Cybergoth #1 Posted February 7, 2006 Hi there! ...how do you do that easy and safe? Just received Secret Quest with one of the things broken, so I can't insert it Greetings, Manuel Quote Share this post Link to post Share on other sites
+Omegamatrix #2 Posted February 7, 2006 Manuel, Take some plastic stirsticks and insert them into your 2600 port on the side which the broken tab would go into. Trim them down so they are short enough not to touch the game, but long enough to pull back out. Now you should be able to put the game in? Quote Share this post Link to post Share on other sites
+FujiSkunk #3 Posted February 7, 2006 If all else fails, you can use a 7800. Quote Share this post Link to post Share on other sites
JagFan422 #4 Posted February 7, 2006 (edited) or take the cart apart and just remove it all together so that just the game cart is showing. There are a few manufacturers that didn't use that thing altogether. Actually don't do that, you'll ruin the label because the screw should be under the label. Unless you don't have a label on the cart. Edited February 7, 2006 by JagFan422 Quote Share this post Link to post Share on other sites
Cybergoth #5 Posted February 7, 2006 Take some plastic stirsticks and insert them into your 2600 port on the side which the broken tab would go into. Trim them down so they are short enough not to touch the game, but long enough to pull back out. Now you should be able to put the game in? Ok, I'll try that! or take the cart apart and just remove it all together so that just the game cart is showing. There are a few manufacturers that didn't use that thing altogether. Oh no, it's not that the cart is not opening, it's the VCS PCB slot that is not opening. Actually don't do that, you'll ruin the label because the screw should be under the label. Unless you don't have a label on the cart. Hm... well there's worse things than visible screws. Maybe I should try transplanting the inner plastic things from a spare red label cartridge? Is that an easy fix to do, for someone as lefthanded as me? Quote Share this post Link to post Share on other sites
crunchysuperman #6 Posted February 7, 2006 A 2600 jr. will work, won't it? Quote Share this post Link to post Share on other sites
CPUWIZ #7 Posted February 7, 2006 Is that an easy fix to do, for someone as lefthanded as me? 1014531[/snapback] Nö. Quote Share this post Link to post Share on other sites
Cybergoth #8 Posted February 7, 2006 *sigh* I assume especially since those noses are part of the shell-half where the label is attached? *throwsawaybitsandpiecesofajunglehuntcartridge* Quote Share this post Link to post Share on other sites
CPUWIZ #9 Posted February 7, 2006 *sigh* I assume especially since those noses are part of the shell-half where the label is attached? Yup. Quote Share this post Link to post Share on other sites
Cybergoth #10 Posted February 7, 2006 Well, I cut out a nose from the JH cartridge, so that will do for the moment... Quote Share this post Link to post Share on other sites
Atari-Jess #11 Posted March 27, 2006 for someone as lefthanded as me? If you aren't actually left handed I take offence. Quote Share this post Link to post Share on other sites
Cybergoth #12 Posted March 27, 2006 I'm actually both Not too long ago I rewired the fire buttons of the C64 DTV, so I can finally use it now Quote Share this post Link to post Share on other sites
A.J. Franzman #13 Posted March 27, 2006 Just an FYI to everyone, the things that stick into the cart and into the cart port to open them up and allow the cart to be fully plugged in are called KEYS. Quote Share this post Link to post Share on other sites
Starhopper #14 Posted March 28, 2006 Take some plastic stirsticks and insert them into your 2600 port on the side which the broken tab would go into. Trim them down so they are short enough not to touch the game, but long enough to pull back out. Now you should be able to put the game in? Ok, I'll try that! or take the cart apart and just remove it all together so that just the game cart is showing. There are a few manufacturers that didn't use that thing altogether. Oh no, it's not that the cart is not opening, it's the VCS PCB slot that is not opening. Actually don't do that, you'll ruin the label because the screw should be under the label. Unless you don't have a label on the cart. Hm... well there's worse things than visible screws. Maybe I should try transplanting the inner plastic things from a spare red label cartridge? Is that an easy fix to do, for someone as lefthanded as me? Not a problem--I had to transplant a Solaris chip into a new cart, and it came off without a hitch Quote Share this post Link to post Share on other sites
