Atarian7 #1 Posted December 14, 2005 i got a pair of Gemini paddles and they won't even move the buckets on KAboom!. Is there a simple repair just like the repair for jittery paddles, or are these dead? Quote Share this post Link to post Share on other sites
adams_ale #2 Posted December 14, 2005 I have 3 sets, 6 individual, 2600 paddles that don't work. I don't know if these things break easily, but it sure seems that way. Quote Share this post Link to post Share on other sites
+Omegamatrix #3 Posted December 14, 2005 They won't move the buckets at all? Sounds like the cord has separated somewhere along it’s line. I had that happen with some Atari paddles. One paddle worked and the other one didn't. I soldered on a replacement paddle that I knew worked and it still was dead. You might want to save just the paddles for spare parts, and throw away the cord. You'll need to find a new set of paddles, but at least this way you can mix & match until you have a good pair. Quote Share this post Link to post Share on other sites
Spirantho #4 Posted December 14, 2005 Atari controllers in general are so simple you can always fix them. If they're not controlling anything, it's probably just a loose/broken wire - find the break and repair it and it'll be fine again! The tricky bit is finding the break.... Quote Share this post Link to post Share on other sites
MoonlightKnight #6 Posted December 14, 2005 Just an FYI, it may be something as simple as the insides being dirty. In he past, I've opened up paddles, cleaned them, and put a little WD-40 on them. after putting them back together, they ended up working like they were brand new... no jitters at all. Opening them would give you a chance to check the solders as well. Quote Share this post Link to post Share on other sites
D.Yancey #7 Posted December 15, 2005 I read on a thread here that the goop everyone finds in the paddles is di-electric grease. I cleaned my paddles and got them working well, but the jitter always returns after a few days or weeks. I decided to try and replace the alleged di-electric grease inside to see if it would be helpful. They jitter worse then ever now, so unless I did something wrong, I don't recommend the grease inside the pot. Quote Share this post Link to post Share on other sites
