Atarian7 #1 Posted August 19, 2006 I tried replacing the switch but I don't think i got it soldered in right. It is still stuck onlevel A for the first player. Anyone interested? Quote Share this post Link to post Share on other sites
keilbaca #2 Posted August 19, 2006 (edited) I tried replacing the switch but I don't think i got it soldered in right. It is still stuck onlevel A for the first player. Anyone interested? Your ground isn't connected on the switch. Either that or somehow you broke something inside of the switch, very possible if you ripped it out from one atari and put it in another. The easiest fix is to scrape away some of the ground that's near the switch if you broke the trace in the motherboard during the soldering, and solder a trail going from the pin to the ground. Its not far at all, maybe a quarter inch, probably less, to hit a ground spot. Its even closer for the center pin (either connected to ground would make it work right). Edited August 19, 2006 by keilbaca Quote Share this post Link to post Share on other sites
A.J. Franzman #3 Posted August 20, 2006 If you can't fix it, you could send it to me for repair or as a donation. Quote Share this post Link to post Share on other sites
Atarian7 #4 Posted August 22, 2006 If you can't fix it, you could send it to me for repair or as a donation. I will give to you as a donation. I'd hate to just throw it away. PM me please. Quote Share this post Link to post Share on other sites
