    106
    796
    140,784
HERE'S SOMETHING I've been working on...can't decide if I like it or not.
r1k.bin
Screenshot. Background color is different in screenshot.
EDIT: New version attached. Has 24 sprites instead of the 16 previously. Also added more boundary checking and changed the movement routine.
r1k.bin
New screenshot.
For some reason Stella hates this binary...??? Runs fine in z26 at a (95%) constant 262 scanlines, so I don't know what's up. I think it has something to do with the RIOT timer.EDIT II: New version attached, that works with Stella. Will eventually crash. Still 24 sprites (I think that's the limit of RAM) but some are different now. ;)
r1k.bin
And screenshot:
11 Comments
if you put the white dude about halfway on the bottom white line, you can see where his sprite is being multiplexed. Nice engine! That's a ton of crap moving around...
...but what is it?
It is an engine that multiplexes both players. I'm kind of annoyed with it because it was a ton of work to get it working and it doesn't look much better than just multiplexing a single player (use z26 to turn the players on and off to see what I mean).
What it's for? I was kind of toying with porting Robotron 2084! :)
It only uses 3 bytes for each sprite so I could probably double the number of sprites (to 32) for the demo. I don't think there would be enough time to process them outside the kernel though.
But I don't think my demo supports your belief. :)
Does the demo require the sprites to be of uniform height, or can it work with variable-height ones? Some neat stuff there in any case.
Now that you mention it, it does look quite a bit like Robotron.
I definitely think it looks good enough to make a playable game, if not a flicker-free one. No worse than Asteroids :)
The sprites can be any height, any color. Can't change NUSIZx, though. At least not right now; probably could fit it in with a little tweaking. The kernel is kind of a mess right now, though it seems to work. ;)
