sniperstorm #1 Posted September 24, 2006 What is a ATR8000 And what does it do??? And does anyone want one? Quote Share this post Link to post Share on other sites
a8isa1 #2 Posted September 25, 2006 (edited) The ATR8000 is a multiple I/O interface for the A8. It connects to the SIO port. Has 1 serial port, 1 printer interface w/ 16K or 64K buffer (depending on model), and can control 4 industry standard floppy drives which are connected externally to the unit. Internally ATR8000 is a full fledged 4Mhz Z80 computer. The 64K model can run the CP/M operating system. In this mode the the Atari normally acts as the console but a real RS-232 terminal can also be used. - Steve Sheppard Edited September 25, 2006 by a8isa1 Quote Share this post Link to post Share on other sites
ataridano #3 Posted September 29, 2006 I'd take one! -Dan Quote Share this post Link to post Share on other sites
+warerat #4 Posted September 29, 2006 It could also take a 8088-based daughter card (Co-Power88) that you can "run" PC programs on. The compatibility was pretty limited, but you could at least boot older versions of MS-DOS on it. The other thing you could use it for was to allocate the memory on the card as a ramdisk for the CP/M side. It's a pretty neat little box for its time. Quote Share this post Link to post Share on other sites
