Sign in to follow this
Luigi301
ST and floppies
I've got a 520ST and an external disk drive. I have no games for it. Is there any way to write ST disks with my PC's floppy drive?
Not necessarily -- depends on your PC's drive mech. My floppy can't even format to 720k -- at least, not using high density disks.
Windows 95 and 98 can work with and format 720kb DD disks. But they may not work in the ST. Format them on the ST, then use the PC to copy files to them. I currently have an old laptop set up to do just this, so I know it works!
Support for DD disks was removed in 2000 and XP. Also as some people have rightly pointed out, some modern drive mechanisms don't support it.
977953[/snapback]
Removed, no; hidden, yes.
Mitch
977748[/snapback]
You did cover the extra hole on the floppy disk, right?
Mitch
977748[/snapback]
Mitch
978180[/snapback]
My main PC floppy mech will read and write DDs (720K formatted on ST)
It won't format DDs or HDs with the hole taped over though.
Using HDs with the hole taped over, and DD in HD drives is a lottery. HD drives apparently use a less powerful magnetic field, so disks written on them will not always read back properly on DD drives.
978270[/snapback]
Yeah, that magnetic field/media difference is why anything I'm going to use on the ST/Amiga/IIGS get's written to actual DS/DD disks. Writing DS/DD to HD - not so good.
977953[/snapback]
Mitch
978179[/snapback]
Really? If you could tell me how to turn it back on (so it just works in Exporer without any faffing around) I would greatly appreciate it! I'm intrigued now... Apparently I don't know everything there is to know about XP! :D
977953[/snapback]
Mitch
978179[/snapback]
978581[/snapback]
If you are just trying to read them you should be able to access them like a normal floppy. If you need to format them, you need to do it from the command line (or use a bat file). The command is:
FORMAT A: /T:80 /N:9
Mitch
977953[/snapback]
Mitch
978179[/snapback]
If you're referring to command-line formatting with the /T /N switches, been there, done that, didn't work. (I always format floppies from the command line -- force of habit I guess; plus I have my DOS shell bound to a hotkey, so it's quicker)
977748[/snapback]
Mitch
978180[/snapback]
This matters? Does it refuse to format low density if the sensor finds the other hole?
I'd buy DS/DD 3.5" floppies if I could find 'em, but alas all you can still buy are high density disks.
Thing is I had no trouble on my old system a couple years back -- I could use MAKEDISK to write out anything up to 82/10/2 (820k) or read in anything of the same format. (11 sector disks were a writeoff -- I couldn't read or write those, not that they were very common anyway) Not so with my current mech. (Admittedly I'm running XP now, so that may make a difference. I should try from within a virtual machine running 98)
979010[/snapback]
In my experience, yes - it won't format DS/DD with the HD hole exposed.
This place looks like they're still selling new DS/DD floppies.
Better way are using "PARCP" or "Ghost Link" hardware and software - it working fine and are no problem with it.
Other method: use HD floppy in your ST (I know, you must change WD1772 to use HD format and add one wireless cable to do it, round signal cable at 180 degrees and change id drive from D0 to D1 (jumper or solder)).
Edited by Sikor
979251[/snapback]
Good software. Though I took the easy route and just write .MSAs to 1.44MB floppies and read 'em on the Falcon ;)
Edited by remowilliams
Ho that's why I cant get any of my ST files off my PC  :x
978403[/snapback]
Why not buy some DS/DD disks? I would be willing to sell you a 100 DS/DD disks for only $50. That is only 50 cents per disk, which is cheap when you consider how hard these are to find, even on eBay. I have a closet full of these disks. I have been stocking up on them because I plan to keep my Amiga and Atari ST computers for the next 30+ years. I mainly use hard drives, CD-Rom drives, and ZIP-100 disk drives, but it is always nice to have some disks, just in case I ever do need them. :D
