    657
    2,693
    899,082
Adding Blu-ray content
I'm planning on getting a new computer later this year, and planned to get a Blu-ray drive for it. Last week Macworld posted an article on How to rip a Blu-ray, so I checked out OWC for Mac compatible drives and decided to buy one now rather than later. It connects via FireWire 800 (my current MacBook Pro) and USB 3 (new computer). It also comes with Roxio Toast 11 for creating Blu-ray discs that I could hand out to family and friends.
I was surprised to see that the burner can create 128GB discs as I thought Blu-ray only supported 25 GB single-layer discs and 50 GB dual-layer discs. BDXL, a new format, was added that supports 100 GB on triple-layer discs and 128 GB on quad-layer discs.
I've tried the conversion with the movie 9 as it's only 79 minutes long. Process is to:
  1. use MakeMKV to convert from the Blu-ray disk to an MKV file
  2. use Handbrake to convert to an M4V file
The MKV step went quite fast - it only took 15 minutes to create a 21 GB MKV file, and that's on my MacBook Pro from 2008 that's only sporting a 2.8 GHz Core 2 Duo.
For the next step, I decided to hand the work off to my Mac mini as its 2.6 GHz quad-core i7 converts video about 3x faster than my Mac Book Pro. The mini took about 90 minutes to convert the movie into a 2.8 GB M4V file.
When I view them up close, on the 24" display connect to my MacBook Pro, I can see compression artifacts(mostly in dark scenes) in the M4V file that are not visible in the MKV file. It was a different story when setting on the couch - compression that stood out on the monitor was not at all noticeable on the HDTV. I suspect that's because I periodically calibrate my HDTV, but not my monitor. I also dropped the M4V file on my iPad, and it looks great on it.
Addition - Folder View of MKV files:
Addition 2 - Bad Breaking Bad disc (see comments):
Addition 3 - example of interlaced video that needs to be deinterlaced
Addition 4 - deinterlaced video
20 Comments
I've been working on duplicating my DVD/BR collection for a few years now. Looks like you have the technique down! Good luck!
Thanks!
I'm still getting the hang of it. I did the Extended Cut of Sucker Punch last night, but ended up with the wrong thing - a behind the scenes version of the movie :lol: Oh well, at least I realized that when I checked out the MKV so I didn't waste any time creating an M4V.
Also had a problem with season 3 of Breaking Bad - disc 1 worked OK, but MakeMKV reported a whole bunch of errors on disc 2 and only converted one of the tracks. Possibly studio escalation along the lines of the 99 track issue with the Daria DVDs.
I suspect I'm going to stick with movies for the time being.
Ripping tools are often just GUI wrappers on OSS command line tools. With some research you might be able to avoid the MKV -> M4V transcoding step. Guides / code written for Linux is often easy to use / port to OSX.
Good idea. I'll probably hold off on looking into that until I get my new computer though.
I'd been waiting to see what the next mini will be, but I'm leaning more and more towards getting the new Mac Pro as I'd like to mount a couple 4K displays on my treadmill desk. Text on my iPad Air is so much clearer than text on the 24" 1080p monitors I'm currently using.
I wouldn't hold my breath waiting for a new Mac Mini. I gave up and went with the i7 / 780M iMac (which was probably a better match for my requirements anyway).
Since I have the space, I think I'm going to leave the MKV files on the Drobo. To make the folder view nicer I updated the icons for the files using images from The Movie Database - see added screenshot in the blog entry.
Turned out to be a bad disc, added photo to blog entry. Had trouble getting a good photo of it, had to align the flaw just right so it would stand out, then fight with the auto-focus as it was focusing on the image reflected by the disc. Finally won that fight by putting a note on the disc and directing the iPhone to focus on the paper.
The manufacturing flaw caused it to skip over the first few minutes of one episode and about 10 minutes in the middle of another. I just read the episode summary online to figure out what I missed.
I just started studying this. Unfortunately, my only laptop with a bluray drive is dead, so I'll have to buy an external. Does the ripping program you reference above give a completely lossless copy of the bluray?
Yes, the rip is the exact data from the Blu-Ray without the encryption. You can optionally exclude things like extra sound tracks and closed captioning data. I normally deselect everything except the English track.
Alright! I just did my first DVD. I need to pay attention to the settings. I just hit go and it worked. I am streaming a movie from my NAS right now through my Xbox 360. But it is not the best quality so I'll try again later.
There's definitely a learning curve involved with Handbrake - if you're seeing something like this:
https://www.youtube.com/watch?v=RLSu9Iuevmk
you need to learn how to use the deinterlacing and/or decombing options in the filters. After Handbrake has parsed your material, open up the Preview Window. You may have to move the selection point. If you see something like the new Addition 3 I just added to the blog entry then click settings and try changing the deinterlace setting and hope you get Addition 4 as the result.
I will watch this and try those things. I redid the DVD by changing the preset from normal to high profile and on just a few minutes of watching, it seems to have fixed the problem.
I did the second one with just the decomb. I sampled a small bit this morning and it looks to be as good as the first one but it only took 10 extra minutes instead of the 5 times as long the high profile setting took. Thanks Darrell.
One more question. How do you get closed captioning? It is included in the folder I choose with MKV, but it doesn't seem to show up with Handbrake.
Thanks for this. Very handy for a Region B Blu-ray I just bought. (Seriously... if you can buy Region B discs here, why do they bother restricting them to Region B in the first place?)
