Gunstar
Looking for 'Snapshot' an 8-bit "Multitasking" app.
Back in the early nineties there was a short lived (2-3 years) monthly (later bi-monthly then quarterly the last year) magazine named Atari Interface (A.I.M) that had monthly disks for the ST and later the 8-bits. There were a lot of very cool, modern apps for the 8-bits released through A.I.M. in the last months of publication. One of these applications was a program called 'Snapshot' that allowed two or more programs (depending on extended ram) to be loaded and resident in the Atari, and accessable at the touch of a button. While not true "multitasking," which was also done on the 8-bit (far too slow though), it switched between the programs instantly and was for all intents and purposes "multitasking." I would like to find this utility/app/os extension now. It always intrigued me back in the day, but I did not have the memory necessary at the time. the actual magazine disk it was released on was the volume 4 "Fall" 1992 issue, which I believe was the very last issue released, and incidently is the issue within which I had my first ever, published article.(written&submitted when I was a freshman in college).
The Snapshot file on this 8-bit AIM disk is called Snapshot.arc and a HARD DRIVE (maybe MyIDE users might be interested in this version) version called SNHD30D.arc.
I have the magazine in front of me, but disks were ordered seperately.
Anyone who might have a copy of this PD program please chime in, or if it can be found online somewhere. Thank you.
Edited by Gunstar
Thanks, I'll check it out. VERY MUCH appreciated. Though I do still want to add more about this program here, as I just re-read the description in the magazine: The original .arc file has 2 versions in it, one for SpartaDOS and one for Atari/Mydos. Then there was another .arc file with the hard disk version. I would like to get all the versions if possible. Oh, and these programs were written by Tom Hunt.
I unzipped that file and it's an .ATR image which boots up DOS 2.5 and has a some demo programs on it named demo1, demo2, etc. and at the bottom are a couple of files named SNHDLOW.COM and SNHDMED.COM which I assume are hard disk versions of this program and this zip file was originally the SNHD30D.ARC file from the AIM disk. There is also a .doc file labled SNHD30.DOC, which matches up. I'll look into it further, but my MyIDE hard disk is not currently setup, so I think I might need the spartados or mydos versions for now. But, I am going to see if the hard disk version will work with A.P.E. Still, this will probably be the most used version once I do get my MyIDE setup again. Thanks again Fandal!
Edited by Gunstar
Well, this type of application arent multitasking. They are Task-switching, the best example that I used is GENIE program. Once you load in the memory you can load a game. After you pressed CTRL-SHIFT-ESC Atari keys, the game stop and GENIE appears at the screen, you have a notepad, a calculator and other things.
Its a pity emulator GENIE cant work in the emulator. This combination of keys is tha same that Windows use to call the process list.
Did you try making a custom keyboard template?
If you don't need the numeric keypad you might remap one of those keys to be an Atari ESC.
For example you remap [Keypad *] = [Atari ESC]. Now if you press Ctrl + Shift +
[Keypad *] you get the Atari action for Ctrl + Shift + ESC but don't trigger the Windows action.
Alternatively you can map a single Keypad key to be the whole Atari Ctrl + Shift + ESC combination.
Unfortunately, I don't see a way to re-map a PC function key to do this instead. This would be ideal as I like having full use of the keypad.
- Steve Sheppard
Edited by a8isa1
Uh...I realize it's not real multitasking, that's why I have multitasking in quotes and explain exactly what it does actually do in my first post... :roll:
But this is far better than GENIE becuase you can have any two or more programs resident in memory and switch between REAL programs instantly, not just a notepad and calculator, something I already have when I use ATOS or BOSS GUI anyway...their called "accessories."
mmm... you right...interesting app... I must to read the instructions... will be work with 2 graphic games?...
Edited by Allas
2 or more of ANY game or program, depending on memory, IIRC. you need at least 256k to use Snapshot, IIRC. I still have to read the instructions myself, but I believe I'm right, if memory serves...
this isnt true. I remember using snapshot on my unmodified 130xe.
Yeah. It just "swaps" the base 64k for the first 64k of Extended RAM. KEwl. App. IIRC, it does work on a standard 130xe.
Lets you have two complete "instances" of your ATARI base memory map at the same time and switch between them.
