heatw #1 Posted December 24, 2005 the graphics all work, how ever there is two of everything displayed any ideas, this is the old black and white taito space invaders cocktail table. it's like it's drawn once i nthe right place then again 2 rows down Quote Share this post Link to post Share on other sites
DanBoris #2 Posted December 25, 2005 (edited) Could be a stuck address line going to the video memory. That would cause certain blocks of memory to be repeated because the state of the address line wouldn't change when it's supposed to. Dan the graphics all work, how ever there is two of everything displayed any ideas, this is the old black and white taito space invaders cocktail table. it's like it's drawn once i nthe right place then again 2 rows down 988493[/snapback] Edited December 26, 2005 by DanBoris Quote Share this post Link to post Share on other sites
heatw #3 Posted December 26, 2005 hmm alright, i've never really dealt with these older games, mostly used to neo geo.. and newr games...so o you know exactly where i would look to check this problem and what i would be doing to resolve it? Could be a stuck address line going to the video memory. That would cause certain blocks of memory to be repeated because the state of the address line wouldn't change when it's supposed to. Dan Quote Share this post Link to post Share on other sites
bjk7382 #4 Posted December 26, 2005 I would first clean the edge connector and the pins on the 2 other connectors, and see if that fixes it. (you want to start with clean connections all around before you start digging into the PCB) I would also suggest gettting the Braze Multikit, it has a Diagnostics test that lets you know of ram errors and other things. Quote Share this post Link to post Share on other sites
heatw #5 Posted December 27, 2005 hmm thatnks, i never considered the connector because it looks liek it hasn't been removed in 20 years haha but that would be a whole lot easier to fix! hmm i'd seen that before but becasue it says for MIDWAY space invaders, i assumed it didn't work with mine, since i didn't see midway printed anywhere on it i assumed it was pre midway.. it only has taito lables I would first clean the edge connector and the pins on the 2 other connectors, and see if that fixes it. (you want to start with clean connections all around before you start digging into the PCB) I would also suggest gettting the Braze Multikit, it has a Diagnostics test that lets you know of ram errors and other things. 989449[/snapback] Quote Share this post Link to post Share on other sites
