RSS Bot #1 Posted May 19, 2006 When I was having to code on my Thinkpad I downloaded my mode file for jEdit from here and realized it wasn't my lastest version as some of the syntax highlighting wasn't the same as on my iMac. I got my iMac back, so here's the current version. To use the syntax highlighting, put the assembly-6502.xml file in the MODES directory of jEdit. Then edit the catalog file in the same directory and add the following. CODE<MODE NAME="assembly-6502" FILE="assembly-6502.xml" FILE_NAME_GLOB="*.asm"> I had to disable the assembly-x86 as it also uses *.asm for the file extension. I disabled it by changing its entry as follows(removed the *) CODE<MODE NAME="assembly-x86" FILE="assembly-x86.xml" FILE_NAME_GLOB=".asm" /> assembly_6502.xml.zip http://www.atariage.com/forums/index.php?a...&showentry=1570 Share this post Link to post Share on other sites
