Sign in to follow this
liveinabin
Intellivision controllers
Don't worry, I'm not going to harp on about that useless disc.
Thing is, I'm toying with the idea of rebuilding an Intellivision, in a smaller casing - with built in Intellivoice and detachable controllers.
My only problem is, what should I use for controllers?? The existing ones are famously bad. Ideally, I want to keep that 16-way control, and have a controller that I can mount a little 12 key keypad in (double points if the overlays go in too )
Well, don't use a disc!! I think it would be possible to create a "normal" (that is, Atari style) joystick that can do 16-way motion (though a lot of it would probably have to be custom made).
And I have to say, fitting overlays is a must! I can't imagine trying to play Treasure of Tarmin without the overlay!
--Zero
If you want a 16 direction controller, you would probably have to use an analog joystick (like 5200) and hook the pots up in a voltage divider network.
Use voltage comparators to turn the analog voltage into digital signals.
EX:
0 to 1v = south
1 to 2v = south by (southeast or southwest)
2 to 2.5v = southeast or southwest
2.5 to 3v = east by southest (or west by southwest)
3 to 3.5v = no vertical movement
3.5 to 3.8 = east by northest (or west by northwest)
3.8 to 4.2 = northeast or northwest
4.2 to 4.6 = north by northeast (or north by northwest)
4.6 to 5v = north
I'm typing this quickly and the scaling is a little off.
This is just for vertical movement, you'd need another comparator network for horizontal motion. Then a whole bunch of logic to convert to intv controller encoding.
Jay Tilton's web page has a spiffy adapter to use genesis controllers on an intellivision (or 2600 sticks if you only need 1 fire button). It would be a lot less work, and 8 directions is still fun to play
http://users.erols.com/tiltonj/games/tech/index.html
John
I think 8-way would be just fine
I don't have too many Intelli games, are there any that REALLY need 16-way control?
I did think of modding a NES controller, puting a tiny keypad on the right hand side (heck, I'm only making one of them - I could make my OWN overlays)
