PacManPlus #276 Posted July 11, 2006 Been a while since I've played arcade Ladybug, but it sounds almost exactly like the arcade to my ear. Wonderful work! Sounds pretty much spot-on, to me. Thanks, guys. It was fun, sitting in my office at home with my guitar picking out the harmonies from the arcade version Quote Share this post Link to post Share on other sites
vdub_bobby #277 Posted July 11, 2006 I noticed the Stella jittering in the most recent build, but not in the previous ones. I'll check it on on real hardware tonight. I notice jittering in both z26 and Stella if the phosphor effect isn't turned on. I think this is the 30Hz flicker that you're seeing. If I launch z26 with '-f77', the flicker goes away. But if you launch Stella with '-pp yes', it also removes the flicker. As a further test in Stella, run the game normally, without any commandline options. Now hit Alt-p (Shift-Cmd-p for OSX) and see if the flicker goes away. If so, then everything is working as it should be. Before a final release, I'll need a properties entry for this ROM, so that the phosphor effect will be set automatically. Not quite. I haven't seen the jitter in z26, it might be there, but I guarantee that the jitter is there in Stella 2.2, regardless of whether the phosphor effect is on or off. If I remember correctly, Stella doesn't handle the timers correctly after they hit zero. From the Stella guide: The PIA decrements the value or count loaded into it once each interval until it reaches 0. It holds that 0 counts for one interval, then the counter flips to FF(HEX) and decrements once each clock cycle, rather than once per interval. The purpose of this feature is to allow the programmer to determine how long ago the timer zeroed out in the event the timer was read after it passed zero. I don't remember what Stella does instead of that, but it is something different. I think it immediately begins decrementing once per clock cycle. Something. Anyway, A better way to check the RIOT timers than reading INTIM is to check the interrupt flag, I think. Once it is set (or cleared?) it won't ever change (unlike INTIM, which will hit zero, hold, and then resume counting). There's more info on this somewhere but I've been searching for the last 20 minutes and I can't find it. Quote Share this post Link to post Share on other sites
Vic George 2K3 #278 Posted July 11, 2006 Thanks for the advice, stephana. I put that into the ROM properties command line overwrite for running Z26 through QuickPlay, and it does bring the annoying flickering of the playfield down to nil. Much more fun now to play. Quote Share this post Link to post Share on other sites
+Nathan Strum #279 Posted July 11, 2006 I notice jittering in both z26 and Stella if the phosphor effect isn't turned on. I think this is the 30Hz flicker that you're seeing. If I launch z26 with '-f77', the flicker goes away. But if you launch Stella with '-pp yes', it also removes the flicker. As a further test in Stella, run the game normally, without any commandline options. Now hit Alt-p (Shift-Cmd-p for OSX) and see if the flicker goes away. If so, then everything is working as it should be. Before a final release, I'll need a properties entry for this ROM, so that the phosphor effect will be set automatically. The flicker goes away, the jitter does not. Every so often, the entire screen "hops" up and down by a scanline. Quote Share this post Link to post Share on other sites
Cybergoth #280 Posted July 11, 2006 I just played two full games in ALT-9 mode on Z26 and the scannline count seemed a rock-solid 262 Quote Share this post Link to post Share on other sites
+batari #281 Posted July 11, 2006 If I remember correctly, Stella doesn't handle the timers correctly after they hit zero. From the Stella guide: The PIA decrements the value or count loaded into it once each interval until it reaches 0. It holds that 0 counts for one interval, then the counter flips to FF(HEX) and decrements once each clock cycle, rather than once per interval. The purpose of this feature is to allow the programmer to determine how long ago the timer zeroed out in the event the timer was read after it passed zero. I don't remember what Stella does instead of that, but it is something different. I think it immediately begins decrementing once per clock cycle. Something. Anyway, A better way to check the RIOT timers than reading INTIM is to check the interrupt flag, I think. Once it is set (or cleared?) it won't ever change (unlike INTIM, which will hit zero, hold, and then resume counting). There's more info on this somewhere but I've been searching for the last 20 minutes and I can't find it. There was a discussion about that on [stella] or maybe in one of the blogs here, but I'm too lazy to look for it. I've been doing something different since then. I set TIM64T for $7F+timer value and check INTIM for the sign flag. If your code runs too slow, this also gives an accurate indication of excess cycles since it keeps counting down at 64 clocks per interval instead of one, as is the case when you check INTIM for zero. Quote Share this post Link to post Share on other sites
+johnnywc #282 Posted July 11, 2006 Hello all, Minor update: - fixed an issue where the activate sound wouldn't play if 4 insects were out and one got killed by a skull after the activate sound trigger point - insects reverse less on ADVANCED mode, making them more difficult to avoid No progress on the Stella jitter issue. I have compared changes from a previous version and see nothing that would cause the shaking. The VBLANK timer doesn't even come close to expiring; neither does the overscan. Any other thoughts are welcomed. Thanks, ladybug.bin Quote Share this post Link to post Share on other sites
vdub_bobby #283 Posted July 11, 2006 Hello all, Minor update: - fixed an issue where the activate sound wouldn't play if 4 insects were out and one got killed by a skull after the activate sound trigger point - insects reverse less on ADVANCED mode, making them more difficult to avoid No progress on the Stella jitter issue. I have compared changes from a previous version and see nothing that would cause the shaking. The VBLANK timer doesn't even come close to expiring; neither does the overscan. Any other thoughts are welcomed. Thanks, What are you doing during VSYNC? Anything? I have this recollection...[goes to look for...something] Quote Share this post Link to post Share on other sites
+johnnywc #284 Posted July 11, 2006 I just played two full games in ALT-9 mode on Z26 and the scannline count seemed a rock-solid 262 Thanks for the feedback! Is there anyway in Stella to generate a log file? It appears that the screen jumps up one pixel; does this mean the VBLANK is ending a line early? I checked the z26 log and the VBLANK and overscan are starting and ending at the same exact time (scanline/cycle) for each frame. Any ideas are welcomed. Thanks, Quote Share this post Link to post Share on other sites
Thomas Jentzsch #285 Posted July 11, 2006 Hello all, Minor update: Uhm, the playfield reflection bug is back. Just press RESET when the game starts (tested with z26). Quote Share this post Link to post Share on other sites
+johnnywc #286 Posted July 11, 2006 Hello all, Minor update: - fixed an issue where the activate sound wouldn't play if 4 insects were out and one got killed by a skull after the activate sound trigger point - insects reverse less on ADVANCED mode, making them more difficult to avoid No progress on the Stella jitter issue. I have compared changes from a previous version and see nothing that would cause the shaking. The VBLANK timer doesn't even come close to expiring; neither does the overscan. Any other thoughts are welcomed. Thanks, What are you doing during VSYNC? Anything? I have this recollection...[goes to look for...something] Yes - I am doing stuff during VSYNC - incrementing the frame and cycling the bonus color. I'm setting the timer right after starting VSYNC and before the code. Here is a version with the code moved out of VSYNC (hopefully it doesn't overrun VBLANK). Does this stop the shaking? ladybug.bin Quote Share this post Link to post Share on other sites
Thomas Jentzsch #287 Posted July 11, 2006 Any ideas are welcomed. Add WSYNC before the 1st VSYNC. Quote Share this post Link to post Share on other sites
Cybergoth #288 Posted July 11, 2006 Any ideas are welcomed. Add WSYNC before the 1st VSYNC. Best just use the VERTICAL_SYNC macro and don't do anything else. (Actually this macros main purpose is preventing people from doing funky stuff, like redering their display unstable ) Quote Share this post Link to post Share on other sites
+johnnywc #289 Posted July 11, 2006 Hello all, Minor update: Uhm, the playfield reflection bug is back. Just press RESET when the game starts (tested with z26). Hi Thomas, My bad! I didn't realize you could press RESET from the startup screen! I had moved the init code into another bank that would execute after the init screen was done. Here's another build: - fixes the issue when you press RESET from the startup screen and the reflect bit isn't set properly (also proper sets other startup variables). - also: added a sta WSYNC right before the VSYNC, per TJ's suggestion Question: should I allow for RESET during the startup screen? Thanks Thomas! - John ladybug.bin Quote Share this post Link to post Share on other sites
Thomas Jentzsch #290 Posted July 11, 2006 Best just use the VERTICAL_SYNC macro and don't do anything else. (Actually this macros main purpose is preventing people from doing funky stuff, like redering their display unstable ) Though the code between looks ok to me. Quote Share this post Link to post Share on other sites
fujivox #291 Posted July 11, 2006 Aren't you the same person that made such versions from other games? and anyway he is not even done with the game yet. Yup, the bug is fixed now. I also noticed a slight color problem with the dots at the very right. I hope you can fix that one too. BTW: Any chance for a PAL or PAL-60 version? The flicker just doesn't work that well in PAL. Quote Share this post Link to post Share on other sites
Cybergoth #292 Posted July 11, 2006 Best just use the VERTICAL_SYNC macro and don't do anything else. (Actually this macros main purpose is preventing people from doing funky stuff, like redering their display unstable )Though the code between looks ok to me. Oh... I didn't go so far and disassemble it I think plain RAM fiddling is supposed to be save, but I wouldn't even dare to do that Did you check VBLANK? Any funky stuff like you did in Splatform? Quote Share this post Link to post Share on other sites
Thomas Jentzsch #293 Posted July 11, 2006 Aren't you the same person that made such versions from other games? Yup, but not from homebrews. It's much easier when you know the code. and anyway he is not even done with the game yet. Sure, but PAL-60 requires only adjusting the colors. Pretty simple job, especially when you have to code. And it would make testing on real hardware in PAL countries much better (and more fun ). Quote Share this post Link to post Share on other sites
Cybergoth #294 Posted July 11, 2006 And it would make testing on real hardware in PAL countries much better (and more fun ). So did you buy a Kroko cart lately? Quote Share this post Link to post Share on other sites
+johnnywc #295 Posted July 11, 2006 (edited) and anyway he is not even done with the game yet. Almost! Edited July 11, 2006 by johnnywc Quote Share this post Link to post Share on other sites
Thomas Jentzsch #296 Posted July 11, 2006 So did you buy a Kroko cart lately? Nope. (but I have one now ) Quote Share this post Link to post Share on other sites
vdub_bobby #297 Posted July 11, 2006 (edited) Ok, I tracked down the offending stuff in both z26 log files (ugh) and in Stella's debugger. The issue is that sometimes the stuff you have in VSYNC sometimes takes too long! z26, apparently, doesn't give a damn and will still give you a stable display, while Stella jitters the display up a line (don't ask me why). Here's the trace from z26: This code is normal: (318 263 36 40) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5dd: 85 00 sta VSYNC (319 1 39 49) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5df: 85 02 sta WSYNC (319 2 0 -68) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5e1: e6 80 inc 80 (319 2 5 -53) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5e3: d0 06 bne b5eb (319 2 8 -44) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5eb: a5 81 lda 81 (319 2 11 -35) ( 55 63 8 2 83) nVBdIzC 41 fd 00 fd b5ed: d0 05 bne b5f4 (319 2 14 -26) ( 55 63 8 2 83) nVBdIzC 41 fd 00 fd b5f4: 85 02 sta WSYNC (319 3 0 -68) ( 55 63 8 2 83) nVBdIzC 41 fd 00 fd b5f6: a9 2c lda #2c (319 3 2 -62) ( 55 63 8 2 83) nVBdIzC 2c fd 00 fd b5f8: 8d 96 02 sta TIM64T (319 3 6 -50) ( 55 63 8 2 83) nVBdIzC 2c fd 00 fd b5fb: a5 82 lda 82 (319 3 9 -41) ( 55 63 8 2 83) nVBdIzC 08 fd 00 fd b5fd: c9 11 cmp #11 (319 3 11 -35) ( 55 63 8 2 83) NVBdIzc 08 fd 00 fd b5ff: f0 38 beq b639 (319 3 13 -29) ( 55 63 8 2 83) NVBdIzc 08 fd 00 fd b601: a5 8a lda 8a (319 3 16 -20) ( 55 63 8 2 83) nVBdIzc 4b fd 00 fd b603: 29 80 and #80 (319 3 18 -14) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b605: d0 32 bne b639 (319 3 20 -8) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b607: a5 80 lda 80 (319 3 23 1) ( 55 63 8 2 83) nVBdIzc 3f fd 00 fd b609: 29 3f and #3f (319 3 25 7) ( 55 63 8 2 83) nVBdIzc 3f fd 00 fd b60b: d0 2c bne b639 (319 3 28 16) ( 55 63 8 2 83) nVBdIzc 3f fd 00 fd b639: a9 00 lda #00 (319 3 30 22) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b63b: 85 02 sta WSYNC (319 4 0 -68) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b63d: 85 00 sta VSYNC Note that we start on scanline 263 and end on scanline 4. Here's the jittery portion: (319 263 36 40) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5dd: 85 00 sta VSYNC (320 1 39 49) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5df: 85 02 sta WSYNC (320 2 0 -68) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5e1: e6 80 inc 80 (320 2 5 -53) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5e3: d0 06 bne b5eb (320 2 8 -44) ( 55 63 8 2 83) nVBdIzC 02 fd 00 fd b5eb: a5 81 lda 81 (320 2 11 -35) ( 55 63 8 2 83) nVBdIzC 41 fd 00 fd b5ed: d0 05 bne b5f4 (320 2 14 -26) ( 55 63 8 2 83) nVBdIzC 41 fd 00 fd b5f4: 85 02 sta WSYNC (320 3 0 -68) ( 55 63 8 2 83) nVBdIzC 41 fd 00 fd b5f6: a9 2c lda #2c (320 3 2 -62) ( 55 63 8 2 83) nVBdIzC 2c fd 00 fd b5f8: 8d 96 02 sta TIM64T (320 3 6 -50) ( 55 63 8 2 83) nVBdIzC 2c fd 00 fd b5fb: a5 82 lda 82 (320 3 9 -41) ( 55 63 8 2 83) nVBdIzC 08 fd 00 fd b5fd: c9 11 cmp #11 (320 3 11 -35) ( 55 63 8 2 83) NVBdIzc 08 fd 00 fd b5ff: f0 38 beq b639 (320 3 13 -29) ( 55 63 8 2 83) NVBdIzc 08 fd 00 fd b601: a5 8a lda 8a (320 3 16 -20) ( 55 63 8 2 83) nVBdIzc 4b fd 00 fd b603: 29 80 and #80 (320 3 18 -14) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b605: d0 32 bne b639 (320 3 20 -8) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b607: a5 80 lda 80 (320 3 23 1) ( 55 63 8 2 83) nVBdIzc 40 fd 00 fd b609: 29 3f and #3f (320 3 25 7) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b60b: d0 2c bne b639 (320 3 27 13) ( 55 63 8 2 83) nVBdIZc 00 fd 00 fd b60d: a5 87 lda 87 (320 3 30 22) ( 55 63 8 2 83) nVBdIzc 12 fd 00 fd b60f: 38 sec (320 3 32 28) ( 55 63 8 2 83) nVBdIzC 12 fd 00 fd b610: e9 10 sbc #10 (320 3 34 34) ( 55 63 8 2 83) nvBdIzC 02 fd 00 fd b612: 85 87 sta 87 (320 3 37 43) ( 55 63 8 2 83) nvBdIzC 02 fd 00 fd b614: 29 f0 and #f0 (320 3 39 49) ( 55 63 8 2 83) nvBdIZC 00 fd 00 fd b616: d0 21 bne b639 (320 3 41 55) ( 55 63 8 2 83) nvBdIZC 00 fd 00 fd b618: a5 87 lda 87 (320 3 44 64) ( 55 63 8 2 83) nvBdIzC 02 fd 00 fd b61a: 29 03 and #03 (320 3 46 70) ( 55 63 8 2 83) nvBdIzC 02 fd 00 fd b61c: d0 04 bne b622 (320 3 49 79) ( 55 63 8 2 83) nvBdIzC 02 fd 00 fd b622: 38 sec (320 3 51 85) ( 55 63 8 2 83) nvBdIzC 02 fd 00 fd b623: e9 01 sbc #01 (320 3 53 91) ( 55 63 8 2 83) nvBdIzC 01 fd 00 fd b625: 85 84 sta 84 (320 3 56 100) ( 55 63 8 2 83) nvBdIzC 01 fd 00 fd b627: aa tax (320 3 58 106) ( 55 63 8 2 83) nvBdIzC 01 01 00 fd b628: a5 8b lda 8b (320 3 61 115) ( 55 63 8 2 83) nvBdIzC 40 01 00 fd b62a: 29 c0 and #c0 (320 3 63 121) ( 55 63 8 2 83) nvBdIzC 40 01 00 fd b62c: f0 05 beq b633 (320 3 65 127) ( 55 63 8 2 83) nvBdIzC 40 01 00 fd b62e: bd fd bc lda bcfd,x = bcfe (320 3 69 139) ( 55 63 8 2 83) nvBdIzC 40 01 00 fd b631: d0 02 bne b635 (320 3 72 148) ( 55 63 8 2 83) nvBdIzC 40 01 00 fd b635: 05 84 ora 84 (320 3 75 157) ( 55 63 8 2 83) nvBdIzC 41 01 00 fd b637: 85 87 sta 87 (320 4 2 -62) ( 55 63 8 2 83) nvBdIzC 41 01 00 fd b639: a9 00 lda #00 (320 4 4 -56) ( 55 63 8 2 83) nvBdIZC 00 01 00 fd b63b: 85 02 sta WSYNC (320 5 0 -68) ( 55 63 8 2 83) nvBdIZC 00 01 00 fd b63d: 85 00 sta VSYNC Here you start in the same place (line 263) but end at line 5. Stella doesn't like that. EDIT: By the way, it is completely predictable: start the binary, hold down the fire button, and it will always jitter on frame 320. Edited July 11, 2006 by vdub_bobby Quote Share this post Link to post Share on other sites
Thomas Jentzsch #298 Posted July 11, 2006 (edited) Oh... I didn't go so far and disassemble it Just looking into the z26 log file. I think plain RAM fiddling is supposed to be save, but I wouldn't even dare to do that I did in Thrust. AFAIK everthing except HMOVE is ok during VSYNC. Did you check VBLANK? Any funky stuff like you did in Splatform? On at line 40, off at line 241. Edited July 11, 2006 by Thomas Jentzsch Quote Share this post Link to post Share on other sites
+johnnywc #299 Posted July 11, 2006 Ok, I tracked down the offending stuff in both z26 log files (ugh) and in Stella's debugger. The issue is that sometimes the stuff you have in VSYNC sometimes takes too long! z26, apparently, doesn't give a damn and will still give you a stable display, while Stella jitters the display up a line (don't ask me why). Thanks Bob! I've moved the code out of VSYNC in the latest build so everything should be ok now. Thanks again! Quote Share this post Link to post Share on other sites
+batari #300 Posted July 11, 2006 Any ideas are welcomed. Add WSYNC before the 1st VSYNC. Best just use the VERTICAL_SYNC macro and don't do anything else. (Actually this macros main purpose is preventing people from doing funky stuff, like redering their display unstable ) Yeah, but the problem is that many versions of macro.h, and perhaps the current one, contain the 9-byte VSYNC that seems to cause problems on some games and some hardware. I don't think anyone knows the cause, but using the routine did seem to cause at least one game to roll, and on my hardware it caused one game to display with the TV's frame stable but shifted down so the bottom of the screen was cut off. In each case, switching back to the older VSYNC routine fixed the problems. This is enough for me to avoid the macro and manually insert the old one that's known to work. Quote Share this post Link to post Share on other sites
