Champions_2002 #1 Posted July 10, 2006 I am using Atari 800win and added a hard drive to it, and i was wondering how do i look at what is on the drive with in the emulator Quote Share this post Link to post Share on other sites
a8isa1 #2 Posted July 11, 2006 I am using Atari 800win and added a hard drive to it, and i was wondering how do i look at what is on the drive with in the emulator SpartaDOS works fine but for MyDOS you need to type H1:*.*. "H1:" alone does not work. I believe this was fixed with the new core engine, rev 2.0.x something, but I don't think Atari800Win Plus has been released using this engine, except in alpha versions. Are you using Atari800Win Plus 4.0? This uses engine 1.3.6. - Steve Sheppard Quote Share this post Link to post Share on other sites
Rybags #3 Posted July 11, 2006 As the Atari sees it, it's a normal device just like C: or D: But, the emulator provides extra functionality like NOTE/POINT and DIR. The directory function provides proper wildcard support, but when doing load/save or open operations you have to provide the full filename. It also supports movement among directories (within the filename you specify), use ">" instead of the usual "\", and "<" moves back a level. Quote Share this post Link to post Share on other sites
