chrisbid #1 Posted June 29, 2006 i picked up a heavy sixer last sunday for 20 bucks (the owner had no clue), but after a few minutes of play the colors shift. for instance, on lock n chase, the blue maze turns green. what would cause this and could it be fixed? Quote Share this post Link to post Share on other sites
A.J. Franzman #2 Posted June 30, 2006 There are several possibilities: Chroma phase pot. Power supply. 7805 voltage regulator. etc. Of course any problem can be fixed, but just going in and doing a bunch of haphazard part-swapping can get expensive and frustrating. You can start by trying another power supply if you have one. If that's not it, turning the color pot back and forth a few times before setting it correctly again may give the unit a temporary stability. If it does, then you've found the problem and should get a replacement. If you get this far without resolution, I recommend you let someone with more experience work on it. Quote Share this post Link to post Share on other sites
