Loccy #1 Posted December 22, 2006 Will one of these http://www.maplin.co.uk/Module.aspx?Module...r&doy=22m12 run my UK woody OK? It's 500mA with a voltage between 3V and 15V, and it has a 3.5mm mono jack. But are there any other gotchas that I'm missing? (yes, I know, I'm sure I can pick one up cheaper, but I can pop down to Maplins and pick one of these up rather than having to wait for one in the post). Quote Share this post Link to post Share on other sites
Uzumaki #3 Posted December 22, 2006 Should be fine. You could set it to lower voltage than the usual 9v to help the 2600 voltage regulator run a bit cooler. Something like 7.5 is the minimum for standard 7805. Quote Share this post Link to post Share on other sites
elliott #4 Posted December 22, 2006 (edited) That adapter outputs AC, it will fry a normal 2600, you need a power supply that outputs DC. The 9V one of these will work: http://www.maplin.co.uk/Search.aspx?criter...R&DOY=22m12 Or if you want a selectable voltage output: http://www.maplin.co.uk/Module.aspx?Module...4&doy=22m12 Or this one, which is on sale for 3.99 http://www.maplin.co.uk/Module.aspx?Module...4&doy=22m12 Edited December 22, 2006 by elliott Quote Share this post Link to post Share on other sites
A.J. Franzman #5 Posted December 22, 2006 Well spotted, elliott! Quote Share this post Link to post Share on other sites
+batari #6 Posted December 22, 2006 That adapter outputs AC, it will fry a normal 2600, you need a power supply that outputs DC. Actually, AC will not fry a normal 2600, at least not right away. I think there is some isolation between the power input and the sensitive components. I didn't check an adapter carefully once, and I ran 9v AC into my 2600. It not only didn't fry it, but it actually worked! The screen showed massive interference and the sound had a constant 60 Hz hum, but it did work. Quote Share this post Link to post Share on other sites
A.J. Franzman #7 Posted December 22, 2006 That's the effect of the big electrolytic filter cap sacrificing itself to protect the 7805 regulator. Leave it on too long and one or more of the following will fail: electrolytic filter cap, 7805, AC adapter. Quote Share this post Link to post Share on other sites
Loccy #8 Posted December 23, 2006 Well that was a bizarre morning. Bought the £3.99 Maplins PSU; also had to buy another set of connectors as the PSU didn't come supplied with a 3.5mm mono jack. Got it home, plugged it into my new Woody fresh from ebay - nothing. Spent an hour watching the TV trying to tune into what was a non-existant signal. I'd actually got to the stage where I was thinking that either the PSU was faulty or the Woody was - I had noticed that as I plugged the PSU into the back of the Woody, there was a spark. Out of desperation, and I was about to give up, when I decided to flip the connector on the end of the PSU around. Now I am absolutely positive that in doing so, I was flipping the polarity to the WRONG setting, ie. center negative. Not expecting anything I set the TV tuning itself - and up pops 1981 Atari (the minimalist title screen of Yars Revenge). It was like coming home after 20-odd years. Quote Share this post Link to post Share on other sites
A.J. Franzman #9 Posted December 24, 2006 The Atari needs a tip-positive supply, so either you had it wrong initially, or your AC adapter wiring or the reversible tip is marked/assembled wrong. Quote Share this post Link to post Share on other sites
