Sign in to follow this
Skatepunk60
Do i have a heavy sixer?
I have a six switch with some srious metal inside but i dont know if its a heavy sixer or not , im thinking not but heres the sn
81336579
Only 150,000 - 200,000 Heavy Sixers were made. Your serial number is over 1 million so doesn't look like it there. Also, Heavy Sixers bear the "Sunnyvale CA" mark on the serial sticker. Others are Taiwan, etc.
Real heavy sixer's also have a VERY thick plastic bottom... as opposed to a lot of normal 6-switch Atari's that have the same bottom piece as 4-switch models. You'll notice the difference if you stick the two beside each other. If the bottom of your 6-switch is the same as the bottom of your 4-switch, it's not a real Heavy Sixer.
--Zero
Do i have a real heavy sixer? The tag on the bottom is gone but the number 460 is pressed on the bottom. What is that number?
