SER BUS
ADRDC6: LDA     #^C<TOPDRV>
        JSR     ANDNMD          ;UPDATE INMODE FOR DRIV 2 SEL
ADRDC8: JSR     CMDI            ;GO COMMAND INTERP---FOR US
        JMP     MMON
ADRDC7: LDA     #TOPDRV
        JSR     ORINMD          ;UPDATE INMODE FOR DRIV 1 SEL
        BNE     ADRDC8
ADRDC3: LDX     #'3
        ASL
        BMI     ADRDC5
        LDX     #'7
        BNE     ADRDC5
;       COMMAND INTERPRETER
CMDI:   LDA     INSTAT          ;CHECK RECEIVE ERROR FLAG
        AND     #CRECR          ;MASK OFF OTHERS
        BNE     CMD2            ;IF CHECKSUM ERROR, GOTO INVALID CMD NAK
        LDA     CTLCMD          ;ELSE, FETCH CMD CODE FROM CMD FRAME
        LDX     #TBBT-TABB      ;MAXIMUM INDEX INTO LEGAL CMD CODE TABLE
XTAB:   CMP     TABB(X)         ;COMPARE REC'D CMD W/LEGAL CMD LIST
        BEQ     GTCMD           ;GOT A MATCH, GO EXECUTE
        DEX                     ;ELSE, DECREMENT INDEX
        BPL     XTAB            ;LOOP IF ^AANY LEGAL ENTRIES LEFT
        BMI     CMD2            ;NO, UNCONDITIONAL SEND INVALID CMD FRAME
GTCMD:  LDA     TABL(X)         ;YES, FETCH LO ADDR OF ROUT
        STA     CTABL           ;SAVE IN INDIRECT JUMP VECTOR
        LDA     TABH(X)         ;FETCH HI ADDR TOO
        STA     CTABH           ;SAVE IN HI ADDR OF VECTOR
        JMP     @CTABL          ;JUMP TO SELECTED COMMAND ROUTINE
CMD2:   LDA     #INVCF0         ;SET INVALID CMD FRAME FLAG
        JSR     OR0STX          ;IN PRESENT DRIVE STATUS BYTE
        JSR     MFUTST          ;SET SPM ON BIT IN STATUS TOO
CMD3:   BIT     PORTB1
        BVS     CMD3            ;WAIT TIL CMD FRAME GONE
        LDA     #NAK            ;LOAD NAK CODE
        JSR     SAA2            ;SEND IT TO COLLEEN
        LDA     #^CCRECR        ;CLEAR CMD RECEIVE ERROR FLAG
        JSR     ANINS           ; IN INTERNAL STATUS REGISTER
        RTS                     ;RETURN TO MAIN MONITOR
;       COMMAND INTERPRETER LOOK-UP TABLES
TABB:   .BYTE   DOWNL,FORMT,WRINOV,RDSPIN,READSC,STATCD,READAD,MTRDLY,VERIFY,WRIVER
TBBT    =.-1
TABL:   .BYTE   DOWNLD&255      ;DOWN LOAD
        .BYTE   FRMT&255        ;FORMAT
        .BYTE   WRITE1&255      ;WRITE, NO VERIFY
        .BYTE   RDSPN&255       ;READ SPIN
        .BYTE   READ&255        ;READ SECTOR
        .BYTE   STCMD&255       ;STATUS COMMAND
        .BYTE   RDADR&255       ;READ FROM ADDRESS
        .BYTE   MOTRON&255      ;MOTOR ON DELAY
        .BYTE   WRITE&255       ;VERIFY ENTERS AT WRITE
        .BYTE   WRITE&255       ;WRITE/VERIFY
TABH:   .BYTE   DOWNLD/256
        .BYTE   FRMT/256
        .BYTE   WRITE1/256
        .BYTE   RDSPN/256
        .BYTE   READ/256
        .BYTE   STCMD/256
        .BYTE   RDADR/256
        .BYTE   MOTRON/256
        .BYTE   WRITE/256
        .BYTE   WRITE/256
;       WRITE ROUTINE
WRITE:  LDA     #RDAFWR
        JSR     ORINST        ;SET INSTAT FOR READ AFTR WRITE
;  WRITE, NO VERIFY ENTRY POINT:
WRITE1: JSR     TSN          ;GO INSUR RECVD SECTR NUMBR VAL
        BCC     WR10         ;BRNCH IF SCTOR VALID
        JMP     WR91
WR10:   LDA     #^H04E
        STA     GAPBYT
        JSR     SETSUP
        BEQ     WR92         ;BRNCH IF NO STEPS NEEDE
        JSR     STEP
WR92:   STY     STPNBR       ;SAV TEMP NUMBR STEPS NEEDED
        STX     STPDIR       ;SAV STEP DIRECT TEMP
        JSR     INPUT        ;GO INPUT DATA FIELD,COMP,CALC-
                             ;-ULATE CS AND COMPAR CS'S
        BEQ     WR20         ;BRNCH IF NO CS ERR
WR5:    LDA     #MTR0+INVDF0
WR51:   JSR     OR0STX          ;SET SPM AND DATA FRAME ERROR FLGS
        JMP     INIT2
WR20:   JSR     SAA1         ;GO ACK DATA FIELD
        LDX     STPDIR
        LDY     STPNBR
        JSR     STPTST       ;GO EXECUT STEPS IF NEEDED
        JSR     SPMDY        ;INSURE SPM STABL
        LDA     CTLCMD
        CMP     #VERIFY         ;CHECK FOR VERIFY ONLY
        BNE     WR201        ;BRNCH IF HERE FOR WRITE
        JSR     CRCSUP
        JMP     WR30         ;GO DO VERFY
WR201:  JSR     WPTST
        BEQ     WR2          ;BRNCH IF NOT WP
        JMP     WR7
WR2:    JSR     CRCSUP
WRITE2: LDY     #0         ;Y SET TO INDICAT PASS
        JSR     SYNC         ;THRU SYNC LOOP FOR IDAM
        BNE     WR21         ;BRNCH IF HAV SYNC
        LDA     #NOID
        JSR     ORST1           ;UPDATE DEVICE STAT FOR NO ID
        JMP     WR8
WR21:   JSR     FWSL
        LDX     #12
        JSR     FSL
        LDX     EGON
        STX     PORTB2
        LDX     #5
        JSR     FSL
        JSR     FWSL1        ;GO XMIT REMAINDR OF DATA FIELD
                             ;GAP AND ID
        SEC                  ;CARRY MUST REFLECT LST BIT XMIT
                             ;ED.
        LDX     #0         ;CLR BUFR POINTR
        JSR     WSL          ;GO XMIT 128 BYTE BUFR THRU
                             ;CLK/DTA LOOKUP TBL
;       WRITE CRC'S
;   (CALLED ONLY ONCE BY WRITE ROUTINE, COULD BE "IN-LINE")
;     WCRC     WRITES 2 CRC'S FOR DATA FIELD
;              DURING WRITE ROUT. NOT USED B
;              BY FORMAT ROUT
WCRC:   LDX     #128-3          ;INDEX FOR 2 BYTES
WCRC1:  BIT     SSDA0
        BVC     WCRC1        ;POLL SSDA FOR XMIT REG AVAIL
        LDA     BAKER-<128-3>(X)
        ROR
        LSR
        LSR
        LSR
        TAY
        LDA     CDLT(Y)
        STA     SSDA1
        AND     #^H01F
        TAY
        LSR
        LDA     CDLT(Y)
        STA     SSDA1
        INX
        BPL     WCRC1
WSPIN:  LDA     SSDA0
        AND     #TUF
        BEQ     WSPIN        ;BRNCH TIL TUF SET IN STATREG
        LDA     #RDA+TDRA+CTS+PE+IRQ
        STA     SSDA0        ;REST XMIT
        LDA     PORTA1
        AND     #^CCTSRST
        STA     PORTA1       ;REST CTS FF
        ORA     #CTSRST
        STA     PORTA1       ;SET CTS FF
        LDA     WGOFF
        STA     PORTB2
        JSR     EGOFF
        LDA     INSTAT
        AND     #RDAFWR
        BEQ     WR36         ;BRNCH IF NO READ CHK REQIRED
WR30:   LDA     #READSC
        STA     CTLCMD
        JSR     RDWRLT
        JSR     WFRD         ;GO RD SCTR TO VRIFY
        BCS     WRITE9       ;BRNCH IF BAD WRITE VRIFY
WR36:   LDA     #MTR0
        JSR     OR0STX       ;UPDTE STAT FOR GOOD WRITE
        JSR     RDSUB
WR360:  LDA     #CMPLT
WR6:    JSR     SAA2            ;OUTPUT TO COLLEEN
        JMP     INIT2           ;GOTO SHUTDOWN
WR91:   LDA     #^CRDAFWR
        JSR     ANINS
        JMP     CMD2
WR7:    LDA     #MTR0+WPS0+RWE0 ;SET STATUS FOR WP
WR70:   JSR     OR0STX
        LDA     #ERROR         ;SET A FOR ERR
        JMP     WR6
WR8:    LDX     PACNTR
        BEQ     WRITE9       ;BRNCH TO GIV UP WRITE ATMPT
        JSR     ERRTRY       ;REPOSITON HEAD
        JMP     WRITE2       ;REATMPT WRITE
WRITE9: LDA     #MTR0+RWE0
        JMP     WR70         ;GO SET STATUS FOR ERR
WFRD:   LDA     #1
        STA     PACNTR       ;SET FOR 2 READ ATTEMPTS
WR3:    LDY     #0
        JSR     SYNC         ;LOOK FOR IDAM
        BNE     WR300        ;BRNCH IF HAV SYNC
        LDA     #NOID
        JMP     WR44
WR300:  JSR     RDSUB
        LDA     #3
        LDY     #1
        JSR     SYNC01       ;LOOK FOR DAM
        BEQ     WR34         ;BRNCH IF NO SYNC
        LDX     #0
WR31:   BIT     SSDA0
        BPL     WR31
        LDA     SSDA1
        CMP     #^H0FB
        BNE     WR34
        LDA     INMODE
        LSR
        BCS     WR40         ;BRNCH IF HERE ON FORMAT CHK
        LDA     SSDA1
        CMP     ZPRL(X)
        BNE     WR34         ;BRNCH IF ONE DATA FIELD WORD
                             ;ERR
WR32:   INX
WR33:   BIT     SSDA0
        BPL     WR33         ;BRNCH TIL RDA
        LDA     SSDA1
        CMP     ZPRL(X)
        BNE     WR34
        INX
        BEQ     WR37         ;BRNCH IF ALL DATA FIELD OK
        LDA     SSDA1
        CMP     ZPRL(X)
        BEQ     WR32
WR34:   DEC     PACNTR
        BPL     WR3          ;BRNCH TO RETRY READ CHK
        SEC
        RTS
WR37:   LDA     SSDA1
        CMP     BAKER
        BNE     WR43         ;BRNCH IF CRC1 NO MATCH
WR35:   BIT     SSDA0
        BPL     WR35
        LDA     SSDA1
        CMP     ABLE
        BNE     WR43
        JSR     RDSUB
        CLC                  ;CRY=NO ERR ON RETRN
        RTS
WR40:   LDA     SSDA1
        CMP     #^H0B6
        BNE     WR34         ;BRNCH IF ERR
WR41:   INX
WR42:   BIT     SSDA0
        BPL     WR42
        LDA     SSDA1
        CMP     #^H0B6
        INX
        BEQ     WR37         ;BRNCH IF 256 BYTES CHKD
        LDA     SSDA1
        CMP     #^H0B6
        BEQ     WR41         ;BRNCH IF NO ERR
        JMP     WR34
WR43:   LDA     #DUM10
WR44:   JSR     ORST1           ;SET BIT IN DEVICE STATUS
        JMP     WR34
;       READ ROUTINE
READ:   JSR     TSN             ;TEST FOR VALID SCT NUMBR
        BCC     READ01
        JMP     CMD2
READ01: JSR     SETSUP
        JSR     STPTST
        JSR     SPMDY        ;GO INSUR SPM STABL
READ0:  LDY     #0         ;Y SET TO INDICAT PASS THRU
        JSR     SYNC         ;SYNC LOOP FOR IDAM
        BNE     READ00
        LDA     #NOID           ;BIT IS IN DEVSTA
        JMP     RD35         ;UPDATE CNTRLR STAT FOR ERR
READ00: JSR     RDSUB
        LDY     #1         ;Y SET TO INDICATE PASS THRU
        LDA     #3
        JSR     SYNC01       ;SYNC LOOP FOR DAM
        BEQ     READ6        ;BRNCH IF NO SYNC
READ1:  BIT     SSDA0        ;POLL STATREG FOR RDA
        BPL     READ1
        LDA     SSDA1        ;SRVICE SSDA
        CMP     #DAM            ;FIRST WORD MUST BE DAM
        BNE     READ6        ;GO TO ERR IF NOT DAM
        LDA     SSDA1
        STA     ZPRL(X)       ;STOR IN XFER BUFR
READ2:  INX
READ3:  BIT     SSDA0        ;POLL STATREG FOR RDA
        BPL     READ3
        LDA     SSDA1
        INX
        BEQ     READ4        ;BRNCH IF BUFRS FUL
        LDA     SSDA1
        STA     ZPRL(X)
        JMP     READ2
READ4:  LDA     SSDA1
        STA     RDCRC1       ;SAVE CRC1
READ5:  BIT     SSDA0
        BPL     READ5
        LDA     SSDA1
        STA     RDCRC2       ;SAVE CRC2
        JSR     CRCSUP
        LDA     RDCRC1
        CMP     BAKER
        BNE     RD34
        LDA     RDCRC2
        CMP     ABLE
        BNE     RD34
RD31:   LDA     #MTR0
        JSR     OR0STX
RD32:   LDA     #CMPLT
RD33:   STA     TMPOUT
        JSR     SETOP
        JSR     BFROUT
        JMP     INIT2
RD34:   LDA     #DUM10
RD35:   JSR     ORST1         ;UPDATE CONTRLR STAT FOR ERR
READ6:  LDX     PACNTR
        BEQ     READ7        ;BRNCH TO GIV UP READ ATTEMPT
        JSR     ERRTRY       ;GO REPOSITION HEAD
        JMP     READ0        ;TRY TO READ AGAIN
READ7:  LDA     #MTR0+RWE0
        JSR     OR0STX       ;UPDATE STATUS TO REFLECT ERR
        LDA     #ERROR
        JMP     RD33         ;OUTPUT "E" TO COLEN
RDSUB:  LDA     #^C<NOID+DUM10>
        JSR     ANDST1
        RTS
;   DOWNLOAD
;             INPUTS 256 BYTES FROM COLN,
;    XECUTES PROGRAM THEN,STRTNG AT ZP00.
DOWNLD: JSR     SAA
        LDX     #1
        STX     AUX2
        JSR     INPUT
        BNE     DNLD6        ;BRNCH IF DATAFRAM ERR
        PHA
        JSR     ZPRL         ;GO XECUTE PROGRM
        BIT     INMODE
        BVC     DNLD2        ;BRNCH TO SET DRV2 STAT BYTES
        STA     STFLGS       ;SAV A(Y)(X),PS IN DRV1 STAT BYTES
        STX     STFLGS+1
        STY     STFLGS+2
        PLA
        STA     STFLGS+3
        JMP     DNLD4
DNLD2:  STA     STFLG2       ;SAV [email protected](Y),PS IN DRV2 STAT BYTEZ
        STX     STFLG2+1
        STY     STFLG2+2
        PLA
        STA     STFLG2+3
DNLD4:  LDA     #CMPLT
        JSR     SAA2
        JMP     INIT21
DNLD6:  JSR     MFUTST       ;UPDATuE SPM FLG BIT
        LDA     #2
        JMP     WR51         ;GO UPDATE STAT FOR DATA FRAM ER
;       READ-SPIN (ALIGNMENT TEST)
;   RDSPIN---TURNS ON SPM,RDLITE,&HD
;   NABL. SPINS TIL NXT CMD RECVD.
;   USED FOR TSTIN ONLY
RDSPN:  LDX     #READSC
        STX     CTLCMD
        JSR     SETSUP
        JSR     STPTST
        JMP     INIT71
;       READ FROM ADDRESS (128-BYTE)
RDADR:  CLC
        LDA     AUX1
        TAY
        ORA     AUX2
        BEQ     EXTST
        LDA     AUX2
        JMP     RDADR1
EXTST:  LDY     #XSTAT&255
        LDA     PORTB3
        AND     #XTPROM
        BNE     RDADR0
        SEC                  ;SET CRY IF XTNDED ROM INSTALD
RDADR0: LDA     #XSTAT/256
RDADR1: STY     ZPNTL
        STA     ZPNTH        ;SET 0-PGE POINTR
        LDY     #0
RDADRL: LDA     @ZPNTL(Y)
        STA     ZPRL(Y)       ;MOV 128 BYTES TO BUFRS
        INY
        BPL     RDADRL
        BCC     RDADR3
        JSR     XTND1        ;GO TO UPDATE IF X ROM INSTLD
RDADR3: LDX     #1
        STX     AUX1
        DEX
        STX     AUX2
        JMP     RD32
;    STATUS CMND
;           TESTS TO DETERMINE WHICH
;    DRIVE TO XMIT STATUS FOR, SENDS
;    4 BYTE STATUS AND CHKSM TO COL-
;    -LEEN WHICH RELECTS STATE OF
;    DRIVE DURING LAST COMMAND. UP-
;    DATES DRIVE STATUS UPON COMPLET-
;    -ION OF STATUS CMND
STCMD:  JSR     SAA          ;ACK CMND
        LDX     #4
        BIT     INMODE
        BVC     SCMD20       ;BRNCH IF CMND FOR DRV2
SCMD10: LDA     WCTMSB-4(X)     ;MOVE 4 BYTE STAT FOR DRV1
        STA     STPNT(X)      ;INTO MORE CONVENIENT LOC.
        DEX
        BNE     SCMD10
STCMD1: LDY     #4
        STY     INSCRT
        JSR     CDCKSM       ;GEN CS ON 4 BYTE STAT
        STA     RCDCSM
        LDA     #CMPLT
        STA     TMPOUT       ;SET TO XMIT "C"
        JSR     SETOP        ;OPEN SERIAL OUTPUT PORT
        LDX     #128-5          ;5 BYTES TO SEND
        JSR     OUTPUT
STCMD2: LDY     #15
STCMD3: DEY                  ;SET DELA OF
        BNE     STCMD3       ;74 MACH CYC
        LDY     UNITNB-<128-5>(X)
        STY     TMPOUT
        JSR     OUTPUT       ;OUTPUT 1 BYTE
        INX
        BPL     STCMD2
        JSR     RSTOUT       ;CLOSE OUTPUT PORT
        BIT     INMODE
        BVC     SCMD21       ;BRNCH IF CMND FOR DRV2
        JSR     CLRST        ;CLR ALL STAT BUT WP
        JSR     SPMFU        ;UPDATE DRV1 SPM FLG
        JMP     INIT2
SCMD20: LDA     WCTMB2-4(X)     ;MOVE 4 BYTE STAT FOR DRV2
        STA     STPNT(X)      ;INTO MORE CONVEINIENT LOC
        DEX
        BNE     SCMD20
        BEQ     STCMD1       ;FWR BUYTES THAN JMP
SCMD21: JSR     CLRST2       ;CLR ALL BUT BASIC STATUS FOR DR
                             ;VE 2
        JSR     SPM2FU       ;UPDATE DRV2 SPM FLG
        JMP     INIT2
;       FORMAT ROUTINE
FRMT:   JSR     SAA
        JSR     SPMON        ;TURN ON SPM IF NOT ALREADY
        JSR     RDWRLT
        JSR     SPMDY        ;INSURE MOTOR UP TO SPEED
        JSR     WPTST
        BEQ     CONFRM       ;TEST DISC NOT WP,IF NOT,BRNCH.
        LDA     #MTR0+WPS0+RWE0
        JSR     OR0STX
        LDA     #^H0FF
        STA     ZPRL         ;DS TRMS TO FRNT
        STA     ZPRL+1
        JMP     READ7
CONFRM: LDY     #MAXTRK+5
        JSR     REHME
        LDX     #^H0FE
        STX     IDAM         ;INIT ID FIELD LIST
        LDX     #^H04E
        STX     BYTE4E
        LDX     #0
        STX     BYTE00
        STX     TRKNO
        STX     SCTTBL+4
        INX
        STX     BYTE01
TRKLP:  JSR     STSUP2         ;GO TO TST FOR <20 TRK SWITCH
        LDX     #0
        STX     SCTPT
        STX     CRCLP
        INX
        STX     SCTTBL+6
FCRCLP: LDX     #^H0F8
        JSR     CRCGEN       ;GO GEN 2 BYTE CRC ON 5 BYTE ID
                             ;FIELD FOR THIS TRK,SCT NUMBER.
        LDX     CRCLP
        LDA     BAKER
        STA     FRMCRC(X)
        INX
        LDA     ABLE
        STA     FRMCRC(X)
        INX
        STX     CRCLP
        LDY     SCTPT
        LDX     SCTRS(Y)
        BIT     STFLGS
        BPL     FORM0
        JSR     XTND4      ;GO TO XTRA ROM IF 38K CAPABL
FORM0:  STX     SCTTBL+6
        INC     SCTPT
        CPY     #18
        BNE     FCRCLP       ;BRNCH IF MOR CRCS TO DO
        LDX     #0
        STX     SCTPT
        LDA     FRMCRC(X)
        STA     CRC1         ;STORE FIRST CRC IN ID LIST
        INX
        STX     SCTNO        ;REST SCT NUMBER TO 01
        LDA     FRMCRC(X)       ;STOR SECOND CRC IN ID LIST
        STA     CRC2
        STX     CRCLP        ;SAVE CRC LIST POINTER
FWT:    LDA     TIMR1R
        BPL     FWT          ;WAIT FOR LAST STEP TO SETTLE.
        JSR     STST1        ;WAIT 10MS FOR LAST STP SETL
        JSR     FWSL
        LDX     EGON
        STX     PORTB2       ;TURN ON ERASE GATE
        LDX     #255         ;SET X AS 255 BYTE COUNTER.
        JSR     FSL          ;GO XMIT 255 BYTES OF "4E"
        DEX                  ;SETS X TO FF AS X EQUALS 00 ON
                             ;RETURN FROM PREVIOUS JSR.
        DEX
        JSR     FSL          ;XMIT 255 BYTES OF "4E"
SCTLP:  LDA     #^H0AA
        TAY
        LDX     #8
        JSR     FSL          ;XMIT 8 BYTES OF "00". THIS IS S
                             ;ECOND HALF OF GAP3.
        LDA     #^H044
        LDY     #^H089
        LDX     #3
        JSR     FSL          ;XMIT 3 BYTES OF "A1". THIS IS
                             ;ID AM SYNC LEADER.
        LDA     #^H055
        LDY     #^H054
        LDX     #1
        JSR     FSL          ;XMIT 1 BYTE "FE". THIS IS ID AM
        LDX     #^H0F9
        CLC
        JSR     WSL          ;XMIT 7 BYTES OF ID FIELD THRU
                             ;ID FIELD TABLE.
        LDA     #^H092
FONE:   BIT     SSDA0
        BVC     FONE
        STA     SSDA1
        LDY     #^H054
        STY     SSDA1        ;XMIT 1 BYTE "4G" FAST-LATE
        LDX     #18
        JSR     FSL          ;XMIT 20 MORE BYTES OF "4E". THI
                             ;S IS FIRST HALF GAP 2.
        INC     CRCLP
        LDX     CRCLP
        LDA     FRMCRC(X)       ;MOVE CRC1 FOR NXT SCTOR INTO
        STA     CRC1         ;ID FIELD LIST
        LDA     #^H0AA
        TAY
        LDX     #12
        JSR     FSL          ;XMIT 12 BYTES OF "00". THIS IS
                             ;LAST HALF OF GAP 2.
        INC     CRCLP
        LDX     CRCLP
        LDA     FRMCRC(X)       ;MOVE NXT CRC2 INTO ID
        STA     CRC2         ;FIELD LIST
        LDA     #^H044
        LDY     #^H089
        LDX     #3
        JSR     FSL          ;XMIT 3 BYTES "A1" THIS IS DAM
                             ;SYNC LEADER
        LDA     #^H055
        LDY     #^H045
        INX
        JSR     FSL          ;XMIT 1 BYTE "FB" THIS IS DAM.
        LDA     #^H045
        LDY     #^H014
        INX
        JSR     FSL          ;XMIT 1 BYTE "00"
        LDA     #^H045
        LDX     #^H0FF         ;XMIT 255 BYTES "00". THIS,PLUS
        JSR     FSL          ;PREVIOS XMIT=128 BYTE DATA FLD
        LDA     #^H045
        LDY     #^H029
        INX
                             ;XMIT 1 BYTE "48" THIS IS
        JSR     FSL          ;CRC1 FOR DATA FIELD OF ALL "00"
        LDA     #^H014
        LDY     #^H0AA
        INX
                             ;XMIT 1 BYTE "29" THIS IS
        JSR     FSL          ;CRC2 FOR DATA FIELD ALL "00"
        LDA     #^H092
        LDY     #^H054
        INX
                             ;XMIT 1 BYTE "4E" THIS IS
        JSR     FSL          ;1 BYTE OF GAP 3 FIRST HALF
        LDA     #^H092
        LDX     #23         ;XMIT 23 BYTES "4E" THIS
        JSR     FSL          ;COMPLETES FIRST HALF GAP3
        LDY     SCTPT
        LDX     SCTRS(Y)
        STX     SCTNO        ;MOV NXT SCTR IN
        INC     SCTPT
        CPY     #17         ;CHK FOR 18 SCTRS FRMTD
        BNE     JSCTLP       ;IF NOT, GO DO ANOTHER
        LDA     #RXRS+TXRS+CLEARS+AC1+AC2
        LDA     WGOFF
        STA     PORTB2       ;TURN OFF WG
        INC     TRKNO
        INC     SCTTBL+4
        JSR     EGOFF
        LDX     #MAXTRK+1
        LDA     DH80T
        BEQ     FONE1
        JSR     XTND3           ;GO TEST FOR MAX # OF TRKS TO FORMAT
FONE1:  CPX     TRKNO        ;CHK FOR ALL TRKS FORMATED
        BEQ     FTST
        LDX     #^H080         ;X MUST BE NEG VALUE BEFOR ENTRY
                             ;TO STEP ROUT TO STEP IN
        JSR     STEP
        JMP     TRKLP        ;GO FORMAT ANOTHR TRK
JSCTLP: JMP     SCTLP        ;MUST GO TO SCTLP FROM HERE BRNCH
                             ;OUT OF RANGE
;       FORMAT TEST
;    TESTS ALL SCTRS
;                    AFTR ACTUAL
;   FORMAT AND COMPILES LISTING OF
;   BAD SCTRS TO SEND TO COLEN AT
;   END. (63 BAD SCTRS MAX)
FTST:   LDA     #READSC
        STA     CTLCMD
        JSR     RDWRLT
        LDX     #0
        STX     BFRPNT
        LDY     #^H080
FT1:    LDA     SCTRS(X)      ;ALTRNATLY MOVE SCTR #'S
        STA     ZPRL(Y)       ;FROM ROM INTO BUFRS
        INY                  ;AT HEX LOC.0080 TO 0091
        INX                  ;INCLUSIV
        INX
        CPX     #18
        BNE     FT2
        LDX     #1
        STX     ZP91
FT2:    CPX     #17
        BNE     FT1
        DEC     SCTTBL+4
FT21:   LDX     #128
FT3:    LDA     ZPRL(X)
        INX
        STX     FSCTBP       ;SAV SCTR PNTR
        STA     SCTTBL+6
        JSR     STSUP1       ;DO CRC ON SCTR ID FIELD
        LDA     #^H060
        STA     ABLE
        LDA     #^H0B1
        STA     BAKER
        LDA     #DUM11
        JSR     ORINMD        ;SET LSB INMODE FOR WFRD
                             ;ROUT TSTING
        JSR     WFRD         ;READ 1 SCTR
        DEC     INMODE
        BCS     FT5          ;BRNCH IF SCTR READ ERR
FT4:    LDX     FSCTBP
        CPX     #128+18
        BNE     FT3          ;BRNCH IF MOR SCTRS TO READ
        LDY     SCTTBL+4
        BNE     FT40            ;BRANCH IF ALL TRKS NOT READ
        LDA     DH80T
        BEQ     FT6             ;BRANCH IF NOT DH OR 96 TPI DRVS
        JSR     XTND5
        JMP     FT6
FT40:   DEY
        STY     SCTTBL+4
        LDX     #0
        LDY     #1
        JSR     STPTST       ;STP TO NXT TRK
        JMP     FT21         ;CONT TST
FT5:    LDA     #FMTER
        JSR     ORINST        ;SET FORMAT ERR BIT INSTAT
;    TRACK/SECTOR CONVERSION TO
;    2 BYTE SECTOR NUMBER
SCTBU:  LDY     #0
        STY     MSBSB
        LDX     BFRPNT
        LDA     SCTTBL+4     ;GET TRK NMBR
        ASL
        STA     TMPSB        ;SAVE TIMES TWO
        ASL
        ROL     MSBSB
        ASL
        ROL     MSBSB
        ASL
        ROL     MSBSB
        ADC     TMPSB
        TAY
        LDA     #0
        ADC     MSBSB
        STA     MSBSB
        TYA
        CLC
        ADC     SCTTBL+6
        STA     ZPRL(X)
        LDA     #0
        ADC     MSBSB
        INX
        STA     ZPRL(X)
        LDA     DH80T
        BEQ     FT51
        JSR     XTND11          ;GOTO INCREASE SEC # FOR SIDE 2
FT51:   INX
        STX     BFRPNT
        CPX     #128-2
        BNE     FT4          ;BRNCH IF BAD SCTR BUFR NOT FULL
FT6:    LDA     #^H0FF
        LDX     BFRPNT
        STA     ZPRL(X)
        INX
        STA     ZPRL(X)
        STA     SCTTBL+4
        LDA     #FORMT
        STA     CTLCMD
        LDA     INSTAT
        AND     #FMTER
        BNE     FT7          ;BRNCH IF ANY BAD SCTRS
        JMP     RD31
FT7:    LDA     #^CFMTER
        JSR     ANINS        ;CLR FRMTERR BIT INSTAT
        JMP     READ7
;    FORMAT SERVICE LOOP
FSL:    BIT     SSDA0        ;POLL STATRG FOR XMITRA
        BVC     FSL
        STA     SSDA1        ;DBL LOAD TO SSDA--16 BITS
        STY     SSDA1        ;0F CLK/DTA=8 BIT WORD TO DISC
        DEX
        BNE     FSL          ;CONT SRVCE TIL X=00
        RTS
;       MOTOR DELAY 30 SECS
;   TURN ON SPM AND SETS FOR 30
;   SEC DELAY BEFORE SHUTOFF
MOTRON: JSR     SAA
        JSR     SPMON
        LDX     #255
        BIT     INMODE
        BVC     MON2
        STX     SPMSDC       ;SET DRV1 MOTR FOR 30 SEC DLA
        BVS     MON4
MON2:   STX     SPSDC2       ;SET DRV2 MOTR FOR 30 SEC DLA
MON4:   JMP     STCMD
;    STEP
;    DRIVE TO PERFORM 1 STEP ON. STEPS,
;    SETS UP 5MS TIMER BUT DOES NOT WAIT
STEP:   BIT     INMODE
        BVC     STP2         ;BRNCH IF HERE TO STEP DRIV2
;    REHOME HEAD
;    STEP ROUTINE
STEP1:  LDA     #^H0A0
        STA     TIMR3        ;SET FOR 5.25MS STEP WIDTH
        LDA     PORTB1
        AND     #SPTOP1+SPTOP2+SPTOP3+SPTOP4
        INX
        BMI     STPIN
        DEC     PRSTRK       ;STP TO OUTR TRK
        LSR
        STA     STPSCR
        AND     #BIT1
        BEQ     STEP2
        LDA     #SPTOP4
        ORA     STPSCR
        BPL     STEP3
STPIN:  INC     PRSTRK       ;STP TO INNR TRK
        ASL
        STA     STPSCR
        AND     #BIT6
        BEQ     STEP2
        LDA     #SPTOP1
        ORA     STPSCR
        BPL     STEP3
STEP2:  LDA     STPSCR
STEP3:  STA     PORTB1       ;THIS IS PHYSICAL STEP
        DEY                  ;Y=NUMBER OF STEPS TO GO
        RTS
STP2:   LDA     #^H0A0
        STA     TIMR3        ;SET FOR 5.25MS DELA
        LDA     PORTB3
        AND     #SPBOT1+SPBOT2+SPBOT3+SPBOT4
        INX
        BMI     STPIN2
        DEC     PRTRK2       ;STP TO OUTR TRK
        LSR
        STA     STPSCR
        AND     #BIT1
        BEQ     STEP22
        LDA     #SPBOT4
        ORA     STPSCR
        BPL     STEP32
STPIN2: INC     PRTRK2       ;STP TP INER TRK
        ASL
        STA     STPSCR
        AND     #BIT6
        BEQ     STEP22
        LDA     #SPBOT1
        ORA     STPSCR
        BPL     STEP32
STEP22: LDA     STPSCR
STEP32: STA     PORTB3       ;THIS IS PHYSICAL STEP
        RTS
;       SECTOR TEST
;          TESTS IF PRESENT CMND
;   SECTOR NUMR IS 1,2,OR3. SETS
;   CARRY IF SO FOR TESTING ON
;   RETURN TO BUFRS OUT OR INPUT.
SCTTST: LDX     #0
        CPX     SCTTBL+4
        CLC
        BNE     SCTST1       ;BRNCH IF PRESENT TRK# NOT 00
        LDA     SCTTBL+5        ;BRANCH IF ON SIDE 2
        BNE     SCTST1
        LDA     #3
        CMP     SCTTBL+6     ;TST IF PRSNT SCT 1,2,OR3
SCTST1: RTS
;   MOTOR STATUS UPDATE
;         TSTS TO DETRMIN WHICH DRV
;   TO UPDATE MOTR STAT ON. THEN,
;   UPDATES ONLY THAT STAT BIT
MFUTST: BIT     INMODE
        BVC     SPM2FU       ;BRNCH IF HERE TO UPDATE DRV2
                             ;MOTR STAT
SPMFU:  LDA     PORTA1
        LSR
        LSR
        LDA     #MTR0
        BCS     MFU1
        LDA     #0
MFU1:   JMP     ORSTF
SPM2FU: LDA     PORTA3       ;TST IF DRV 2 MOTER
        LSR                     ;ON
        LSR
        LDA     #MTR0
        BCS     MFU12        ;BRNCH IF DRV2 MOTR ON
        LDA     #0
MFU12:  JMP     ORSTF2       ;GO UPDATE DRV2 STATUS
;       ERROR HANDLING
;    ERRTRY    TSTS TO DETRMIN WHICH DRV
;              TO REPOSITION HEAD ON FOR
;    RD OR WRIT RETRY. EITHR REHOMES AND
;    REPOSITIONS OR STPS ONCE AND BACK.
ERRTRY: DEX
        STX     PACNTR
        TYA
        BNE     ERR2         ;BRNCH IF DAM NOT FOUND
        CPX     #2
        BNE     ERR2         ;BRNCH IF ONLY ONE PASS MADE
        LDY     #MAXTRK+5
        JSR     REHME        ;REHOME HEAD
        BMI     ERR6         ;ALWAYS BRNCH
ERR2:   CPX     #1
        BNE     ERR8         ;BRNCH IF THIS NOT THIRD ATMPT
        LDY     STPDIR
        BMI     ERR4         ;BRNCH TO STP IN AND BACK
        DEC     TRKNBR
        JSR     ERRSUB       ;STP OUT
        INC     TRKNBR
        BPL     ERR6         ;ALWAYS BRNCH TO STP BACK
ERR4:   INC     TRKNBR
        JSR     ERRSUB       ;STEP IN
        DEC     TRKNBR
ERR6:   JSR     ERRSUB       ;STP BACK
ERR8:   RTS
ERRSUB: LDA     TRKNBR
        JSR     CSTEP
        JSR     STPTST
        RTS
;       READ/WRITE LITE SELECT
;    RDWRLT       TSTS TO DETRMIN WHICH
;    READ HD TO NABL AND TRNS ON EITHR RD
;    OR WRIT LITE FOR PROPER DRV
RDWRLT: LDA     INMODE
        ASL
        BPL     RWLT4        ;BRNCH IF CMND FOR DRV2
        ASL
        BMI     RWLT1        ;BRNCH IF CMND FOR SIDE2
        LDX     #BDBHRD+BDTHRD+TDTHRD
RWLT1:  STX     PORTA2
        LDA     PORTA3
        STA     PORTA3
        LDX     CTLCMD
        CPX     #READSC
        BEQ     RWLT2
        ORA     #WLTOP
RWLT3:  STA     PORTA3
        RTS
RWLT2:  ORA     #RLTOP
        BNE     RWLT3           ;UNCONDITIONAL BRANCH (SAVE A BYTE)
RWLT4:  LDX     #RLBOT+BDBHRD+TDBHRD+TDTHRD
        ASL
        BMI     RWLT5        ;BRNCH IF CMND FOR SIDE2
        LDX     #RLBOT+BDTHRD+TDBHRD+TDTHRD
RWLT5:  TXA
        LDX     CTLCMD
        CPX     #READSC
        BEQ     RWLT6
        CLC
        ADC     #RLBOT          ;ADC?
RWLT6:  STA     PORTA2
        RTS
;    COMMANDS INPUT
;             INPUTS FROM COLLEEN TO
;    COMMANDS BUFRS. COMPLIMENTS DATA
;    RUNS AT 19.2K EXCEPT -- WHEN
;    INPUTTING DATA FIELD CS FOR INPUT
;    ROUTINE. MAY RUN AT 19.2K OR 38.4K
;    THEN
CHKIN:  LDA     PORTB1       ;NTR HERE FOR DATA FIELD CHKSM
        BPL     CHKIN
        BMI     CIN0         ;HAV CS STRT BIT,BRNCH
CINPUT: BIT     PORTB1
        BVC     CIN5         ;BRNCH IF CMD FRAM GONE--ERR
        BPL     CINPUT       ;BRNCH IF NO STRT BIT YET
CIN0:   LDA     INMODE
        AND     #BAUD19+CMDFIN
        CMP     #CMDFIN
        BEQ     CIN1         ;BRNCH IF RUNNING AT 38K SPEED
        LDY     #11
CNDLA1: DEY
        BNE     CNDLA1       ;DELA OF 54 M CYC
CIN2:   LDY     #128-8         ;SET BIT CNTR
CNDLA2: TYA                  ;SAVE BIT CNTR
        LDY     #14
CNDLA3: DEY
        BNE     CNDLA3       ;DELA OF 69 M CYC AT 19K, 9
                             ;M CYC AT 38K FOR BIT SPACE,
                             ;44 M CYC AT 38K FOR STRT BIT
        TAY                  ;RETREIV BIT CNTR
        LDA     PORTB1       ;RETREIV 1 BIT
        ROL                     ;SHIFT OUT CRY
        ROR     UNITNB(X)     ;ASSEMBL BIT TO PRSNT WORD
        INY
        BPL     CIN3         ;BRNCH TIL 8 BITS DONE
        LDA     UNITNB(X)
        EOR     #255
        STA     UNITNB(X)     ;COMPLMNT LAST BYTE IN
        INX
        CPX     INSCRT
        BNE     CIN4         ;BRNCH IF MORE BYTES TO BRING IN
        RTS
CIN1:   LDY     #128-8
        NOP
        LDY     #9
        BNE     CNDLA3       ;ALWAYS BRNCH
CIN3:   LDA     INMODE
        AND     #BAUD19+CMDFIN
        CMP     #CMDFIN
        BNE     CNDLA2       ;BRNCH IF RUNNING AT 19K SPEED
        TYA
        LDY     #2
        NOP
        NOP
        NOP
CIN4:   LDY     #13
CNDLA4: DEY
        BNE     CNDLA4       ;DELA 64 M CYC
        BEQ     CINPUT       ;ALWAYS BRNCH
CIN5:   JMP     CMD2         ;HAVE CMND FRAM ERR
;       CRC SETUP FOR DATA FIELD
CRCSUP: LDA     #CRCTST
        JSR     ORINMD          ;SET LSB IN INMODE FOR CRC TSTIN
        LDX     #0
        LDY     #^H0E2
        STY     BAKER
        LDY     #^H095
        STY     ABLE
        JSR     CRCETR
        LDA     #^CCRCTST
        JSR     ANDNMD        ;CLR LSB IN INMODE
        RTS
;       ERASE GATE OFF
;    EGOFF   TIMESOUT 832US BEFOR
;             TURNING OFF PROPR EG
EGOFF:  LDA     #^H01A
        STA     TIMR3        ;SET TIMR FOR 832US
EGOFF1: LDA     TIMR1R
        BPL     EGOFF1       ;WAIT FOR TIMR INTRUPuT
        LDA     #BDBHER+BDBHWR+BDTHER+BDTHWR+TDBHER+TDBHWR+TDTHER+TDTHWR
        STA     PORTB2       ;TURN OFF EG
        RTS
;     SETSUP
;              PRFORMS COMMON HOUSE
;     KEEPING FOR READ AND WRITE ROUTS.
SETSUP: JSR     SAA          ;ACK CMND
        JSR     RDWRLT
        LDA     #3              ;ERROR RETRY COUNT
        STA     PACNTR
        JSR     SCTBD        ;CONVRT RECEIVD SEC TO TRK/SEC
STSUP0: LDA     SCTNBR
        STA     SCTTBL+6     ;INIT SYNCTBL
        LDA     TRKNBR
        STA     SCTTBL+4
STSUP1: LDX     #^H0F8
        JSR     CRCGEN
        LDX     BAKER
        STX     SCTTBL+8        ;CRC1
        STA     SCTTBL+9        ;CRC2
STSUP2: LDA     PORTB3
        LDX     SCTTBL+4     ;GET TRK NMBR GOING TO
        CPX     #20
        BIT     DH80T
        BVC     STUP20
        JSR     XTND13       ;GO XTRZ ROM IF 96TPI
STUP20: BCC     STSUP3
        AND     #^CAMPADJ         ;CLR RD/WRITE >20 TRK GATE
        BNE     STSUP4
STSUP3: ORA     #AMPADJ         ;SET RD/WRITE <21 TRK GATE
STSUP4: STA     PORTB3
        LDA     TRKNBR
        JSR     CSTEP
        RTS
;     BUFFERS OUT
;             OUTPUTS ASCII "C"/"E",
;             256 BYTE BUFFER AND CHECK
;     SUM. COMPUTES CHECKSUM
BFROUT: JSR     SCTTST       ;TST IF SCTR 1,2,OR 3
        STX     CSSCRT       ;CLR FOR FIRST CS ADD
        BCC     BOUT01       ;BRNCH IF TST RESLT NOT 1,2,OR 3
        LDA     #FORMT
        CMP     CTLCMD
        BEQ     BOUT01       ;BRNCH IF PRSNT CMND A FORMAT
BOUT0:  LDA     ZPRL(X)       ;MOVE LOWR HALF
        STA     ZP80(X)       ;OF BFRS TO
        INX                  ;UPR HALF
        BPL     BOUT0
BOUT01: CLC
        BIT     INMODE
        BMI     BOUT02        ;BRNCH IF 19.2K
        JMP     XTND9
BOUT02: PHP
        JSR     OUTPUT       ;OUTPUT "C" OR "E"
        LDY     #8
BOUT1:  DEY
        BNE     BOUT1        ;DELA OF 39 MACH CYC
BOUT2:  LDY     #8
BOUT3:  DEY
        BNE     BOUT3        ;DELA OF 39 MACH CYC
        LDY     ZPRL(X)
        STY     TMPOUT       ;MOVE 1 BYTE INTO OUTPUT SCRATCH
        PLP                  ;RETREIV CRY
        JSR     DFCKSM       ;ADD LAST BYTE OUT TO CS
        PHP                  ;SAV CRY FROM LAST CS ADD
        INX
        BNE     BOUT2        ;BRNCH IF 256 BYTES NOT DONE
        LDA     CSSCRT
        PLP
        ADC     #0         ;ADD LAST CS ADD CRY TO CS
        STA     TMPOUT
        LDY     #7
BOUT4:  DEY
        BNE     BOUT4        ;DELA OF 34 MACH CYC
        JSR     OUTPUT        ;OUTPUT CHEKSUM
RSTOUT: LDX     PBDDR1
        DEX
        STX     PBDDR1       ;REST OUTPUT PORT
        RTS
;       WRITE SERVICE LOOP
WSL:    BIT     SSDA0        ;POLL STATREG FOR XMITRA
        BVC     WSL
        LDA     ZPRL(X)       ;GET DATA WORD FROM BUFR
        ROR            ;SHIFT OUT LOWR 4 BITS,BRING
        LSR            ;IN LSB OF LAST BYTE XMITED
        LSR            ;THRU CARRY
        LSR            ;NOW HAV 5 BIT POINTER IN LSB'S
        TAY                  ;Y WILL BE POINTR
        LDA     CDLT(Y)       ;GET 1 BYTE C/D FROM TABLE
        STA     SSDA1
        LDA     ZPRL(X)       ;GET DATA WORD FROM BUFR AGAIN
        AND     #^H01F         ;MASK OFF TOP 3 BITS
        TAY                  ;Y WILL BE POINTER
        LSR            ;SAV LSB IN CRY FOR NXT WORD
                             ;TO XMIT
        STA     SSDA1        ;XMIT
        INX                  ;CONT SERVICE ROUTINE TIL X=00
        BNE     WSL
        RTS
;   REHOME
;            TESTS TO DETERMINE TO
;   REHOME DRIVE 1 OR 2. REHOMES,
;   WAITING 5MS AFTR EACH STEP.
;   WAITS ONLY 5MS AFTR LST STP
;   SETS RESPECTIV DRIV SCRATH LOC
;   TO INDICAT TRK 00
REHME:  LDX     #SPTOP1+SPTOP4
        BIT     DH80T
        BVC     RHM10
        JSR     XTND7      ;GO TO XTRA ROM IF 96TPI
RHM10:  BIT     INMODE       ;TST TO REHME DRV1 OR 2
        BVS     REHME1       ;BRNCH TO REHME DRV1
        STX     PORTB3       ;INIT STP PHASE TO REHME DRIV 2
RHM12:  JSR     STEP
        BEQ     RHM42
RHM22:  LDA     TIMR1R
        BPL     RHM22        ;SPIN TIL 5MS UP
        JMP     RHM12
RHM32:  JMP     REHME1       ;GO REHOME DRIV 1
RHM42:  STY     PRTRK2       ;SET PRTRK2 TO INDICATE DRIV 2
                             ;ON TRK 00
RHM52:  LDA     #128
        STA     TIMR3        ;SET TIMR FOR 50MS
RHM62:  LDA     TIMR1R
        BPL     RHM62
        RTS
REHME1: STX     PORTB1       ;INIT STP PHASE
REHM4:  JSR     STEP
        BEQ     REHM3
REHM2:  LDA     TIMR1R
        BPL     REHM2        ;WAIT 5MS FOR STP SETL
        BMI     REHM4
REHM3:  STY     PRSTRK       ;SET FOR TRK 00
        BEQ     RHM52
;     OUTPUT
;           OUTPUTS 1 BYTE FROM TMPOUT
;     TO COLLEEN AT 19.2K
OUTPUT: LDA     PORTB1
        AND     #^CSEROUT
        STA     PORTB1       ;START BIT OUT
        LDY     ZPRL         ;DELA 3 MACH CYC
        LDY     #128-8         ;SET BIT COUNTR
OUT1:   NOP
        NOP
        NOP              ;DELA 6 MACH CYC
        STY     YSAVE        ;SAV BIT COUNTR
        LDY     #14
OUT2:   DEY
        BNE     OUT2         ;DELA 69 MACH CYC
        LDY     YSAVE
        LSR
        ROR     TMPOUT
        ROL
        STA     PORTB1
        INY
        BPL     OUT1         ;BRNCH TIL 8 BITS OUT
        LSR
        SEC
        ROL
        LDY     #17
OUT3:   DEY
        BNE     OUT3         ;DELA 84 MACH CYC
        NOP
        NOP              ;DELA 4 MACH CYC
        STA     PORTB1       ;STOP BIT OUT
        RTS
;       SPINDLE MOTOR ON
;   DRIVE TO TURN ON SPM. TURNS ON SPM I
;   F NOT ALREADY ON AND SETS TO INDICAT
;   500MS DELA REQUIRED
;SETS FOR 6 SEC DELA ON SHUTDOWN
SPMON:  BIT     INMODE
        BVC     SPO02        ;BRNCH IF HERE TO TURN ON SPM 2
;    TEST IF SPM IS ON. IF NOT,TURN ON AND
;            SET TO INDICATE 500MS DELAY REQ.
SPMON1: LDA     PORTA1
        LSR
        LSR            ;TEST IF SPM IS ON. IF OM,LEAVE
        BCS     SPO1         ;ROUTINE
        LDA     #CLKRST+CTSRST+MRSSDA+SELTOP
        STA     PORTA1       ;TURN ON SPM
        LDA     #255
        STA     TIMR2        ;SET FOR 125MS DELAY
        LDA     #4
SPO1:   LDA     #24
        STA     SPMSDC       ;SET FOR 3 SEC DLA ON SHTDWN
        RTS
SPO02:  LDA     PORTA3
        LSR
        LSR
        BCS     SPO12        ;BRNCH IF SPM2 ALREADY ON
        LDA     #SELBOT
        STA     PORTA3       ;TURN ON SPM2
        LDA     #255
        STA     TIMR23       ;SET FOR 125MS DELA
        LDA     #4
        STA     SPMDC2       ;SET FOR 4 DELAS
SPO12:  LDA     #24
        STA     SPSDC2       ;SET FOR 3 SEC DELA ON SHTDN
        RTS
;       SPINDLE MOTOR READY
;    DRIVE TO PERFORM DELAY ON. WAITS
;    FOR 500 MS IF NEEDED. UPDATES STUTUS
;     TO REFLECT THIS SPM ON AND STABL
SPMDY:  BIT     INMODE
        BVC     SPDY12       ;BRNCH IF HERE FOR SPM2 DELA
;    TEST IF SPM SPEED STABLE/WAIT IF NOT.
SPMDY1: LDA     INSTAT
        LSR
        LSR
        LSR
        BCC     SPMDY4       ;IF SPM STABL,LEAVE ROUT
SPMDY2: LDA     TIMR1R
        BPL     SPMDY2       ;WAIT 125MS
        DEC     SPMDLC
        BEQ     SPMDY3       ;CONT DELAY LOOPS TIL SPMDLC=00
        LDA     #255
        STA     TIMR2        ;RESET TIMER FOR 125MS DELAY
        JMP     SPMDY2
SPMDY3: LDA     #^CS1NRDY
        JSR     ANINS        ;CLEAR MOTOR NOT READY BIT IN IN
SPMDY4: LDA     #NODISK         ;TERNL STAT REG
        JSR     OR0ST        ;SET SPM ON FLG IN XFER STAT
        RTS                  ;REG
SPDY12: LDA     INMODE
        AND     #S2NRDY
        BEQ     SPDY42       ;BRNCH IF SPM2 STABL
SPDY22: LDA     TIMR3R
        BPL     SPDY22       ;WAIT 125MS
        DEC     SPMDC2
        BEQ     SPDY32       ;CONT DELA LOOPS TIL SPMDC2=00
        LDA     #255
        STA     TIMR23       ;RESET TIMR FOR 125MS DELA
        JMP     SPDY22
SPDY32: LDA     #^CS2NRDY
        JSR     ANDNMD        ;CLR MOTOR UNSTABL BIT IN INMODE
SPDY42: RTS
;       CRC GENERATION LOOP
CRCGEN: LDA     #^H0FF
        STA     ABLE
        STA     BAKER
CRCETR: LDA     INMODE
        LSR
        .BYTE   ^H0BD           ;ABSOLUTE ADDR. SO INDEX DOESN'T WRAP INTO
                                ;0 PAGE
        .WORD   ZPCRC           ;"LDA ZPCRC(X) ABSOLUTE"
        BCC     CRCT1
        LDA     ZPRL(X)
CRCT1:  EOR     BAKER
        STA     SCRT1
        LSR
        LSR
        LSR
        LSR
        EOR     BAKER
        TAY
        LDA     INMODE
        LSR
        TYA
        BCC     CRCT3
        EOR     ZPRL(X)
CRCT2:  AND     #^H00F
        STA     SCRT2
        LDA     SCRT1
        AND     #^H0F0
        EOR     SCRT2
        STA     SCRT2
        LSR
        LSR
        LSR
        EOR     ABLE
        STA     ABLE
        LDA     SCRT2
        ASL
        ASL
        ASL
        ASL
        STA     SCRT1
        EOR     ABLE
        STA     BAKER
        LDA     SCRT1
        ASL
        EOR     SCRT2
        STA     ABLE
        INX
        BNE     CRCETR
        RTS
CRCT3:  .BYTE   ^H05D           ;FORCE ABS. ADDR. SO INDEX DOESN'T WRAP
        .WORD   ZPCRC           ;"EOR ZPCRC(X) ABSOLUTE"
        JMP CRCT2
;       SYNCRONIZATION LOOP
SYNC00: JMP     SYNC7
SYNC:   LDA     #6         ;SET TIMR LOOP CNTR FOR 5 LOOPS
        STA     SPMDC2
SYNC0:  DEC     SPMDC2
        BEQ     SYNC00       ;BRNCH IF 5 TIMR LOOPS DONE
        CPY     #1
        BEQ     SYNC00       ;BRNCH IF HERE FOR DAM AND 1 TIM
                             ;R LOOP DONE
        LDA     #255         ;SET TIMR FOR 130 MS
SYNC01: STA     TIMR23
NUTS:   LDA     TIMR3R
        BMI     SYNC0        ;BRNCH IF TIMR DONE
        STA     SSDA0
        LDA     #^H09B
        STA     SSDA1
SYNCLP: LDA     #RXRS+TXRS+CLEARS+AC2
        STA     SSDA0        ;REST REC(X)MIT. NABL SR WRITE
        LDA     #^H044         ;LOAD SYNC REG WITH HEX 44 (FIRS
        STA     SSDA1        ;T HALF SYNC CHAR CLK/DATA PATRN
        LDA     PORTA1
        AND     #^CCLKRST
        STA     PORTA1       ;REST PA6(PORTA1) TO RESET READ
        ORA     #CLKRST         ;CLOCK FAST.
        STA     PORTA1       ;NABL READ CLOCK SWITCH
        LDA     #TXRS+AC2
        STA     SSDA0        ;NABL REC
SYNC1:  LDA     TIMR3R
        BIT     PORTA1
        BPL     SYNC1        ;BRNCH IF NO SYNC MATCH FROM
                             ;SSDA CHIP
        LDA     #^H089         ;HAV FIRST SYNC MATCH. LOAD SYNC
        STA     SSDA1        ;REG WITH SECND HALF CLK/DATA
        LDX     #4         ;PATRN OF SYNC CHAR AND
SYNC2:  DEX                  ;WAIT APPROX. 13US MORE BEFORE
        BNE     SYNC2        ;VERIFICATION OF SECOND SM
        BIT     PORTA1       ;MUST HAV SECOND SM NOW. IF NOT,
        BMI     NUTS         ;FALSE STRT RESTRT SYNCLOOP
                             ;P.
        LDA     #TXRS
        STA     SSDA0        ;NABL C2 WRITE,CONT REC
        LDA     #PC1+PC2+WS1+WS2+TXSUND+EIE
        STA     SSDA1        ;NOW HAV SYNC. INHIBIT
                             ;FURTHER SM OCCURENCES.
        CPY     #2
        BEQ     SYNC6
        LDX     #2
        LDA     #3
        STA     TIMR3
SYNC3:  BIT     TIMR1R
        BMI     NUTS
        BIT     SSDA0
        BPL     SYNC3        ;POLL SSDA STAT REG FOR RDA
SYNC4:  LDA     SSDA1        ;CMPRE NXT 2
        CMP     #^H0A1         ;BYTES IN TO "A1"
        BNE     NUTS         ;NOT EQUAL=FALSE STRT
        DEX
        BNE     SYNC4
        TYA
        BNE     SYNC6
        LDX     #128-8
SYNC5:  BIT     SSDA0
        BPL     SYNC5
        LDA     SSDA1        ;CMPARE NXT 8 WORDS IN
        CMP     SCTTBL+3-<128-8>(X)     ;WITH THIS TRK,SCT DATA
        BNE     NUTS         ;IN TBLE. IF ANY ERRS
        INX                  ;HAV FLSE STRT--RESTRT LOOP
        LDA     SSDA1
        BEQ     SYNC8
        JMP     NUTS
SYNC8:  INX
        BPL     SYNC5
SYNC6:  LDA     #1
SYNC7:  RTS                  ;Z=0 ON EXIT MEANS HAV SYNC
;       TIMEOUT WG BEFORE STEP
TWGBS:  LDA     #8
        JSR     TIMER        ;DELAY
        JSR     STEP
        RTS
;       TIMER
TIMER:  STA     TMRSCR
TMR1:   DEY
        BNE     TMR1
        DEC     TMRSCR
        BNE     TMR1
        RTS
;   STATUS CLEAR AND UPDATE
;        TSTS TO DETRMIN WHICH DRV TO
;   UPDATE STAT ON. CLEARS ALL BUT BASIC
;   STATUS BITS, THEN UPDATES STAT BY
;   CONTNTS OF ACCUMULATR ON ENTRY TO
;   THIS ROUT
OR0STX: BIT     INMODE
        BVC     OR0ST2       ;BRNCH IF HERE TO UPDATE DRV2
OR0ST:  PHA
        LDA     #^C<MTR0+RWE0+INVDF0+INVCF0>
        AND     STFLGS
        STA     STFLGS
        PLA
ORSTF:  ORA     STFLGS
        STA     STFLGS
        RTS
ORINST: ORA     INSTAT
        STA     INSTAT
        RTS
OR0ST2: PHA
        AND     STFLG2
        STA     STFLG2
        PLA
ORSTF2: ORA     STFLG2
        STA     STFLG2
        RTS
CLRST:  LDA     #^C<MTR0+RWE0+INVDF0+INVCF0>
CLRST1: AND     STFLGS
        STA     STFLGS
        RTS
CLRST2: LDA     #^C<MTR0+RWE0+INVDF0+INVCF0>
CLRS12: AND     STFLG2
        STA     STFLG2
        RTS
;       WRITE PROTECT TEST
;    WPTST      TESTS TO DETRMIN WENICH
;    DRV TO PERFORM WP TEST ON.  Z FLG
;    RESET IF DRV WP
WPTST:  LDA     PORTA1
        BIT     INMODE
        BVC     WPTST1       ;BRNCH IF HERE TO CHK WP DRV2
WPTST0: AND     #WPTOP
        RTS
WPTST1: AND     #WPBOT
        RTS
ANINS:  AND     INSTAT
        STA     INSTAT
        RTS
;        UPDATE INMODE BITS
ORINMD: ORA     INMODE
        STA     INMODE
        RTS
ANDNMD: AND     INMODE
        STA     INMODE
        RTS
;       UPDATE DEVICE STATUS FLAGS
ORST1:  BIT     INMODE
        BVC     ORST10
        ORA     DEVSTA
        STA     DEVSTA
        RTS
ORST10: ORA     DEVST2
        STA     DEVST2
        RTS
ANDST1: BIT     INMODE
        BVC     ANST10
        AND     DEVSTA
        STA     DEVSTA
        RTS
ANST10: AND     DEVST2
        STA     DEVST2
        RTS
;   TEST RECEIVED SECTOR NUMBR
TSN:    LDX     AUX2
        LDA     AUX1
        BEQ     TSN2         ;BRNCH IF LS HALF 00
TSN1:   CPX     #3
        BCS     TSN3         ;BRNCH IF MS HALF 03 OR MORE
        CMP     #^H0D1
        BCS     TSN4         ;BRNCH IF LS HALF D1 OR MORE
TSN11:  CLC                  ;SET CRY FOR NO ERR
        RTS
TSN2:   CPX     #0
        BNE     TSN1         ;BRNCH IF MS HALF NOT 00
TSN3:   SEC                  ;SET CRY FOR ERR
        LDA     DH80T
        AND     #DBLHED+TPI96
        BEQ     TSN31
        JSR     XTND6        ;GO XTRA ROM IF 96TPI 0R DH
TSN31:  RTS
TSN4:   CPX     #2
        BEQ     TSN3         ;BRNCH IF MS HALF 02
        JMP     TSN11
;    DATA FIELD CHECKSUM COMPUTE
;               SMALL ROUT USED TO
;    GENERAT CS ON DATA BUFRS FOR BOTH
;    I/O ROUTS
DFCKSM: LDA     CSSCRT       ;GET CURENT CS WORD
        ADC     ZPRL(X)       ;ADD LAST WORD TO CS
        STA     CSSCRT       ;SAV TEMP
        RTS
;    COMMANDS CHECKSUM
;             GENERATES CS ON 4 BYTE CMND
;    AND COMPARES RESULT AGAINST REC CS
;    ON EXIT,Z=1 IF NO ERR
CDCKSM: LDA     #0
        CLC                  ;CLR A & CRY FOR FIRST ADD
CS1:    ADC     UNITNB(X)     ;ADD ONE WORD TO CS
        PHP                  ;SAV CRY FOR NXT ADD
        INX
        CPX     INSCRT       ;CHK FOR ALL BYTES ADDED
        BEQ     CS2          ;BRNCH IF ALL ADDED
        PLP                  ;RETREIV CRY
        JMP     CS1          ;GO DO ANOTHR ADD
CS2:    PLP                  ;RETREIV CRY
        ADC     #0              ;ADD LST CRY TO CS
        CMP     UNITNB(X)     ;COMPAR CS TO RECVD CS
        RTS
;       FORMAT/WRITE SETUP
;           PERFORMS BASIC
; SETUP OPRATIOMS FOR BOTH WRITE
; AND FORMAT ROUTS
FWSL:   LDA     PORTA2
        ORA     #BDBHRD+BDTHRD+TDBHRD+TDTHRD
        STA     PORTA2          ;DISABLE ALL READ HEADS
WGEGSU: LDA     INMODE
        ASL
        BMI     WGEG2        ;BRNCH IF DRV2 ADDRSD
        ASL
        ASL
        LDA     #^H0EF
        LDX     #^H0CF
        LDY     #^H0DF
        BCS     WGEG1
        LDA     #^H0BF
        LDX     #^H03F
        LDY     #^H07F
        BCC     WGEG1
WGEG2:  ASL
        ASL            ;LOAD CRY WITH "SIDE" BIT
        LDA     #^H0FE
        LDX     #^H0FC          ;PORTB2 VALUES (IN X, Y)
        LDY     #^H0FD
        BCS     WGEG1        ;BRNCH IF SIDE2 ADRSD
        LDA     #^H0FB
        LDX     #^H0F3
        LDY     #^H0F7
WGEG1:  STX     EGON
        STY     WGOFF        ;SAV TMP EG AND WG CODES
        STA     PORTB2
        LDA     #^H0D3
        STA     SSDA0        ;RST REC AND XMIT NABL
                             ;XMIT FIFO WRITE
        LDA     #^H092         ;PRELOAD XMIT FIFO
        LDY     #^H054         ;CLK/DTA PATRN
        STA     SSDA1        ;FOR 1 BYTE OF
        STY     SSDA1        ;"4E"
        LDX     #^H093         ;HOLD REC,
        STX     SSDA0        ;NABL XMIT,NABL XMIT FIFO WRITE
        RTS
;       FORMAT/WRITE SETUP PART 2
;           XMITSTHE SECOND HALF OF
;   THE GAP AND ALL OF THE ID FOR
;   THE DATA FIELD IN BOTH THE WRITE
;   AND FORMAT ROUTS
FWSL1:  LDA     #^H0AA
        TAY
        LDX     #^H00C
        JSR     FSL          ;XMIT 12 BYTES "00"
        LDA     #^H044
        LDY     #^H089
        LDX     #^H003
        JSR     FSL          ;XMIT 3 BYTES MODIFIED "A1"
        LDA     #^H055
        LDY     #^H045
        INX
        RTS
;    DATA FIELD INPUT
;    DATA BUFRS. COMPLIMENTS DATA. GEN-
;    -ERATES CS.INPUTS COLLEEN'S CS
;    THRU COMMANDS CHECKSUM ROUT AND
;    COMPARES IT TO IT'S OWN CS. SETS
;    Z FLG IF THEY MATCH.
;               ALSO, TESTS SCRATCH LOC
;    INMODE TO DETERMIN WHAT SPEED TO
;    INPUT AT (19.2K OR 38.4K)
INPUT:  JSR     SCTTST       ;TST IF PRSNT CMND SCTR NUMBR
                             ;1,2,OR 3
        BCC     IN0          ;BRNCH IF TST RESLT NOT 1,2OR3
        LDX     #128         ;SET TO BRING IN ONLY 128 BYTS
IN0:    LDA     #255
        STA     TIMR22       ;SET TIMR FOR 125MS
        LDY     #7
        STY     INSCRT       ;SET POINTR FOR CS IN
        INC     INMODE       ;SET BIT 0 IN INMODE FOR INPUT
        CLC
        BIT     INMODE
        BMI     IN00         ;BRNCH FOR 19.2K RATE
        JMP     XTND8      ;GO TO XTRA ROM FOR 38K
IN00:   PHP
                             ;ADD
IN01:   LDA     TIMR2R
        BMI     IN9          ;BRNCH IF TIMD OUT--DTA FLD ERR
IN1:    LDA     PORTB1
        BPL     IN01         ;BRNCH IF NO STRT BIT
        LDY     #12
INDLA1: DEY
        BNE     INDLA1       ;INDLA1=54 MACHIN CYCLS
INDLA2: TYA                  ;SAV BIT COUNTR TEMP
        LDY     #15
INDLA3: DEY
        BNE     INDLA3       ;DELAY 74 MACH CYC AT 19K, 14
                             ;CYC AT 38K FOR BIT CNTRS AND
                             ;49 CYC AT 38K FOR STRT BIT DLA
        LDA     PORTB1       ;RETREIVE 1 BIT
        ROL                     ;SHIFT TO CRY
        ROR     ZPRL(X)       ;ASSEMBL TO PRSNT WORD
        INY
        BPL     IN4          ;BRNCH UNTIL 8 BITS ASSEMBLED
        LDA     ZPRL(X)
        EOR     #255
        STA     ZPRL(X)       ;COMPLIMENT LAST BYTE ASSMBLD
        PLP                  ;RETREIVE LAST CS ADD CRY
        JSR     DFCKSM       ;GO ADD LAST WORD IN TO CS
        PHP                  ;SAVE CRY FROM LAST CS ADD
        INX
        BNE     IN5          ;BRNCH IF BUFRS NOT FULL
        LDX     #4
IN6:    DEX
        BNE     IN6          ;SET DELA OF 21 MACH CYC
        LDX     #6
        JSR     CHKIN        ;GET CS FROM COLEN
        STA     DICKSM       ;SAV RECVD CS TEMP
        BCC     IN8          ;BRNCH IF NOT SCTR 1,2,OR 3
IN7:    LDA     ZP80(X)
        STA     ZPRL(X)       ;MOVE TOP HALF OF BUFRS TO
        INX                  ;LOWR HALF
        BPL     IN7
IN8:    LDA     CSSCRT       ;GET COMPUTED CS
        ADC     #0         ; ADD LAST CRY TO CS
        DEC     INMODE       ;REST INMODE "INPUT BIT" FOR
                             ;EXIT FROM INPUT ROUT
        CMP     DICKSM       ;COMPARE TWO CS'S
                             ;T FROM INPUT ROUT
;  DELAY OF 225 USECS ADDED BY DAVE:
        PHP                     ;SAVE Z FLAG FROM COMPARE
        LDY     #90             ;LOAD TIMER
INDLY:  DEY
        BNE     INDLY           ;LOOP TIL TIME OUT
        PLP                     ;RESTORE Z FLAG
        BEQ     IN10            ;IF GOOD CHECKSUM, RETURN Z SET
        LDA     #NAK            ;ELSE, GET NAK BYTE
        JSR     SAA2            ;SEND BACK TO COLLEEN
        JMP     WR5             ;UPDATE FLGS & GOTO INIT2
IN10:   RTS
IN4:    LDA     INMODE
        BMI     INDLA2
IN5:    LDY     #6
        STY     TIMR22       ;SET TIMR FOR 2.5MS DELA
INDLA4: DEY
        BNE     INDLA4       ;INDLA4=29 MACH CYC
        BEQ     IN1          ;ALWAYS BRNCH
IN9:    DEC     INMODE
        PLP
        LDA     #255
        RTS
;   SECTOR BREAKDOWN ROUTINE
;               BREAKS THE TWO BYTE
;   SECTOR NUMBER RECEIVED OVR THE
;   BUS DOWN TO A TRK AND SCTOR NUMBR
SCTBD:  LDA     AUX2
        STA     SSCTMS
        LDA     AUX1
        STA     SSCTLS
        LDX     #^H004
SCTBD1: ROR     AUX2
        ROR
        DEX
        BNE     SCTBD1
        ROR     AUX2
        LDX     #^H004
SCTBD2: LSR     AUX2
        DEX
        BNE     SCTBD2
SCTBD3: ASL
        CMP     AUX2
        BCS     SCTBD4
        STA     AUX1
        LSR
        STA     TRKNBR
        SEC
        LDA     AUX2
        SBC     AUX1
        STA     SCTNBR
        RTS
SCTBD4: LSR
        TAX
        DEX
        LDA     #^H010
        CLC
        ADC     AUX2
        STA     AUX2
        TXA
        JMP     SCTBD3
;       COMPUTE STEP/DIRECTION
;   COMPUTE # OF STEPS AND DIRECTION
;             TO DESIRED TRK
CSTEP:  LDX     #^H080         ;ASSUME POS RESLT "STP IN"
        LDY     #0         ;ASSUME NO STEP NEEDED
        SEC
        BIT     INMODE
        BVS     CST10
        SBC     PRTRK2
        JMP     CST3
CST10:  SBC     PRSTRK       ;SUB PRSNT TRK FROM DESIRED TRK
CST3:   BEQ     CST2         ;RESULT=00 MEANS NO STP,BRNCH
        BPL     CST1         ;IF RESULT POS ,BRNCH
        LDX     #0         ;SET X TO INDICATE "STP OUT"
        EOR     #^H0FF         ;2'S COMP RESLT
        CLC
        ADC     #1
CST1:   TAY              ;Y= NUMBR OF STPS TO EXECUTE
CST2:   RTS
;   STEP TEST
;              TESTS FOR FURTHER STEPS
;   TO EXECUTE,STEPz,WAITS 5 OR 10 MS
STPTST: BEQ     STST2        ;EXIT IF NO STPS TO DO
GOSTP:  JSR     STEP
        BEQ     STST1
WAIT5:  LDA     TIMR1R       ;WAIT 5 MS BFOR NXT STP
        BPL     WAIT5
        JMP     GOSTP
STST1:  LDA     #20
        STA     TIMR2        ;SET FOR 10 MS DELAY
WAIT10: LDA     TIMR1R       ;WAIT 10 MS FOR HEAD SETL
        BPL     WAIT10
        STX     STPDIR
STST2:  RTS
;       SEND ACKNOWLEGE/ACCUM
;            XMITS AN ACKNOWLEDGE OR THE
;    CONTENTS OF THE ACCUMULATR TO COLLE
SAA:    BIT     PORTB1
        BVS     SAA          ;WAIT TIL COMND FRAME GONE
SAA1:   LDA     #ACK
SAA2:   STA     TMPOUT       ;SET TO XMIT CONTNTS OF ACUM
        JSR     SETOP
        JSR     OUTPUT
        JSR     RSTOUT       ;RESET OUTPUT PORT
        RTS
;    SET OUTPUT PORT
;            NABLS OUTPUT PORT AND PUTS
;    A "1" ON IT (STOP BIT)
SETOP:  LDX     PORTB1
        STX     PORTB1       ;INSURE A "1" ON PORT
        LDX     PBDDR1
        INX
        STX     PBDDR1       ;NABL OUTPUT PORT
        RTS
;       DATA TABLES
;ID FIELD TABLE
IDFLD:  .BYTE   ^H0A1,^H0A1,^H0A1,^H0FE,^H0FF,^H000
        .BYTE   ^H0FF,^H001,^H0FF,^H0FF,^H04E
;    SCTRS---TABL USED BY FORMAT ROUT
;    FOR SECTOR STAGR
SCTRS:  .BYTE   10,9,18,8,17,7,16,6,15
        .BYTE   5,14,4,13,3,12,2,11
;       CLK/DATA LOOK-UP TABLE
CDLT:   .BYTE   ^H0AA,^H0A9,^H0A4,^H0A5,^H092,^H091,^H094,^H095,^H04A,^H049,^H044
        .BYTE   ^H045,^H052,^H051,^H054,^H055
        .BYTE   ^H02A,^H029,^H024,^H025,^H012,^H011,^H014,^H015,^H04A,^H049,^H044
;  EXTENDED STATUS BYTES:
XSTAT:  .BYTE   ^H004,^H0D0,^H002,^H000,^H001
        .BYTE   ^H007,^H00C,^H000,^H000,^H000
        .BYTE   ^H0AA,^H055
ENDCOD  =       .
AVAIL   =       VEC-ENDCOD              ;# OF FREE BYTES IN THIS ROM
;       POWER-UP VECTORS
        .=      ^H017FC
VEC:    .WORD   INIT,INIT
        .END
  • Like 7
