Sign in to follow this
Josh
Which Game Have Chip Roms Or Eproms?
Which Of Theese Games Have Chip Roms Or Eproms?
If so How many K Is That game?
Star Wars: Empire Strikes Back (PB)
Tutankham (PB)
Stampede (Activision)
Infiltrate (Brownish Red Label) (Apollo)
Combat (Text) (Atari)
Sky Jinks (Activsion)
RealSports Tennis (Atari)
Swordquest: Earthword (Atari)
Pitfall (Activision)
Also If There Is A Chip Rom Or somethin In The Is It Desolderable Whithout Killing The Rom Inside The Chip?
Edited by Josh
If you want to know the sizes look up the file sizes.txt on google it has all the info your after and all the games you listed are all ROMs AFAIK. And what the hell is a chip ROM that you would remove and not harm the ROM?? Do you mean an inverter or something??
No I Mean Dosent Use A Glop Top
And Also Can I Desolder The Chip Such As The one That Infiltrate has And Put It In My Eprom Cart.
I Was Just Wonder Which Games Have Eproms Or Chips And Not Glop Tops!
Here is an idea, if your so intent on finding out open them up and find out. And in the case of the games you mentioned, I do belive they are all ROMS chips and not globs, and NO you can't put them in your little 4k socketed board you put togther, they are not the same type of chips.
Also how old are you?
Edited by Shawn Sr.
Then Can I Use Boards (Like The Combat board Since you Say it Use's A Chip) And Just Modify Them With a Hex Inverter and A Socket?
Also Where can I some Eproms That Came With Someone Elses Eprom Cartridge.
No you can't use a combat cart with a 2732 as simple as you are asking.
Someone elses EPROM cart? What the fuck are you talking about? :?
Language , Language...
I've Seen On AA Plenty Of Other Peoples Eprom Carts They Got at fleamarkets And Such...
I was Wondering If anyone Was Willing to Sell some of the Eproms They Got With It.
You See I Am Making a Homemade 4K Eprom Cart From
A Combat Carts Case.
A AA 4K PCB
An 4K Eprom
All The Stuff From AA It Tells You To Buy (Hex Inverter , Etc)
A Industrial 24 pin socket (Has Round holes)
Edited by Josh
Hey Shawn - Let me give it a try -
Hi Josh:
If you have the cart case, and the 4K board from AA, (I usually just buy the board with the hex inverter already assembled in the board. It's a little more expensive, but worth it.) you are almost there.
If you are just missing the eproms, you will find that not many retail carts actually used eproms (Especially Atari). Most used ROMS that cannot be re-used. your best bet is to buy them (like I have done in the past) on ebay. There is a seller 'Dentedtwo' that usually sells eproms in batches of 50 for about $25. You need 2732 eproms.
I hope you have an eprom eraser!
Hope this helps...
Bob
Edited by PacManPlus
Thanks!
Also In A Box Of Electronics Old Stuff (I know Someone who Works At A Lighting control Company) I Found Six Eproms! (I know They may Be Too Big For A Eprom Cart,But Hey! I Found instructions For A VCS Multicart On The Net)
1 - 128K
2 - 256K
3 - 128K
4 - 256K
5 - 512K
6 - 128K
I Also Found Little Plastic Cases For Them Complete With Little Anti-Static Foam You Stick In In...
Oh Well
I soldered Everything Myself Using AA Little Instruction booklet they sent me
Next Version Will use a ZIF Socket And Will Be 8K
(Don't Worry I Already Set The Eproms In Front Of My window For A Week :D )
All I want Is Some help with my new creation!
(If you Want The Instructions for The Multicart here :D http://members.cox.net/rcolbert/multi.htm )
Edited by Josh
ok
I Just Oppened Up My combat Cartridge
Just ran into a stumble...
Can i Just Take Out And Not use The dust Thingy?
Becuase The Eprom socket will Get In The Way Of The Metal Thingy That Makes It Springy
Also i'm Still Asking If anyone Is Selling Eproms?
ok
THE ATARIAGE STORE YOU BOUGHT THE BOARD FROM SELLS EPROMS. EBAY SELLS EPROMS. NO YOU DON'T NEED THE GROUND SHEILD. NO LEAVING EPROMS IN THE SUN WILL NOT PROPERLY ERASE THEM. IS THAT CLEAR ENOUGH? :x
I Mean More Already Burn't Eproms
what for you own a burner do you not?? Nothing like openly asking for people to pirate games for you. :roll:
What did I tell you yesterday? ;)
Ok Dad, I know I'm not suposed to hang out with the bad kids. I'll go play somewhere else ;)
Sorry!
Oh Well
The Eprom Cart Is almost done!
All It Needs Is some Labeling And Some Dremeling.
How Do I Make A Switch That Switches Between 2K And 4K :?
I understand that there's been some questions about why the AtariAge veterans don't have much patience with newcomers these days.
I give you Exhibit A.
