jaymz887 #1 Posted May 8, 2006 i have an atari 7800 the joystick port for the player 2. on of the steel points broke off. can it be fix..or should i trash it. my gemini the power port on the system is loose and the system wont start and i have an atari heavy sixer the player 2 seems like the fire button is stuck (its not the joystick) but in the system itself... what can i do? Quote Share this post Link to post Share on other sites
A.J. Franzman #2 Posted May 8, 2006 (edited) Send them all to me. The 7800 controller port is an easy fix, as is the loose Gemini power jack (if it's just loose and not broken). The heavy sixer probably needs the buffer IC replaced, and they're usually not socketed, so this is probably the most difficult repair. If you can take the circuit boards out of the cases and still pack them safely, the reduced weight might save you some of the shipping costs. I normally charge $10 per unit, plus cost of parts (common inexpensive stuff like resistors, small capacitors, wire, etc. are free) plus cost of return shipping. In this case, if the 2 simple repairs really are as simple as they sound I'll do them at half price. Also, you can pay me by barter instead of cash if you have anything I want [EDITED] - see the first link in my signature. PM me for more details. Edited February 6, 2007 by A.J. Franzman Quote Share this post Link to post Share on other sites
tta583 #3 Posted May 8, 2006 Send them all to me. The 7800 controller port is an easy fix, as is the loose Gemini power jack (if it's just loose and not broken). The heavy sixer probably needs the buffer IC replaced, and they're usually not socketed, so this is probably the most difficult repair. If you can take the circuit boards out of the cases and still pack them safely, the reduced weight might save you some of the shipping costs. I normally charge $10 per unit, plus cost of parts (common inexpensive stuff like resistors, small capacitors, wire, etc. are free) plus cost of return shipping. In this case, if the 2 simple repairs really are as simple as they sound I'll do them at half price. Also, you can pay me by barter instead of cash if you have anything on my want lists - see the link in my signature. PM me for more details. Unless you want to get into it yourself I vote for A.J. Not a commercial, I don't know him and he has never done any work for me but if he is willing to do the work I think that is the way to go especially given the price. I have done joystick ports on a 7800 myself. No huge deal but I would charge more than 10 bucks labor. Then again, I am not the fastest with an iron...still kind of feeling it all out. Quote Share this post Link to post Share on other sites
D.Yancey #4 Posted May 8, 2006 Franzman knows his stuff and is trustworthy. It's worth letting him do it if you're not really comfortable fixing them yourself. Quote Share this post Link to post Share on other sites
omne #5 Posted May 11, 2006 Yup, at the price Franzman just offered you, you couldn't do it yourself for less! Quote Share this post Link to post Share on other sites
jaymz887 #6 Posted June 4, 2006 can you send me your address so i can ship to you.. Quote Share this post Link to post Share on other sites
