danwinslow #1 Posted July 22, 2006 Well, I have a CT63 Falc humming along nicely now, have mint+xaaes+teradesk. The one thing I note is that the 640x480 stock rez is starting to suck. I researched a bit for screen rez stuff, and found : videlity videomode centscreen centvid3 None of them seem to work very well. I have a VGA LCD flat panel that works well with the stock resolutions, but it seems to be pretty hard to get anything other than that. What I am looking for is some advice on what utility to use, what settings might be useful, and can I really expect to get a significantly higher resolution out of the stock videl? Specifically, I would really like to get 1024x768, or at least 800x600. I can switch to a multisync tube monitor if that would be better. Thanks folks. Quote Share this post Link to post Share on other sites
GT Turbo #2 Posted July 22, 2006 Well, I have a CT63 Falc humming along nicely now, have mint+xaaes+teradesk. The one thing I note is that the 640x480 stock rez is starting to suck. I researched a bit for screen rez stuff, and found : videlity videomode centscreen centvid3 None of them seem to work very well. I have a VGA LCD flat panel that works well with the stock resolutions, but it seems to be pretty hard to get anything other than that. What I am looking for is some advice on what utility to use, what settings might be useful, and can I really expect to get a significantly higher resolution out of the stock videl? Specifically, I would really like to get 1024x768, or at least 800x600. I can switch to a multisync tube monitor if that would be better. Thanks folks. I use everyday my Falcon CT63 with a Vga (Tube) monitor in 800*592 with Centscreen, any problem, before i used Videl Inside but he was a little more technic but allow you to create your own rez, but that can be dangerous GT Turbo Quote Share this post Link to post Share on other sites
danwinslow #3 Posted July 22, 2006 That sounds good, would you mind posting the settings you are using in centscreen? Quote Share this post Link to post Share on other sites
+DarkLord #4 Posted July 22, 2006 That sounds good, would you mind posting the settings you are using in centscreen? Guys, I gotta ask, I thought that you couldn't get higher than stock rez's without the video/bus mod? I mean the CT series is awesome, but didn't think that they do anything for video enhancement.... Quote Share this post Link to post Share on other sites
GT Turbo #5 Posted July 22, 2006 That sounds good, would you mind posting the settings you are using in centscreen? I use an yet defined settings : 80 columns 16 colors No line doubling 800*592 Centscreen (Rev 3.5.2) GT Turbo Quote Share this post Link to post Share on other sites
GT Turbo #6 Posted July 22, 2006 Guys, I gotta ask, I thought that you couldn't get higher than stock rez's without the video/bus mod? I mean the CT series is awesome, but didn't think that they do anything for video enhancement.... I have no video or bus mod, i have just plugged my CT63 and use Centscreen, anything else, that will do one year i'm using this setting without any problems. GT Turbo Quote Share this post Link to post Share on other sites
harveymush #7 Posted July 22, 2006 Just wondered does centscreen work on a stock falcon running Magic 6.1? Quote Share this post Link to post Share on other sites
GT Turbo #8 Posted July 22, 2006 Just wondered does centscreen work on a stock falcon running Magic 6.1? I don't use Magic but i think it must run with, in 68030 mode Centscreen run nice, i have had any problems in two modes (68030 and 68060) with this prog. GT Turbo Quote Share this post Link to post Share on other sites
harveymush #9 Posted July 22, 2006 cheers GT i'll try it tonight Quote Share this post Link to post Share on other sites
jens #10 Posted July 22, 2006 All those proggies will work, as the Videl has a higher bus frequency clock which is not used for stock resolutions. A program as Videl Inside or CentScreen uses those better frequency to get higher resolutions. I have a stock Falcon running 800x608, and I tried CentScreen some years ago, that gave me flickering 1024x768. Ah, yes: Videl Inside has resolutions that should work on every Falcon, most other proggies have to be toyed around with... Quote Share this post Link to post Share on other sites
danwinslow #11 Posted July 22, 2006 Videl Inside? Do you mean Videlity? Quote Share this post Link to post Share on other sites
jens #12 Posted July 22, 2006 No, I mean Videl Inside or Videl Insight - not too sure about the spelling, but I think the first one is right. Videlity is for fiddling around, Videl Inside is just for click, save and go. Quote Share this post Link to post Share on other sites
