Sign in to follow this
Josh
2600 SD Card Cart?
Would It Be Possible To Make A 2600 SD Card Cart?
i Believe A SD Card Has Atleast 200K
But Could You Fit A Slot For It In A 2600 Cart?
I Was Wondering?
If It Is Possible Can Someone Post A Schematic For It?
Also would it be compatible with A Cartridge Modded FB2?
Edited by Josh
The Cuttle Cart 2 is quite close to this idea, although he uses the very similar but not the same MMC (of which SD was derived from)
the 7800 allows for some important differences that made the cuttle cart 2 easier, so im sure there are some big differences
And as far as your-device-in-question being compatible with a cart port modded fb2, well in theory yes, but thats impossible to know without building one and testing it.
prototyping and small batch making products like these is *expensive* and I mean, a couple hundred dollars would do the trick each.
Yeah,
I Think I'll Just Purchuse the supplies to make a 4k cart since i have a eprom burner i'm gonna use wires to be able to move the eprom to the end of the cart so i can cut a hole in the cartridge itsself so i can use eproms as i please.
you see this way i'll be able to test homebrews,hacks,and prototypes up to 4K on my AF2.
Edited by Josh
