Sign in to follow this
SmileyDude
looking for some OS X / x86 expertise...
I'm working on porting z26 over to OS X/Intel, and I've run into issues with Mach-O. If anyone with OS X and x86 asm experience is willing to help, I would appreciate it. I've documented my current status at http://dmunsie.wordpress.com/. Leave a comment here or there if you have any insight/suggestions/etc.
thanks!
thanks!
I'm not sure if this will help, but I had some Mach-o issues with PPC asm a few years ago. I can't remember the details but the problem had something to do with statically linked binaries, and OSX apparently does not support them. I did manage to create the statically linked binaries but they would crash with strange errors.
Well, there is no static libraries in z26. But, this does appear to be a library problem of sorts -- the program is crashing when a symbol is called that hasn't been binded yet. Somehow, the stack pointer is messed up when calling from asm->C. I can get it to work for some cases, but not for all. If I just knew what the correct way to call from asm to C under OS X was, this problem would be easy solve.
About all I know is to put "-arch ppc -arch i386" into the GCC command line to make a universal binary. Beyond that, good luck. I did once almost get MESS recompiled, but it turns out to use what is currently a PPC-only closed-source library (with a universal of the next version in a "someday it'll be a release version" beta), in addition to a few bits PPC assembler that could probably have been left out in favor of their C equivalents.
Just make sure that you aren't somehow creating a PPC binary and trying to link x86 assembler into it. Remember that you can use the "file" command from the shell to identify the CPU types in a mach-o file, and presumably a .o file as well.
