lowscore #1 Posted December 22, 2006 I recently acquired an all black NIB 2600 Trak-Ball, only to discover what most here already know, that there is not a single game designed to use it in TB mode. I was so looking forward to arcade like Centipede action, that the discovery of it only working in JS (and very sluggishly, at that) was a real heartbreak. I took someone on the forums advice and tried Decathalon with it in JS mode. A sports game I always hated is now super awesome action fun-time that I really break a sweat to. I also tried it with California Games, and found that the footsack game works super, skateboarding sucks, BMX sucks, and surfing, a game I could never get the hang of, is saved. What I would like to know: is there a way to connect both a joystick and Trak-Ball without unplugging or destroying either cord so that I can switch mid-game. I am also going to try the Trak-Ball with Winter and Summer Games. I think it will add an element that is missing, while not completely thrashing my re-built joysticks. Any advice would be helpful. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #2 Posted December 22, 2006 I recently acquired an all black NIB 2600 Trak-Ball, only to discover what most here already know, that there is not a single game designed to use it in TB mode. That's not exactly true. Quote Share this post Link to post Share on other sites
lowscore #3 Posted December 22, 2006 That's not exactly true. I was only referring to original games. I am aware of the (homebrew?...pardon my ignorance) version from reading the site you quote. I did try the original Missile Command with the Trak-Ball in both positions and had my sadness confirmed. Please, sir, enlighten me on new games, both hacks and homebrews, that support my new toy. I would be most grateful! Quote Share this post Link to post Share on other sites
shadow460 #4 Posted December 23, 2006 Reactor doesn't actually support the ball, but with the ball set to JS and the diff switch set to A, you get a pretty good experience. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #5 Posted December 23, 2006 Please, sir, enlighten me on new games, both hacks and homebrews, that support my new toy. I would be most grateful! Unfortunately there is no other game. Quote Share this post Link to post Share on other sites
lowscore #6 Posted December 23, 2006 Reactor doesn't actually support the ball, but with the ball set to JS and the diff switch set to A, you get a pretty good experience. Thank you for that tip. I do not currently have Reactor, but perhaps soon. Just the same, is there a way to switch between joystick to Trak-Ball and verse-vise that would not destroy the integrity of the original equipment that I have? (broken record plays on and on and on and on...) Quote Share this post Link to post Share on other sites
alex_79 #7 Posted December 23, 2006 Just the same, is there a way to switch between joystick to Trak-Ball and verse-vise that would not destroy the integrity of the original equipment that I have? (broken record plays on and on and on and on...) icon_dunce.gif The Atari joystick (and then the trackball in JS mode, I think) uses normally-open contacts for directions and fire button, so connecting them with a simple Y-cable should be fine. You'll need 2 male db9 and 1 female db9 connector, some cables and a soldering iron. Simply connect each pin on the male connectors to the corresponding pin on the female one (pin "1" on both male db9 connectors must be connected to the pin "1" of the female one, and so on with pin 2,3 etc.)). Pin 5,7 and 9 are not used by the joystick, but if you connect them you can use the adaptor also to keep both paddles and joystick plugged in the same port without swapping them when you change the game. Since the paddle buttons act like the left and right joystick directions, they can also be useful in some "joystick-only" game: In Midnight Magic, for example, you can use them to control the flippers, but you need the joystick to launch the ball (A "Track&Field" controller can be used instead of the paddles too). Look at the schematics in the Atariage Archive for further details about controller pinouts. ------ Ciao! Alessandro Quote Share this post Link to post Share on other sites
lowscore #8 Posted December 27, 2006 Is this the device you are referring to, Allessandro? I found this at http://www.trianglecables.com/12indb9serya.html Thanks for the advice. I appreciate your expertise! Quote Share this post Link to post Share on other sites
alex_79 #9 Posted December 28, 2006 Yes, that one will allow you to keep the joystick plugged together with the trackball. Quote Share this post Link to post Share on other sites
+Nathan Strum #10 Posted December 28, 2006 I found this at http://www.trianglecables.com/12indb9serya.html A semi-unrelated question - will this also work for keeping an AtariVox and player 2 joystick plugged in at the same time? Quote Share this post Link to post Share on other sites
Almost Rice #11 Posted December 28, 2006 I was only referring to original games. I am aware of the (homebrew?...pardon my ignorance) version from reading the site you quote. I did try the original Missile Command with the Trak-Ball in both positions and had my sadness confirmed. Please, sir, enlighten me on new games, both hacks and homebrews, that support my new toy. I would be most grateful! Also, the Atari 8bit Computer had support for the trakball. Missile command on the 8bit(after you hit Ctrl-T) and the hacked version with 3 silos. I believe someone hacked 8bit Centipede with trakball support. I have not used it on my 2600 so I would not know. I did use the trakball on my 7800 though. Quote Share this post Link to post Share on other sites
lowscore #12 Posted December 31, 2006 (edited) The adapter worked beautifily. I did have to carve off all of the plastic around the female end with a utility knife and cut off the metal ground in order to fit it into my console's port. The effect is versatile conveniance. There is probobly a simpler, or more Mcguyveresque way, but for 7 buck, I am not complaining. Thanks for everyones input. Edited December 31, 2006 by lowscore Quote Share this post Link to post Share on other sites
shadow460 #13 Posted January 2, 2007 Next time, hack in an Atari Joystick cable. My 7800 has a hacked joystick cable running to the parallel port on the PC. Quote Share this post Link to post Share on other sites
