Sign in to follow this
onkyo_emu
N64 with Boom USB 64/PS adapter problems
I've read the faq's and what not, but I can't seem to get this going. The analog stick always want's to go down when it's not being touched. I've adjusted deadzones and range, but still the same. It shows up in control panel as a "4-axis" stick. I think this is the root problem with this adapter. Can anyone make it a "2-axis." The z rotation is what throws everything off.
Thanks!
I think you might be right. Have you tried:
* using the adapter with it's own drivers (if it has any)?
* using the adapter without them (so windows just assigns the default HID settings)
* On your emulator (which one is it?): Use a different controller plugin? There is one called "Nrage" or similar which works pretty well.
You should post this question at the emutalk.net forums which is devoted to N64 emulation. In there you probably will have more luck finding a solution to your problem. Be sure to check out the plugin section for controller plugins. Good luck!
I know. Someone should just release the plans to build one. It can't be that hard. Oh well.
Years ago before USB someone made a circuit that would let you connect a N64 pad to your pc's parallel port with the back then popular DirectPadPro's drivers. Anyway what's the name of your adapter?
Edited by Dones
Boom. It's the one that has the Playstation option. Which works damn good except that the analog sticks don't work, but that really never bothered me.
I like to use original joysticks with all of my emulation. Currently I've got the following:
2600-CX40
NES-NES Pad
SNES-SNES Pad
N64-Well, you know.
PS-Ditto
Atari 7800-New 7800 stick, need to make an external crossover to use with my sega adapter
Sega Genesis-Sega 6 button
Sega SMS-SMS controller
TG16-NES pad or logitech wingman
