Sign in to follow this
RSS Bot
SpiceWare's Blog - Main Menu
Oh well, I thought the Main Menu was pretty much done; but, in reviewing my blog entry I noticed I left out an e in medieval :lolblue: I'm going to post this anyway as a friend's going to be in Houston this week so there won't be any updates for a while.
Use your paddle to highlight the option. Either tap or hold down your fire button to change the values. I set it up so that repeated tapping will work as expected, I hate games that force the delay. When you hold down the firebutton the paddle is "locked" until you release the button so that only the selected option will be changed. While holding down the button, the option's value will color cycle like Medieval Mayhem does.
I based the text on a font I found called MA Gotic. I had to take some liberties due to the resolution, but I think it turned out well. It does take a bit more room than I expected so I revamped my Main Menu plans. Specifically I dropped "rebuild" and the selectable AI levels for the computer players. Depending on how the AI works out I'll tie it into the Speed option(the word Difficulty most likely won't fit) and expand the range beyond the current 1-4. I think Big Player will like how Players turned out :ponder:
I'm also debating a change in how the Start option looks. I center aligned it as there's no value for it, but I think I'll shift it back to the left and add a shield or crossed swords to the right.
Note: while the Main Menu correctly updates the two bytes holding the game options, the game routines have not yet been updated to use them.
Current Source and BIN Medieval_Mayhem_2006_03_26.zip
Stella Reminder - to try the ROM in Stella you'll need to hit TAB, select GAME PROPERTIES, the CONTROLLER tab, then set the controllers to PADDLE. Finally you'll have to reload the ROM by selecting Restart Current Game under the File menu(at least that's where the option is at under OS X, I don't know if it's different on other platforms) You might have to hit COMMAND-G to select the File Menu if Stella grabbed your mouse.
http://www.atariage.com/forums/index.php?a...&showentry=1392
